450 Pages « < 401 402 403 404 405 > »
> Despre PC-uri, Orice "probleme"
yhattori
post 26 Feb 2014, 16:48
Post #12061
ca s-a spart USL-ul!
post 26 Feb 2014, 17:15
Post #12062
E bibelou?
daniM
post 26 Feb 2014, 17:20
Post #12063
QUOTE(yhattori @ 26 Feb 2014, 14:14)
care-i diferenta dintre reballing si reflow?
Reballing am facut la al meu si au inlocuit pastilele alea de plumb(plm),la reflow doar le topeste .Diferenta si de pret
<span class='edit'>26 Feb 2014, 17:24:</span>
QUOTE(4x4 @ 24 Feb 2014, 20:09)
1.Laptopu cand l-am dus lua bluescreenuri de la placa video.
Dupa 120 ron, laptopu continua sa ia bluescreenuri, cei drept la frecvente la care inainte era stabil. Nui bai, ma asteptam sa dea fail reballul oricum.
La 120 nu e reball,a dat cu foehnul nevesti-sii de doua ori peste.Eu la reballing de 350 ron am garantie 6 luni;deocamdata merge ca migu.Reflow se face si acasa la cuptor ,la 200 si ceva de grade,exista tutoriale
This post has been edited by daniM: 26 Feb 2014, 17:25
. . . - Skoda Octavia
post 26 Feb 2014, 17:35
Post #12064
Cuptor pe gaz?
daniM
post 26 Feb 2014, 17:42
Post #12065
Cica decat pe microwaves sa nu fie,caldura si gradele conteaza
yhattori
post 26 Feb 2014, 18:04
Post #12066
QUOTE(ady77 @ 26 Feb 2014, 17:15)
E bibelou?
swarowski filipinez
Post #12067
QUOTE(daniM @ 26 Feb 2014, 17:42)
... caldura si gradele conteaza
minim căpitan.
This post has been edited by gabize: 26 Feb 2014, 18:05
daniM
post 26 Feb 2014, 18:07
Post #12068
Cu 6 stele
Alydor
post 26 Feb 2014, 18:23
Post #12069
Pressar
Da' ce ... e coniac?
Suma respectelor, Alydor
Igo8 - C520
When everything fails, RTFM!
daniM
post 26 Feb 2014, 18:25
Post #12070
Metaxa Marcosesc
post 26 Feb 2014, 18:45
Post #12071
QUOTE(daniM @ 26 Feb 2014, 18:25)
Metaxa Marcosesc
post 26 Feb 2014, 18:54
Post #12072
L-a cunoscut pe Alexandros Alexandrionos asta vara. S-au impacat.
daniM
post 26 Feb 2014, 18:55
Post #12073
K este asijderea litera greceasca.Ar trebui sa se impace si cu ea
This post has been edited by daniM: 26 Feb 2014, 18:56
4x4
post 28 Feb 2014, 21:28
Post #12074
Übermensch
QUOTE(4x4 @ 21 Feb 2014, 17:55)
Am un singur pixel mort/blocat, pot returna produsul?
De asemenea mi se pare ca am o crapatura langa butonul de power, dar pot trai cu asta urmatoarele 12 luni pana se topeste placa video si ma folosesc de garantie  laugh.gif
Metode recomandate de deblocat pixelu, ceva?
Update:
Am aflat ca nu am destui pixeli morti ca sa beneficiez de garantie. Iar crapatura de pe carcasa e considerata un defect optic. Bine ca are garantie 4 ani.
showfinger.gif Maguay
W S S
Attere Dominatum!
Lord Hades
post 3 Mar 2014, 08:06
Post #12075
Memento Mori
Se da urmatoarea problema:
Roter Asus, nou noutz. Configurat ca la carte, conexiune la net prin RDS, verificata cu smartphone (2 buc).
Reteaua WiFi detectata cu semnal bun de laptop, conexiune stabila, comunicare prin WiFi laptop router OK, lipsa totala de net pe laptop!
Se cere rezolvarea.
post 3 Mar 2014, 08:17
Post #12076
Oprește firewall-ul (nativ windows sau al antivirusului) de pe laptoapă. Dacă fenomenul dispare, tre' să vezi ce setări ai pe acolo aiurea.
