> Logan's AC
Aleksandar
post 19 Jun 2007, 16:36
I have noticed that when I start the AC in my Logan a clear "click" sound can be heard which disappears instantly after the AC starts working (as if the AC is kicked into work). During the AC work there are no problems whatsoever and it works really fine. The abovementioned sound is not heard when the AC is being turned off. Again, I have not faced any problems with AC functioning and quality of work or noise during its usage apart from this initial sound.
Anyone that can explain this?
Thanks
Dacia Logan 1.4MPI Laureate 2006, Aegean Blue
post 19 Jun 2007, 19:56
Is the AC compressor clutch. Is no problem.
Keka
post 20 Jun 2007, 14:10
Logan driver :P
I have other problem....On a really hot day, when outside temperature is over 30 C, when I turn AC on, it makes funny noises between 2000 and 3500 rpm, something like RRRRRRR.
Guys in service checked it and said that everything is OK.
When outside temperature is lower, it is quite quiet.
Does anybody have an idea or some expirience with this?
Dacia Logan 2004 1.6 MPI Laureat pack LPG by Dora - Kadett 1.6D 1983
look
post 20 Jun 2007, 15:42
Yes, the same problem is going on with my AC.
In the service they also sad everythink is OK
Dacia Logan laureate - 1.4
dantes
post 22 Jun 2007, 12:41
You have to go into a service and check the fluids from A/C system. You must have 145ml of compressor oil and 750 of cooling agent, if i remember right.
It's possible that you have less oil than normal, or almost minimal.
Good luck
O masina oarecare . - .
Old school
Keka
post 22 Jun 2007, 21:17
Logan driver :P
As soon as I come home, I'll have those levels checked.......but I wonder how much will that cost mad.gif
dantes
post 23 Jun 2007, 08:36
If the levels are not correct, nothing if it's in warranty time, if they are correct it should be around 25-30 euros... There are services that for this operation don't charge a penny if it's in warranty time...
It's best if you ask your local dealer.
Old school
Amedeus
post 23 Jun 2007, 17:49
Membru cu Logan
From Sanden:
The compressor (like any other machine) creates noise. Noise level inside the vehicle depends on many factors rather than compressor’s NVH level itself.
A proper design of the A. C system (compressor bracket, hoses, pipes, HVAC insulation, etc.) is key to avoid noise.
Abnormal A.C. Noise
WITH CLUTCH UN-ENGAGED.
Armature contact with pulley. -> Replace clutch.
Pulley oscillation due to external hit.-> Replace clutch.
Pulley contact with foreign element -> Remove contact
WITH ENGAGED CLUTCH.
Incorrect refrigerant amount -> Verify charge.
Liquid refrigerant arriving to compressor -> Check expansion valve.
Pipes/hoses contacts with vehicle body-> Remove contact
Clutch slippage due to oil -> Remove compressor.
Particle under discharge valve -> Pressures are quickly balanced when AC stops.
Internal compressor damages -> Replace compressor
Keka
post 26 Jun 2007, 17:30
Logan driver :P
26.06.2007. 17:23 CET outside temperature 33 C smile.gif
I just came from Dacia service in Beocin. They took a look at my noisy AC, and said that everything is OK and that I have no need to worry and to enjoy cool air bla bla bla....Nobody checked oil and refrigerant level although I said that I saw on Dacia forum something about that issue. I paid nothing for this.
If they checked levels, that costs 3500 RSD (some 45 E), because in order to check oil level, they need to empty refrigerant.
So, what is next? To write to Renault Serbia or to drive like this? I have no warranty any more. Or to go to some independent AC service?
Or to drive trough city and imagine I'm driving big John Deer sounding RRRRR radmasa.gif
C@talin
post 26 Jun 2007, 18:56
martin245
post 26 Jun 2007, 21:42
EX PAT
dacia logan 14 mpi Simply RED 2007 - GB 1
Bessy Regs
Keka
post 27 Jun 2007, 14:01
Logan driver :P
27.06.2007. 13:59 27 C
I just returned from Belgrade.....Today the temperature is lower than testerday, and AC was quiet today smile.gif
paykan
post 18 Jul 2007, 18:25
Hi from Germany !
