Renault Megane II Grandtour Avantage [2005], Jurnal de bord
13Lucian37 |
#121
![]() Membru Group: Members Posts: 117 Joined: 30 August 17 From: Medgidia ![]() |
Attached thumbnail(s) 531bd85f_b63c_4a81_9723_da1258fe63fe.jpg ( Size: 99.67k ) Number of downloads: 1017 dcd38e7a_4997_446a_b3c9_7d9e17d31676.jpg ( Size: 141.92k ) Number of downloads: 1030 |
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
13Lucian37 |
#122
195.7 k km
Avem baterie noua la Megane. Am tot tras de cea veche desi dadea semne de oboseala pana m-a lasat pe plaja la Vadu ![]() Bateria veche a fost montata pe masina in luna mai 2015, a tinut 5 ani si ceva.. chiar mai mergea o vara ![]() Bateria a costat 280 de lei, are garantie 2 ani. 26 Aug 2020, 20:04: Eroarea de ABS/ESP a fost cauzata de senzorul de ABS de la roata din fata stanga. Cine stie de cand e asa ![]() Am comandat alt senzor, sper sa nu fie nevoie si de alt rulment. 26 Aug 2020, 20:07: Am facut upgrade la becul din portbagaj cu un led pentru numarul de inmatriculare. Cumparasem setul de mult insa nu s-a potrivit la break, era pentru berlina. Intr-un final i-am gasit un loc ![]() This post has been edited by 13Lucian37: 26 Aug 2020, 19:07 Attached thumbnail(s) 6942d3e0_0cd8_4677_9292_3891ee72fa66.jpg ( Size: 49.9k ) Number of downloads: 986 21d87325_152f_400c_bb91_564974254ba0.jpg ( Size: 265.9k ) Number of downloads: 986 118040751_913643872379929_6505533421936575626_n.jpg ( Size: 351.85k ) Number of downloads: 989 118070391_303218414090223_1383932824568202867_n.jpg ( Size: 575.04k ) Number of downloads: 110 118054739_1573213622857364_2929615863355228424_n.jpg ( Size: 299.34k ) Number of downloads: 115 118084636_2856227241146048_4907079746548258159_n.jpg ( Size: 652.8k ) Number of downloads: 116 |
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
Raduchu |
#123
![]() Nu-mi arde becu' Group: Members Posts: 1.453 Joined: 21 April 09 ![]() |
Daca nu vezi intr-o noapte cand dai cu spatele, deschizi portbagajul si se rezolva.
Renault 25 '86
2 x Volkswagen Passat
'08 Highline '10 R-Line There is a light somewhere, it may not be much, but it beats the darkness!
Rage, rage against the dying of the light! 500.000 km and counting. |
rue |
#124
![]() Membru autentic Group: Members Posts: 1.713 Joined: 18 September 05 From: Internet ![]() |
Pentru logan 1 pe unde gasesti asa lampa led de portbagaj, daca stiti?
2021, 1.0 TCE eco-G, Comfort
- RUE
13Lucian37 |
#125
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
13Lucian37 |
#126
Am avut o patanie cu Megane-ul de care n-am avut timp sa mai scriu aici.
