2 Pages < 1 2
> 1.4 MPI engine problem?, Sometimes fails to start when warm
martin245
post 7 May 2006, 13:22
EX PAT
TRY DISCONECTING THE BATTERY AND THEN REMOVE THE MAIN FUSE
FOR A COUPLE OF SECONDS THIS WILL TAKE THE MEMORY OUT OF THE ECU
WAIT 5 MINS AND RECONECT EVERYTHING
NOW THE ECU WILL BE BACK TO DEFAULT....FACTORY SETTINGS
IT MAY RUN ROUGH BUT THIS WILL IMPROVE IN 1 TO 2 DAYS
TRY IT
STU
dacia logan 14 mpi Simply RED 2007 - GB 1
Bessy Regs
zorpetus
post 7 May 2006, 15:04
QUOTE(martin245 @ 7 May 2006, 13:22)
TRY IT
STU
We tried to disconnect battery but it didn't help.
But we didn't try to remove main (which one is the main one?) fuse as well.
Will try that as well and let you know if problem has been solved.
None None - None
2 Pages < 1 2
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 21st July 2025 - 02:02
