sasait in habitaclu
sasait in habitaclu
di3g0 |
6 Sep 2007, 17:55
Membru autentic Group: Members Posts: 484 Joined: 1 February 06 |
dacia break
1987
- b 11 wji totul incepe de la dacia
6 Sep 2007, 17:58
bord cn?
di3g0 |
6 Sep 2007, 17:59
nop,e vorba de bordul cu cele 2 ceasuri in dreapta
dacia break
1987
unikat45 |
6 Sep 2007, 18:03
Membru autentic Group: Members Posts: 375 Joined: 4 May 06 |
bord cn si servo am si eu...asa se aude si la mine... nu stiu care e faza... dar face de mult... de fapt de cand am luat masina din ce stiu eu e zgomot de la servofrana o dar mai astept si eu pareri.... verifica daca nu ai cumva aeroterma pornita ca eu am mai uitat-o pe treapta unu de viteza si asa se auzea..
This post has been edited by unikat45: 6 Sep 2007, 18:05 |
Dacia 1310
Dacia 1310
- IS 01882
florinutzu |
7 Sep 2007, 08:10
Membru autentic Group: Members Posts: 290 Joined: 6 July 05 From: Piatra Neamt |
Fasaitul e sigur de la capsulele vacuumatice daca aveti bord CN. Sunt sparte si scapati de fasait numai inlocuindu-le si punand unele noi. Spor la treaba.
Daca veti altfel de model de bord ... atunci nu ma pricep. Bafta! This post has been edited by florinutzu: 7 Sep 2007, 08:11 |
BERLINA 1310L
- NT 05 XXX Cel ce pune o intrebare e prost pana afla raspunsul.
Cel ce nu intreaba e prost pentru todeauna! |
7 Sep 2007, 08:13
daca e alt model de bord e de la servofrana.
Kruger |
7 Sep 2007, 08:46
Membru autentic Group: Members Posts: 1.660 Joined: 18 August 05 From: Bucuresti |
ssait...? Ati cautat pe la pedale sa nu fie vreun sarpe >?
Honda
Accord
2005, Sport Tourer Automatic 2.0 VITEZA NU UCIDE
OPRIREA BRUSCA DA |
di3g0 |
7 Sep 2007, 22:18
sigur nu e:D..si am observat ceva,cand apas pedala de frana scap de sasait...deci sa nu fie ceva de la acel cilindru existent la pedala:????daca da cum il pot schimba?!!!
dacia break
1987
ATM |
9 Sep 2007, 08:15
1948 Tucker Torpedo Group: Members Posts: 596 Joined: 28 December 05 From: Bucuresti |
Daca sasaie, nu e cilindrul, ci servofrana cu totul (tulumba). Cel mai simplu sa-ti dai seama e din variatia motorului cand calci frana (la tata e invers, nu se aude in mers normal, dar cand calca frana incepe sa suiere si creste turatia de la 900 la 1200 rpm). Si daca intr-adevar e servofrana, nu prea merge reparata (are o garnitura /membrana care probabil s-a crapat) si se schimba cu totul (toata oala dintre pompa de frana si panoul de foc).
Zi-ne daca asta e sau am batut campii. |
MITSUBISHI
COLT
Z30-2005 Inchiriez fiare de calcat, geamuri termopan, betisoare de urechi, aparate de ras. Rog seriozitate.
SSilent |
9 Sep 2007, 09:27
Membru Vitezoman Group: Members Posts: 1.235 Joined: 23 July 07 From: ...I'm everywhere... nowhere |
QUOTE Daca sasaie, nu e cilindrul, ci servofrana cu totul (tulumba). Cel mai simplu sa-ti dai seama e din variatia motorului cand calci frana (la tata e invers, nu se aude in mers normal, dar cand calca frana incepe sa suiere si creste turatia de la 900 la 1200 rpm). Si daca intr-adevar e servofrana, nu prea merge reparata (are o garnitura /membrana care probabil s-a crapat) si se schimba cu totul (toata oala dintre pompa de frana si panoul de foc). Zi-ne daca asta e sau am batut campii. am avut si io problema asta pe masina de la munca (Dacia 1410 -1998) si problema era de la supapa care intra in pompa de frana ...era crapata rau ....costa 4ron si se inlocuieste in cca 30 secunde |
1210
1986
- N/A dacie dezmembrata... in curs de RK ^_^
cu planuri de viitor (adica vise): -Yamaha Fazer 600 cm3 -Ford Escord 2000RS -Mercedes Benz W201 |
ydaniel |
9 Sep 2007, 10:11
ori supapa ori membrana.ai franat brutal in ultima perioada?la un preten de-al meu avea parte de plastic alba sparta;)
Oriunde,
oricand...
Cand esti rau ,nu te uita! |
di3g0 |
9 Sep 2007, 19:11
tot ceea ce pot spune este ca am observat asta de cateva zile..asa ca,chiar nu am idee dak am franat brusc,dar eu zic ca nu prea imi sta in fire,si tot d ultima ora este faptul ca nu mai face tot timpu',inca imi vine sa cred ca e vorba de o garnitura ceva....
dacia break
1987
ydaniel |
11 Sep 2007, 11:14
fa un test:la relanti-daca sasaie apasa usor pedala de frana si sa zici daca dispare;)
Oriunde,
oricand...
ageana |
11 Sep 2007, 11:30
-> Group: Members Posts: 1.885 Joined: 9 September 06 |
Mie imi facea asa cand s-a spart furunul ce intra in servo. Schimba si supapa aia de in care intra furunul.
