Noul Logan Renault eco2, cu 3,8% consum
tribunul |
#451
"Megane" Scenic 2
#452
![]() - Group: Members Posts: 22.542 Joined: 19 April 05 From: Romania ![]() |
QUOTE(sobolan @ 7 Sep 2011, 00:05) vad poze cu Zonda p-aci si multa fibra de carbon....cata agitatie ca sa mai scadem cu 0,2% din consum.....de fapt,aici se discuta de aerodinamica la general nu doar despre aerodinamica logan-ului....culmea S-a transformat si intr-un topic de stiri aero sau ce se mai face in domeniu pentru turbulente cat mai mici.![]() QUOTE(tribunul @ 7 Sep 2011, 09:06) Amarokul e cam dublu la pret O masina mai patrata decat un duster si cu un motor mai potent, are totusi niste bucati de plastic la rotile din fata. Asta trebuia sa intelegi, nu pretul. |
Squirrel |
#453
![]() Captain of Black Pearl™… Group: Members Posts: 4.466 Joined: 13 March 08 From: partea mea: Drum bun! ![]() |
O fi făcută pentru autobahn…nu pentru praf/pietriș/grohotiș/noroi/zăpadă unde nu te ia vântul decât pe creastă…
This post has been edited by Squirrel: 7 Sep 2011, 09:00 |
Duster
2010 1,6 16v 4Ś4 Laureaté Noir Nacré
- RO 44 AWD Fire, walk with me...in 4 strokes, water cooled.
#454
Intradevar, are sasiu de autostrada. ![]() |
tribunul |
#455
Mai multe poze, Ironick a fost cam zgarcit in cazul asta.
http://www.vw-vehicule-comerciale.ro/modele/noul_amarok/ |
"Megane" Scenic 2
#456
Curios, Megane 3 respecta anumite legi ale aerodinamicii.
![]() M3.jpg ( Size: 283.58k ) Number of downloads: 1694 QUOTE Exclusive Aerodynamic Package While the standard all-new Focus already boasts an exceptionally aerodynamic bodyshell (5-door CD = 0.295), the ECOnetic model has been designed with a number of additional features to minimise drag still further. Much of the aerodynamic development was concentrated on smoothing the airflow underneath the vehicle. The ECOnetic derivative features additional undershields and deflectors, which cover most of the underfloor between the front and rear axles, together with a new undershield on the rear axle. Aerodynamic performance is also improved by the use of steel wheels combined with special low-drag ECOnetic wheel covers, which are more streamlined than a conventional alloy wheel design. The ECOnetic model features, as standard, the innovative Active Grille Shutter – an advanced new system that optimises aerodynamics by using vents to control airflow through the grille to the cooling system and engine compartment. If air is required to cool the engine the vents are opened; but if no airflow is needed, the vents are shut, thereby significantly reducing aerodynamic drag Mounted in the grille aperture ahead of the radiator, the Active Grille Shutter features motorised horizontal vanes which can rotate through 90 degrees to block the air flow. Automatically controlled by the car’s electronic control unit, the vanes can be rotated into 16 different positions – from fully closed to fully open – depending on the amount of cooling air required. When fully closed, the reduction in drag means that the Active Grille Shutter can reduce CO2 emissions by 2 per cent. Ford_Focus_Econetic_3.jpg ( Size: 134.97k ) Number of downloads: 1669 Ford_Focus_Econetic_6.jpg ( Size: 615.09k ) Number of downloads: 1617 Ford_Focus_Econetic_7.jpg ( Size: 636.83k ) Number of downloads: 1572 Ford_Focus_Econetic_8.jpg ( Size: 155.97k ) Number of downloads: 191 Intodeauna se gaseste informatia in alta limba, la noi revistele auto (si site-urile) sunt praf si pulbere, vai de steaua lor. Nu sunt in stare sa aduc adeloc informatie tehnica. This post has been edited by IRONICK: 13 Sep 2011, 12:12 |
P-A-C-O |
#457
![]() What you see is what you get! Group: Members Posts: 2.350 Joined: 3 October 10 ![]() |
QUOTE(IRONICK @ 13 Sep 2011, 12:37) Curios, Megane 3 respecta anumite legi ale aerodinamicii. ![]() si B52 o sa respecte aceleasi legi ![]() This post has been edited by Logan_Stepway: 13 Sep 2011, 20:14 |
- Ziua de 16 nov 2014 a ramas in istoria Romaniei ca fiind ziua in care omul politic Victor Ponta a fost cel mai aproape sa devina Presedintele Romaniei
#458
Logan_Stepway, nu se vede deloc in consum sau tinuta de drum. Motoarele cu martoage in loc de cai si prea multa topaiala.
