Dacia 1310 1,6
Dacia 1310 1,6
Dedek963 |
Membru incepator Group: Members Posts: 2 Joined: 24 August 24 ![]() |
12 TS
1978
Ov |
![]() Academician doctor inginer, savant de renume mondial Group: Moderatori Posts: 7.533 Joined: 11 November 03 From: Bucuresti ![]() |
Hi,
the engine is derived from the cleon engine but with bigger bore/stroke and a simple single point injection. If maintained it's reliable (I would also risk saying that is more reliable than the 1300 engine). The only thing that can fail it's the catalytic converter because it's mounted too low and it can be easily damaged. As you know it's a simple car so no major issues are to be expected if it was garage parked and maintained. Rust is the biggest issue, but after year 2000 (and I assume that what you have found is after that year because it's fuel injected) they had some kind of rust protection (cavity wax). This post has been edited by Ov: 26 Aug 2024, 10:00 |
Dedek963 |
Thank you for your advice and quick response.
It seems though that those 1,6i 1310 are not very common. I found only 1 currently for sale. https://www.ooyyo.com/romania/used-dacia-13...09C66FAA651453/ I sent the owner a whtas app message, but he did not respond. 26 Aug 2024, 11:48: Is there any way one can tell the difference between a 1.4i and a 1.6i at a glance (e.g. into the engine)? Because most people don't put in the ad what kind of engine it is. This post has been edited by Dedek963: 26 Aug 2024, 11:48 |
12 TS
1978
Ov |
there are no visual differences just the engine code and model name on the trunk lid or on the front fenders depending on year model (Ti for 1.6 and Li for 1.4, if it's a wagon/break then it's CTi and CLi)
The differences between the engines are the crankshaft, pistons, cylinders, head (but 1.4 head will work on 1.6 and will give a little bit more compression) and ECU map. Engine block is identical and replacing those (cylinders are also removable) can easily turn a 1.4 to a 1.6L engine. This post has been edited by Ov: 26 Aug 2024, 13:54 |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 9th September 2025 - 01:25 |
