intrebare bujii
intrebare bujii
#511
![]() - Group: Members Posts: 22.548 Joined: 19 April 05 From: Romania ![]() |
YRX |
#512
![]() Membru autentic Group: Members Posts: 5.050 Joined: 6 July 06 From: Bucuresti ![]() |
12 % e.... cam multicel. Dar depinde si de conditiile in care l-ai obtinut. Eu intotdeauna fac corelatia consum mediu - viteza medie. La sub 18km/h am undeva la 11%, intre 18-20 km/h am 10, 10 si ceva, iar la peste 20km/h scade sub 10.
La 63 km/h (drum afara) am tras 5,3... |
2005 Ambition 1.6 MPI
vi_escu |
#513
![]() Membru somnambul Group: Members Posts: 1.996 Joined: 13 November 04 From: republica procurorilor ![]() |
facem ce facem si-o dam in consum....
ABS plus 1,6MPi
mykissfm |
#514
![]() Membru autentic Group: Members Posts: 349 Joined: 11 May 09 From: Bucuresti ![]() |
si pina la urma care e cea mai buna bujie pentru logan? pentru benzinar ma intereseaza,dar nu o lista ,ceva la sigur.
This post has been edited by mykissfm: 9 Mar 2010, 07:57 |
Nissan
Qashqai /Sandero
george_scala_2004 |
#515
salut,
dupa parerea mea, cele mai bune bujii sint acelea care tin cit mai mult, indiferent daca sint de origine sau aftermarket. circula diverse opinii apropo de cele care ar tine 100, 90 sau 60 de mii de km. probabil ca as o fi. deocamdata eyquem-urile mele se comporta o.k. succes, |
costyg |
#516
Membru incepator Group: Members Posts: 6 Joined: 27 January 10 ![]() |
si eu am schimbat bujiile la logan 16cc si am cumparat acelasi model care au venit din fabrica adica marca eyquem si merg bine
logan 1.6 i
2007 benzina
- vn05kxx
surube |
#517
![]() Membru autentic Group: Members Posts: 236 Joined: 25 November 09 ![]() |
1.5 dci
2006 Unde dragoste nu e nimic nu e /
#518
![]() fan Dacia Group: Members Posts: 21.386 Joined: 12 November 05 From: Bucuresti ![]() |
Pe naiba, exista NGK iridium care tin 120 000 fata de astea care zic ca tin 60 000. Set 4 din astea e vreo 90 de lei la augsburg, cu electrod central de platina.
- negru pe alb
#519
QUOTE(einstein1984 @ 10 Mar 2010, 12:54) Pe naiba, exista NGK iridium [...] cu electrod central de platina Deci astea cu iridium au electrod central din platina? ![]() This post has been edited by IRONICK: 10 Mar 2010, 13:19 |
george_scala_2004 |
#520
#521
QUOTE(IRONICK @ 10 Mar 2010, 14:08) Deci astea cu iridium au electrod central din platina? ![]() Deci mai citeste. Beru Ultra X Titanium au electrod central de platina si electrod de masa din aliaj titaniu nickel. Pretul de mai sus era pentru beru, nu pentru NGK Iridium ca a lu doctpru', ca alea sunt 50 de lei bucata. This post has been edited by einstein1984: 10 Mar 2010, 14:18 |
- negru pe alb
george_scala_2004 |
#522
stati calmi. nu va certati.
