Audio - Difuzoare, RCAS,RCD, amplif. si altele, tot ce tine de modificari audio Logan
madkat |
#571
Alfa Romeo & VW
156 2.5 V6 & Bora TDI
GIC |
#572
![]() Doar membru Group: Members Posts: 930 Joined: 13 January 04 From: Oradea ![]() |
QUOTE(madkatweb @ 4 Aug 2005, 15:30) @ gic - ataseaza-i omului si partea din schema cu stecherele din usi - ca sa vada pozitia plusului si minusului - ca se prinde dupa orientarea in mufa (ca papucii sunt perpendiculari unul pe altul maine pot si eu sa atasez de la supernova dar nu stiu daca nu difera... @bassfreak - pune aparatul pe masura sa vezi ca fir din mufa corespunde carui fir din usa, stiind care e plus si minus in mufa (dupa schema) - asta ca sa nu te mai complici cu alte scheme etc... OK This post has been edited by GIC: 4 Aug 2005, 15:22 Attached thumbnail(s) mufa_dif.JPG ( Size: 93.5k ) Number of downloads: 308 |
madkat |
#573
despre asta vorbeam - bassfreak acum ai toate informatiile
Alfa Romeo & VW
VeNoM386 |
#574
![]() Membru autentic Group: Members Posts: 330 Joined: 7 September 04 From: Bucuresti ![]() |
PIO/P-RCA (IP-Bus to RCA)
Aveti idee unde gasesc asa ceva ? The Precision Interface Electronics PIO/P-RCA auxiliary input adapter is designed for use with Pioneer IP Series products. The adapter serves two functions: * converts the output (IP-BUS OUT) connection of the Pioneer GEX-FM903XM XM-Satellite tuner into stereo RCA outputs, avoiding the use of an FM modulator, gaining superior frequency response, and allowing connection to any receiver with auxiliary inputs; * converts the CD changer port of a Pioneer receiver to RCA input, allowing a variety of program sources to be added to the Pioneer receiver, including satellite radio tuner, DVD player, VCR/VCP, PlayStation™, or portable MiniDisc, MP3, or CD. The direct connection (without FM modulation) results in optimum sound quality. |
Citroen
C4
Champion 2007
bassfreak |
#575
sunt si eu interesat de asa ceva, in special pentru a putea folosi intrarea AUX prin intermediul unor mufe RCA.. |
B80VRG |
#576
Membru incepator Group: Members Posts: 7 Joined: 7 July 05 ![]() |
Are sau a avut cineva radio cd panasonic CQ-C3300N? Va intreb fiindca am posibilitatea sa-mi cumpar unul nou la 110 EURO, si din ce am vazut pe internet nu e prostut.
Dacia LOGAN
Preference
- B80VRG
madkat |
#577
este decent - este aproape intrarea de gama - nu are nici macar dot matrix la afisaj
la banii astia e ok daca e din magazin cu garantie, daca e de la cineva, chiar si nou e scump (a, si sper 110 cu tva etc cu tot, nu?) |
Alfa Romeo & VW
B80VRG |
#578
Nu e din magazin e de la cineva, insa e nou. O sa-i zic sa mai lase ceva la pret, dar in general e bun sa inteleg. |
Dacia LOGAN
Preference
- B80VRG
madkat |
#579
panasonicurile sunt ok, da, si daca mai lasa la pret poti sa il iei linistit
Alfa Romeo & VW
B80VRG |
#580
Dacia LOGAN
Preference
- B80VRG
madkat |
#581
daca ai putea sa le asculti inainte ar fi bine - oricum prost nu au cum sa sune
Alfa Romeo & VW
B80VRG |
#582
Stie careva cat sunt dif astea - JBL GTO 526e (13cm);JBL GTO 936e (6x9 100W RMS), la Tornado in Vitan, va vreau sa ma duc maine pe acolo sa le si iau. Daca tot imi iau panasonicul in seara asta.