C3X_Corvid_CFD1.jpg ( Size: 152.75k ) Number of downloads: 283 15 Sep 2011, 12:35: Aerodinamica la masini de ... RMH3257W.jpg ( Size: 83.99k ) Number of downloads: 330 15 Sep 2011, 15:22: Cateva amanunte de la Subaru XV. subaru_xv_jpg_20.jpg ( Size: 1.5mb ) Number of downloads: 342 This post has been edited by IRONICK: 15 Sep 2011, 14:22 |
Ion_R5 |
#459
Membru autentic Group: Members Posts: 256 Joined: 19 December 08 From: Bucuresti ![]() |
Domnu' Ironick, cand ne mai pui niste poze cu Loganul din dotare - unde sa vedem "pe viu" imbunatatirile aerodinamice??
Multumesc anticipat! |
2010 Black Line 1.6 16v euro4
- B-xxxxxxx Jegul se curata cu apa si sapun. Insa nesimtirea, lipsa educatiei si a caracterului nu se anihileaza la fel de usor.
#460
QUOTE(Logan_Stepway @ 13 Sep 2011, 21:14) si B52 o sa respecte aceleasi legi O sa respecte o pu... uite exemplul de mai jos, desi nu se pupa cu pefectiunea, consuma mai putin. Altii reusesc.![]() Lexus CT 200h cth200.jpg ( Size: 47.22k ) Number of downloads: 344 This post has been edited by IRONICK: 20 Sep 2011, 11:10 |
P-A-C-O |
#461
QUOTE(cristic1982 @ 2 Aug 2011, 18:04) Suna interesant, pe cand niste poze cu toate modificarile tale? QUOTE(Ion_R5 @ 18 Sep 2011, 00:26) Domnu' Ironick, cand ne mai pui niste poze cu Loganul din dotare - unde sa vedem "pe viu" imbunatatirile aerodinamice?? Multumesc anticipat! Ironick, vezi bre' ca vor sa-si faca colegii (de forum) altar cu modificarile tale ![]() ![]() |
YRX |
#462
![]() Membru autentic Group: Members Posts: 5.045 Joined: 6 July 06 From: Bucuresti ![]() |
Pana nu apare noul Logan nu pune poze, sa nu-i fure Dacia ideile.
2005 Ambition 1.6 MPI
P-A-C-O |
#463
S-a definitivat lucrul la partea de aspect exterior - aerodinamica pentru X52 asa ca e drumu' liber...
![]() ar trebui macar apreciat gestul userului Ionercinci care a iesit din "silentio stampa" dupa mai bine de 4 luni pentru-ca nu mai putea sa doarma noaptea de grija modificarilor aduse de Ironick la masina personala ![]() |
AR-18-MOS |
#464
BMW
730Ld
'07 High Executive
#465
Aerodinamica in Canada!
