> Dust/Polen filter on Logan
martin245
post 19 May 2006, 17:08
EX PAT
I would like to fit a pollen filter to the fresh air intake on my Logan as I have a bit of a problem (like lots of people )with Pollen
any ideas out there
CU
Stu
Still in the UK and soon to travel back to Germany
dacia logan 14 mpi Simply RED - GB 1 2007
Bessy Regs
Codrin
post 19 May 2006, 17:41
You can use a Clio III filter, they are about 25 euro. Here you have the pictures from the operation.
Mazda . .
martin245
post 19 May 2006, 18:36
EX PAT
Thanks mate
But I cannot read a word on that site (You know us Brits we dont learn much in our SKOOLS) LOL
Bessy Regs
marksman
post 19 May 2006, 21:03
Post mortem nihil est
QUOTE(martin245 @ 19 May 2006, 20:36)
Mate, a picture is worth a thousands words. However I'll try to translate that for you english speakers out there.
QUOTE(klaus @ 22 Apr 2006, 22:35)
I haven't used the filter from Modus as it is too expensive, but instead I've used a filter from Clio 3 (part number 77 01 062 227)
This is the cover that seals the filter's housing 1.jpg ( Size: 73.22k ) Number of downloads: 15064
I've cut it out by drilling one hole after another with a drilling mill and a small saw. 2.jpg ( Size: 66.76k ) Number of downloads: 15203
After that I've smoothed the cuts around borders using a grindstone attached to the drilling mill (minimum efficiency) then a coarse file (much better!) and then a fine file for smoothing.
This is the filter; it goes into the housing with the upper side first. 3.jpg ( Size: 53.01k ) Number of downloads: 15040
The filter is thin - it is actually a thin, kitchen hood filter on a plastic netting.4.jpg ( Size: 56.47k ) Number of downloads: 9679
Inserting the filter into it's housing 7.jpg ( Size: 67.36k ) Number of downloads: 13634
Because the lighting in that area is very weak I've came up with a state of the art, high-tech sollution smile.gif 8.jpg ( Size: 84.01k ) Number of downloads: 4017
With this occasion I've realised that my fears were not founded (I thought that there would be no space in front of the filter for the airflow)
In fact there is a tunnel for the airflow just in front of the filter.
That place is surely designed for the cabin filter.
PS: after cutting and smoothing there will be quite many plastic debris inside the filter housing.
As it is very difficult to clean that place up I've closed the air vents, moved the ventilation directioning to "air vents" position and started the ventilation on "4" (maximum).
As the air vents were closed, the air was directed to the newly cut opening in the filter housing thus cleaning the debris in that area.
But still you have to clean up the debris at the base of the condenser, which do not come out with the airflow.
This post has been edited by Illusi0n: 20 May 2006, 13:58
Opel/Mazda/Mercedes Crossland X / CX-30 / SLK200 2019 / 2020 / 2002
Discipline equals freedom
post 20 May 2006, 12:03
I have inserted the pictures into Illusi0n translation...
As a cutting tool anything suitable can be used
A strong knife, a hot welding tools (to melt the plastic cover), etc…
martin245
post 20 May 2006, 15:25
EX PAT
QUOTE(klaus @ 20 May 2006, 12:03)
Thanks a bunch mate for your time
I will print it all out when i returne to Germany and have a go at fitting it
cu
Stu
Bessy Regs
clan
post 4 Jul 2006, 15:57
Mann filter, product code "CU 1829" also fits.
Dacia Logan Laureate 1,4 - B-00-000 2005
martin245
post 29 Oct 2006, 12:13
EX PAT
No realy I stole two of my wifes small Bobby Socks (Small sock like Nylons) blush.gif
Then took off the top of the air intake cover above the wiper motor and pulled them over it the right side fitted perfect and the left side I have done the half so I will still be getting a good airflow minus 80% of the rubbish that comes with it (and it does not restrict too much airflow)
lets see how it works as next Sunday I am off to England and expect to travel3000km
Hope this idea is a help to you
Stu
This post has been edited by martin245: 29 Oct 2006, 12:15
Bessy Regs
jaksa
post 29 Oct 2006, 16:54
Ford Mondeo 1.8TD Estate - Serbian
martin245
post 29 Oct 2006, 17:09
EX PAT
Not to worry Jaksa its not rust just dust that looks red in the flashlight
I took the photo in the garage
Stu
Bessy Regs
jaksa
post 29 Oct 2006, 22:12
Will warranty be void if one installs Clio's filter, as described above?
martin245
post 29 Oct 2006, 22:17
EX PAT
OF COURSE it will blink.gif You need to butcher half of the heating system !!! radmasa.gif
didnt you notice that ???? wacko.gif just place the nylon sock on the intake and you have sorted it for 1 euro biggrin.gif
Stu
look closely at my photos
This post has been edited by martin245: 29 Oct 2006, 22:34
Bessy Regs
martin245
post 29 Oct 2006, 22:32
EX PAT
AND dont forget if you put the filter inside the car ...the leaves and stuff will get down to it and block it !! (think about it ) I had this problem in my Rover 825
.I think my idea for the filter above is greeeeeeat
Stu
Bessy Regs
jaksa
post 29 Oct 2006, 22:57
If you travel from somwhere-near-Karlsruhe, will it be 3000km in both directions? Are you going to travel to UK in one day or in two maybe?
