Inspectia tehnica periodica (ITP), Tips
cannavaro |
#301
![]() . Group: Members Posts: 812 Joined: 15 July 05 From: Ploiesti ![]() |
- PH-89-XXX
TSP Dacia 1300 1981 - B-83-GRS
ydaniel |
#302
Oriunde,
oricand...
Cand esti rau ,nu te uita! |
emircea |
#303
![]() membru cu Te-FiSI Group: Members Posts: 756 Joined: 14 June 04 From: Timisoara ![]() |
Asa este.
Apropos de motoare diesel... se pare ca turarea gen 'pedala la podea' pentru testul de noxe nu este un test specific RAR Romania... se practica la nivel international. Mai jos este un extras de pe un site britanic, unde este descrisa metoda de inspectie pentru motoare diesel: <<If appropriate remove the oil temperature probe. Raise the engine speed to around 2500rpm or half the maximum engine speed if this is lower and hold for 30 seconds to fully purge the inlet and exhaust system. Raise the engine speed slowly to maximum to check the operation of the governor. Once the engine speed has stabilised or it becomes clear that the govenor is not working, release the pedal, return to idle and stop the engine. Prompt the meter to carry out a zero check . Check that the smoke meter probe can be inserted into the tailpipe Insert the probe fully and securely , in line with the gas flow and restart the engine. Fast Pass : Following the meter prompts, press the accelerator pedal quickly and continuously, but not violently, to reach full fuel position in less than 1 second. Hold it there until a release prompt is given, then immediately release the pedal. Allow the engine and any turbocharger fitted to return to idle speed. At the end of the 1st acceleration, read the smoke level displayed on the meter. If it is at or below 1.5m-1 the vehicle has passed this part of the test and a pass result will be displayed on the meter. Go to Method of inspection 3 . If the 1st acceleration smoke level is greater than 1.5m-1 carry out two further accelerations following the meter prompts At the end of the 3rd acceleration, read the smoke level displayed on the meter. If it is at or below the appropriate level the vehicle has passed this part of the test and a pass result will be displayed on the meter. Go to Method of inspection 3 If the mean smoke level is too high carry out further accelerations up to a maximum of six in total. After each acceleration, check the mean reading. This part of the test is complete when either: - the mean of any 3 smoke levels is at or below the appropriate limit, or - six accelerations have been performed Method 3: Assess whether the smoke emitted from the exhaust, regardless of measured density, is likely to obscure the vision of other road users. >> Tehnicii de la reprezentantele auto au o strangere de inima in ce priveste ITP-ul la diesel-uri, pe motiv ca e chinuita masina (si, motiv real, ca unele piese de calitate indoielnica cedeaza la un astfel de test, dandu-le dureri de cap cu garantii, etc). Ce nu-mi este clar: 1. normele de inspectie prezentate mai sus sunt stabilite la nivel, sa zicem, international; 2. producatorii de autovehicule sunt constienti de testele de mai sus, deci ar trebui sa prevada stresul ocazional la proiectarea motorului; 3. aceiasi producatori, la un test asa de destructiv, de ce nu prevad taierea alimentarii motorului daca un anumit interval de siguranta este depasit intr-un astfel de regim - mai ales ca nu este regim normal de functionare pentru acel motor. |
Dacia 1300, 1981;
- MH / TM / B
1981 / 1977 / 2009 Daca nu poti sa-i lamuresti, zapaceste-i! (Murphy)
magelan_explorer |
#304
![]() membru intamplator ! Group: Members Posts: 546 Joined: 25 November 07 From: bucuresti ![]() |
QUOTE(gygy @ 3 May 2008, 13:07) Am si eu o intrebare : Pot face actele vanzare /cumparare daca masina are itp expirat , sau mai are o luna pana expira?? risti f mult,la verificarea ITP ului,daca valabilitatea se apropie de final te obliga sa-l faci (chiar daca ,teoretic,e in perioada de valabilitate) si daca incapi pe mana celor de la RAR greu mai scapi...eu zic sa-l pui pe actualul proprietar sa-i faca ITP-ul,asa ti-o si repara si vezi si defectele ascunse! |
scala 2003 / logan dci 2007
ex:supernova.dacia 95.dacia 87
Tiberiu-Andrei |
#305
![]() Om al muntelui Group: Members Posts: 721 Joined: 25 September 07 From: Sfantu Gheorghe ![]() |
Vin si eu cu o intrebare,itp e valabil pana pe 26 mai.Problema e ca vreau sa vopsesc masina din considerente estetice.Masina merge bine evident,directie,noxe,tot tot in afara vopselei care e programata la inceputul lunii iunie.Cum vreau sa i-au treaba pe bune si nu pe spagi ce mi-ati recomanda sa fac?Am inteles ca se poate achita taxa itp si primesc o dovada cu care pot circula o luna,timp in care va fii gata si vopseaua.
