7 Pages  1 2 3 > »
> Renault Megane II Grandtour Avantage [2005], Jurnal de bord
13Lucian37
post 5 Sep 2017, 18:35
Data achizitie: 29.08.2017
153k km
<span class='edit'>5 Sep 2017, 19:37:</span>
Poze:
<span class='edit'>5 Sep 2017, 19:39:</span>
Poze:
<span class='edit'>5 Sep 2017, 19:40:</span>
Poze:
Poze:
This post has been edited by 13Lucian37: 12 Jan 2022, 17:08
Renault Megane II Grandtour 2005 1.6 16v - CT 63 TER
13Lucian37
post 6 Sep 2017, 21:01
153k km
01.09.2017
Ulei ELF 10W40
Filtru ulei MANN
Filtru aer MANN
Filtru habitaclu MANN
03.09.2017
Arc fata stanga&dreapta MONROE
Bascula echipata - fata stanga&dreapta
Bieleta directie - fata stanga&dreapta
Cap bara fata - stanga&dreapta
Bieleta antiruliu - fata stanga&dreapta
06.09.2017
Suruburi prindere bara fata, capace protectie motor.
This post has been edited by 13Lucian37: 4 Sep 2020, 08:27
bogdanpaul
post 14 Sep 2017, 14:39
https://www.reno.ro/index.php?act=ST&f=126&...=0#entry4672667
This post has been edited by bogdanpaul: 14 Sep 2017, 15:32
Renault Megane II Grand Tour 2.0 16v
13Lucian37
post 26 Sep 2017, 00:25
QUOTE(bogdanpaul @ 14 Sep 2017, 15:39)
Sa o stapanesti sanatos! Frumoase jante ai pe ea.
Update:
23.09.2017
Dupa ce am facut unghiul am constatat ca s-a desprins un colier (cel dinspre roata) de la burduful exterior din partea stanga. Am schimbat colierul si am mai pus vaselina pentru ca imi sarise o parte.
Tind sa cred ca e afectata si planetara, insa nu sunt foarte sigur. O sa mai verific.
DanCVA
post 27 Sep 2017, 11:51
Membru care arde gazu'... accelerand
Daca zici ca este 2005, inseamna ca e cea mai batrana faza 2 pe care am vazut-o.
Renault Megane Sedan 2007/Expression/Keyless-Go/MP3/6CD Changer/Autolights/CC/Heated seats/Tuxedo/1.6 16V - B 82 KVA
Repar oglinzile de Megane 2, Senic 2 si Clio 3.
Danut 88
post 9 Oct 2017, 15:38
Sa o stapanesti sanatos. Foarte frumoasa culoarea. si a ta sta ridicata de bot?
Dacia Logan /exSolenza /ex1310 2007 /2003 Scala/1999 L - IF __ PTR/IF 05 SYZ/
13Lucian37
post 13 Oct 2017, 12:56
QUOTE(Danut 88 @ 9 Oct 2017, 16:38)
Multumesc! nu mi se pare ca sta ridicata de bot. A ta cum e de ti se pare asta?
bogdanpaul
post 13 Oct 2017, 18:39
Folia pe geamuri ai pus-o tu sau asa ai luat-o ? Eram curios ce transparenta are. Vreau si eu sa-i pun la a mea si as vrea ceva mai transparent / deschis cum ai tu.
Danut 88
post 13 Oct 2017, 21:44
Uite asa sta ridicata.
13Lucian37
post 16 Oct 2017, 21:40
QUOTE(bogdanpaul @ 13 Oct 2017, 19:39)
Asa am luat-o, insa nu mi se pare foarte transparenta, seara mi se pare destul de dificil de dat cu spatele smile.gif) as vrea sa pun una putin mai transparenta si sa o omologhez.
QUOTE(Danut 88 @ 13 Oct 2017, 22:44)
Da, aparent si a mea sta la fel. Chiar nu am sesizat asta pana acum. Poate se vede asa de la roti, am cauciucurile 205/55/16. Tu?
13Lucian37
post 24 Oct 2017, 20:37
Revin cu niste vesti mai rele, am avut accident. Lovita in partea dreapta spate, fix in roata. Impactul a fost relativ usor, astfel ca tabla nu a fost decat putin infundata, portiera nu are nimic, se inchide perfect. Inafara de tablarie si vopsitorie, care sunt deja gata, am schimbat cate ceva:
Punte spate - am cumparat una echipata de la dezmembrari, cu tot ce trebuie, insa am pastrat amortizoarele vechi, pentru ca nu au necesitat sa fie schimbate, le tin de rezerva pe astea de la punte.