De obicei vara, renou' asta merge cel mai mult si in cele mai grele conditii. Este cort, rulota, duba si ce mai vrei. De 2 ani merg in fiecare vara la plaja salbatica de la Vadu. Mergeam si inainte, doar ca nu cu masina asta. Nu-mi place in cort, pentru ca nu pot sa dorm pana tarziu (de obicei daca a iesit soarele te cam sufoci in cort); problema rezolvata cu un break, o saltea si niste folie de aluminiu pe geamuri. Am mers de multe ori la Vadu, insa vara asta le-am patit pe toate. Am ramas in nisip cu masina, de data asta era imposibil sa o scot singur de acolo; de altfel am mai patit sa raman in nisip dar am rezolvat singur cu lopata, niste lemne si presurile din masina. Alta data am ramas fara baterie. Scenarii nasoale, mai ales acolo. Acum spre finalul verii am mers la plaja salbatica Pescarusul. E pe langa Olimp. Nu aveam asa mult de mers pana acolo (eram la Neptun) si pentru ca mergeam pentru prima data am zis sa nu raman peste noapte acolo ca nu stiu cum e. Am mers doar pentru o plaja pe zi. In drum spre plaja Megane-ul se tot oprea in mers, drumul nu este asflatat si e plin de gropi si denivelari. Pur si simplu se oprea tot, nu mai aveam lumina in bord, nimic. Dar pornea imediat inapoi. Ma rog, a trecut si ziua asta, am strans si am zis ca plec acasa. Cand urc in masina sa pornesc, surpriza: masina nu mai porneste, nu se aprindea nimic in bord, nu aveam curent (sau cel putin asa am zis eu); Ciudat pentru ca abia schimbasem bateria. Gasesc intr-un final pe cineva dispus sa ma ajute cu o galeata de curent. Problema era ca eu aveam cablurile la roata de rezerva, portbagajul si bancheta din spate erau pline de bagaje, umbrele, mese, scaune si alte lucruri de camping iar portbagajul nu se deschidea. Am reusit sa-l deschid de pe interior, numai eu stiu cum >_< Montam cablurile, asteptam cateva minute.. nimic. Dupa vreo 10 minute i-am multumit omului, mi-am cerut scuze de deranj si n-am mai incercat. Pur si simplu masina nu avea curent, de parca am scos o borna de la baterie. Il sun pe tatal meu care era la Neptun sa vina sa ma ajute. Am incercat inca o data sa-i dam curent apoi am luat bateria de la Skoda (masina cu care a venit el) si am pus-o pe Megane. Nu se intampla nimic, bateria era buna. Ne-am lasat pagubasi si am plecat. Am lasat Megane-ul acolo. Am venit a doua zi cu forte proaspete. Pe drum ne gandeam, cum ar fi sa ajungem si sa porneasca. Aproape ca a fost asa ![]() Am zis ca poate nu face masa bateria. Am incercat cu un fir sa iau masa de pe motor. Nimic. Am curatat bornele, toti papucii circulari care sunt pe "+" la sigurantele alea 3. Am incercat cu un fir sa ocolesc sigurantele. Nimic. La un moment dat cand umblam pe la panoul de sigurante s-a aprins lumina. Hopa. Am pornit si masina. Am zis sa strangem repede sculele si sa plecam ![]() ![]() Cand am ajuns la linia de cale ferata, am deschis geamul, mi-am dat centura jos si mi-am facut curaj ![]() Am incercat cu motorul pornit sa mai misc de panoul de sigurante de la motor, se misca cu totul de parca nu era prins cu nimic. Problema am gasit-o repede. Firul care alimenteaza panoul de sigurante are un papuc circular si un surub. Surub care nu era strans. Am curatat zonele metalice de contact, papucii si mufele pe acolo. De la cutia de sigurante lipseau niste piulite. Am gasit unele sa se potriveasca, la fel si pentru manunchiul de fire din compartimentul motor. Am strans niste suruburi, am bibilit niste mufe, am fixat niste clipsuri si am rezolvat problema. 8 Sep 2020, 21:54: Intre timp s-a mai schimbat senzorul de la ABS pe stanga fata. Am scapat de eroarea de ABS/ESP. Masina a mai fost verificata cu un tester si nu mai are nicio eroare. Sper sa ramana asa mult timp de acum inainte ![]() This post has been edited by 13Lucian37: 8 Sep 2020, 20:54 Attached thumbnail(s) 4019ccc2_84e7_43a2_a4e7_67b0bebfe8ea.jpg ( Size: 128.08k ) Number of downloads: 114 ef2624e0_e647_46eb_b2a6_5cedde02b0e5.jpg ( Size: 74.16k ) Number of downloads: 90 c9517317_3d19_4973_b4b8_dbdbc5757e71.jpg ( Size: 174.37k ) Number of downloads: 86 b01f32dc_18fc_4a9f_bea0_494ab4b0520c.jpg ( Size: 141.99k ) Number of downloads: 84 83596014_bc39_4be5_a622_01345261daa1.jpg ( Size: 190.65k ) Number of downloads: 89 06acb653_7069_48e6_afb2_3ba8738569e3.jpg ( Size: 50.51k ) Number of downloads: 89 |
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
13Lucian37 |
#127
196.6 k km
Am schimbat senzorul de poziție al arborelui cotit. Daca are cineva probleme cu identificarea codului potrivit poate folosi codul din poza pentru ca senzorul asta se potrivește la ambele mufe (are toate canelurile necesare pentru ambele mufe). Attached thumbnail(s) IMG_20200922_112426.jpg ( Size: 2.74mb ) Number of downloads: 106 IMG_20200922_123436.jpg ( Size: 2.29mb ) Number of downloads: 93 |
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
13Lucian37 |
#128
Din pacate a inceput sa apara iar acel zgomot la pornirea motorului (la rece). Am crezut ca am rezolvat-o cu senzorul, dar nu. Habar n-am de unde sa mai incep acum..