Astept sfaturi/pareri. PS:Minele felicitari de masina!!! |
1410
- CV 03 MBO
1988 toamna1397 cmc
dan.gutu |
#306
![]() Membru autentic Group: Members Posts: 499 Joined: 26 February 07 From: Europa ![]() |
Cu raportul de inspectie tehnica nu ai voie sa circuli decat pana la poarta statiei I.T.P. In regulament spune sa te duci cu cel putin o luna innainte sa expire I.T.P. ul,sa-l faci,iar daca sunt ceva nereguli sa le poti remedia in luna aceea pana expira.Practic,cu acel raport mai tare te invinovatesti,ca circuli cu buna stiinta fara I.T.P.
TOYOTA
COROLLA & AURIS HSD
2009 & 2012
capone |
#307
Membru incepator Group: Members Posts: 9 Joined: 10 December 07 ![]() |
In primul rand salutare tuturor , am reusit sa citesc intreg topicul (sau aproape tot) si as avea si eu o intrebare . (Daca administratorii considera ca nu are legatura cu topicul rog sa se stearga) .Multumesc anticipat
Tocmai ma pregatesc sa vand o masina si anume un Opel Astra caravan din 1993 daca masina nu rata ff bine estetic ( parbriz fisurat , o usoara lovitura in usa , etc.) si scoate ceva fum (papa ulei) , pot avea probleme la identificare R.A.R sau acolo se uita doar la serii ? ![]() This post has been edited by capone: 20 May 2008, 00:05 |
prestige 2007
#308
nu ai treaba la identificare cu asta.
- 2.0 DCI 16v 180
Adrian_Boy |
#309
Se uita doar la serii (se fac si poze la ele), doar daca nu ai ITP-ul valabil atunci te baga si acolo.
Astra Z16XE
- B
2001 16V 101 caluti de rasa!
wind |
#310
Membru autentic Group: Members Posts: 630 Joined: 19 January 07 From: bucuresti ![]() |
ITP la Motor Service. Cost 80 ron + revenirea 60 ron
Nu recomand la nimeni . Este foarte aglomerat. Dupa ce am avut respingere am incercat de 3 ori sa ma prezint. in primele 2 zile de sambata nu am mai putut intra deoarece mai erau vreo 10 masini in fata mea si nu mai era timp. Primul de la coada venise de la ora 6 dimineata !!!!! in rest sunt ok. |
2004 Scala
crystygye |
#311
![]() Membru autentic Group: Members Posts: 392 Joined: 14 August 06 From: Bucuresti ![]() |
Am si eu o mica intrebare.
