2 Pages < 1 2
> OK, here I come, first question
veveritz
post 24 Aug 2006, 13:40
for the first 1000 km don't exceed 3000 rpm... And they say that only after 3000km you'll enjoy the full potential of your car... (I presumed that your car is LOGAN 1.4 mpi, as you described before).
All the best
dacia Sandero1.5 dci 2016-august - b xx xxx
homerolo
post 24 Aug 2006, 16:39
QUOTE(martin245 @ 23 Aug 2006, 11:47)
Darkozi
You enjoy your car .We all seem to be enjoying ours Eh Lads n Lasses! tongue.gif
Check the screws on the door and dont Go fast in it  excl.gif Run the motor in as it says in the handbook excl.gif  that is the way to do it  excl.gif
Stu
Well on my experience here in Ecuador what Renault told me was not to go over 100km/h and not go higher then 3000 RPM for the first 3000 KM after that the engine will be fine to go higher. One thing to remenber, never go higher then 4000 RPM really take good care of you car.
Homero
RENAULT LOGAN LOGAN 1.6 LOGAN 1.6 - GJC123
martin245
post 24 Aug 2006, 18:01
EX PAT
Read your handbook
dacia logan 14 mpi Simply RED 2007 - GB 1
Bessy Regs
marksman
post 24 Aug 2006, 22:59
Post mortem nihil est
QUOTE(homerolo @ 24 Aug 2006, 18:39)
Homero
While it is true that constantly keeping your car's engine on high rpm is not so good for the engine's life, the built-in limitation kicks in at 6000 rpm and prevents engine damage. I found myself very close to such situation when I accidentally changed from 4th gear in 3rd gear instead of 5th gear so the needle went ballistic and showed around 5800 rpms.
As fas as I have seen, you can achieve the consumption given by the factory in the 2500-3000 rpm interval, but the car has greater torque somewhere in the 3500-5000 rpm interval. Besides it's better to run the engine at some high rpms (eg: change gear when revs drop under 2000-1500 rpm, don't drive it in such low revs and high gear). I generally change gears up at around 3000-3500 rpm and down around 2000 rpm or less.
Nick Ușor
mccoy
post 25 Aug 2006, 15:31
QUOTE(Boris @ 22 Aug 2006, 23:38)
you two seem bored like hell
Dacia Logan Laureate 1.6 - ...98-7.
Divide et impera ... and unite in EU !
mccoy
post 25 Aug 2006, 15:38
And the gears are goin` in H...
DiMaggio
post 25 Aug 2006, 18:52
We are still waiting for more commets and eventually a photo shot tongue.gif
Renault Megane RS 2012
mccoy
post 26 Aug 2006, 00:17
Darkozi, you know .......“ National Class”.
darkozi
post 26 Aug 2006, 17:18
So, here are the first immpressions after few days driving and 150km on the counter.
Well it will be short because I am totally immpressed with the car.
This is not very objective because I am a driver that was driving a 15 years rusty old Yugo, so I feel like I am driving a Merz!
Maybe for someone who drove a better car this is not so big fuss but for me it is enourmus.
I have no complanits but one question about gear changing: When I want to go from Neutral to 1st gear there is a but of hardness in it, I mean it doesn't go so fot as other gears. Is it common on Logan?
Photo? Well, as I am kind of a experienced photographer I don't intend to put a usual photo, because you have all seen Logan. So I am waiting for nice weather to wash it and make an interesting one. So these days...
Dacia Logan Ambience 1.4 mpi
martin245
post 27 Aug 2006, 11:34
EX PAT
Mine goes into 1st gear like cutting through Butter
stu
Bessy Regs
prody
post 3 Sep 2006, 13:23
membru iradiat
@ darkozi
After 2000 km or something, your first and 2nd gear will go very smoothly. Mine did so!
This post has been edited by prody: 3 Sep 2006, 14:03
Mazda 3 2011 TX
2 Pages < 1 2
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 21st July 2025 - 05:02
