37 Pages « < 5 6 7 8 9 > »
> Mici intrebari - mai tehnice, Ca si celalalt, dar diferit
psychoo
post 26 Mar 2022, 13:15
Post #181
Inb4 huo
Victorine
post 26 Mar 2022, 15:02
Post #182
Ce prostan sunt... m-am apucat să caut INB4 huo curios ce becuri îs alea. Mă simt bătrân.
Marty
post 26 Mar 2022, 16:00
Post #183
Membru cu privire de ansamblu
QUOTE(Victorine @ 26 Mar 2022, 16:02)
psychoo
post 26 Mar 2022, 18:57
Post #184
Totusi trebe sa.mi fac mea culpa.
Ma asteptam deja sa vad 2 pagini de discutii.
Ca sa raspund si ontopic, eu nu as pune altceva decat osram sau philips, dar daca scrie pe ele ca nu sunt legale pe drumul public nu as pune
Raduchu
post 27 Mar 2022, 15:44
Post #185
Nu-mi arde becu'
QUOTE(Marty @ 26 Mar 2022, 13:01)
Ai vreunul becuri LED in far cu oglinda? Daca da, recomenzi vreun model anume?
Pls, don't.
Daca vrei becuri mai puternice, recomand Philips 150% Racing Vision sau Osram 150% Night Breaker Laser (frate tongue.gif ).
Renault 25 '86 2 x Volkswagen Passat '08 Highline '10 R-Line
There is a light somewhere, it may not be much, but it beats the darkness!
Rage, rage against the dying of the light!
500.000 km and counting.
post 27 Mar 2022, 15:54
Post #186
QUOTE(Marty @ 26 Mar 2022, 12:01)
Ultima oara cand m-am uitat. H4 LED by Philips erau marcate cu "track use only"
paul_damian
post 27 Mar 2022, 16:47
Post #187
Membru mult
Pe Logan am folosit numai H4 Osram Nightvision (acum modelul curent e Laser). Lumina buna, dar tin cam un an. Isi face fiecare calculul daca merita sau nu. Pe LED cica Novisight sunt pret / performanta super ok, dar... sunt scumpe rau.
Dacia Sandero Stepway, 2021
Ex Dacia Logan KissFM 1.4, 2008
Ex Dacia 1310, 1999
Ex Dacia 1100, 1969
post 27 Mar 2022, 16:56
Post #188
QUOTE(Raduchu @ 27 Mar 2022, 15:44)
Pls, don't.
150% a fost acum ceva timp, se poarta 200% acum
philips doar a rebrenduit un bec cu 200% (testat cum trebuie, nu la ochiometru)
osram a scos bec nou, chiar face lumina aia
27 Mar 2022, 16:59:
QUOTE(paul_damian @ 27 Mar 2022, 16:47)
Novisight este doar un nume pentru leduri chinezesti, un fel de adibas
This post has been edited by IRONICK: 27 Mar 2022, 16:59
bgdrenault
post 27 Mar 2022, 18:06
Post #189
bgd
Se tot vorbeste de inlocuirea gazului natural de la rusi cu gpl de la americani.
In industrie, se poate realiza acest lucru? In utilizarea casnica? Stiu ca erau diuze diferite la aragaz, cand se folosea butelie si cand gaz metan.
In productia de ingrasaminte chimice, unde e utilizat la scara mare gazul metan, se poate folosi acest gpl?
Ca tare ma tem ca e o alta gaseslnita care nu va duce la efectul scontat.
Megane Sedan 1,33 140 CP 2019 Intens - XXX
Cosstel
post 27 Mar 2022, 19:32
Post #190
GPL-ul este un amestec de propan și butan în proporții variabile, vara mai mult butan, iarna mai mult propan pe motiv de volatilitate
cit despre gazul lichefiat presupun ca e vorba de metan ce la presiunea de 16 ATM este în stare lichida la temperatura ambianta, asta din aduceri aminte
cit despre înlocuirea gazului de țeavă cu cel lichefiat, nici vorbă sau chiar dacă se dorește costurile cresc amețitor
situația e foarte delicata, o întreaga industrie chimica se sprijină pe acest gaz, nu numai dar e componentul fără care nu prea se poate
ce vor face?.. chiar nu-mi trece prin minte
nu degeaba se perinda diverși lideri occidentali pe la Putin, tot încercau sa găsească o solutie
dar cind SUA are alte interese...
noi așteptăm cu nerăbdare gazele din Marea neagră 😁
VW Caddy Furgon 2006 - B03???
I'm a simple man, I see boobs, I press LIKE!
paul_damian
post 27 Mar 2022, 19:51
Post #191
Membru mult
<span class='edit'>27 Mar 2022, 16:59:</span>
Novsight este doar un nume pentru leduri chinezesti, un fel de adibas
[/quote]
Chinezii stiu sa faca si lucruri de calitate, contrar la ce crede lumea wink.gif
Ex Dacia 1310, 1999
Ex Dacia 1100, 1969
post 28 Mar 2022, 07:51
Post #192
de la americani se aduce LNG, nu gpl, adica tot metan dar lichefiat la -164 de grade parca? Odata vaportizat si pus in conducta nu e nici o diferneta fata de metanul curent.
https://en.wikipedia.org/wiki/LNG_carrier astea le cara.
This post has been edited by einstein1984: 28 Mar 2022, 07:55
Marty
post 28 Mar 2022, 09:01
Post #193
QUOTE(Raduchu @ 27 Mar 2022, 16:44)
Pls, don't.