exista si cu platina si cu iridium. pentru toata lumea. ![]() LASER PLATINUM® Laser Platinum® spark plugs provide high ignitability and longer service life. Dual platinum surfaces ensure slow wear rate providing stable idle, superior anti fouling, improved fuel efficiency and lower emissions. * Laser welded Platinum center electrode tip * Platinum disc welded to backside of ground electrode provides long life * Trivalent Metal Plating provides superior anti-corrosion and anti-seizing properties * Faster starts and quicker acceleration * Better fuel economy and lower emissions * Best Platinum spark plug available * Original Equipment Manufacturer approved design http://www.ngksparkplugs.com/products/spar...um.asp?mode=nml Iridium IX® The Spark Plug Serious Enthusiasts Rely On Designed specifically for the performance enthusiast. Iridium IX® offers extreme ignitability, improved throttle response and superior anti fouling * Fine Iridium tip ensures high durability and a consistently stable spark * Iridium alloy has extremely high melting point, perfect for today’s high-tech, high-performance engines * Trivalent Metal Plating - superior anti-corrosion and anti-seizing properties * Outstanding acceleration, high fuel efficiency and durability * Ultimate design, technology and performance. http://www.ngksparkplugs.com/products/spar...ix.asp?mode=nml LASER IRIDIUM® Laser Iridium® spark plugs provide superior ignitability and long service life. Smallest tip diameter available Iridium / Platinum surfaces ensure slow wear rate providing stable idle, superior anti fouling, improved fuel efficiency and lower emissions * Laser welded Iridium center electrode tip * Platinum disc welded to backside of ground electrode provides long life * Trivalent Metal Plating for superior anti-corrosion and anti-seizing * Faster starts and quicker acceleration * Better fuel economy and lower emissions * Best OEM Iridium spark plug available * Original Equipment Manufacturer approved design http://www.ngksparkplugs.com/products/spar...um.asp?mode=nml http://beru.com/english/produkte/zuendkerzen/ultraxtitan.php Technical Features of Ultra X Titan * Extremly reliable ignition: With a high erosion-resistant nickeltitanium alloy: filigree ground electrode in specially developed Poly-V shape for extremely reliable ignition. * Cold-start reliability: Center electrode with platinum ignition tip for excellent cold-start performance. * Reliable: Corona ring for systematic predischarge and stable ignition. http://beru.com/english/produkte/zuendkerzen/ultraxtitan.php Technical Features of Ultra X and Ultra X Platinum * Reliable ignition: Combined air/surface gap technique. Ignition reliability by several spark paths. * Powerful: Optimal combustion due to protruding spark position * Cold start reliability: Self-cleaning function by surface gap spark technology. * Reliable: Quickly reaches the ideal operating temperature by a special insulator mount and intricate earth electrodes. * Environmentally friendly: Pollutant emissions minimised and catalytic converter protected due to effective combustion http://beru.com/english/produkte/zuendkerzen/ultrax.php Technical Features of BERU Ultra * Optimal, environmentally friendly combustion: saves fuel and protects the catalytic converter * Reliable ignition under all operating conditions * Long life, high dependability * Proven materials: Two-component earth and centre electrode with nickel-jacketed copper core adapted exactly to the application purpose * Versions same as OEM http://beru.com/english/produkte/zuendkerzen/ultra.php Beru Spark Plugs with Platinum/Silver Electrodes Technical Features * Centre and, if required, ground electrodes made of special materials, for example silver for high thermal conductivity or platinum for extremely high resistance to erosion. * Optimal, environmentally friendly combustion: saves fuel and protects the catalytic converter * Long life, high dependability * Good cold starting properties * Excellent mixture access * First equipment quality http://beru.com/english/produkte/zuendkerzen/platin.php 10 Mar 2010, 17:44: eyquem. un pic mai vechi... http://www.autopilot.dp.ua/catalog/eyquem.pdf This post has been edited by george_scala_2004: 10 Mar 2010, 17:44 |
surube |
#523
1.5 dci
SorinXp |
#524
Membru Group: Members Posts: 196 Joined: 30 June 05 ![]() |
Bujiile sunt de 2 tipuri: reci si calde. Daca cumparam alte bujii decat trebuie nu prea e bine. Sa luati in calcul si aceste lucruri.
