Schimbare boxe Megane II, Pt. cei care s-au saturat de boxele stoc
jmpr |
#61
Membru incepator Group: Members Posts: 10 Joined: 5 February 08 ![]() |
Megane Sedan
Manager - 2007
Aragorn |
#62
![]() Megane Uber Alles Group: Members Posts: 179 Joined: 18 December 07 From: Brasov / Bucuresti ![]() |
Ce parere aveti ?
Vroiam sa schimb la masina sistemul audio stock cu altceva, sper ca mai bun ![]() ![]() 1. Player imi place cum arata si sper ca merge bine un player pioneer FH-P80BT ( http://www.pioneer.eu/eur/products/25/121/...80BT/index.html ) . Totusi, cam pe la acelasi pret ( mai mult cu cca 100 dolari ) este si Pioneer AVH-P4000DVD ( http://www.sonicelectronix.com/item_12283_...0DVD.html#specs ) care pare ok si el, nu are bluetooth decat optional ) 2 . Adaptor pt comenzi volan am gasit aici si sper ca merge : 703934 Adaptor Stalk Renault diverse modele 2005> CAN> Pioneer ( http://www.metrafo.ro/produse.html?keyword=Renault&where=0 ) 3. La boxe am cele mai multe probleme ![]() ![]() Ce parere aveti, merg asa ? Care boxe ziceti ca sunt mai bune ? Trebuie si cu amplificator sau merge direct din player si sa caut doar boxe ? Pe spate ce ar merge cat de cat ? ( cautam mai ieftine decat cele de pe fata ) PS - De fapt pana la urma cat de adanc e locul ala la Megane ( unele site-uri mai zic mounting depth pt boxe si ar fi mai usor de cautat ) Sau ce model sunt boxele stock sa caut pe net dimensiunile sa nu mai mor de stress ![]() Cred ca playerele au Preamp RCA Outputs si Sub Preamp RCA Output care pare ok pt conectare la un amplificator. .. Multumesc tuturor pentru raspunsuri ![]() Focal___Polyglass_130_V_Slim.jpg ( Size: 18.45k ) Number of downloads: 4980 Focal___K2_Power_130_KF.jpg ( Size: 21.72k ) Number of downloads: 4877 [atta chmentid=1627469303] This post has been edited by Aragorn: 2 Sep 2008, 21:32 Attached thumbnail(s) Avh_4000DVD.jpg ( Size: 55.94k ) Number of downloads: 4768 |
Megane Bicorp
- BV - 28 - R O L
2007/II.2
ThunderRa |
#63
![]() posesor posedat Group: Members Posts: 412 Joined: 8 April 05 From: Piatra Neamt ![]() |
Am schimbat si eu boxele originale: pe fata Pioneer TS-Q131C iar pe spate Pioneer TS-E1302i. Stau mai bine la bas decat cele recomandate in tutorial. Am ramas cu zdranganeli in portiera stanga spate...
Megane Sedan 2.2
- NT-23-DAC
2008 - Lux Privilege 1.6 16v Dacia MCV Laureat 1.6 16v recolta 2007
http://radunastasa.com |
AlexBanu |
#64
![]() Chiptuner Group: Members Posts: 44 Joined: 4 March 07 From: Bucuresti ![]() |
QUOTE(Aragorn @ 2 Sep 2008, 19:56) Ce parere aveti ? Vroiam sa schimb la masina sistemul audio stock cu altceva, sper ca mai bun ![]() ![]() 1. Player imi place cum arata si sper ca merge bine un player pioneer FH-P80BT ( http://www.pioneer.eu/eur/products/25/121/...80BT/index.html ) . Totusi, cam pe la acelasi pret ( mai mult cu cca 100 dolari ) este si Pioneer AVH-P4000DVD ( http://www.sonicelectronix.com/item_12283_...0DVD.html#specs ) care pare ok si el, nu are bluetooth decat optional ) 2 . Adaptor pt comenzi volan am gasit aici si sper ca merge : 703934 Adaptor Stalk Renault diverse modele 2005> CAN> Pioneer ( http://www.metrafo.ro/produse.html?keyword=Renault&where=0 ) 3. La boxe am cele mai multe probleme ![]() ![]() Ce parere aveti, merg asa ? Care boxe ziceti ca sunt mai bune ? Trebuie si cu amplificator sau merge direct din player si sa caut doar boxe ? Pe spate ce ar merge cat de cat ? ( cautam mai ieftine decat cele de pe fata ) PS - De fapt pana la urma