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
13Lucian37 |
#129
Cum nu se poate sa treaca o luna fara probleme, acum cateva zile am avut eroarea "Check injection" in bord si masina nu mai avea putere, nu se mai tura.
Am pus un tester pe ea, am resetat eroarea, am facut o proba dupa si am monitorizat valorile citite la pedala de acceleratie si acum e ok. Daca mai patesc o sa schimb pedala ![]() This post has been edited by 13Lucian37: 12 Oct 2020, 14:36 Attached thumbnail(s) 92659f53_fc17_49e7_92aa_717778c704ef.jpg ( Size: 117.96k ) Number of downloads: 87 |
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
13Lucian37 |
#130
Un consum pentru Medgidia - Bucuresti Regie (dus-intors)
La dus a fost plina de bagaje si am mers mai lejer: 130-150 pe autostrada La intors am fost doar eu in masina si am mers cat au tinut-o planetarele. Am plecat din Regie cu 380km range si am ajuns acasa cu 100km range (drum de aprox. 200 km) Attached thumbnail(s) WhatsApp_Image_2020_10_26_at_16.02.34__1_.jpeg ( Size: 234.68k ) Number of downloads: 113 WhatsApp_Image_2020_10_26_at_16.02.34__2_.jpeg ( Size: 192.93k ) Number of downloads: 118 dist.jpeg ( Size: 38k ) Number of downloads: 108 avg.jpeg ( Size: 36.11k ) Number of downloads: 68 fuel_used.jpeg ( Size: 36.03k ) Number of downloads: 53 |
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
Bicicleta galbena |
#131
![]() Sunt nembru, domnule! Group: Members Posts: 2.193 Joined: 29 January 13 From: Bucuresti ![]() |
La o frana brusca, monitorul ala devine un proiectil in scafarlia cuiva.... ai grija cu impachetarea.
