Driver seat
Driver seat
DenNy |
![]() Membru Group: Members Posts: 118 Joined: 22 August 05 From: Vojvodina, Banat ![]() |
Logan Laureat Plus
1.4
- PA-81
DFA |
![]() moderator://DC/Logan Group: Moderatori Posts: 3.562 Joined: 30 September 05 From: Buzău, RO ![]() |
Go to the service! The seat is defective, it can be replaced or repaired.
Logan III Comfort
ECO-G 100cp
2021 sedan
ex Logan I 1.5 |
DenNy |
Logan Laureat Plus
1.4
- PA-81
adister |
![]() Membru autentic Group: Members Posts: 371 Joined: 2 July 04 From: Bucuresti ![]() |
It does not matter if the seat is adjustable on height - the backrest should not move at all. So for your own safety go to service.
Megane Sedan 2.2 1.5 dCi 80cp
- B56... Prostii par conceputi pe cale artificiala, ca sunt multi ai dracu` si n-au nicio boala - Parazitii |
martin245 |
![]() EX PAT Group: Members Posts: 913 Joined: 1 April 06 From: Karlsbad Germany (again) ![]() |
logan 14 mpi Simply RED
- GB 1 Bessy Regs
DenNy |
Ok, I'll check this problem in service. But I'm afraid that they will tell me tu put seat to level at which backrest stop moving
Logan Laureat Plus
1.4
- PA-81
mccoy |
![]() Membru autentic Group: Members Posts: 273 Joined: 2 January 05 From: small town in Vojvodina ![]() |
Mine is on the lowest position but the backrest doesn’t play the game.
Everything that is somehow made might be defective… ![]() |
Laureate 1.6
- ...98-7. -----------------------------
Divide et impera ... and unite in EU ! ----------------------------- |
Boris |
![]() Croatian member Group: Members Posts: 497 Joined: 20 October 04 From: Zagreb, Croatia ![]() |
I have a height adjustiing seat and notnin's moving there unless I want it to.
So, if you haven't solved it by now go to the service. |
Logan Laureate 1.6
2005 + LPG Landi Renzo sequent Reliability of machines is inversely proportional to the number and importance of people watching it
kodrix |
![]() Membru tanar Group: Members Posts: 220 Joined: 20 July 05 ![]() |
You should go to the service to solve your problem. I understood that there is a problem with a certain lot of Logans at the driver seet.
This post has been edited by kodrix: 15 Aug 2006, 14:51 |
- Skoda Fabia 1.2TSI 2010
Logan 1.4MPI Laureate 2005 de la 0 km la peste 180.000 km Logan 1.4MPI 2009 E0 Logan 1.4MPI 2009 Ambiance |
DenNy |
I'v visited main service in Belgrade. They ckecked driver seat and told me that maybe is the best to change seat ( only construction of seat, they are repacking it)
They are "trained" for this stuff but he was quiet sceptic about this. ALSO! This guy told me that, all seats are a little bit moving, that this is problem in almost all new Logans. Seat are soft and bad...... lalalalal etc..... They do not have this type of seat. It must be ordered. That is no problem. Well, after this I dont know what to do really, becasue I'm quiet afraid that even if new seat construction came, they "dont know" to do this well, and even they do it well, maybee it wont solve the problem. ![]() |
Logan Laureat Plus
1.4
- PA-81
zorpetus |
Membru Group: Members Posts: 120 Joined: 17 April 06 ![]() |
QUOTE(DenNy @ 16 Aug 2006, 09:40) This guy told me that, all seats are a little bit moving, that this is problem in almost all new Logans. Seat are soft and bad...... lalalalal etc..... So, in all new Logans seats are not good? I've checked in my friends Logan and back rest of the seat could be moved some 1-2 centimeters (measured at the top of the seat) if moved by hand in front-back dirrection. I don't know if this is normal or this is that problem that you are talking about? This post has been edited by zorpetus: 16 Aug 2006, 12:07 |
None
None
- None
DenNy |
Well, really I dont know what to do about this problem. In main service they told me that if I want, they could start warranty procedure with seat....as I told before. But as I said QUOTE "Well, after this I dont know what to do really, because I'm quiet afraid that even if new seat construction came, they "dont know" to do this well, and even they do it well, maybee it wont solve the problem. " dont know should I do this..... |
Logan Laureat Plus
1.4
- PA-81
martin245 |
QUOTE(DenNy @ 14 Sep 2006, 12:30) Well, really I dont know what to do about this problem. In main service they told me that if I want, they could start warranty procedure with seat....as I told before. But as I said dont know should I do this..... Well its worth a try so go for it and let them sort it out for you Stu |
- GB 1 Bessy Regs
prody |
![]() membru iradiat Group: Members Posts: 1.365 Joined: 26 November 05 From: Cetatea Banilor ![]() |
Replacing driver seat is one of the mos easiest things they could do to your car, have no worry, there is really nothing they could do wrong there. Replace it in warranty, it has a problem, the seat can be moved a little back and forward manual, but they never move when you hit the brake pedal or in any other case when you are sitting on it.