I am curious because my limit for one day trip is under 1000km, from Belgrade to Northern Greece and from Belgrade to Istria - Trieste.
martin245
post 30 Oct 2006, 07:45
EX PAT
Ha !!
Yes i drive from Karlsruhe to Calais 700km then jump on the train (with the car)
get out at Dover and then drive up north to GRIMSBY it is about 1150km total
then I have my traveling around kms that will be around 800km so that is the 3000km
I will leave karlsruhe in the evening and it takes normaly with stops 7hrs to Calais
then from Dover I will take around 5 hours to grimsby (With eyes like a Panda bear) wacko.gif
I will put up some photos of Gods Town (GRIMSBY) when I return
cu
and 1 euro is about right she gets em at A.Schlecker http://www.schlecker.com/
It is pretty easy to travel this distance over here and I will be using the French motorways they are VERY good and you are not being pushed all the time .not like in Germany it is one big race on the Autobahn and you get tired easy .
I have been doing this since 1970
Stu
This post has been edited by martin245: 30 Oct 2006, 07:49
Bessy Regs
jaksa
post 30 Oct 2006, 10:42
From my point of view, in Greece is also one big race at the highways.
martin245
post 30 Oct 2006, 18:32
EX PAT
I have driven to Athens from Hamm in Germany it must have been in 1982
I remember stopping at some traffic lights and loads of Kids wanted to clean my Trucks window .in fact all the time in Greece there was someone trying to get money out of you .......But a nice place
Stu
This post has been edited by martin245: 30 Oct 2006, 18:46
Bessy Regs
jaksa
post 1 Nov 2006, 00:39
Almost forgot:
martin245
post 1 Nov 2006, 09:39
EX PAT
Shit I am going daft looking for Winter tires now !!! as they are Law in Germany
I will find out today if I am getting the ones I was after PANIC
Stu
Bessy Regs
Marty
post 1 Nov 2006, 12:01
Membru cu privire de ansamblu
Stu, www.reiffendirekt.de or locate an ATU store near your "Plaz". Delticom (Reiffendirekt) are quite cheap on tyres and they have an extensive offer. ATU are perfect for those looking for complete wheels. You may chek with them for tyres only as well.
This post has been edited by Marty: 1 Nov 2006, 12:06
Gillette De unica folosinta - B 999 NAM 2011
martin245
post 1 Nov 2006, 12:11
EX PAT
Thanks Marty
But its sorted now and I have them for Saturday (I leave on Sunday)
Oh yes and My super filter I removed some leaves that it has caught and they would have gone down the bigger holes into the blower
so it seems to work
cu
Stu
Bessy Regs
martin245
post 9 Nov 2006, 00:32
EX PAT
Hi Guys
I am now in the Uk and had a real good drive over .I used an average of 6,8 ltrs per 100 km so am very happy The wnter tires are very good and quiet The car is very dirty so you are not going top get a photo until it is clean and tidy
Cu
Stu
Bessy Regs
Boris
post 9 Nov 2006, 07:13
Croatian member
QUOTE(martin245 @ 8 Nov 2006, 23:32)
Hi Guys
Cu
Stu
Glad to hear that you arrived whithout problems.
Nice consumption if you used highways.
Dacia Logan Laureate 1.6 2005 + LPG Landi Renzo sequent
Reliability of machines is inversely proportional to the number and importance of people watching it
martin245
post 10 Nov 2006, 19:56
EX PAT
yes the roads were good and the fuel consumption is also part of my reluctance to floor the gas pedal ,I drove at 130 most of the time with a few bursts of 140
I must say though that the speed was taken from my Sat Nav because the Speedo is wrong (as on all cars) .The Sat nav gives Perfect readings of your speed (if not it would not be able to work out where to turn) So driving at 130 iwas doing about 120 and 140 was 130km so dont worry about thrashing it at 150 cos your are doing arround 140 ahhh the wonder of Sat navs blink.gif
Stu
Bessy Regs
Marty
post 11 Nov 2006, 14:55
QUOTE(martin245 @ 10 Nov 2006, 19:56)
the Speedo is wrong
Have you been swiming all the way back from GB to DE ? Is this your Speedo ?
martin245
post 12 Nov 2006, 12:10
EX PAT
What was that Bue thing??? Underpants??
But the speedo readings that I gave you are correct
as with most cars they read wrong .AND i have 15" wheels which also affect (a little bit ) your readings
swimming ???No I went through the Eurotunnel
Cu
Stu
Bessy Regs
Marty
post 13 Nov 2006, 09:02
"The blue thing" is usually called "swimming trunks" and they are produced by Speedo, wink.gif
This post has been edited by Marty: 13 Nov 2006, 09:05
martin245
post 13 Nov 2006, 09:43
EX PAT
Speedo is also the nickname for the Tachometer
stu
Bessy Regs
martin245
post 24 Nov 2006, 23:15
EX PAT
I drove the car back pretty hard traveling from Calais to karlsruhe in 6hrs 30mins icon_mrgreen.gif
I now have 11ooo km and the car seems to have a bit mor power
Hills are no Problem and i never had to change down once
so looking forward to the next holiday
I have hung a photo on the end for you to enjoy
Stu
Bessy Regs
Boris
post 25 Nov 2006, 11:24
Croatian member
QUOTE(martin245 @ 24 Nov 2006, 22:15)
I hope you did not make the whole 2000 km in 6 h 30 min, that would be some really hard driving smile.gif
7 l/100 km is not a bad consumption.
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 10th September 2025 - 18:02