Peugeot
407 1.8 16v
13Lucian37 |
#132
QUOTE(Bicicleta galbena @ 26 Oct 2020, 19:11) La o frana brusca, monitorul ala devine un proiectil in scafarlia cuiva.... ai grija cu impachetarea. Era proptit in ceva pe acolo, in plus avea si centura de siguranta ![]() Oricum am plecat putin pe fuga atunci cand am incarcat masina si le-am cam aruncat, nu am stat sa le asez pentru ca eram sigur ca e loc pentru toate ![]() |
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
13Lucian37 |
#133
21.11.2020
199 k km Schimbarea sosetelor. Deja au inceput sa scada temperatura si pneurile de vara nu-si mai aveau rostul, mai ales dimineta cand era si putin polei pe drum. Megane-ul intra in sezonul in care nu o sa mai fie spalat. Am aflat si de ce imi tot aparea si disparea eroarea de airbag - spira de la volan. Din pacate, fiind de pe China, nu a tinut prea mult. Am avut totusi speranta pentru ca am vazut persoane care le aveau de peste 5-6 luni si nu au aparut probleme. 24 Nov 2020, 18:50: Am curatat si filtrul de aer. Nu era foarte murdar, dar merita si el putina atentie din cand in cand. This post has been edited by 13Lucian37: 24 Nov 2020, 17:50 Attached thumbnail(s) WhatsApp_Image_2020_11_23_at_00.38.23__1_.jpeg ( Size: 351.63k ) Number of downloads: 85 WhatsApp_Image_2020_11_23_at_00.38.24__1_.jpeg ( Size: 46.84k ) Number of downloads: 96 2020_11_24_17_49_43_Photos.png ( Size: 1.28mb ) Number of downloads: 65 |
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
13Lucian37 |
#134
200 k km
O sa ii fac revizia mai devreme, trebuia la 202k km. Am cumparat si gatul de la rezervorul de parbriz pentru ca era crapat si mereu curgea lichid de parbriz cand umpleam rezervorul. Am fost surprins cand am vazut ca vine cu o joja de lichid de parbriz ![]() Amortizoarele de la portbagaj sunt cam obosite de un an si nu se mai ridica singur hayon-ul atunci cand il deschid, asa ca am luat si 2 amortizoare pentru portbagaj. Am comandat si suportul ala pentru capitonajul de la motor - prooblema clasica intalnita - insa nu am gasit si surubul cu piulita/clema. Sper sa gasesc alt surub potrivit sau sa improvizez ceva cu suportul asta. Attached thumbnail(s) WhatsApp_Image_2021_01_14_at_23.16.05.jpeg ( Size: 126.58k ) Number of downloads: 78 WhatsApp_Image_2021_01_14_at_23.16.06.jpeg ( Size: 84.41k ) Number of downloads: 79 2021_01_14_23_19_43__17_170_unread____andrey_xtq_yahoo.com___Yahoo_Mail___8211__Google_Chrome.png ( Size: 34.13k ) Number of downloads: 79 |
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
13Lucian37 |
#135
200k km
Am facut azi schimbul de ulei. A fost cam frig si a fost o tentatie de a ninge dar a mers bine treaba. A mers bine pentru ca ultimele revizii le-am facut eu si nu a strans nimeni surubul de la baia de ulei pana sa crape, nu a strans nimeni filtrul de ulei pana sa se sudeze de blocul motor si asa mai departe ![]() Tin minte ca la prima revizie pe care am facut-o eu, atunci cand am vrut sa desfac surubul de la baia de ulei avea capul unde intra cheia decalibrat. Nu mergea cu cheia speciala nici cu alte improvizatii. Mecanicul care imi facuse revizia inainte avea o cheie facuta de el dintr-un torx taiat cu flexul ca sa aiba forma de patrat. Din pacate cheia standard patrat de 8 nu era la fel si nu am reusit sa-l desfac ![]() Attached thumbnail(s) WhatsApp_Image_2021_01_16_at_23.04.26.jpeg ( Size: 321.48k ) Number of downloads: 76 WhatsApp_Image_2021_01_16_at_23.04.27__1_.jpeg ( Size: 40.33k ) Number of downloads: 69 WhatsApp_Image_2021_01_16_at_23.04.27__2_.jpeg ( Size: 39.95k ) Number of downloads: 46 WhatsApp_Image_2021_01_16_at_23.04.27.jpeg ( Size: 40.08k ) Number of downloads: 36 |
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
Diac |
#136
![]() Membru autentic Group: Members Posts: 3.024 Joined: 18 April 05 From: Bucuresti. ![]() |
Amortizaoarele QWP de la haion nu-s un pic cam prea tari? Am luat unele acu 3 ani si iti cam zboara haionul din mana in sus. Intre timp s-au mai lasat.
Megane sedane/Nissan X-trail
2005/2017 Influence/Tekna
- HAN/AIZ/DIA Alexandru.
