450 Pages « < 443 444 445 446 447 > »
> Despre PC-uri, Orice "probleme"
iulia_boris
post 9 Jul 2018, 12:41
Post #13321
Este un chichirez intre setarile routerului si conexiunea data de RDS..Parca..
DannyY
post 9 Jul 2018, 13:05
Post #13322
Marele plictisit
Pe cablu isi ia adresa IP automat (DHCP) sau ai IP static?
Run-->cmd--> ipconfig /all
Posteaza rezultatul, daca nu sunt date confidentiale.
kato
post 9 Jul 2018, 13:09
Post #13323
Windows IP Configuration
Host Name . . . . . . . . . . . . : kato
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
Physical Address. . . . . . . . . : 40-8D-5C-E3-2F-F9
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : 2a02:2f05:4100:3c00:428d:5cff:fee3:2ff9(Preferred)
Lease Obtained. . . . . . . . . . : luni, 9 iulie 2018 12:46:41
Lease Expires . . . . . . . . . . : joi, 15 august 2154 20:37:39
IPv6 Address. . . . . . . . . . . : 2a02:2f05:4200:f300:428d:5cff:fee3:2ff9(Preferred)
Lease Obtained. . . . . . . . . . : luni, 9 iulie 2018 10:34:27
Link-local IPv6 Address . . . . . : fe80::ad59:62c9:5609:da7d%6(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.2(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : luni, 9 iulie 2018 12:27:02
Lease Expires . . . . . . . . . . : marți, 10 iulie 2018 12:46:39
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 54562140
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-22-B4-3A-81-40-8D-5C-E3-2F-F9
DNS Servers . . . . . . . . . . . : fe80::1%6
192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:90d7:c61:e92:b08f:39c6(Preferred)
Link-local IPv6 Address . . . . . : fe80::c61:e92:b08f:39c6%5(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 117440512
NetBIOS over Tcpip. . . . . . . . : Disabled
renault scenic 2000 rxt - scenic III 1.6 dci - vs 05 glx vs 79 glx
Post #13324
Vezi prin Network and sharing centre - Advanced sharing centre dacă nu ai discovery pe OFF.
Presupun că acces la net e și pe cablu și prin Wifi...
This post has been edited by gabize: 9 Jul 2018, 13:10
kato
post 9 Jul 2018, 13:11
Post #13325
reiau, cu aceleasi setari, cand am conectat prin wireless totul a fost ok. la cablu e beleaua....... accees la net am, nu e nici o problema. doresc partajare ca sa pot transfera rapid fisiere intre ele si sa am imprimanta accesibila de pe orice dispozitiv
This post has been edited by kato: 9 Jul 2018, 13:14
post 9 Jul 2018, 13:14
Post #13326
Întrebarea e simplă: la net ajunge pe cablu?
kato
post 9 Jul 2018, 13:15
Post #13327
da
Post #13328
Văd că ai editat.
Du.te în This PC și accesează rețeaua. Îți apare în partea de sus, sub meniul dinamic, o bandă care-ți cere acceptul pentru discovery network?
Pe cablu, firește!
kato
post 9 Jul 2018, 13:17
Post #13329
nu cere nimic sus.... pe retea apare doar pc-ul si cand dau click pe el ce am dat share
post 9 Jul 2018, 13:21
Post #13330
Vezi totuși unde am spus eu (Network and sharing centre - Advanced sharing centre), eventual compară cu un PC care merge.
E greu de dat cu presupusul...
kato
post 9 Jul 2018, 13:24
Post #13331
pai am facut reteua de le zero, aceleasi setari, de aici si frustrarea mea..... culmea ca merge si home groupe in win 10 ...... (la cele 2 care se vad)
iulia_boris
post 9 Jul 2018, 13:50
Post #13332
Suna la RDS.Dar este ceva,ca nu ma pricep deloc sa explic,cu conexiunea cand semnalul este transmis odata prin router si altceva cand este prin cablu.