Urmatorul link da cateva detalii : http://www.atao.ro/2008/02/05/motorul-stri...ri-de-calamina/ |
Prestige 1.6 16v Dec2008
- B97GCT
cristio_79 |
#525
Citroen / Peugeot
C3 / 308
#526
Io astept sa vina ale de dastar, ca-s de suv si sunt mai puternice. Astea cu 4 electrozi se potrivesc perfect, mai ales cand ai 4x4 pe masina, ca ajuta la suctiunea de pe puntea spate. Dalea vreau sa pun la urmatorul schimb.
This post has been edited by IRONICK: 10 Mar 2010, 21:32 |
YRX |
#527
Numai sa nu-ti iei din alea de la DCI 110. Nu cred ca face fata viblochenu' la puterea degajata, maxim de 16V...
george_scala_2004 |
#528
QUOTE(surube @ 10 Mar 2010, 20:11) ![]() ![]() ![]() de unde se cumpara ? de pe ebay ? ca in romania nu prea pare sa vinda cineva untitled.JPG ( Size: 139.45k ) Number of downloads: 621 cataloage bosch http://www.bosch.com.au/content/language1/...stralia_Web.pdf http://www.scribd.com/doc/2677582/BOSCH-Sp...al-Bujias-Bosch This post has been edited by george_scala_2004: 11 Mar 2010, 10:28 |
#529
Nuuuuuuuuuuuuuu, a invatat sa puna si poze acum!!!!!!!!!!!!
#530
eu v-am zis la cafenea sa nu-i ziceti...voi nu, batman..
dr_mKe |
#531
![]() Membru cu stetoscop Group: Members Posts: 7.221 Joined: 25 November 06 From: Deva ![]() |
Eu nu mai testez nimic in afara de durata de viata preconizata de 90.000 km; deocamdata au implinit 50 k
Pe argoneatza tre' sa-l trec cumva pe iridium ![]() |
2010 / 2022
#532
eu am schimbat bujiile clasice NGK ' v-line nr.14' la 75.000 km si inca mai mergeau pana la 90.000, eu nu pun botul la vrajala cu iridium si alte sf-uri.
Attached thumbnail(s) index.php.jpg ( Size: 333.21k ) Number of downloads: 672 |
YRX |
#533
Alea nu mai mergeau deloc.....
Stii ce-i gulerul ala maro de pe izolatorul ceramic? |
#534
QUOTE(argon @ 11 Mar 2010, 11:14) la 75.000 km si inca mai mergeau pana la 90.000 Mai mergeau pe naiba. |
#535
radlog |
#536
Membru incepator Group: Members Posts: 46 Joined: 23 March 07 ![]() |
Eu nu stiu cum tineti voi bujiile astea asa mult.La mine NGK-urile,dupa ~12000km aveau distanta~1.0 in loc de 0.9 cand le-am montat.Ca sa nu mai spun ca una sau doua aveau o uzura cel putin ciudata la electrodul central.
2005 1.4 ambiance
- IS ** *** am dacie...nu ma plictisesc niciodata
YRX |
#537
E normal la bujii vechi si uzate. Sunt gaze scapate din cilindru printre izolatorul ceramic si partea metalica, cu cat mai mare pata cu atat mai ne-etansa bujia.
#538
Pata nu poate fi mai mare de atat, pana acolo vine mansonul de la fisa. Nu sunt convins ca aia e, dar e posibil, e ca un email sticlos, toate 4 la fel, din pacate nu mai gasesc acum unde am citit ce e aia exact.
Attached thumbnail(s) 2.jpg ( Size: 428.29k ) Number of downloads: 709 1.jpg ( Size: 341.56k ) Number of downloads: 648 3.jpg ( Size: 508.92k ) Number of downloads: 622 |
YRX |
#539
Da, se face pana unde izoleaza fisa, se depune un strat asemanator calaminei
De aia nu sunt adeptul bujiilor prea scumpe care tin mult, mai bine normale schimbate mai des. |
#540
corect pana aici, dar unii au impresia ca alea scumpe cu kriptonita, sau cu 15 electrozi le dau shpe cai putere in plus .
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 13th May 2025 - 03:55 |