13Lucian37 |
#137
QUOTE(Diac @ 17 Jan 2021, 13:51) Amortizaoarele QWP de la haion nu-s un pic cam prea tari? Am luat unele acu 3 ani si iti cam zboara haionul din mana in sus. Intre timp s-au mai lasat. Nu voiam sa iau QWP, dar asta au avut pe stoc. Pe ele scrie ca au 500N. Cand au venit am incercat sa comprim unul dintre ele si efectiv nu am reusit, am crezut ca e blocat/gripat ![]() Inca nu le-am montat, dar intr-adevar sunt foarte tari. In cel mai rau caz montez doar unul dintre ele. O sa revin azi cu un raspuns. 17 Jan 2021, 20:25: QUOTE(Diac @ 17 Jan 2021, 13:51) Amortizaoarele QWP de la haion nu-s un pic cam prea tari? Am luat unele acu 3 ani si iti cam zboara haionul din mana in sus. Intre timp s-au mai lasat. Sunt cam tari.. ![]() Se deschide super ok, lin, nu bruscheaza cand ajunge sus.. dar cand trebuie inchis, pas ![]() Am testat si cu un singur amortizor nou si era perfect ![]() O sa raman cu amandoua de la QWP in speranta sa se mai domoleasca. This post has been edited by 13Lucian37: 17 Jan 2021, 19:25 |
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
13Lucian37 |
#138
Am avut o eroare pe motor, s-a rezolvat cu resetarea erorii. Masina functiona normal, era doar martorul aprins.
Fault log report generated by Torque for Android ================================================= Vehicle VIN: Vehicle Manufacturer: Vehicle Calibration ID: Current Fault Log ------------------ P0110: Intake Air Temperature Circuit Pending Fault Log ------------------ ECU reports no pending faults Historic Fault Log ------------------ ECU reports no historic faults Other discovered fault codes (possibly pending, current or manufacturer specific) ---------------------------------------------------- ECU reports no other fault codes logged End of report. Attached thumbnail(s) 17666f9d_bcc6_4f15_8ff9_ec7a89f6d2ef.png ( Size: 1.57mb ) Number of downloads: 65 4edfc001_5305_43fc_a919_2aac1f20d5f2.png ( Size: 325.3k ) Number of downloads: 63 |
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
sorin1983 |
#139
![]() Membru autentic Group: Members Posts: 5.629 Joined: 3 July 06 From: Bucuresti-Rahova ![]() |
verifica mufa senzorului de temperatura de pe admisie.
Megane1-
kommodore_ss |
#140
Membru Group: Members Posts: 110 Joined: 26 July 17 ![]() |
Mai merita bagat bani in ea?
wolfin |
#141
![]() Haha Group: Members Posts: 8.875 Joined: 2 December 05 From: Bucuresti ![]() |
Aceeasi intrebare si pt hartie igienica?
pegas
3120
13Lucian37 |
#142
QUOTE(sorin1983 @ 22 Jan 2021, 12:15) Raspunsul era fix acolo ![]() Atunci cand am schimbat filtrul de ulei, am scos mufa pentru a avea acces la filtru mai usor, dar am uitat sa o pun inapoi ![]() QUOTE(kommodore_ss @ 22 Jan 2021, 16:05) Atunci cand iei o masina care a cam trecut de perioada utila de functionare se mai intampla sa bagi si bani, asta e. Intr-un fel problemele pe care le-am avut s-au rezolvat usor, dar problema e ca apare mereu cate ceva. De cand a cedat spira de la airbag prima data, am tot schimbat-o iar in momentul asta tot am probleme cu ea ![]() ![]() Am montat azi si suportul ala, sa-i spun asa, care sustine captuseala ![]() This post has been edited by 13Lucian37: 23 Jan 2021, 22:03 Attached thumbnail(s) WhatsApp_Image_2021_01_23_at_21.51.26__2_.jpeg ( Size: 151.73k ) Number of downloads: 62 WhatsApp_Image_2021_01_23_at_21.51.26.jpeg ( Size: 126.41k ) Number of downloads: 68 WhatsApp_Image_2021_01_23_at_21.51.26__1_.jpeg ( Size: 204.41k ) Number of downloads: 67 |
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
sorin1983 |
#143
am patit si eu de asta ti-am zis...