Mazda
3
2011 TX
DenNy |
QUOTE(prody @ 14 Sep 2006, 18:19) Replacing driver seat is one of the mos easiest things they could do to your car, have no worry, there is really nothing they could do wrong there. Replace it in warranty, it has a problem, the seat can be moved a little back and forward manual, but they never move when you hit the brake pedal or in any other case when you are sitting on it. I'm aware of that! And, yes this mostly happens when I hit the brake pedal. But also I'm sceptic,and afraid a little, because they are not changeing complete seat, but only its "construction". And the guy in main service was pretty much sceptic about that they could do this "change" well. He is the main one for problems like this, and he told me something like "well we are trained, but... we did not change any seat yet....seats are "bad''....bla,bla..." Whatever, I will start warranty procedure 'asap' and I hope that the problem will disappear. This post has been edited by DenNy: 15 Sep 2006, 10:20 |
Logan Laureat Plus
1.4
- PA-81
marksman |
Post mortem nihil est Group: Members Posts: 7.745 Joined: 1 November 04 From: sat ![]() |
That is incredible, how come they can't change a seat because they haven't done it yet?
I've removed and re-added the seats myself. All you need is a "torx" screwdriver and quite a lot of force, because the screws are very tightened. |
Opel / Mazda
Crossland X / CX-30
2019 / 2020 Nick Ușor
DenNy |
QUOTE(Illusi0n @ 15 Sep 2006, 12:52) That is incredible, how come they can't change a seat because they haven't done it yet? I've removed and re-added the seats myself. All you need is a "torx" screwdriver and quite a lot of force, because the screws are very tightened. Well, as I told you, they do not chage complete seat, they are ‚‚repacking‚‚ it. So it is not only few screws... |
Logan Laureat Plus
1.4
- PA-81
prody |
Do it anyway, you simply cannot tolerate that bloody seat! It is dangerous to, if you will be involved in a crash , the seatbelt will brake your bones beacause if the seat moves a bit in front when your car is on a powerfull brake, then it is a much higher pressure on you.
Mazda
3
2011 TX
martin245 |
Do You live on another planet ?? I have never heard such rubbish in my life .It is either faulty or not and if it is... then its the workshops job to sort it and if they cant sort it then they should not be trading in cars
Stu |
- GB 1 Bessy Regs
prody |
Well, those guys have a very nice job. If you come into their workshop with a problem, they advice you not to try fix it , because it may end up worse than it was before. So you are leaving home and they may return to their beer and cards game
![]() Just kidding, but do it anyway...even so, not replacing the entire seat it is not a difficult job. |
Mazda
3
2011 TX
DenNy |
Well, I said that I'll do it.
I'm just "sceptic" that they would solve this problem smoothly |
Logan Laureat Plus
1.4
- PA-81
martin245 |
YOU !!!! are my perfect example of a Dumb Customer
SAY NO MORE!!............Sorry friend Stu |
- GB 1 Bessy Regs
DenNy |
QUOTE(martin245 @ 17 Sep 2006, 02:09) I'm not a "dumb customer" my friend. I just know how does it work here. I'm just realistic. And as I said few posts before, I'll quest for changeing that seat ASAP! This post has been edited by DenNy: 17 Sep 2006, 13:19 |
Logan Laureat Plus
1.4
- PA-81
martin245 |
You first posted the Problem on the 8th of August .It is now the 17th of Sept . Isnt this a bit of a long time to be driving with a seat that is not safe
Stu PS No offence meant about the Dumb Customer |
- GB 1 Bessy Regs
DiMaggio |
![]() Membru autentic Group: Members Posts: 465 Joined: 8 November 05 From: Bucuresti ![]() |
Denny, Stu is living in Germany, we are all aware that in Germany they do not treat the customer like in other countries.
If I would be in your shoes, what I would is send a couple of angry e-mail to the Renault of your country, and renault France, explaining exactly the attitude of the workshop. Make a big fuss and demand that they change the whole seat, that you donŽt trust the service, that you have young kids, blah blah. DontŽt forget to mention to your Renault distributor that you also send emails to Renault France and if the problem is not solved very soon, you are planning to send e-mails to car maganizes in your country. Thy this way, I am confident you will get a positive answer faster than you expect. Alex |
Megane RS
2012
DenNy |
At last, driver seat came(well 3 weeks ago, but I was not at home that moment), and today they have change it.
And it works :-) I mean it is not moving (till now). They said that something was broken in seat construction.... what ever... it is ok now! I just noticed that seat handle is not painted(maybee whole construction). There is no color on it. This post has been edited by DenNy: 7 Dec 2006, 10:30 |
Logan Laureat Plus
1.4
- PA-81
Boris |
Logan Laureate 1.6
DenNy |
Handle for height/position adjusting
Logan Laureat Plus
1.4
- PA-81
mccoy |
Laureate 1.6
DenNy |
Logan Laureat Plus
1.4
- PA-81
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 26th July 2025 - 19:18 |