Arcuri spate - unul dintre ele era rupt, insa nu de la impact, cu ocazia asta totusi l-am depistat si le-am cumparat pe amandoua, noi.
Inainte sa se intample minunatia am avut probleme cu niste senzori: ABS, ESP si senzorul de la axul cu came.
ABS-ul si ESP-ul aveau o problema cu suportii, i-am schimbat si pe stanga si pe dreapta+rulmentii de la roti.
Legat de cel de la motor, in prima faza m-am speriat putin pentru ca imi arata in bord sa verific sistemul de evacuare. Dupa ce m-am documentat despre ce probleme puteau fi, m-am mai linistit, masina nu avea niciun simptom, doar senzorul era defect. Am cumparat unul OEM, nou dupa recomandarea mecanicului.
Bazinul de expansiune, era putin fisurat. Nu curgea lichid, dar am zis sa-l schimb si pe asta daca tot am bagat masina in service.
Mai am de cumparat si schimbat airbag-urile. Nu au sarit decat cel din scaunul pasagerului si cortina.
Cum masina nu are cruise-control, ma gandesc sa-i fac acest upgrade. Insa nu e graba pentru ca circul in cea mai mare parte in oras.
bogdanpaul
post 24 Oct 2017, 20:45
Nasol. Cauza accidentului ?
Diac
post 24 Oct 2017, 23:52
Și calculatorul de la airbaguri nu se schimba?
Renault Megane sedane/Nissan X-trail 2005/2017 Influence/Tekna - HAN/AIZ/DIA
Alexandru.
13Lucian37
post 25 Oct 2017, 18:45
QUOTE(bogdanpaul @ 24 Oct 2017, 21:45)
Nu eram eu la volan. Pe scurt neacordare de prioritate intr-o intersectie.
QUOTE(Diac @ 25 Oct 2017, 00:52)
Nu cumpar si calculatorul de la airbag-uri pentru ca mi l-a rescris cand a bagat-o pe tester. A ramas sa cumpar doar airbag-urile. Nu ma pricep la asta, sincer, dar daca asa mi-a zis mecanicul asa o sa fac biggrin.gif Sper sa nu fie probleme.
UPDATE: cumpar si calculatorul de la airbag pana la urma smile.gif)
This post has been edited by 13Lucian37: 25 Oct 2017, 20:04
Danut 88
post 26 Oct 2017, 15:07
QUOTE(13Lucian37 @ 16 Oct 2017, 21:40)
Si eu tot aceleasi dimensiuni am la anvelope. Dar nu e de la ele.
13Lucian37
post 27 Oct 2017, 12:23
QUOTE(Danut 88 @ 26 Oct 2017, 16:07)
Sincer, chiar m-am uitat si la alte Megane-uri la chestia asta de care zici tu si cam toate ar fi la fel de "barci". Cred ca asa e suspensia asta stock.
Update: am reusit sa comand si calculatorul de la airbag. Maine ajunge si luni am RAR-ul.
Legat de partea tehnica, nu am emotii, sper totusi sa nu imi faca vreo surpriza senzorii aia.
Stie cineva cum ar trebui sa procedez cu foliile? Nu sunt omologate, trebuie sa le dau jos sau merg cu ele asa si daca e problema le dau jos acolo :-?
espacern
post 27 Oct 2017, 17:48
ART-ist
RENAULT are mistere pe care OMUL nu va reusi niciodata sa le afle!
Danut 88
post 27 Oct 2017, 22:38
Apropo de folii, normal iti trebuie autorizatie. Dar multi nu se mai uita la ele.
13Lucian37
post 30 Oct 2017, 00:40
Am dat foliile jos, m-am gandit mai bine dupa ce am mai citit legislatia si nu are rost sa ma risc cu asta. Luni am RAR-ul, masina e ok din toate punctele de vedere.
Winter is coming... asa ca i-am pus si rotile de iarna, ma dor ochii cand o vad cu jantele astea de tabla dar o rezolv la urmatorul sezon. Cauciucurile sunt Hankook, din experienta mea de pana acum nu am avut probleme iarna cu cauciucuri Hankook.
