Despre PC-uri, Orice "probleme"
AR-18-MOS |
#12451
BMW
730Ld
'07 High Executive
DannyY |
#12452
Uite solutia.
Opel/Honda/Opel
Astra G/Civic 4D/Corsa E
2004/2015/2019
marksman |
#12453
Post mortem nihil est Group: Members Posts: 7.705 Joined: 1 November 04 From: sat ![]() |
QUOTE(diaconuliviu @ 7 Jan 2015, 09:51) O fi locul aici? N-o fi? Probleme cu un stik Kingston. Am date pe el dar de cite ori il vir in port ma invita la formatare. Datele extrase despre el ar fi: Volume: F: Controller: SSS 6696 B9 Possible Memory Chip(s): Hynix H27UCG8T2B Memory Type: MLC Flash ID: ADDE94EB 7444 Flash CE: 1 Flash Channels: Single VID: 0951 PID: 1665 Manufacturer: Kingston Product: DataTraveler 2.0 Query Vendor ID: GENERIC Query Product ID: USB Mass Storage Query Product Revision: 1.00 Physical Disk Capacity: 0 Bytes Windows Disk Capacity: 0 Bytes Internal Tags: 386D-QAD2 USB Version: 2.00 Declared Power: 100 mA ContMeas ID: 70CF-01-00 Microsoft Windows 7 SP1 x64 ------------------------------------ http://www.antspec.com/usbflashinfo/ Program Version: 8.0.0.550 Pe la rusi am incercat, la sfaturile cuiva, nimic. Pt SSS6696 se pare ca (pina acum) nu e solutie. Am mai resuscitat citeva stik-uri cu diverse 'scule", dar pe asta nu-l citeste nimic.. Poate aveti voi o solutie. Bagat intr-un sistem cu Linux, ce zice? |
Opel / Mazda
Crossland X / CX-30
2019 / 2020 Nick Ușor
DragosP |
#12454
Că-l înjuri.
Ceva de plastic
Cu noi este Dumnezeu! |
Markos |
#12455
Megan
DragosP |
#12456
sit back and relax.
Ceva de plastic
marksman |
#12457
Opel / Mazda
Crossland X / CX-30
corbex |
#12458
Dupa reformatare poa' sa mearga, sa mearga o vreme sau sa mearga foarte putina vreme.
2005, cheala
vioara |
#12459
Membru autentic Group: Members Posts: 212 Joined: 1 November 07 From: Bucuresti ![]() |
Am scos placa video sa vad ce model este si cand am pus-o la loc nu o mai vede pc-ul, zice: reboot and select proper boot device
or insert boot media in sected boot device and press a key. Cum as putea rezolva problema ? |
Clio 1.5
marksman |
#12460
QUOTE(vioara @ 7 Jan 2015, 15:15) Am scos placa video sa vad ce model este si cand am pus-o la loc nu o mai vede pc-ul, zice: reboot and select proper boot device or insert boot media in sected boot device and press a key. Cum as putea rezolva problema ? Conectand la loc cablul de date sau de alimentare al harddiscului. |
Opel / Mazda
Crossland X / CX-30
vioara |
#12461
M-am uitat la fire si par toate la locul lor.
Clio 1.5
corbex |
#12462
![]() Verifica daca ai pus-o corect, adica o scoti si reintroduci cu grija, la fel si cablul de date. This post has been edited by corbex: 7 Jan 2015, 15:25 |
2005, cheala
Markos |
#12463
Par, dar nu sunt. Mai împinge mufele alea de la harddisk.
Megan
gabize |
#12464
![]() DECONECTAT Group: Members Posts: 6.020 Joined: 21 July 08 From: ©City of Mini Roundabouts ![]() |
⚓ Am avut
cândva o... barcă...
acum doar un gândac H247 "Unde poți lega cu sârmă, e păcat să pui șurub!"
diaconuliviu |
#12465
Corsa
bmwh548 |
#12466
QUOTE(vioara @ 7 Jan 2015, 15:23) Uita-te mai insistent si daca tot nu merge uita-te si la bacteria BIOS-ului (cu alimentarea de la sursa scoasa de pe placa de baza/PC-ul scos din priza, apasat scurt pe butonul de start sa se descarce condensatorii si apoi revii la uitatul insistent la baterie). |
vioara |
#12467
Ce ar trebui sa se intample cu bateria in situatia asta ?
Rezolvarea era aici https://www.youtube.com/watch?v=6CeXX2NfIAY |
Clio 1.5
Markos |
#12468
N-ai zis că ai mai multe diskuri.
Megan
vioara |
#12469
Nu m-a intrebat nimeni...oricum nu stiam daca are importanta.
Clio 1.5
Markos |
#12470
Păi are. Pisiul tre'să știe de pe care butează.
Megan
Bicicleta galbena |
#12471
![]() Sunt nembru, domnule! Group: Members Posts: 2.193 Joined: 29 January 13 From: Bucuresti ![]() |
Doi probleme am:
1. A trebuit sa reinstal Win XP SP2 pe hardul 1 (sa zicem), dar acu nu mai vede hardul nr. 2; in BIOS il vede, in Device manager la fel; o fi de la mufa de alimentare a hardului, scoasa pe perioada instalarii Win? 2. Am pierdut deja multa muzica de pe hard; exista vreun cloud pe care sa uploadez vreo 200MB ? |
Peugeot
407 1.8 16v
Markos |
#12472
Megan
Bicicleta galbena |
#12473
cum il reactivez? am doar optiunea "Convet to basic disc" si-mi comunica "all data will be lost" ... exact ce nu vreau
Peugeot
407 1.8 16v
kato |
#12474
Membru autentic Group: Members Posts: 236 Joined: 17 October 06 From: barlad ![]() |
asa zice el, dar se pot recupera datele, important este sa nu scrii nimic pe el dupa aia
renault
scenic
2000 rxt - scenic III 1.6 dci
- vs 05 glx vs 79 glx
Bicicleta galbena |
#12475
![]() adica? cum recuperez datele daca nu-i vad continutu'? |
Peugeot
407 1.8 16v
kato |
#12476
datele de pe un hard disck se pot recupera chiar si dupa formatare. sunt o gramda de programe care fac treaba aceasta
renault
scenic
bmwh548 |
#12477
Ai avut un motiv special sa scoti un hard la instalare? Ai putea sa incerci reinstalarea sistemului (cu ambele harduri active) sau sa scoti hardul si sa-l pui pe alta unitate. Daca aia il vede copii chestiile vitale pe un stick mare/hard extern si pe urma nu te mai intereseaza ce face Windows-ul cand il activeaza.
QUOTE(vioara @ 8 Jan 2015, 20:33) Ce ar trebui sa se intample cu bateria in situatia asta ? Rezolvarea era aici https://www.youtube.com/watch?v=6CeXX2NfIAY Duci rationamentul pana la capat si iti dai seama ca sugeram un reset de BIOS. |
Bicicleta galbena |
#12478
Hardul nu l-am deconectat eu, ci unul la care l-am dus; si eu dobitoc am vazut faza, insa l-am lasat asa - se pricepe el mai bine! In fine, o sa fac asa cum ai spus - scos hardu si pus pe alt pc.
Peugeot
407 1.8 16v
#12479
fratilor ma intereseaza si pe mine driverele pentru easynote alp-ajax c2 eventual pentru win 7 32
ca am cautat de mi-a sarit ochii This post has been edited by bygy007: 11 Jan 2015, 11:50 |
CAPTUR E-Tech full hybrid 145
2024
gabize |
#12480
Aici ai încercat?
⚓ Am avut
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 14th June 2025 - 11:01 |
