Wet Windows, condensation
martin245 |
21 Sep 2006, 18:18
EX PAT Group: Members Posts: 913 Joined: 1 April 06 From: Karlsbad Germany (again) |
logan 14 mpi Simply RED
- GB 1 Bessy Regs
GoGu |
21 Sep 2006, 20:54
Prea de la tara Group: Moderatori Posts: 1.970 Joined: 14 August 03 From: Iasi |
From breathing and air moisture condensating on the windows...
Use the air conditioning, it works wonders on the moisture... This post has been edited by GoGu: 21 Sep 2006, 20:54 |
Scenic 1.5dCi
recolta 2012
martin245 |
21 Sep 2006, 22:18
I have no AC and the windows get wet as soon as i turn on the blower
I suspect this is the lack of a pollen filter and it is pulling in the damp morning air I will try not using the blower tommoro until I have warm air STU |
- GB 1 Bessy Regs
GoGu |
21 Sep 2006, 22:30
Well, it helps if you open the front windows a little (1 cm or half inch )
Air admission lever should be on "outside", the air distribution control on "window defrosting", close the two central ventilation holes, max. heat and use the 2nd or 3rd blower speed... It should solve the problem in a short time. This post has been edited by GoGu: 21 Sep 2006, 22:30 |
Scenic 1.5dCi
recolta 2012
21 Sep 2006, 23:57
Don't drink anymore in the car!
Just lick a wet sponge... |
DenNy |
22 Sep 2006, 11:18
Membru Group: Members Posts: 118 Joined: 22 August 05 From: Vojvodina, Banat |
Read user manual for Logan. I have same problem before I read this
There they said that you need to open recirculation of cabin, put air direction only to front window, and close all front vents, like GocGu says. It works 100% This post has been edited by DenNy: 22 Sep 2006, 11:23 |
Logan Laureat Plus
1.4
- PA-81
martin245 |
22 Sep 2006, 17:43
I think that my problem comes from living in a wooded area and we have lots of ground fog The cars are soaking wet in the mornings .This morning I left the window down a bit and it was ok
As for the putting the the air recycle on outside .I only use the outside position (Unless I let a good fart and want everyone to enjoy it ) anyway it seems ok now so hope it is ok in the winter. I will be going to my Homeland of England in Nov for a little holiday .so will keep you all posted on this subject from the LAND OF FOG Stu |
- GB 1 Bessy Regs
My Berlina |
23 Sep 2006, 15:17
Membru American Group: Members Posts: 509 Joined: 29 November 04 From: Romania/United States |
There are also different types of anti-fog sprays you can spray on the inside of the window.
This post has been edited by My Berlina: 23 Sep 2006, 15:19 |
- Sibiu/North Carolina Volkswagen Passat GLS V6 2.8L
4x4 Jeep Cherokee 4.0L 6-cylinder Dacia Berlina L A/C |
mcv_rulez |
27 Nov 2006, 17:25
Mai mult spațiu. Mai multe posibilități. Group: Members Posts: 222 Joined: 14 November 06 From: Zenica, Bosnia |
If you want to get ridd of that, every morning turn up your heating to max, put air direction to front window only, and lower your windows for a five centimeters(around 2.3 inches). If temperature is above 5°C the AC is very good in helping you...
CYA This post has been edited by mcv_rulez: 27 Nov 2006, 17:33 |
Going to buy Dacia
Logan MCV
1.6 16V Laureate (5 seats) MCV really rules!!!
My Berlina |
28 Nov 2006, 04:49
QUOTE(My Berlina @ 23 Sep 2006, 08:17) I use this on my Berlina. I don't know if you can buy it in Romania because I always bring some from over here, but there should be similar products. http://www.rainx.com/ (Rain-X) http://www.amazon.com/Rain-X-Anti-Fog-3-5-oz/dp/B0002JN26I (Amazon) http://www.motormania.co.uk/product_detail...er=Rain-X&Code= (England) This post has been edited by My Berlina: 28 Nov 2006, 04:50 |
28 Nov 2006, 18:31
fan Dacia Group: Members Posts: 19.920 Joined: 12 November 05 From: Bucuresti |
Welcome to the wonderfull world of Dacia ! You should see a '99 Dacia 1410 with all the windows covered by condensation , and the front passanger struggling with a piece of cloth to keep at least the windshield clear.
Like everyone said: Rain X, blower to the max on the front windows and maybe the sun visors lowered. Cheers! |
martin245 |
28 Nov 2006, 18:47
Not just a Dacia problem though our Twingo gets it bad
and my Passat used to completly freeze inside I have resorted to leaving my window down and blower OFF till warm if I put the blower on it blows fog on the window ah well Soon be summer Stu |
- GB 1 Bessy Regs
28 Nov 2006, 22:12
No, I meant ALL cars made by Dacia have this problem.
mcv_rulez |
30 Nov 2006, 18:31
QUOTE No, I meant ALL cars made by Dacia have this problem. Why's that? My friend haves Logan 1.4 MPI Ambiance (with AC, and ....), for a year aprox. And he haven't that problem yet... CYA |
Going to buy Dacia
Logan MCV
martin245 |
30 Nov 2006, 19:56
Does he have the car in a garage overnight ?? When I do I dont have steamy windows .....when I dont I do have steamy windows ...
and if I have a nice blond in it it will definatly get STEAMY WINDOWS Stu This post has been edited by martin245: 30 Nov 2006, 19:57 |
- GB 1 Bessy Regs
mcv_rulez |
1 Dec 2006, 21:00
He hasn't garage. But je has a nice brunette...
CYA Dino |
Going to buy Dacia
Logan MCV
martin245 |
1 Dec 2006, 23:19
HEY
You are to young for these type of jokes LOL Stu |
- GB 1 Bessy Regs
mcv_rulez |
5 Dec 2006, 09:49
Going to buy Dacia
Logan MCV
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 3rd May 2024 - 20:22 |