Oare ce e asa greu sa pornesti motorul, sa deschizi capota, sa-ti dai fundul jos din masina si sa localizezi sunetul. Doar asa iti dai sema. |
Ideal
Pro Rider
2009 Percussive maintenance engineer.
Turkish rhombus owner. Dezmembrez Ferrari Enzo 2003, motor bun, nu papă ulei. |
ydaniel |
11 Sep 2007, 11:41
furtun:12 lei,supapa 5 lei,servo 85 lei=de autonova satu mare.este si de comefin:)
Oriunde,
oricand...
di3g0 |
11 Sep 2007, 18:06
nu e mare lucru sa deschid capota,dar eu va spun ca se aude in interior nu la compartimentul motor,si spre surprinderea mea nu mai face,ce sa fi fost??vreu sa schimb ceea ce sasaia atunci,sa nu las asa fiindca acum nu mai face!!
This post has been edited by di3g0: 11 Sep 2007, 18:12 |
dacia break
1987
Dyda |
12 Sep 2007, 09:23
bag seama ca ori nu pricepi , ori te prefaci ca nu pricepi, nu ai incercat nimic din ce ti s-a spus, atunci de ce mai intrebi?
Un test si mai elocvent_ scoti furtunul vacuum de la servo , il opturezi cu un surub sau cu un lemn din pomul sub care parchezi masina , pornesti motorul si vei observa ca dispare fisiitul. Dupa care scoti clapeta servo - supapa alba o pui la gura cu partea unde vine furtunul si faci vacuum ( ca la o sticla ) obturezi imediat cu limba si vezi daca mentine vacuumul daca da este de vina simeringul de la servo daca nu clapeta.In ambele cazuri le vei inlocuii. Si iar dupa care dai de stire rezultatul obtinut |
-------------------- Kox
di3g0 |
12 Sep 2007, 11:04
eu am priceput ff bine,am incercat tot ceea ce mi s-a spus,dar fara rezultat,iar despre ce vorbeau colegii in postatrile anterioare pot spune ca nu m-au ajutat cu nimic,tot sasaie(uneori),cum ziceai si u ar trebui sa fie un semering ceva.maine ma duc la un tovaras la service sa vad ce imi poate face,voi reveni cu rezultatul final
dacia break
1987
ydaniel |
12 Sep 2007, 20:22
a zis f bine dyda;)desi nu l-am mai vazut de ceva vreme aici:)
Oriunde,
oricand...
Brainie |
14 Sep 2007, 08:53
Membru autentic Group: Members Posts: 464 Joined: 2 May 07 From: Bucuresti |
Nu pare să fie aceeași problemă cu a inițiatorului, dar și la mine tot de sâsâit a fost vorba.
Deci: imediat după oprirea motorului se auzea pentru 3-4 secunde un sâsâit. Investigând am găsit că pe la o îmbinare (tablă cu tablă) de pe corpul servofrânei (din zona bombată orientată către fața mașinii) iese aer sub presiune, curent care se simțea și la mână. Bineînțeles că ieșea permanent cât timp motorul mergea, dar nu se auzea decât după oprirea motorului. Nu am sesizat scăderea eficienței frânei. Am rezolvat curățând bine zona cu șmirghel și ceva degresant și aplicând puțin silicon. De trei ani nu mai scapă pe acolo. |
Ex Dacia 1310 Li ;
Ex Logan ABS+ 1.6 MPI
di3g0 |
18 Sep 2007, 20:48
am rezolvat-o baieti,era vorba de acel semering de care zicea Dyda,l-am schimbat si e perfect.multumesc frumos pentru contributie,adevarati prieteni
dacia break
1987
CiprianPJM |
5 Oct 2007, 10:33
Membru Avertizat Group: Members Posts: 197 Joined: 17 October 04 From: Bucuresti |
La mine se rupsese aproape de tot (de mai tinea foarte putin) stutul de la supapa, in care intra furtunul ce vine de la motor. N-are rost sa va spun cum era pedala de frana. Cumpar supapa (2,5 ron supapa, 0,5 ron colierul), incerc supapa (lasa aerul sa circule numai intr-un sens, daca "sug" :> prea tare nu mai da drumul deloc), pare OK. O montez si, ce sa vezi. Cate-odata nu functioneaza servo. Uneori e pedala tare, daca ridic si apas iar imediat isi revine (e cum trebuie). De la ce o fi? Nu am observat sa se coreleze cu nimic, turatia motorului, cat astept dupa ce eliberez frana si o apas iar, nimic. Face UNEORI.
Omega 2.0i
1997
- B 33 EZW Zic si io, nu dau cu paru!
di3g0 |
5 Oct 2007, 18:59
clar ca e servo,la mine a fost simpu ,intr-un final,sa nu ai probleme cu corpu',tare sunt curios sa vad ce zic si baietii
dacia break
1987
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 1st May 2024 - 17:51 |