tapejetta1.jpg ( Size: 91.93k ) Number of downloads: 339 tapejetta4.jpg ( Size: 93.75k ) Number of downloads: 338 tapejetta6.jpg ( Size: 66.89k ) Number of downloads: 343 ![]() ![]() ![]() QUOTE(Logan_Stepway @ 20 Sep 2011, 22:11) S-a definitivat lucrul la partea de aspect exterior - aerodinamica pentru X52 asa ca e drumu' liber... Si de ce nu a intrebat pe forum macar ce se mai poarta in domeniu, daca tot ii aia grija? Ca iar a iesit lipsa la apel si asta cand s-a strigat prezenta aerodinamicii pe masina.![]() This post has been edited by IRONICK: 22 Sep 2011, 10:59 |
#466
Ma bufneste rasul ce zice pacaliciul asta. GM rulez,
![]() QUOTE Rear fender skirts look great, but flunk in other ways FRANKFURT -- Rear fender skirts certainly make a car appear sleek and extremely aerodynamic. So it is just a matter of time before they become standard equipment on all cars, right? Automakers continue to search for a wide range of styling tricks to reduce aerodynamic drag in an effort to improve fuel economy. General Motors global styling boss Ed Welburn, interviewed last week on the sidelines of the Frankfurt auto show, said “anything that helps reduce the interference along the side of a car is a good thing.” So it looks like removable rear fender skirts are a done deal, right? Not so fast. It turns out after extensive testing by GM, removable fender skirts flunked. They are more of a problem than a solution. According to Welburn, there are several drawbacks: • The fender skirt causes tire pressure to increase. Although he did not say it, neither GM nor any automaker wants to create a design that increases the probability of tire failure. • Removable skirts are difficult to keep in place properly, plus there’s the added cost of each skirt. • Pick one: To use a fender skirt, the rear tires need to be narrower to fit inside the wheel well or the vehicle track needs to be narrower or the body needs to be what he called “pulled out” to accommodate the same size tires that are steering the car. Welburn said pulling the body out, essentially widening the body where the rear tires are located, increases aerodynamic drag. While Welburn didn’t explain the other two choices described above, a narrower tire would reduce vehicle capacity and a narrower vehicle track could slightly increase the probability of rollover. Says Welburn: "The short answer is, skirts don’t help on a production car." Singura problema reala este mizeria. Atat timp cat nu se monteaza pe masini de wrc, nu are nici o problema incalzirea cauciucului. This post has been edited by IRONICK: 23 Sep 2011, 13:54 |
Squirrel |
#467
Ford Focus
QUOTE Grilă radiator auto-adaptivă – o aerodinamică optimizată înseamnă performanțe sporite și consum redus. Închidere grilă radiator automată Noul Focus este dotat cu un sistem cu închidere grilă radiator automată (active grill shutter). Orificiile de aerisire de la nivelul grilei sunt mereu deschise pentru a asigura răcirea motorului la deplasarea cu viteză redusă, însă se închid automat când accelerezi. Acest lucru îmbunătățește aerodinamica, ceea ce reduce consumul de combustibil cu până la 0,8% conform noilor cicluri de măsurare NEDC (New European Driving Cycle). În timp, vei simți diferența. Sursa This post has been edited by Squirrel: 25 Sep 2011, 20:37 |
Duster
tribunul |
#468
Probabil viata ne invata ceva, nu conteaza cate inovatii tehnice exista pe piata ci cate ne permitem sa cumparam.