Dacia LOGAN
Preference
- B80VRG
shefful |
#583
![]() Cititor de forum Group: Members Posts: 134 Joined: 14 July 05 From: Bucuresti ![]() |
As vrea sa-mi schimb si eu cd-playerul de pe Logan (nu datorita calitatii, care e decenta pentru mine), cat pentru faptul ca nu are fata detasabila. Caut ceva care sa aiba (in ordinea importantei):
-fata detasabila -acelasi tip de conectori (eventual daca exista adaptor) + acelasi sistem de prindere (nu vreau sa dau gauri) -functia "speed" (asa cum e ea pe cd-playerul original -mp3 -rds-af Ce imi recomandati? Zicea cineva de Blaupunkt ca s-ar potrivi... e valabil si pentru sistemul de prindere? Are vreun model functia "speed"? Multumesc This post has been edited by shefful: 8 Aug 2005, 11:18 |
Maybach
ZKR Ambition 1.6MPI
Sedan 2005
- Gri Perla
kurupt |
#584
![]() Membru autentic Group: Members Posts: 282 Joined: 29 May 05 ![]() |
Sunt curios ce face acest sistem Speed?
Sistemul de prindere este standardizat, adica DIN, sunt si aparate care sunt de doua ori mai mari dar nu prea se gasesc la noi, si oricum nu ne intereseaza ![]() Daca ai casco, mai bine asteapta pana te "ajute" cineva, si pe banii obtinuti poti sa iei un aparat bunicel ![]() |
Ambiance
- ##### --=-- The KING Of The Hill --=--
shefful |
#585
"speed" este o functie a aparatului care regleaza volumul in functie de viteza masinii. Vezi aici: http://www.daciaclub.ro/index.php?showtopic=10070
Nu am montat niciodata un casetofon insa, desi dimeniunile sunt standard, ma indoiesc ca sistemul de prindere in bord este identic (nu cred ca toate casetofoanele au sistemul "mine de pix" ![]() |
Maybach
ZKR Ambition 1.6MPI
Sedan 2005
- Gri Perla
#586
QUOTE(kurupt @ 8 Aug 2005, 11:49) Sunt curios ce face acest sistem Speed? Sistemul de prindere este standardizat, adica DIN, sunt si aparate care sunt de doua ori mai mari dar nu prea se gasesc la noi, si oricum nu ne intereseaza ![]() Daca ai casco, mai bine asteapta pana te "ajute" cineva, si pe banii obtinuti poti sa iei un aparat bunicel ![]() Sunt si eu curios daca ai citit pagina 21 din manualul de utilizare al casetofonului... PS: Citirea manualelor de utilizare nu dauneaza nici sanatatii fizice, nici celei mentale... |
shefful |
#587
Klaus, omul zice ca e in asteptare Loganul lui, deci probabil inca n-are manualul ;-)
Maybach
ZKR Ambition 1.6MPI
Sedan 2005
- Gri Perla
#588
Da, corect, mea culpa...
Dar... http://www.daciaclub.ro/index.php?showtopic=23237&hl= http://www.daciaclub.ro/index.php?showtopic=10070&hl= Iaca, ca discutii se mai dusera... |
shefful |
#589
Ce am mai aflat intre timp (probabil se stie deja, dar pentru mine sunt noutati - iar daca gresesc va rog sa ma corectati): mufa de la cd-playerul de pe ambition este ISO, iar sistemul de prindere este standard DIN (nu degeaba sarmele in forma de U pentru scoaterea aparatului se cheama "DIN-tools"). In concluzie orice cd-player din zilele noastre se poate monta in 5 minute pe Logan
Maybach
ZKR Ambition 1.6MPI
Sedan 2005
- Gri Perla
kurupt |
#590
Da inca mai astept masina