![]() ca sfat cauta-i un capac de motor si mai scapi de problemele cu umezeala pe la bobine. la cum vad capitonajul ala de la grila sigur iti intra apa chiar daca i-ai pus si suportul ala(care de altfel cred ca singurul lui scop e sa tina mocheta sa nu ajunga pe evacuare si sa ia foc) This post has been edited by sorin1983: 23 Jan 2021, 23:31 |
Megane1-
13Lucian37 |
#144
QUOTE(sorin1983 @ 24 Jan 2021, 00:28) am patit si eu de asta ti-am zis... ![]() ca sfat cauta-i un capac de motor si mai scapi de problemele cu umezeala pe la bobine. la cum vad capitonajul ala de la grila sigur iti intra apa chiar daca i-ai pus si suportul ala(care de altfel cred ca singurul lui scop e sa tina mocheta sa nu ajunga pe evacuare si sa ia foc) Am capac la motor doar ca era dat jos in poza. A fost mai usor sa montez suportul ala fara el ![]() Ar fi bine sa gasesc o solutie pentru chederul ala, poate cu ocazia asta nu mai intra frunze in grila aia de sub stergatoare. Ca fapt divers, am vazut la cineva chedere puse pe aripi - unde sta capota peste aripile din fata. hai ca am gasit poza.. se intelege mai bine asa ![]() This post has been edited by 13Lucian37: 24 Jan 2021, 02:22 Attached thumbnail(s) 26951722_1804776309554784_825708657780773654_o.jpg ( Size: 180.44k ) Number of downloads: 86 |
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
Catalinmodena |
#145
![]() Membru autentic Group: Members Posts: 2.547 Joined: 7 April 08 From: Aproape de Craiova ![]() |
Da, sunt ok. Am avut și eu. Poți pune și sită la gura aerotermei, sub grila de la ștergătoare, pentru un filtru de polen mult mai curat.
megane sedan
manager 1.4 16v 2007
13Lucian37 |
#146
QUOTE(Catalinmodena @ 24 Jan 2021, 11:22) Da, sunt ok. Am avut și eu. Poți pune și sită la gura aerotermei, sub grila de la ștergătoare, pentru un filtru de polen mult mai curat. O sita ceva acolo ar merge super bine ![]() 25 Jan 2021, 14:10: Ca tot vorbim de rable si de bagat bani, dimineata a pocnit bateria la Skoda ![]() Noroc ca am pastrat bateria veche de la Megane si ma pot baza pe ea pana iau alta baterie la Skoda. This post has been edited by 13Lucian37: 25 Jan 2021, 13:10 |
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
13Lucian37 |
#147
Am gasit niste poze mai vechi cu Megane-ul, proaspat spalat
![]() De atunci n-a mai fost asa curat xD This post has been edited by 13Lucian37: 30 Jan 2021, 16:53 Attached thumbnail(s) IMAG0081.jpg ( Size: 2.5mb ) Number of downloads: 47 IMAG0076.jpg ( Size: 2.68mb ) Number of downloads: 36 IMAG0075.jpg ( Size: 2.6mb ) Number of downloads: 37 |
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
geoman |
#148
![]() George Group: Members Posts: 399 Joined: 28 October 07 From: Iasi ![]() |
auite bah. Ti-ai pus modul chinezesc la airbag. Da n-ai observat ca ei interzic sa montezi modulul si cu rotile drepte.
renault
megane sedan 2 1.5dci 80 cp, 1.9 dci E4 FAP
2004, 2006
13Lucian37 |
#149
Megane II Grandtour
2005 1.6 16v
- CT 63 TER
geoman |
#150
sau ai vreun traseu nelipit la unul din capetele benzii. Am patit si eu cu unul luat de la ei. Ia da oleaca capacelul ala de langa conector la o parte si vezi. Se poate vedea capatul benzii si lipiturile pe conector. Eu acolo il aveam dezlipit si nu a mai trebuit demontat.
renault
2004, 2006
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 13th June 2025 - 15:16 |