I have faced the same problem two days ago.
The "RRRRRRRRR" sounds like plastic is scratching somewhere.
I think I will visit my Dacia Dealer soon. I am really afraid of damage.
And with guarantee...
So lets see what will happen ...
You hear from me
Paykan
Dacia Logan Sedan 2006 1,4 MPI Ambiance - -
Proud to be a Dacia driver !
dizzy
post 18 Jul 2007, 18:29
Work smart not hard!
Relax guys,
Mine does this sound for the last 60 000 km and 2,5 years.
It will work okay, only some noise
marksman
post 19 Jul 2007, 10:32
Post mortem nihil est
The "RRRR" noise seems to be related to very high temperatures. When the outside temperature is >35-38 deg. Celsius my car's A/C begins to make that noise. I have driven last night with the A/C on (the temperature was about 28-30 deg. Celsius) and there was no "RRRR" noise.
Nick Ușor
gxg86
post 19 Jul 2007, 10:49
when i start my AC i hear some "clicks" for a period of time(1-2 minutes). it's sound a "click" at 3-5 secs for about 2 mins,and at every click the engine tends to accelerate.What can it be?
DACIA LOGAN ABS Plus
marksman
post 19 Jul 2007, 13:05
In 1st gear or in reverse, when the rpm is low (below some minimum threshold), the A/C compressor will disengage and then engage back when the rpm reaches minimum threshold. When it starts back up the fuel injection computer automatically adjusts the rpm to compensate the power surge caused by the A/C compressor.
Nick Ușor
martin245
post 19 Jul 2007, 13:10
EX PAT
I am pleased that i didnt get the AC i open the windows at the back and it is lovely
Just got back from England again in my New Dacia logan 14mpi lauri (again)
Stu
Bessy Regs
HenkM
post 19 Jul 2007, 13:59
Our 1998 Laguna's airco sounds the same for 9 years now.
The click sound is the clutch, the Laguna's airco is "controlled" (no climate control) and switches on/off while operating (to minimize fuel consumption it will not "overcool").
The "hissing" sound is caused bij de expanding gass over the expansion valve (expansion needs energy and this is why the system is able to cool the air).
Dacia Logan MCV 1.6 16V 7p 2007
Braveheart
post 19 Jul 2007, 19:36
From my point of view the noise of de A/C sucks big time but it's not so much to do about this. Just cheking from time to time the fluides, the radiator and...try to put some loud music biggrin.gif. Anyway it's better than nothing sad.gif
This post has been edited by Braveheart: 19 Jul 2007, 19:47
Dacia Logan 1,6 MPI 2006 Laureat
The answer my friend is blowing in the wind
nh1980ro
post 19 Jul 2007, 20:45
Don't worry about the grinder sound. It does the same to some more expensive cars.
If the A/C makes it cool, then step the gas and don't worry about it.
This noise is made at high temperatures (above 30 Celsius usually).
@gxg86 When you press the A/C button (first turn on the ventilation system), you should hear only one click (usually the rpm changes a little bit when your car is stopped, but the engine running). If the A/C goes on and off a few times when you try to start it maybe there is a problem with it. You should go to service to check it out.
g100sic
post 19 Jul 2007, 23:40
The temperatures have been around (and over) 40 deg. C these days in Serbia, and probably in the whole southern Europe! Boy am I glad I have an AC in my Logan (and Stu, you would be glad to, I'm certain!), and I don't care if it clicks, grinds, squeals, or whatever sound it makes, it may even bark if you ask me biggrin.gif, I wouldn't mind as long as it does what it is supposed to do - keep me cool! And I can not tell enough how useful it was in the ever scorching hot Podgorica valley, when I was traveling to and from my vacation some month ago!
Yes, it is loud, but it is only noticeable when the outside temperatures are well over 35 deg. C, which means that temperature inside the car may reach even 50 deg., and over, so I suppose that the AC compressor is pushed to it's limits under such conditions. Not to mention that it is a budget Dacia, not a Mercedes or BMW or Volvo! Isn’t it good enough just that we can have it at all for less then 10000 EUR?!