"Megane" Scenic 2
#469
Innovative Active Grille Shutter fitted as standard
The new Focus is the first car in its class to standardise an Active Grille Shutter – an innovative new system that optimises aerodynamics by using vents to control airflow through the grille to the cooling system and engine compartment. If air is required to cool the engine the vents are opened; but if no airflow is needed, the vents are shut, thereby significantly reducing aerodynamic drag Mounted in the grille aperture ahead of the radiator, the Active Grille Shutter features motorised horizontal vanes which can rotate through 90 degrees to block the air flow. Automatically controlled by the car’s electronic control unit, the vanes can be rotated into 16 different positions – from fully closed to fully open – depending on the amount of cooling air required. When fully closed, the reduction in drag means that the Active Grille Shutter can reduce CO2 emissions by 2 per cent. As an additional benefit, the system keeps the vanes closed as long as possible when starting from cold, so that the engine reaches its most efficient operating temperature more quickly. This benefits both fuel consumption and exhaust emissions, as well as ensuring that the vehicle cabin warms up quicker. With careful optimisation of aerodynamic details, it was possible to achieve a significant reduction in drag compared to the previous Focus: • 4-door – CD = 0.274 (was 0.304), reduced by 10 per cent • 5-door – CD = 0.295 (was 0.318), reduced by 7 per cent open.jpg ( Size: 81.83k ) Number of downloads: 332 closed.jpg ( Size: 80.88k ) Number of downloads: 262 The Chevy Eco Cruze utilizes an innovative automatic air shutter system that closes the grill vents at higher speeds to reduce drag by .016 – adding .5 mpg and helping push the Cruze to the magic 40 mpg number. The shutter system is fitted to sensors that measure changes in speed or temperature. If the temperature drops or the sensors measure sufficiently high speeds, the vents will be closed by electric motors, cutting down the amount of air that enters the engine bay. Why not simply keep the grill vents closed all the time? Because added airflow is needed to help cool the engine at lower speeds. shutter.jpg ( Size: 69.14k ) Number of downloads: 247 IMG_2235.jpg ( Size: 87.55k ) Number of downloads: 246 IMG_2236.jpg ( Size: 35k ) Number of downloads: 258 IMG_2238.jpg ( Size: 70.09k ) Number of downloads: 249 IMG_2239.jpg ( Size: 79.04k ) Number of downloads: 234 IMG_2240.jpg ( Size: 84.93k ) Number of downloads: 208 IMG_2241.jpg ( Size: 84.89k ) Number of downloads: 219 IMG_2242.jpg ( Size: 68.92k ) Number of downloads: 211 IMG_2243.jpg ( Size: 85.74k ) Number of downloads: 219 IMG_2245.jpg ( Size: 60.51k ) Number of downloads: 246 PS. Despre Focus am mai postat in #456 (13 Sep 2011, 12:37) This post has been edited by IRONICK: 26 Sep 2011, 14:23 |
#470
YRX |
#471
Cam complicat sistemul cu grilele adaptive. Senzori, motorase, clapete - o gramada de chestii care se pot strica. E loc de imbunatatiri in alta parte fara a mai fi nevoie de chestia asta.
Nu in ultimul rand mai adauga si un pic de greutate, ceea ce nu e deloc benefic pentru economia generala a eficientei. |
#472
Ford Focus Sedan (2011)
a.jpg ( Size: 514.2k ) Number of downloads: 279 b.jpg ( Size: 593.22k ) Number of downloads: 259 c.jpg ( Size: 941.52k ) Number of downloads: 247 d.jpg ( Size: 488.43k ) Number of downloads: 226 YRX, nu este deloc complicat sistemul. Iar greutatea este extrem de mica, nu cantareste mai mult de 1kg. Fara scut: a.jpg ( Size: 893.76k ) Number of downloads: 195 b.jpg ( Size: 942.25k ) Number of downloads: 195 This post has been edited by IRONICK: 10 Oct 2011, 14:53 |
#473
JAGUAR
a.jpg ( Size: 781.8k ) Number of downloads: 255 b.jpg ( Size: 896.04k ) Number of downloads: 201 c.jpg ( Size: 1.2mb ) Number of downloads: 179 d.jpg ( Size: 997.1k ) Number of downloads: 179 e.jpg ( Size: 934.13k ) Number of downloads: 159 f.jpg ( Size: 850.1k ) Number of downloads: 133 g.jpg ( Size: 672.6k ) Number of downloads: 124 h.jpg ( Size: 691.92k ) Number of downloads: 122 i.jpg ( Size: 853.33k ) Number of downloads: 126 j.jpg ( Size: 999.03k ) Number of downloads: 122 k.jpg ( Size: 782.86k ) Number of downloads: 111 |
#474
YRX |
#475
Misto pieptenele de sub Jaguar, astia au trecut la nivelul urmator, vortex sub masina.