![]() ![]() ![]() Functia asemanator ca si speed, au destul de multe cd playere, numai ca se cheama altfel,asta mai bine intrebi la magazie de unde vrei sa le cumperi, iar pt montare nu trebuie sa faci probleme, fiecare firma foloseste sistem de prindere relativ simplu, de ex la playere alpine nu ai nevoie de mine de pix, ai nevoie de surubelnita. Sistemul e asamanator, numai din cauza ca se poate lua jos fata la player, se foloseste sistemul cu cleme, care se desface simplu cu ajutorul surubelnitei. |
Ambiance
marius_rg |
#591
Membru incepator Group: Members Posts: 1 Joined: 9 August 05 ![]() |
Salutare.In primul rand vreau sa mentionez ca sunt nou pe acest forum si as dori sa va intreb ce parere aveti despre combinatia:
Sony CDX-2220 http://www.mediaonline.de/shop/product_500...9858_5000.13004 si, pe spate Clarion SRS1325 -------------------------------------------- # In-Line –6 dB/Okt.-Frequenzweiche # Musik-Spitzenbelastbarkeit : 180W # Dauerleistung: 40W # Fs : 75Hz # Qts : 0.69 # Vas : 4.6Liter # Frequenzgang: 40 ~ 35.000 Hz # Wirkungsgrad: 90 dB/W/m -------------------------------------------- Si inca o rugaminte.Daca se poate sa-mi spuneti care ar fi o montare cat mai optima(in sensul,contact direct pe tabla,mocheta/tabla....) orice m-ar putea ajuta in ideea asta. This post has been edited by marius_rg: 9 Aug 2005, 16:18 Attached thumbnail(s) SRS1325_Eu_01.gif ( Size: 40.93k ) Number of downloads: 211 |
Logan-Preference
- PH-30-ELY
SUPERCAR |
#592
![]() Membru autentic Group: Members Posts: 624 Joined: 6 June 05 From: Constanta ![]() |
Pana la urma mi-am cumparat aceste boxe pentru usile fata Infinity 52.7i
Speaker Size 13 cm Design 2-Way Sensitivity 94 dB Frequency Response 55 Hz - 25 kHz Peak Power Handling 165 watts RMS Power Handling 55 watts Impedance 2 ohms 9816908.jpg Iar pe spate Infinity REF5000cs astea luate de aici Frecventa de taiere - 3.5 kHz Impedanta nominala - 4 ohm Putere de iesire RMS - 75 W Raspuns in frecventa - 67 Hz - 21 kHz Sensibilitate - 92 dB (2.83 V @ 1m) REF5000CS.jpg This post has been edited by SUPERCAR: 13 Aug 2005, 21:11 |
1.5 dCI Martie 2007 Euro4 - 70CP@90CP
- CT 82 PWR
Boggy |
#593
![]() Membru Group: Members Posts: 180 Joined: 5 May 05 From: Bucuresti ![]() |
NU POT SA CRED:
am achizitionat un Cd-Player Sony Xplod CDX-R3350 de la selgros si cand am fost la reprezentanta (Rent Car Constanta) nu au vrut sa mi-l monteze deoarece nu era cumparat din reteaua Dacia (desi aveau exact acelasi model sub ochii mei cu 3 milioane mai scump) ... chipurile nu corespunde, este diferit si alte balarii ... si mi-au zis ca pierd garantia pe toata partea electrica daca il monteaza ... e normal asa ceva? eu nu cred ... ce sa fac? innebunesc ![]() |
Laguna III
2.0dCi 150cp
madkat |
#594
vocea clientului - dar verifica sa fie si indicativul aparatului EXACT acelas la reprezentanta - pentru ca aacum exista cateva modele de soni care arata aproape la fel dar sunt oleaca diferite (evindent acele mici diferente nu justifica ce zic ei dar oricum e bine sa fii acoperit sa le zici celor de la VC ca e ACELAS model)
bafta |
Alfa Romeo & VW
#595
![]() - Group: Members Posts: 22.635 Joined: 19 April 05 From: Romania ![]() |
Intreaba la VC. Nu cred ca este normal sa se intample lucrul acesta.
eqqie |
#596
Membru incepator Group: Members Posts: 2 Joined: 16 August 05 ![]() |
In concluzie care ar fi cele mai bune boxe de 13cm pt. fatza pana in 1.700.000?