Scumpe si fara fiabilitate. Alea de 200% au o durata de viata garantata de vreo 500 de ore (parca mai putin chiar, dar hai sa zic asa), deci la cel putin 2 seturi pe an, mai bine-mi bag un bat in ruc!
QUOTE(bucatzel @ 27 Mar 2022, 16:54)
TOATE sunt "offroad use"!
QUOTE(IRONICK @ 27 Mar 2022, 17:56)
Ideea e ca mai multa lumina aduce cu ea mai multa caldura, deci in timp degenereaza si oglinda.
QUOTE(paul_damian @ 27 Mar 2022, 20:51)
Corect!
Am gasit un baeat in Cta care pune lupe in far cu oglinda. Sa vad cat vrea pe o asemenea minune, macar sa fac o treaba.
P.S.: Culoarea pe care o caut e de 4300K, deci o culoare cat de cat ok ochiului, nu ca 6000K, chill!
post 28 Mar 2022, 09:07
Post #194
odata ce tot 55/60W au ca si alea chioare, nu vad de unde sa faca mai multa caldura...
AR-18-MOS
post 28 Mar 2022, 09:42
Post #195
( -_・) ︻デ═一
Led It Up... vorbeste cu ei si vezi ce îți recomandă. Eu mi-am pus H7 led pe faza lungă la CC, foarte mulțumit.
post 28 Mar 2022, 10:08
Post #196
acu poti da flashuri de la 100m nu de la 50 ca inainte.
paul_damian
Post #197
Membru mult
QUOTE(Marty @ 28 Mar 2022, 09:01)
De gustibus non nisputandum! 4300 e lumina calda, me not like. 6500 e alb natural (cum are Logan/Sandero III), ce e peste 6500 deja devine albastrui, care ma deranjeaza si pe mine.
Ex Dacia 1310, 1999
Ex Dacia 1100, 1969
Marty
post 28 Mar 2022, 10:13
Post #198
QUOTE(AR-18-MOS @ 28 Mar 2022, 10:42)
Sa stii ca inainte sa fac vreun pas in directia LED-urilor, pe ei ii sun, ai cuvantul meu de onoare! Din pacate, nu vand decat 6000K.
QUOTE(paul_damian @ 28 Mar 2022, 11:08)
Nu e vorba numai de gusturi, e vorba ca atrage atentia farul cu oglinda inundata-n 6000K. La 4300K nu e chiar asa saritor in ochi/deranjant. Repet, la farurile cu oglinda, nu la cele cu lupa!
post 28 Mar 2022, 10:14
Post #199
Nope, 5000k este alb neutru.
volint
post 28 Mar 2022, 12:11
Post #200
membru miserupist
Intreaba kaç para si cu banii aia te duci la oftalmolog. De diferenta iei oloi d-ala special dedicat only gepeleu.
post 28 Mar 2022, 12:14
Post #201
Raduchu
post 28 Mar 2022, 13:22
Post #202
Nu-mi arde becu'
Led pe faruri cu oglinda inseamna sa-ti bati joc de cei de pe contrasens..
@Marty pt lupe poti vorbi cu colegul, sigur te poate ajuta:
https://www.daciaclub.ro/MONTEZ-LUPE-IN-FAR...ml#entry5025351
post 28 Mar 2022, 13:28
Post #203
QUOTE(Raduchu @ 28 Mar 2022, 13:22)
Este adevarat doar in proportie de 90%, pentru ca 99% isi monteaza chinezarii ieftine.
Raduchu
Post #204
Nu-mi arde becu'
Iei de la Led It Up, de unde a recomandat Mosu', ca aia au lucruri ok.
Dar totusi, una e un far cu lupa, si una e un far cu oglinda. Stii la ce ma refer. smile.gif
post 28 Mar 2022, 13:29
Post #205
restul chinezarii scumpe.
post 28 Mar 2022, 13:37
Post #206
QUOTE(Raduchu @ 28 Mar 2022, 13:28)
Nu, nu stiu la ce te referi. Lumina de cea mai buna calitate in faruri se obtine cu reflector. La led chiar mai bine. M-am uitat si eu la aia, vand doar niste chinezarii, nimic deosebit.
28 Mar 2022, 13:50:
QUOTE(einstein1984 @ 28 Mar 2022, 13:29)
koito, morimoto, ichikoh, stanley, mobis etc ...
This post has been edited by IRONICK: 28 Mar 2022, 13:50
marksman
post 28 Mar 2022, 14:08
Post #207
Post mortem nihil est
Stanley e chinezărie?
Nick Ușor
post 28 Mar 2022, 14:16
Post #208
depinde unde fabrica...
post 28 Mar 2022, 14:20
Post #209
QUOTE(marksman @ 28 Mar 2022, 14:08)
QUOTE(einstein1984 @ 28 Mar 2022, 14:16)
Eu vorbesc de firma aia din Japonia. Nu de aia cumparata de Black & Decker si care face surupelnite ...
This post has been edited by IRONICK: 28 Mar 2022, 14:22
Raduchu
post 28 Mar 2022, 14:44
Post #210
Nu-mi arde becu'
QUOTE(IRONICK @ 28 Mar 2022, 14:37)
Lupele >>> oglinzi (reflector, mna). Modul in care lumina este distribuita este mai ok la farurile cu lupe, indiferent ca vorbim de lupe cu halogen, ori lupe cu "senoane".
Cum am zis, leduri pe faruri cu oglinzi e crima. Lumina o sa fie foarte puternica si foarte "imprastiata"..ceea ce nu e tocmai placut noaptea pentru ceilalti participanti la trafic.
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 13th July 2025 - 03:54
