2 Pages < 1 2
> Project Spring restotarion in Bulgaria, I get one totaled spring and i will try to restore
post 5 Apr 2023, 12:54
for the SW angle sensor, try to do 2 full lock to lock manouvers with ignition on and see if clears up.
alexis
post 4 Jun 2023, 13:50
daciot
Any updates on your project?
Dacia Spring 2021 - B XX HXX
chiMol
post 17 Jul 2023, 09:45
Hello, project is online again.
Front windshield replaced.
Hood painted with test paint - have problems with clear coating
Wings repaired and painted ....
Front bumper ( replacement one) fixed and painted ...still down grill not in Bulgaria
Software bugs fixed
No airbag lights
No sound problems reported( all work)
No AEB ( cleared functionality)
dacia Spring 2022 - still no
chiMol
post 18 Jul 2023, 20:56
I drive it today. Still have problems with abs, esc, and hill auto braking (brake hill assistant).
I can not read the error code, but I can clear it. May be I must check all wires to sensors,
Crowns (tooth wheels for damage) , alinenment between. Error appears when speed go to 5 km/h. The story continues....
I use renolink 1.98 cable and soft .... It works almost good...
Still look for procedure for key learning
This post has been edited by chiMol: 18 Jul 2023, 21:01
chiMol
post 18 Aug 2023, 14:36
USED down part for front bumper found and installed.
ABS,ESC problems fixed. sensors cheked,problem was with steering sensor witch was not in right position - 0 degrees mean strait. Renolink software can not reset or relearn the position of sensor and i fix it manual from steering rack and rod compensation. after cleaning the error it not appear any more .... before glow again after 15km/h.
There are no errors on dash and all works normal for now.
second key (with remote control ) still not set.
rue
post 18 Aug 2023, 15:48
bravo!
final costs?
Dacia Logan 2021, 1.0 TCE eco-G, Comfort - RUE
tatabobu
post 19 Aug 2023, 01:05
membru
Congrats, neighbour!
DACIA 1300 1995
chiMol
post 22 Aug 2023, 10:22
Total cost of project:
_________start______
Crashed Spring - 6400e
Transport DEtoBG - 1000e
_________parts_______
windshield - 120e (with small chip from stone)
hood - 200e with minor damage
left DRL/Blinker - 200e
front grill - 250e
front bumper upper part - 200e with minor damage
front bumper lower grill - 100e
front fan - 30e (universal)
engine mount - 20e ( from other car)
cv boot - 15e universal
_______repaired parts_____
vacuum pump - 10e (inlet pipe change )
water pump - 5e (epoxy glue work)
water radiator - 20e (argon weld )
ac radiator just adjustments
front headlights repair cracked rear parts
front wings hummer ed
front left ark - plastic welded
under motor frame back part hard repair
under motor frame front part very hard repair
front mask repair hard
electric installation repair 40e ( wires,isolation,crimps )
seat belts repair ... just time===( no longer pyr
_______aditional materilas ________
paint 0.5l - 60e
primer- 30e
filer - 30e
more small stuff - 100e
renolink cable and soft - 60e
-----------TOTAL-------------
8900e
May be there is more that i forgot but if remember i will update it ....
My target was electric car for less that 10000e ..... if i get airbags this will cost me more than 1500e but till now i not plan to reactivate them.
post 22 Aug 2023, 10:26
repaired non pyro seatbelts and no airbags? You like to live dangerously.
chiMol
post 22 Aug 2023, 11:06
This model is available without airbags from factory in non europe modification. I realy hope that 18 Kw pure power will be not so dangerous. If i found good price airbags i will fix them ... this will be easy smile.gif the soft work perfect int his part smile.gif
Ps my old electric scooter is far more dangerous ...60+km/h on 6.5 inch wheels blink.gif
post 22 Aug 2023, 11:26
cars without airbags have different seatbelts compared to the ones with airbgas. Without teh airbag, thea seatbelt is not eo effective at restraining the occupant.
<span class='edit'>22 Aug 2023, 11:26:</span>
cars without airbags have different seatbelts compared to the ones with airbgas. Without teh airbag, thea seatbelt is not eo effective at restraining the occupant. But yes, the scooter is far worse smile.gif
and 18kW is still enough to get you to 100kph, far more than most crash tests.
This post has been edited by einstein1984: 23 Aug 2023, 07:26
post 22 Aug 2023, 11:27
QUOTE(chiMol @ 22 Aug 2023, 12:06)
alfabit
post 22 Aug 2023, 15:10
Who ever runs with such a thing deserves his fate,
Lord helps him, Amen !
Dacia patru cilindri 201x
Bullet81
post 15 Jul 2024, 22:17
Hi !
And I think mine is with bad crash ......
Mine came two weeks ago and I already find the airbags driver and passenger and restore with new piro the belts.
I still don't have OK on the dash and the engine is not running I still don't have diagnostic tool but I saw that you used Renolink and I have ordered one for me.
I had a broken brake pipe also but it's already changed .
I hope that the airbag central blocks the engine to start ...
Dacia Spring Extreme 2023 - CB6333CM
Stmario
post 29 Jul 2024, 21:44
Hi im Mario from Poland. I bought my Spring 3 weeks ego. My car wad esef like carshareing at Paris. It also had accodent . Maybe with street lamp. Now i try start it but a i have few problems. Maybe you can help me .
29 Jul 2024, 21:55:
Fotki mojego autka
This post has been edited by Stmario: 29 Jul 2024, 21:55
Dacia Spring 2021
Magzi
post 16 Nov 2024, 21:06
how could you clear the crash light on the dashboard?
Dacia Spring 2023
poolistu
post 16 Jan 2025, 03:21
Nice job 👍. Any mechanical faults caused by the accident?
Dacia 1310 1990 - SM 01 MXJ
chiMol
post 7 Jun 2025, 14:10
Hello, all
I was not active much time ,but soon will come my new project spring 2(hope that all will be ok with delivery)
https://youtu.be/Vtgl37Pznzo?si=6lHth3akLqTA-5gq
This is video with my family cars 😁 showing differences with models 2021 ,2022 and 2023/24
Unclogging drains.... Do it before self flooding
https://youtu.be/PRVqU1zNbkk?si=GlCZMzSx4TH2kDVA
This post has been edited by chiMol: 7 Jun 2025, 14:20
chiMol
post 8 Jun 2025, 19:03
Project White 65 Ex
chiMol
post 10 Jun 2025, 17:51
Before and after
If someone know where I can Buy second hand front bumper and front grill for spring 2 I will be glad to give me link.
And this is how I install old-new opel rims to my rebuild spring
https://youtu.be/8dOz3vRgfIA?si=uQiY1pDBpJ0sNibh
This post has been edited by chiMol: 10 Jun 2025, 17:53
2 Pages < 1 2
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 16th June 2025 - 15:16