Imi voi lua un Pioneer DEH-4700 MP si nu stiu la ce boxe (de fatza) sa ma opresc. Stie cineva cum sunt TS-G1348 : http://www.magazinultau.ro/product_id/9469...ER-TS-G1348.htm Sau asi lua TS-A1311 dar nu stiu daca se potrivesc pe usile din fata Logan ... ca nu vad nici o gaura de prindere http://www.pioneer-eur.com/eur/product_det...onomy_id=25-131 A montat cineva TS-A1311 pe fatza ? This post has been edited by eqqie: 16 Aug 2005, 14:25 |
Ambiance 1.4 MPI
- 123
VeNoM386 |
#597
Eu le am TS-A1310 si vin perfect.
Citroen
C4
Champion 2007
drakool21 |
#598
![]() Membru autentic Group: Members Posts: 238 Joined: 10 July 05 From: Bucuresti ![]() |
eqqie, dintre difurile de 13 TS-A1311 sunt cele mai bune (parerea mea) dar nu cred ca le gasesti pana in 1.700.000...seria TS-A sunt destul de scumpe...
eu zic totusi sa iei TS-G1348...sunt foarte bune...si poti sa ai incredere si in magazinultau.ro, eu am luat de mai multe ori de la ei si am fost super multumit de fiecare data...iti aduc la usa tot ce comanzi in maxim 24 de ore... bafta |
Dacia / SEAT
1310 / Ibiza
1999 1,4l carburatie / 2006 1,4l TDi
- B-nn-XXX In Trance We Trust
DigitalScribe |
#599
Ma bate un gand sa-mi schimb RCD-ul cu ceva de aici: http://www.mini-box.com/
Un mini PC de forma RCD-ului. Dispare si interfata care da de gol ca ar fi un aparat bun de furat acolo si cu un adaptor wireless ceva pe USB poti incarca muzica in masina de acasa ![]() Baietii au si surse de alimentare specializate pentru auto cat si adaptor de intrerupt curentul la mini-PC in caz ca-l uiti deschis sa nu se descarce bateria. Ar fi interesant de montat si niste senzori pe portiere, buson, capota motor si portbagaj pe care sa le poti monitoriza de acasa de pe PC prin wireless, eventual si un webcam ceva sa arunci din cand in cand un ochi in strada ![]() Ai putea face inregistrari video de la vreun web-cam ceva montat pe botul masinii sau undeva lipit cu niste ventuze de parbriz la traseul parcurs (calitate mai slaba + un hdd mai marisor). Ar putea fi si un soi de cutie neagra a masinii in afara de faptul ca poti reda mp3-uri cu el si alte chestii din categoria divertisment. O interfatare la computerul masinii ar fi iarasi ceva interesant desi ar fi dificil din cauza lipsei de acces la documentatia proprietara folosita. Avand PC-ul integrat in masina se poate merge si la idei mai "salbatice" precum ecrane LCD incluse in tetiere / bord si asa mai departe. Car kit: http://www.mini-box.com/s.nl/c.ACCT127230/.../category.94/.f $219.90 Sunt si alte chestii mai ieftine si mai economice ca si consum electric precum: http://www.mini-box.com/s.nl/sc.8/category.15/it.A/id.212/.f $98.00 Sunt curios ce idei va starneste voua posibilitatea asta de a include un mini-PC in masina. P.S.: Ideea asta cred ca se poate aplica la orice masina nu neaparat Logan (asta ca sa nu apara iar carcotasii si sa se lege iar de Logan). Intamplator viitoarea mea masina va fi Logan. This post has been edited by DigitalScribe: 16 Aug 2005, 16:48 |
Renault Espace V
Renault Zoe
D-Max 2022
- n/a
eqqie |
#600
multumiri de tips drakool21 si VeNoM386
am gasit TS-A1311 la ~ 1.7 mil aici: http://www.amazon.de/exec/obidos/ASIN/B000...4897777-5580800 nemtii au reduceri pe bune 45% nu praf in ochi ca la noi ... acuma trebuie sa mai gasesc un prieten in Germania ![]() |
Ambiance 1.4 MPI
- 123
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 17th June 2025 - 22:07 |
