Reset AirBag after crash
moxb |
Membru incepator Group: Members Posts: 29 Joined: 26 November 22 ![]() |
1.6 2005.
![]() fan Dacia Group: Members Posts: 21.376 Joined: 12 November 05 From: Bucuresti ![]() |
You need to delete crash info in injection ecu so it can start- (clip can do that, so can DDT). That will not make airbag ecu serviceable again. Some people can do that and put out awl, but I woudln't drive a car that didn't replace it's airbag ecu after a crash
This post has been edited by einstein1984: 22 Jan 2025, 12:31 |
- negru pe alb
moxb |
Sorry, can you explain a little bit more?
I am not familiar with those devices and software. What is DDT? What exactly should I do, is that done via OBD? |
1.6 2005.
yes, it's a diag software used via obd plug.
- negru pe alb
moxb |
QUOTE That will not make airbag ecu serviceable again. Some people can do that and put out awl, but I woudln't drive a car that didn't replace it's airbag ecu after a crash If I understood correctly, via OBD airbag ecu can't be fixed. But I read online that it's possible by repogramming it's chip. This post has been edited by moxb: 22 Jan 2025, 17:05 |
1.6 2005.
The second sentence you quoted says just that. But saying it's "fixed" is bulshit.
- negru pe alb
moxb |
Of course it will not be fixed, just circumvented.
1.6 2005.
moxb |
If I install same airbag from another vehicle (second hand), will that work?
What needs to be done? I was checking today faults with Torque via OBD, and it showed nothing. The airbag light is ON. This post has been edited by moxb: 24 Jan 2025, 16:19 |
1.6 2005.
airbag ECU needs tio be replaced, even if airbag is replaced.
- negru pe alb
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 9th May 2025 - 21:15 |