Asa, ai fost la SAB fara mine ... ![]() |
#476
@YRX, am fost cu Klaus.
![]() Am adaugat o comparatie. Focus sedan cu carenaj si logan cu carenaj. Se vede perfect unde este eficient (bine, la focus mai exista si varianta cu esapament sub portbagaj, nu ca in imaginile de mai sus sub bancheta spate, copiat sau nu dupa vw passat). comp.jpg ( Size: 1.98mb ) Number of downloads: 268 This post has been edited by IRONICK: 11 Oct 2011, 23:38 |
#477
FORD MUSTANG
Ford_Mustang_Boss_302_2012_1600x1200_wallpaper_7fa.jpg ( Size: 423.66k ) Number of downloads: 235 Ford_Mustang_Boss_302_Laguna_Seca_2012_1600x1200_wallpaper_5aa.jpg ( Size: 615.5k ) Number of downloads: 185 Ford_Mustang_Boss_302_Laguna_Seca_2012_1600x1200_wallpaper_56a.jpg ( Size: 843.93k ) Number of downloads: 174 EXTRA (pentru ca intodeauna mi-au placut genul asta de masini) This post has been edited by IRONICK: 14 Oct 2011, 11:04 Attached thumbnail(s) Ford_Mustang_2010_1600x1200_wallpaper_5a.jpg ( Size: 352.43k ) Number of downloads: 166 Ford_Mustang_2010_1600x1200_wallpaper_5d.jpg ( Size: 326.51k ) Number of downloads: 144 Ford_Mustang_Boss_302_2012_1600x1200_wallpaper_6f.jpg ( Size: 332.56k ) Number of downloads: 146 Ford_Mustang_Boss_302_Laguna_Seca_2012_1600x1200_wallpaper_57.jpg ( Size: 331.66k ) Number of downloads: 134 Ford_Mustang_Boss_302_Laguna_Seca_2012_1600x1200_wallpaper_58.jpg ( Size: 285.85k ) Number of downloads: 141 Ford_Mustang_Boss_302_2012_1600x1200_wallpaper_7e.jpg ( Size: 277.75k ) Number of downloads: 108 |
andreig1982 |
#478
Membru autentic Group: Members Posts: 1.412 Joined: 15 January 06 ![]() |
un pic de offtopic
interesanta evacuarea, si citez "One of the most interesting features of the 2012 Boss 302 is its quad exhaust system, developed to give the car a unique sound. The two primary pipes exiting the rear handle most of the exhaust gases, while two smaller pipes branch off from the exhaust crossover and exit discreetly along the lower body sides, just in front of the rear wheels, sending gases through a set of metal discs that generate unique sounds. Should the owner live somewhere with more lax noise regulations, the plates can easily be removed in favor of aftermarket dump valves." un alt lucru interesant este elementul de rigidizare al caroseriei care inlocuieste bancheta spate This post has been edited by andreig1982: 14 Oct 2011, 10:24 Attached thumbnail(s) 12MustangBoss302_34.jpg ( Size: 256.58k ) Number of downloads: 188 |
Logan Ambition
#479
“We’re also going to be offering aerodynamic wheels that will enable 320 mile range,” Musk told us earlier. “There were some skeptics who said we couldn’t do a 300 mile range, but we’re going to do better than that. We’re going to offer 320 mile range, as tested on the EPA 2 cycle test.”
20 miles > 6.7% din jante tesla_model_s_100351652_m.jpg ( Size: 58.1k ) Number of downloads: 183 |
sobolan |
#480
![]() membru paros... Group: Members Posts: 8.241 Joined: 10 March 06 From: GL ![]() |
Logan-1.5dci-2017--
Golf mk5 - syncro - 2007--
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 1st May 2025 - 20:15 |