Revin de maine cu poze, fara folii, cu jante de tabla iar dupa ce i-am schimbat arcurile pe spate s-a inaltat foarte mult smile.gif) chiar pot sa zic ca am un tractor de acum..
post 30 Oct 2017, 12:44
Si daca nu ai folii, dar geamurile sunt inegrite din fabrica, iti trebuie ceva? ca eu nu am nimic la mana, la RAR cand am facut cartea, s-au chinuit sa dezlipeasca, dar nu au gasit nici o folie de dezlipit, si nu au mai zis nimic.
bgdrenault
post 30 Oct 2017, 14:49
bgd
Bine ca nu ti le-au zgariat.
Din cate stiu, geamurile colorate din fabrica au o sigla ceva, care certifica acest lucru.
This post has been edited by bogdanbiciusca: 30 Oct 2017, 15:44
Megane Sedan 1,33 140 CP 2019 Intens - XXX
post 30 Oct 2017, 15:43
Da, scrie pe langa informatiile obisnuite ceva procent. Inseamna ca sunt safe...
cj98czh
post 30 Oct 2017, 20:31
Membru de la Cluj ...
QUOTE(bogdanbiciusca @ 30 Oct 2017, 14:49)
nu am nimic din ce spui tu .. si nici nu m-a intrebat nimeni nici la RAR, nici la ITP ..
Mazda 3 Zoom-Zoom 2018
marksman
post 30 Oct 2017, 22:00
Post mortem nihil est
"Privacy glass" se numeste optiunea, si apare la dotari dupa decodarea VIN, sau asa ar trebui. Cel putin la grupul VAG am gasit-o la doua masini. Sa faci retrofit la asa ceva e destul de greu.
Nick Ușor
bgdrenault
post 30 Oct 2017, 22:37
bgd
DA, dar la skoda cel putin, din 2007-2008, am vazut la doi colegi ceva inscrisuri. Daca mai ajung pe la masinile lor am sa fac o poza.
13Lucian37
post 30 Oct 2017, 23:39
Daca geamurile sunt asa din fabrica nu ai absolut nicio problema, ca nu stiu aia de la RAR asta, e altceva; insa se poate dovedi, scrie in cartea masinii, cum a zis si @marksman, la VAG se numeste "Privacy glass".
Am trecut si de RAR fara nicio problema. Initial mi-a spus ca nu tine frana de mana dar nu a tras-o decat foarte putin (la primii dinti) si dupa ce i-am aratat a zis ca e in regula smile.gif)
Asta e tractorul acum fara folii, arcuri noi, cauciucuri de iarna si jante de tabla.
This post has been edited by 13Lucian37: 30 Oct 2017, 23:39
13Lucian37
post 3 Jan 2018, 18:44
Am parcurs putin mai mult de 4k km cu ea de cand o am. In ultima vreme masina a mers numai in oras, consumul mi se pare putin mai mare decat ma asteptam, avand in vedere ca locuiesc intr-un oras destul de liber din punct de vedere al traficului, consuma 10.5-11.
Am scos-o la drum intins cand am plecat la revelion si am fost putin curios de cat "duce". In conditiile in care aveam masina plina, mi se pare destul de ok, acum depinde prin ce prisma privesti asta smile.gif)
Am verificat si uleiul, culoarea e ok si nu a consumat deloc.
13Lucian37
post 12 Mar 2018, 23:32
159.623 km, 7.1% consum mediu (30% in oras - 70% in afara)
Am trecut de prima iarna cu ea. Nu am avut probleme cu pornirea la rece (-15°C/-20°C), am fost multumit de cum s-a comportat iarna, mai ales ca se incalzeste foarte repede motorul.
Setul de cauciucuri de vara urmeaza sa fie schimbat (uzura iar unul dintre ele are o pioneza foarte mare in el, daca o scot, e pana smile.gif), cel mai probabil tot Hankook.
Mai sunt de schimbat si planetarele, o sa le iau pe amandoua noi.
TomachE
post 13 Mar 2018, 17:56
Eu am Hankook Kinergy Eco K425 si asta vara s.au cumportat super ok ! Cam peste 15 mii am facut vara trecuta cu ele ! smile.gif
Megane II 1.6/16v 82kW 112 cp Break 2005 - B 301 AAT
Catalinmodena
post 13 Mar 2018, 19:00
Dubios cu planetarele la km astia.
Renault megane sedan manager 1.4 16v 2007
7 Pages  1 2 3 > »
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 13th June 2025 - 12:56