Recently I had an opportunity to drive in a new Fiat Grande Punto and to compare it's behavior to Logan's. I noticed that the noise from the engine was less loud than in Logan (especially if taken into account that it runs at higher revs than Logan), so it can be concluded that Logan has worse sound insulation between the passenger space and the engine, which is probably why it's AC can be heard so loud in the cabin. But, I can also tell you that the noise of the wind and rolling tires was louder in Punto than in Logan!
Ford Fiesta 1.4 (96 HP) 2010 / Trend (Flex Pack 11)
Never argue with a fool -- people might not notice the difference! (Murphy's First Law of Debate)
heinz57g
post 24 Jul 2007, 10:13
IN PAT
we have almost 20 logans in our fleet (10 of our own, one personal, 9 with a sister company), most of the 1.4 MPIs, and ALL of them have
the same RRRRRR sound and the clicking of the aircon at high (34++ C) temperatures. and as i have now heard the same from so many people,
i guess it is really nothing to worry about.
when the aircon kicks in and out, shortly after starting, there is also a noticeable loss of power on the engine, more on the 1.4 then on the others.
but this again is logical, as the aircon needs some 5+ horsepowers for a few seconds during start (going back to 2 during normal operation), so
however noticeable and unpleasant, also totally normal and not to be worried about.
greetings - heinz -
DACIA LOGANs, several 2004 - 2008
There is nothing wrong with change, if it is in the right direction. Thats why the British drive on the left.
Keka
post 16 Aug 2007, 00:06
Logan driver :P
Few days ago someone stole mine radio-antenna. I got so pissed......because I had to go to Subotica to buy another one, there are no available in Novi Sad. And it costs 945 RSD excl.gif But, something good happened then biggrin.gif I asked in AK Vidakovic about RRRR AC and they told me to come in the morning, they are familiar with that problem and it can be easily solved. So I came next morning, guys did something with it, but haven't revealed secret to me, and there is no more RRRR sound radmasa.gif I think that they mentioned that problem was in the AC clutch, not oil levels etc.......Repair took some 15 minutes, and I paid NOTHING for that, although I have warranty no more excl.gif
Maybe this sound like commercial, but I'm very very pleased with those guys from AK Vidakovic Subotica icon_mrgreen.gif
marksman
post 16 Aug 2007, 09:08
Try an antenna from Peugeot Partner. The thread of the bolt is identical. The Peugeot Partner antenna is cheaper (at least here in Romania).
Nick Ușor
nh1980ro
post 16 Aug 2007, 11:15
Try to tighten the antenna using pliers or a wrench if it has a nut head. So they can't take it using their bare hands.
Can you describe what they did to your A/C clutch?
Did they use any components or they just adjusted something there?
Keka
post 16 Aug 2007, 19:14
Logan driver :P
I really wanted to stay there and watch what guys are doing with it, but they were polite and asked me to be in waiting room, so I haven't seen what they did........I suppose they used no spare parts and all they did was some fine tuning in the AC clutch. Also I saw that funny machine for refrigerant filling near my car, but can't say if they used it.....Anyway servicers are supposed to exchange informations right? cool.gif
I bought antenna for LGN, and it is right now on back seat of my car radmasa.gif just in case......these days I'll for sure tighten it so nobody can remove it again.....ever icon_mrgreen.gif
prody
post 16 Aug 2007, 21:04
membru iradiat
We also had such "wonder repairs" on our AC here in Romania . It will only last for a couple of days, then the RRRR sound wil come back again as mighty as ever.
They just adjusted the fluids, nothing more.
This post has been edited by prody: 16 Aug 2007, 21:04
Mazda 3 2011 TX
Keka
post 17 Aug 2007, 16:33
Logan driver :P
MiticaLGN
post 26 Aug 2007, 15:24
A lot of Logan owners here in Romania have that RRRRRR sound from the air condoning when it's hot outside. Dacia dealer told me that it is ok and there is no reason to worry but for me it seems like a design problem.. I've never encounter any other car to behave like this. I'm wondering if all of those AC compresor will fail in 2 years, let;s say so, what Dacia will tell? "Don't worry, it's normal! " smile.gif
Logan Prestige KIA CEED SW BEST 2007
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 26th July 2025 - 07:28