This post has been edited by iulia_boris: 9 Jul 2018, 13:51
DannyY
post 9 Jul 2018, 14:38
Post #13333
Marele plictisit
Nu are legatura RDS cu reteaua locala.
Nici prin pinguri nu se vad intre ele?
kato
post 9 Jul 2018, 15:05
Post #13334
nici.......acum am dat update la drivere, dezactivat firewall, sa vedem ce va fi unsure.gif
DragosP
post 9 Jul 2018, 15:49
Post #13335
Nu zic nimic...nou
Dar cablul e bun?
Placa e bună?
Ceva de plastic . . - BRRC
Cu noi este Dumnezeu!
post 9 Jul 2018, 15:53
Post #13336
As zice ca da.
QUOTE(kato @ 9 Jul 2018, 14:11)
iulia_boris
post 9 Jul 2018, 16:40
Post #13337
Io ti.am zis sa suni la RDS ca te lamuresc aia..Ceva de genul asta de belea am avut si eu ,mai demult,dar n.am retinut decat chestia cu logatul prin cablu legat direct in PC sau logarea prin routerul legat la PC.Adica semnalul trece prin router intai si apoi prin PC.Ceva si cu IP.ul..Sper sa nu ma insel.
post 9 Jul 2018, 16:44
Post #13338
Iulia, el are probleme in rețeaua internă, nu se potriveste ceea ce spui. wink.gif
marksman
post 9 Jul 2018, 17:43
Post #13339
Post mortem nihil est
Reteaua pe cablu ai setat-o "Home network"? Ca daca ai setat-o "Public network", goodbye!
Charlie Foxtrot: Massively vote Charlie Golf for President!
iulia_boris
post 9 Jul 2018, 17:56
Post #13340
QUOTE(gabize @ 9 Jul 2018, 16:44)
kato
post 9 Jul 2018, 17:58
Post #13341
este pe home smile.gif aceeasi versiune de win, aceleasi setari pe 2 pc-uri..... unul vrea, celalalt nu. daca il conecterz wireless (recreez conditiile primului) vrea si celalalt....... cred ca mai incerc maine
DannyY
post 9 Jul 2018, 18:05
Post #13342
Marele plictisit
Am citit undeva "firewall"?
kato
post 9 Jul 2018, 18:14
Post #13343
dezactivat:))))
iulia_boris
post 9 Jul 2018, 18:34
Post #13344
Cele mai frustrante chestii si de durata..Ti.ai pierdut toata ziua configurand..Mie.mi venea sa dau cu ele de toti peretii..
paul_damian
post 9 Jul 2018, 18:48
Post #13345
Membru mult
Cuvantul cheie e "routerul RDS". La care partea de wireless nu comunica cu partea de porturi LAN.
Dacia Sandero Stepway, 2021
Ex Dacia Logan KissFM 1.4, 2008
Ex Dacia 1310, 1999
Ex Dacia 1100, 1969
post 9 Jul 2018, 19:29
Post #13346
Pe bune? E un fiuciăr? Așa e ele?
DragosP
post 9 Jul 2018, 19:31
Post #13347
Nu zic nimic...nou
kato
post 9 Jul 2018, 19:45
Post #13348
merg toate cand sunt wireless,,,,,, cand conectez pe cablu, adio,,,,, are sens ce zice colegu,,,,,,,,,,multam mult pentru idei
iulia_boris
post 9 Jul 2018, 19:53
Post #13349
QUOTE(paul_damian @ 9 Jul 2018, 18:48)
Asa.i,maica..Cu LAN.urile alea..
paul_damian
post 9 Jul 2018, 22:25
Post #13350
Membru mult
Nu ma intrebati cat a durat, cate certificate de incompetenta mi-am semnat, si ce a fost la gura mea cand ala de la relatii clienti mi-a confirmat ca asa e, pana m-am lamurit ca porturile sunt pe chip-uri diferite, pe VLAN-uri diferite... Solutia gasita de mine a fost sa transform ONT-ul in bridge si sa pun in spatele lui un router citav.
Ex Dacia 1310, 1999
Ex Dacia 1100, 1969
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 13th May 2025 - 01:27