Dacă nu...
Lord Hades
post 3 Mar 2014, 10:09
Post #12077
Memento Mori
nu e din firewall. efectiv nu vede conexiunea la net prin WiFi ...
Tince1290
post 3 Mar 2014, 10:13
Post #12078
Membru cititor
....greseala
This post has been edited by Tince1290: 3 Mar 2014, 10:14
post 3 Mar 2014, 10:24
Post #12079
QUOTE(Lord Hades @ 3 Mar 2014, 08:06)
Se cere rezolvarea.
QUOTE(Lord Hades @ 3 Mar 2014, 10:09)
Andy_ACS
post 3 Mar 2014, 10:39
Post #12080
Yes, I'm not!
Adica are ping in router dar nu are ping intr-un ip din exterior (yahoo.com)
Ai IP prin DHCP?
Ai gateway setat corect?
Ai DNS setat corect?
post 3 Mar 2014, 10:46
Post #12081
Ai șapcă?
4x4
post 3 Mar 2014, 11:44
Post #12082
Übermensch
Tu zici ca esti connected dar nu ai internet access right?
Incearca protocolul wep la router.
W S S
Attere Dominatum!
Lord Hades
post 4 Mar 2014, 11:06
Post #12083
Memento Mori
Dificil de explicat.
Router OK, WiFi OK, net OK probat cu telefoane mobile!
Pana aici e clar?
Conexiune laptop retea WiFi OK, pot accesa meniul routerului prin WiFi (ca si pagina web daca intru direct pe IP gen 189.206.1.1).
Lipsa net pe laptop.
Uneva lipseste o chestie in laptop, dar sa mor daca ma prind ce anume. Pe alta retea WiFi merge netul de pe acelasi laptop.
Idei?
DragosP
post 4 Mar 2014, 11:27
Post #12084
Nu zic nimic...nou
Da.
Pune-i manual cu mâna: IP, DNS, GATEWAY.
IP-unul nefolosit , ceva cu 200 și ceva-n coadă, gen: 192.168.0.234 (de exemplu). Evident, în clasa de IP-uri pe care o servește routerul tău.
Celelalte, DNS și GATEWAY ia-le ca atare din ce-ți zice routerul.
Ceva de plastic . . - BRRC
Cu noi este Dumnezeu!
Altis
post 4 Mar 2014, 11:28
Post #12085
Restrictie din router pentru laptop? Adica e setat routerul sa nu permita accesul laptopului la net din firewall, prin IP sau mac?
Edit: Asta vroiam sa adaug si eu, aloca-i manual un IP.
This post has been edited by Altis: 4 Mar 2014, 11:33
Tucson JM 2007 - .
Luati saitu' de cultura si bagati-l in duba sa-i acordam "primul ajutor"!
post 4 Mar 2014, 11:48
Post #12086
QUOTE(Lord Hades @ 4 Mar 2014, 11:06)
Idei?
Sigur WiFi pe laptop e configurat cu IP address automatically (IP dinamic) și DNS server address automatically?
DragosP
post 4 Mar 2014, 11:54
Post #12087
Nu zic nimic...nou
Cel mai probabil...nu.
Lord Hades
post 4 Mar 2014, 14:01
Post #12088
Memento Mori
La mine acasa pe WiFi a mers totul din prima. Laptopul cu pricina de care povestesc s-a conectat fara dubii.
Ma asteptam sa mearga la fel de easy si cu noul router; se pare ca tre sa mai bibilesc si sa mai invat chestii smile.gif
post 4 Mar 2014, 14:14
Post #12089
START - Control Panel - Network and Sharing Center
Change adapter settings
Click dreapta pe conexiunea Wifi din panoul din dreapta - Properties
Dublu-click pe Internet Protocol Version 4 (nu pe bifă, pe nume, și ai grijă să rămână bifat!)
Te asiguri că ai bifate Obtain an IP address automatically și Obtain DNS server address automatically
OK - OK - ...
post 3 Apr 2014, 12:08
Post #12090
8 aprilie, la Microsoft:
- end of support pentru XP
- idem pentru Office 2003
- se lanseaza Win 8.1 Update
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 17th June 2025 - 00:29
