> New EV Air Conditioner Refrigerant, Said To Extend Range By 50%
DFA
post 13 Jul 2021, 13:16
moderator://DC/Logan
New EV Air Conditioner Refrigerant Said To Extend Range By 50%
That means that an EV with a range of 124 miles would be able to cover an additional 62 miles simply by using Daikin's new refrigerant.
In extreme temperatures, cabin cooling and heating eat up significant amounts of power from an EV’s battery. As a result, there are many gains to be made in terms of boosting driving range by making heating/cooling systems more efficient.
That’s where Japanese top air conditioner maker Daikin Industries comes in, as the company claims it has developed a refrigerant for EVs that can extend their range by up to 50%, with the product scheduled to go on sale by 2025.
It is obviously great news and, as the report from Nikkei Asia reveals, Daikin’s new refrigerant has a boiling point of about minus 40 C, which is 10 to 15 degrees lower than the product currently used by EV makers worldwide.
Since air conditioners use the heat generated by compressing the refrigerant to heat and cool the air inside the car, the new product reduces the power required for compression, freeing up more electricity for the vehicle to cover a longer distance on a full charge.
To be more specific, Daikin claims that in an EV with a range of 200 km (124 miles) on a full charge operating in an urban area of Japan with the air conditioner running, the new refrigerant could unlock an additional 100 km (62 miles) of range.
The Japanese company says it will “consider the price of the new refrigerant while looking at market prices,” according to the same report. Currently, the most common refrigerant for use in EV air conditioners, a product jointly developed by U.S. companies Honeywell and Chemours, costs around 30,000 yen ($270) per vehicle. Since the alternative to increase battery capacity to extend range by 100 km is much more expensive, automakers are likely to pay twice the current price for the new refrigerant without blinking.
Daikin has already developed the product, and U.S. industry group SAE International will verify its performance and safety under operating conditions. Interestingly, Daikin is not currently involved in the automotive market, despite being the world’s largest air conditioner manufacturer by sales and the leading producer of refrigerant. That will obviously change as Daikin will enter the market with its new EV air conditioner refrigerant by 2025.
By that year, global EV production is estimated to rise to 11.84 million units, 5.3 times higher than in 2020, according to IHS Markit.
https://insideevs.com/news/519703/ev-aircon...t-boosts-range/
ex Logan I 1.5
post 13 Jul 2021, 13:25
Bizar, credeam ca ACul trage vreo 2 kWh la un zoe, fata de 12 cat trebuie sa misti masina. Ok, e minunat sa creasca COP al inslatiei de racire/incalzire, poate raci si bateria si e mai scump ca whiskyul de 10 ani, banui ca or sa faca bani frumosi cu el.
DFA
post 13 Jul 2021, 13:38
Cred că Daikin se referă la AC folosit ca pompă de căldură, fie că e vară, fie că e iarnă - și iarna e jale cu consumul de curent pentru încălzire, dacă ai putea folosi o pompă de căldură iarna și la temperaturi foarte joase, fără să mai fii nevoit să apelezi la aeroterme cu rezistențe sau PTC ai face o economie de curent considerabilă.
Deci o pompă de căldură utilizabilă permanent în condiții extreme de frig.
ex Logan I 1.5
post 13 Jul 2021, 14:02
Mda, ai crede ca ar rupe hamu' cu asa ceva in instalatiile obisnuite de AC, sau alea nu consuma energie?
post 13 Jul 2021, 14:06
pai daikin face pompe de caldura care merg la -25 de grade, pentru casa. Zoe are pompa de caldura, nu incalzeste rezistiv (de vreo 3 ori mai eficient poate pana la 5)
dizzy
post 13 Jul 2021, 14:33
Work smart not hard!
1-2 cai putere din... macar 75CP la o masina moderna, nu e mare sfaraiala.
2-3kW, in 10-50KWh, se cam simte.
post 13 Jul 2021, 14:45
QUOTE(einstein1984 @ 13 Jul 2021, 15:06)
Sigur, are?
post 13 Jul 2021, 14:49
QUOTE(dizzy @ 13 Jul 2021, 15:33)
compresorul pompei de caldura are motor separat, nue rotit de motorul de tractiune care sta pe loc cand viteza masinii e 0....
@Ironik, lmgfy
https://www.renaultgroup.com/en/news-on-air...-weather-tests/
This post has been edited by einstein1984: 13 Jul 2021, 14:50
Agrig
post 13 Jul 2021, 14:54
QUOTE(einstein1984 @ 13 Jul 2021, 14:06)
Au cum sa n`aiba, la fel si altii, insa problema este randamentul, 3/4 din timp se lupta sa dejivreze unitatea exterioara, restul timpului mai baga si caldura...
This post has been edited by Agrig: 13 Jul 2021, 14:56
Nelson Mandela
post 13 Jul 2021, 15:19
au rezsitente de degivraj mai nou, dar nu aici e discutia.
Agrig
post 13 Jul 2021, 17:07
Au demult insa cu rezistenta de dejivraj eficienta e si mai mica...aia se foloseste doar in conditii extreme de temperatura.
Nelson Mandela
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 11th May 2025 - 04:52