ITP meu expira in august anul acesta.Are ceva daca il fac acuma? Sau trebuie sa astept neaparat pana expira? Multumesc |
Fiesta
2007 facelift 1.3 benzina, 51kw, jh1 https://portalultautv.net
cannavaro |
#312
Am fost la itp si m`au trimis acasa ptr gumele 175 50 13
- PH-89-XXX
#313
- 2.0 DCI 16v 180
Minel |
#314
1310-L /VW Passat
- CS-01-TMS
1995/1397cmc Mandru posesor de Dacia
cannavaro |
#315
Masina fiind veche, era normal ca imi da revenire, asa ca nu m-am obosit sa le schimb 1 data ca apoi sa le mai schimb inca o data.Ma mir ca in afara de frana de mana care tinea cam sus, nu mi-a gasit mai nimic la masina,
- PH-89-XXX
oviancuta |
#316
Membru incepator Group: Members Posts: 23 Joined: 17 June 06 ![]() |
Astazi am facut ITP la Simpotrans Colentina , programare la 8 dimineata (programare facuta miercuri). Totul a fost OK.Pret 70 RON
- verificat lumini (TOATE, inclusiv bec spate la numar inmatriculare) - verificat joc roti - fata + spate - verificat de rugina - a tras de toba ... nu am intrebat de ce - verificat bateria - verificat noxe - verificat franele pe stand La sfarsit poze la seria caroseriei + poza fata sa se vada ca a pus bulina. Nu se apuca de treaba la masina pina nu o verifica pe site la RAR. PS. - se poate plati cu cardul. - nu m-a intrebat de triunghi reflectorizant + stingator ... dar le aveam oricum. Acte necesare: buletin/ CI, cartea de identitate a masinii, certificat inmatriculare + RCA Bafta ! This post has been edited by oviancuta: 23 May 2008, 13:03 |
Ambition
2006, 1.6 MPI
magelan_explorer |
#317
QUOTE(capone @ 20 May 2008, 00:04) In primul rand salutare tuturor , am reusit sa citesc intreg topicul (sau aproape tot) si as avea si eu o intrebare . (Daca administratorii considera ca nu are legatura cu topicul rog sa se stearga) .Multumesc anticipat Tocmai ma pregatesc sa vand o masina si anume un Opel Astra caravan din 1993 daca masina nu rata ff bine estetic ( parbriz fisurat , o usoara lovitura in usa , etc.) si scoate ceva fum (papa ulei) , pot avea probleme la identificare R.A.R sau acolo se uita doar la serii ? ![]() daca cel care face identificarea e un jegos,cheama un inspector,ai arata masina si ti-o baga fortat la verificari,e o practica obisnuita pt cei de la RAR normal nu e nicio legatura intre identificare si verificare,dar stiu cazuri,deci..cu mare grija... |
freeman30 |
#318
Membru autentic Group: Members Posts: 576 Joined: 31 May 04 From: Bucuresti ![]() |
Am facut ITP-ul acum 2 sapt la o masina veche un Fiesta MK1 din 1979 , prima oara respinsa pt un rulment si un pivot ,s-au remediat numai ca la trimiterea datelor catre RAR masina a fost blocata pentru suprainspectie RAR.
Mi sa reverificat toata masina in mod corect fara a se cauta eventuale hibe ascunse , si desi e o masina veche a trecut cu brio reverificarea RAR.Am vazut discutiile de aici si nu iau partea nimanui dar cred ca daca masina e in parametri nu conteaza vechimea.Masina a fost refacuta aproape complet, mai putin motorul. |
Daewoo
Tico
SX 2000
cannavaro |
#319
motivul blocarii care a fost?
- PH-89-XXX
nambanidealtceva |
#320
![]() Pe volan din 96 Group: Members Posts: 335 Joined: 31 October 05 From: B U C U R E S T I ![]() |
blocarea nu se face cu motiv... ciudat este faptul ca nu am auzit pe nimeni sa ii fi fost blocata masina, daca era relativ noua..
Citroen C4
1.6 16V, 2005,
vandut Dacia 1310 Li, 2000 (cu regret)
WNS |
#321
![]() Membru Group: Members Posts: 169 Joined: 1 May 08 ![]() |
Mi s-a intamplat mie acum doua sau trei luni de zile.
M-am dus pt ITP cu masina unei cunostiinte, un Daewoo Tacuma din 2006. Dar era in regula masina avea 17000 km. Au verificat-o si razverificat-o, se uitau ca broasca la sudura, dar nu au avut ce sa gaseasca. Doar am pierdut eu o groaza de timp. ![]() This post has been edited by WNS: 24 May 2008, 12:44 |
Audi
A4 B7
2.0 TDI-2007-Multitronic Poți folosi orice limbaj dorești, niciodată nu poți spune altceva ... decât ceea ce ești.
freeman30 |
#322
nu a fost un motiv anume ,eu chiar am intrebat daca a fost blocata pt ca e veche si mi s-a spun ca nu .Calculatorul de la RAR alege aleatoriu masina.Sincer gogoasa asta nu am inghiti-o......si tot nu cred ca e aleatoriu.....au ceva introdus in calculatorul ala cand alege....poate mai mult masinile vechi....
Daewoo
Tico
SX 2000
magelan_explorer |
#323
QUOTE(freeman30 @ 24 May 2008, 13:39) nu a fost un motiv anume ,eu chiar am intrebat daca a fost blocata pt ca e veche si mi s-a spun ca nu .Calculatorul de la RAR alege aleatoriu masina.Sincer gogoasa asta nu am inghiti-o......si tot nu cred ca e aleatoriu.....au ceva introdus in calculatorul ala cand alege....poate mai mult masinile vechi.... "texte" tipice pt rar-isti sunt presati de la conducere (clica tariceanu-renault) sa sperie utilizatorii de masini vechi... vezi reportaje cu dedicatie pe la tv:"din 2010 se interzic auto non-euro" etc...(si orban a declarat ca vrea sa interzica masinile non-euro in bucuresti ) |
freeman30 |
#324
Si stii ce tare m-a speriat...
Daewoo
Tico
SX 2000
dan.gutu |
#325
QUOTE(freeman30 @ 24 May 2008, 14:39) nu a fost un motiv anume ,eu chiar am intrebat daca a fost blocata pt ca e veche si mi s-a spun ca nu .Calculatorul de la RAR alege aleatoriu masina.Sincer gogoasa asta nu am inghiti-o......si tot nu cred ca e aleatoriu.....au ceva introdus in calculatorul ala cand alege....poate mai mult masinile vechi.... Blocarea se face aleatoriu,dar la o statie unde a fost blocata o masina sau remorca pentru reinspectie sigur in acea zi va mai fi blocata inca una.Au fost cazuri la noi in judet cand inspectorul I.T.P. a respins un autoturism pe motiv de parbriz fisurat si la reinspectie acesta a fost admis,pt. ca inspectorul R.A.R. a considerat ca acea fisura nu incomoda vizibilitatea.Deci inspectorii I.T.P. pot fi sanctionati daca trec cu vederea unele neconformitati si daca fac exces de zel si te resping pe nedrept.In curand clientul poate sa ceara reinspectia de catre R.A.R daca acesta crede ca a fost nedreptatit. |
TOYOTA
COROLLA & AURIS HSD
2009 & 2012
BZN |
#326
Am facut ITP-ul recent la RADET, fost Ilioara , fara probleme , cel de acolo foarte
amabil. Masina a fost OK, doar la carburator a fost nevoie de un mic reglaj (aici tipul m-a ajutat in sensul ca m-a lasat sa umblu la surubul de reglaj al aerului...) Ce am mai remarcat, la testul de franare, dezechilibrul aproape 0 , rotile spre finalul cursei se blocau in acelasi timp doar ca atunci practic masina se ridica de pe "tamburi" si rezultatul nu aparea OK... ![]() ![]() nefiind corect calibrat si pentru o masina de numai 655kg (Tico)... Poate gasesc aici o parere avizata.? |
Tico 0,796 6v, 1998
/Logan 1,598 16v, 2009
- AGXXMAV / AGXXVAB
tribunul |
#327
Trebuia sa te duci si tu cu plinul facut...
![]() ITP la meridian sud, sunat azi si facut programare pt. maine. Taxa 85 lei, program pana seara, parca ora 20 Am incercat sa fac programare si la Nesti, doar peste vreo 4 zile aveau liber si programul era pana la 5. |
"Megane" Scenic 2
BZN |
#328
Ce programare
![]() Am preferat intotdeauna statiile mai mici ,din mai multe motive. This post has been edited by BZN: 28 May 2008, 10:41 |
Tico 0,796 6v, 1998
- AGXXMAV / AGXXVAB
diskem |
#329
Membru incepator Group: Members Posts: 29 Joined: 28 May 08 ![]() |
salutare. am si eu o intrebare daca sunteti amabili sa ma ajutati si pe mine. vreau sa cumpar o dacia 1300 din 1978 si are itp-ul expirat in octombrie anul trecut. la ce ar trebui sa ma uit si cam cate sanse sa-i fac itp-ul am?
multumesc anticipat |
renault
lagunaII
- ag99abc
2002, 2.2dci, 150cp, (dacia 1300 e cea mai tare)
BZN |
#330
Nu (prea) conteaza anul ,ci cum arata...Sa nu fie "coptura", cu urme de accident, vezi starea parbrizului, a blocurilor optice, sistemul de directie, franare, partea electrica...Daca masina are "linie" si nu are probleme mari cu tablaria ai sanse mari.
Tico 0,796 6v, 1998
- AGXXMAV / AGXXVAB
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 4th August 2025 - 17:41 |
