deactivate asr on 1.0 LPG
chandler1408 |
Membru incepator Group: Members Posts: 5 Joined: 5 January 21 ![]() |
Duster
1.0 GPL prestige
RazvanF |
![]() Tech Group: Members Posts: 2.284 Joined: 25 March 14 ![]() |
Hello,
I do not think that is possible to dissable the function, only on the 4x4 model has this possibility. Even if you have that central keyboard with the button, it is not plug'n'play, it has to be programmed into the car's computer and again I don't think it can be programmed. You can give it a try with DTT4ALL and with a ELM 327 to program the new button, but only if you have knowledge about the program. This post has been edited by RazvanF: 5 Jan 2021, 20:04 |
Logan MCV Stepway X52
chandler1408 |
Ok, i gone to dacia service when I tried to disable asr with ddt4all... There is a mode to escape from fresh snow without difficult?
Duster
1.0 GPL prestige
RazvanF |
DTT4ALL is a freeware tool, and it is not approved by your local Dacia dealer or workshop. It is for personal use at your own risk.
As for snow, I recommend good winter tires or winter tires with spikes if they are allowed in your country. If not, see picture below. This post has been edited by RazvanF: 5 Jan 2021, 22:05 Attached thumbnail(s) download.jpg ( Size: 10.11k ) Number of downloads: 258 |
alfabit |
Membru autentic Group: Members Posts: 447 Joined: 26 September 09 ![]() |
QUOTE(chandler1408 @ 5 Jan 2021, 16:08) Hello at all. I'm sorry if I'm writing in English, but I don't know your language. I'm here to know if someone know a tips to disable asr in 4x2 version. In old 1.6 was sufficient disconnect abs' fuse, but in 1.0 it doesn't work. I bought a central keyboard of 4x4 version, with esc key, but it doesn't work... Any idea? Thanks at all Yes, possible, me too i use to drive my sandero stepway winter season ASR off by DDT2000 diagnose deactivation, no issues for me. Interesting is the car is fitted dashboard LED esp off which remains on along with its pair esp warning on We can find ABS ESC ecus firmware which could enable ASR off button ( on 4x4 ver of duster only for max speed 30 kmh ), me tryied on my car but it is not working so the simplest solution was to deactivate perm asr by diag mode ddt Look the pics attached for you my friend, IMG_20210106_083430_5.jpg ( Size: 318.66k ) Number of downloads: 300 IMG_20210106_083023_5.jpg ( Size: 235.77k ) Number of downloads: 300 IMG_20210106_090616_6.jpg ( Size: 299.01k ) Number of downloads: 292 |
patru cilindri
201x
chandler1408 |
QUOTE(RazvanF @ 5 Jan 2021, 22:04) DTT4ALL is a freeware tool, and it is not approved by your local Dacia dealer or workshop. It is for personal use at your own risk. As for snow, I recommend good winter tires or winter tires with spikes if they are allowed in your country. If not, see picture below. I have winter tires (kleber), but in fresh snow asr must be disable... QUOTE(alfabit @ 6 Jan 2021, 09:28) Yes, possible, me too i use to drive my sandero stepway winter season ASR off by DDT2000 diagnose deactivation, no issues for me. Interesting is the car is fitted dashboard LED esp off which remains on along with its pair esp warning on We can find ABS ESC ecus firmware which could enable ASR off button ( on 4x4 ver of duster only for max speed 30 kmh ), me tryied on my car but it is not working so the simplest solution was to deactivate perm asr by diag mode ddt Look the pics attached for you my friend, IMG_20210106_083430_5.jpg ( Size: 318.66k ) Number of downloads: 300 IMG_20210106_083023_5.jpg ( Size: 235.77k ) Number of downloads: 300 IMG_20210106_090616_6.jpg ( Size: 299.01k ) Number of downloads: 292 I tried this long time ago and I finished in dacia service.... I can disable asr but I can't re-enable it. The ECU disable also the abs, HSA and esp with errors. No way from ddt4all... 6 Jan 2021, 15:53: I retried now. My abs led blinks when I read abs configuration in ddt4all. If I try to write new configuration of esc button, ddt4all show me an error message. This post has been edited by chandler1408: 6 Jan 2021, 15:53 |
Duster
1.0 GPL prestige
alfabit |
QUOTE(chandler1408 @ 6 Jan 2021, 15:35) I tried this long time ago and I finished in dacia service.... I can disable asr but I can't re-enable it. how is that, disabling and not succed to re-enable ? and how did they enable it back in dacia service ? but the main question is : why did you end up in dacia service ? no asr made you bite the dust ? ![]() maybe you let the car as it is, asr not active is wrong for you. ![]() |
patru cilindri
201x
chandler1408 |
Dacia service, with ddt2000 has clean all errors and they are enable to activate systems
I want to ask at dacia service if it is possible, for them, enable the esc key. tomorrow I'll call. |
Duster
1.0 GPL prestige
alfabit |
QUOTE(chandler1408 @ 6 Jan 2021, 16:00) Dacia service, with ddt2000 has clean all errors and they are enable to activate systems I want to ask at dacia service if it is possible, for them, enable the esc key. tomorrow I'll call. Sorry mate, ddt2000 is forbidden to be used in representatives Renault/Dacia, so you could find a reasonable explanation. ![]() |
patru cilindri
201x
chandler1408 |
I thought them software is called ddt2000. I don't know the name
Dacia has reset the errors and re-enable abs / asr / HSA / esp with their software. |
Duster
1.0 GPL prestige
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 4th August 2025 - 04:32 |