cat de adanc e locul ala la Megane ( unele site-uri mai zic mounting depth pt boxe si ar fi mai usor de cautat ) Sau ce model sunt boxele stock sa caut pe net dimensiunile sa nu mai mor de stress ![]() Cred ca playerele au Preamp RCA Outputs si Sub Preamp RCA Output care pare ok pt conectare la un amplificator. .. Multumesc tuturor pentru raspunsuri ![]() Focal___Polyglass_130_V_Slim.jpg ( Size: 18.45k ) Number of downloads: 4980 Focal___K2_Power_130_KF.jpg ( Size: 21.72k ) Number of downloads: 4877 [atta chmentid=1627469303] Salutare, Daca vrei un sistem bazat pe sq as zice sa te mai gandesti la componente. Nu este nici o problema cu adancimea de montare. Mai ales daca folosesti si inele MDF pt fixare. Tb sa ai in vedere alegerea unui head0unit de calitate care sa aibe time correction, 4v pe preout, HPF, LPF eventual 3way. Am vazut ca ai postat pe aici link-uri de la noi de pe site (Audiolab.ro). Vad ca te-ai orientat spre ceva calitativ insa se pot face imbunatatiri cum ar fi: montarea unor inele MDF pentru conversie de la 13 la 16.5cm si aici poti obtine performante mai bune pe partea de mid-bass. Ce iti recomand din sistemele componente ar fi Focal K2Power 165KR2 sau Helix P 236 Precision amplificate independent de un amplif pe 4 canale. Ca si head-unit mergi pe Clarion DXZ-788RUSB. Ar fi cam cea mai buna solutie pret calitate avand tot ce am enumerat mai sus. Pentru mai multe detalii si intrebari ai in semnatura detaliile mele. Bafta! This post has been edited by sportc: 6 Oct 2008, 08:48 |
Clio RS
2008 TuningChip Romania - Chiptuning OBD/Classic/FlashTuning DPF OFF
r1cco |
#65
Membru incepator Group: Members Posts: 36 Joined: 14 June 09 ![]() |
salut,
daca masina e in garantie, si eu umblu al boxe, si la casetofon, afecteaza cu ceva garantia? cei care ati schimbat difurile, ati schimbat si radioul original? si ce model? |
Megane
Sedan 2008 II
shoTgunu |
#66
![]() Membru autentic Group: Members Posts: 246 Joined: 25 November 08 From: Bucuresti ![]() |
Foloseste functia search, sunt sigur ca o sa gasesti cel putin 2 topicuri despre boxe si head-unit-uri adaptoare s.a.m.d.
Bafta |
Megane Sedan II 1.6 16V
- Numar de numar
2003 Privilege Life's a bitch... and in the end you marry one... you better hope she sucks
mihai_dorin |
#67
![]() Membru autentic Group: Members Posts: 1.144 Joined: 23 September 07 From: Bucuresti ![]() |
QUOTE(r1cco @ 14 Jun 2009, 14:08) salut, daca masina e in garantie, si eu umblu al boxe, si la casetofon, afecteaza cu ceva garantia? cei care ati schimbat difurile, ati schimbat si radioul original? si ce model? Daca este in garantie si nu montezi la dealer cu piesele lui iti pierzi garantia pe partea electrica, insa la dealer sunt foarte scumpe. Daca vei schimba cdplayer-ul vei observa cum boxele "prind viata", insa nu iti va merge satelitul de comanda fara un adaptor ( iar astea sunt destul de scumpe). Sfatul meu: citeste tot ce este pe forum despre asa ceva si iti vei face o opinie, e mult de povestit insa sunt altii mult mai avizati ca mine. |
Megane Sedan 1.6 16v
2007 Privilege + Mio C720b “Omul este cel mai putin el însusi, atunci cand vorbeste în propria persoana. Da-i o masca, și el va va spune adevarul. ” Oscar Wilde
bahrim II |
#68
![]() Urat! Group: Members Posts: 271 Joined: 26 February 09 From: Pitesti ![]() |
am o intrebare.....adika spunetimi si mie un model de boxe ...buna cu bass ...si cu calitate ......si daca e un player sa arate frumusl in bord ......credit 1500 ron
Megane II Bicorp 1.4 16 V
- Ag----
2005 Capitan' de judet!
Aragorn |
#69
Nu prea ma pricep asa bine la detalii tehnice, dar mie unul imi place si cred ca o sa iau asa ceva : http://www.pioneer.eu/eur/products/25/121/...80BT/index.html Arata super fain, nu vreau ceva tipator ca strica aspectul
![]() Attached thumbnail(s) FH_P80BT.jpg ( Size: 119.41k ) Number of downloads: 526 |
Megane Bicorp
- BV - 28 - R O L
2007/II.2
bahrim II |
#70
aragon si mie imi place ...dar
1 la mana nu stim dimensiuneile ...ca o sa ocupe amandoua locasurile.. 2 la mana am citit undeva ca nu se mai fabrica ...si as vrea s eu un pret daca stii? |
- Ag----
Aragorn |
#71
E 2-DIN, dar sunt adaptoare pentru Megane. Preturi la noi incep cam pe la 12oo-13ooRON, pe Amazon.com am gasit si la 250USD >> http://www.amazon.com/Pioneer-FH-P8000BT-D...46645457&sr=8-1 <<
Sunt putine modele care sa nu aiba afisaj in toate culorile sau sa nu aiba monitor, la noi in masina e cam joasa pozitia ca sa se poate uita cel din dreapta la un film ![]() ![]() ![]() |
Megane Bicorp
- BV - 28 - R O L
2007/II.2
bahrim II |
#72
Am gasit la 17 milioane aici ...mi se pare stigator la cer deoarece .....cu bani astia iau navigatie si statie cu subwoofer
This post has been edited by bahrim II: 3 Jul 2009, 22:22 |
- Ag----
12volti |
#73
Membru Group: Members Posts: 122 Joined: 19 May 09 From: Bucuresti ![]() |
QUOTE(bahrim II @ 3 Jul 2009, 23:10) Am gasit la 17 milioane aici ...mi se pare stigator la cer deoarece .....cu bani astia iau navigatie si statie cu subwoofer In primul rind va trebui sa compari preturile din Romania cu cele din Europa nu din state. In al 2-lea rind, nu vad ce navigatie iei in banii astia, decit o chinezarie ceva. Unde mai pui ca ramin bani si te statie si subwoofer... ![]() |
Wolverine |
#74
![]() Membru autentic Group: Members Posts: 1.085 Joined: 6 September 07 From: Galati ![]() |
Pana la urma renteaza sa schimi boxele stock cu Pioneer TS-Q131C pe fata si TS-E1302i. Toata afacerea duce pe la 700 ron si pentru un 10% better sound parca nu as baga bani astia, mai bine mi-as lua un eleron
MB II.2 2006/1.6 16V 110CP/Expresion
Audio Conenction Box/Folie/ va urma....
12volti |
#75
Problema cea mare la Megane2 e usa care e din plastic, in sensul ca fata de usa tine si difuzoare, macara geamuri etc.... Fiind de plastic, difuzoarele pe linga faptul ca sunt mici ( 13 cm ) su nu pot cobori in frecventa, fac ca usa sa vibreze si sunetul va fi extrem de slab. Singura solutie pentru un sunet mai bun ar fi rigidizarea panourilor cu pasta speciala care se aplica pe interiorul lor. Abia dupa poti spera la un sunet mai bun.
megane1 |
#76
![]() Membru autentic Group: Members Posts: 793 Joined: 27 March 07 From: Moinesti ![]() |
eu am preluat, "din zbor" , o idee conform careia boxele de pe fata ar produce un sunet mai bun decat cele de pe spate
![]() This post has been edited by megane1: 1 Aug 2009, 12:40 |
renault
megane2.2
privilege 1,6 16v mai 2007 privilege, gris platine+mp3
12volti |
#77
Difuzoarele din fata pot produce -eventual- un sunet mai bun datorita incintei mai bune ( mai mari ), dar nu din cauza aia se aud mai bine. Orice difuzor din fata se va auzi mai bine in primul rind pentru faptul ca sunetul iti vine din fata ! E ca atunci cind te duci la concert. Daca stai cu fata la scena e una, si daca stai la usa salii privind afara vei auzi muzica de pe scena mult mai prost pentru ca stai cu spatele la sursa sunetului. Vezi si cum arata urechea umana
![]() Din cauza asta cele mai importante sunt difuzoarele din fata. |
Dhragosh |
#78
![]() Membru forum.reno.ro Group: Members Posts: 284 Joined: 12 February 08 From: Bucharest ![]() |
Intrucat m-am saturat de boxele stock si de cum se aud m-am gandit ca ar prinde bine o mica schimbare, insa nu sunt hotarat ce sa aleg deoarece nu prea ma pricep, tocmai de aceea am sa va cer sfatul
![]() Pentru fata: http://www.car-sound.ro/difuzoare-auto/sis...ass-130-v1.html sau: http://www.caraudiomag.ro/109/449 Iar pentru spate: http://www.caraudiomag.ro/151/644 sau: http://www.be-loud.ro/produse/Difuzoare_au...xiale/TS-E1396/ Bugetul ar fi cam pe undeva la 1000RON pt boxe... Deocamdata HU nu as vrea sa il schimb.. Dat fiind faptul ca HU standard are 4X15W sunt curios care boxe le va "amplifica" mai bine, pe cele pioneer de 30W sau focalurile la 60w? |
Megane Sedan Privilege+ 1.6 16V 110HP
- B-91-DHR
12volti |
#79
Focal sunt difuzoare foarte bune, numai ca difuzoarele alese de tine au nevoie de amplificare. Pioneer nu ies in evidenta cu difuzoarele.
Difuzoare foarte bune, gindite sa functioneze exclusiv pe HU ( adica fara amplificare ), sunt cele din seria Dieci de la Hertz. In cazul tau http://www.be-loud.ro/produse/Difuzoare_au.../Dieci_DSK_130/ pentru fata, si http://www.be-loud.ro/produse/Difuzoare_au.../Dieci_DCX_130/ pentru spate. |
r_vlad |
#80
![]() --- Group: Members Posts: 1.267 Joined: 6 September 06 From: Sibiu ![]() |
Am inteles ca Hertz Dieci sunt gandite pentru a functiona fara amplificare suplimentara. Daca aproximativ la acelasi pret pot sa cumpar o pereche de DLS RS5A ce parere aveti, se aud mai bine tot fara amplificare suplimentara ? Pentru Clio III care are sistemul audio stock identic cu cel de pe Megane II.
This post has been edited by r_vlad: 9 Aug 2009, 22:57 |
VW/Tesla
Tiguan eHybrid/Model 3
2022/2023
12volti |
#81
Sincer, nu stiu cum vor suna DLS-urile pe HU stock al masinii. Ar trebui sa incerci atit dls cit si hertz, pentru ca e chestiune de gust in final.
shokaliptiku |
#82
![]() Membru autentic Group: Members Posts: 297 Joined: 3 April 06 ![]() |
r_vlad ... toate brandurile car audio
au difuri care se pot monta fara a folosit amplificare separata in speta este vorba de difurile cu un consum mai mic de ~50W difuzoare entry level ... la 3 4 5 mil ... deci ... dls , hertz , cat si altele blaupunkt,jbl,jl,audison,spl dynamics,gz etc sunt facute pentru a fuctiona "optim" pe amplificarea HU stok ( 17-22W) sau pentru a functiona pe un HU after market ... 17 27W in cazul in care pui difuri mult mai mari ca putere 60 100 120W ... din cauza puterii mici pe care o va furniza HU difurile nu se vor "misca"..deci nu se vor auzi tendinta imediat urmatoare este de a da HU la max moment in care el va produce distorsiuni ... si se vor auzi prost |
(Oo=oO) p88rs2 + Spl Dynamics + stp + odyssey
LOCUL I -> 4tuning festival 140.6 dB LOCUL II -> ESPL EMMA craiova 2008 LOCUL II -> SQ 3CH EMMA craiova 2008 IM : shokaliptiku |
ThunderRa |
#83
Are cineva un tutorial pentru montat boxe pe polita spate la un Megane Sedan? In portiera se aud oribil...
Megane Sedan 2.2
- NT-23-DAC
Fratzica |
#84
![]() Zen Group: Moderatori Posts: 2.925 Joined: 6 April 04 ![]() |
fa o instalare profesionala a boxelor fata cu tot cu insonorizare si nu vei avea probleme. Sunetul trebuie sa vina din fata, nu din spate.
Kia
Sportage
T-GDI 2021 "The happier we are, the less we see." - some japanese guy
AlexBanu |
#85
QUOTE(ThunderRa @ 17 Oct 2009, 18:51) Are cineva un tutorial pentru montat boxe pe polita spate la un Megane Sedan? In portiera se aud oribil... Nu are rost sa strici policioara degeaba. Nu te va ajuta foarte mult faptul ca pui difuzoare pe spate in afara de faptul ca se va auzi mai tare insa nu si mai calitativ. Daca vrei sa imbunatatesti sunetul foloseste niste material insonorizant pentru usile fata, un set de componente mai sanatoare si eventual amplificator pentru ele. Spor la treaba! |
Clio RS
ThunderRa |
#86
http://www.reno.ro/index.php?showtopic=495...dpost&p=2031476
Acolo am postat exact ce am pe masina. Difuzoarele spate se aud foarte aiurea... Pe difuzoarele fata/spate am taiat frecventele sub 100 hz, frecvente redate doar de subwoofer. Pe fata sunetul este foarte curat si tweeter-ele se aud excelent insa pe spate difuzoarele se aud foarte "sec", fara inalte. Nu am facut altceva decat sa le pun in locul celor de fabrica. Crezi ca problema este de la insonorizare? Daca da, nu-mi ramane decat sa ma apuc de portierele spate. Pe fata sunt multumit, nu cred ca este nevoie. Merci de raspuns. This post has been edited by ThunderRa: 17 Oct 2009, 18:17 |
Megane Sedan 2.2
- NT-23-DAC
Fratzica |
#87
din cate vad sunt doua probleme la tine.
Prima problema o reprezinta difuzoarele, Pioneer nu exceleaza la acest capitol. A doua problema o reprezinta lipsa insonorizarii, Megane pune mari probleme la capitolul muzica. Difuzoarele coaxiale puse de tine in spate nu sunt cine stie ce. Oricum nu inteleg de ce vrei sa auzi muzica din spate. Important e sa se auda bine in fata, boxele spate pot sa si lipseasca dupa parerea mea. |
Kia
Sportage
ThunderRa |
#88
Am posibilitatea sa schimb cu Focal 130 A1 pe fata si 130 CA1 pe spate. Crezi ca ar fi mai bine? Am inteles cu insonorizarea, ma ocup saptamana viitoare insa vreau sa stiu daca sa schimb si difuzoarele. Merci mult.
Megane Sedan 2.2
- NT-23-DAC
Fratzica |
#89
seria low-budget de la focal nu e cine stie ce.. Nu ti-as prea recomanda. Sunt mai ok decat pioneer-urile dar nu o sa simti cine stie ce diferenta. Daca mi-ai spune ce buget ai disponibil ti-as putea recomanda ceva.
Cat despre insonorizare, ai grija sa insonorizezi si fata de usa cu dynamat si pasta brax, sau doar pasta brax daca e prea mare cheltuiala cu dynamatul. Repet, boxele spate nu sunt importante. In loc de doua seturi de boxe low-budget, mai bine iti iei un set bun de boxe pe fata si insonorizezi usile fata. O sa se cunoasca diferenta ,garantat! |
Kia
Sportage
ThunderRa |
#90
Bugetul ar fi de 1500 lei, dar nu vreau sa mai fiu nevoit sa mai cumpar vreo statie. Crezi ca pot face ceva in banii astia?
This post has been edited by ThunderRa: 17 Oct 2009, 18:44 |
Megane Sedan 2.2
- NT-23-DAC
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 9th September 2025 - 01:29 |
