TOTUL despre achizitionarea unui Logan, la ce curs, cind, creditare, Casco etc.
pgpdesign |
#1381
![]() Membru Group: Members Posts: 117 Joined: 28 July 05 From: Șimleu Silvaniei ![]() |
Dacia Duster
1.5 4WD
2012
- B 102 DOT
florin1 |
#1382
![]() Membru incepator Group: Members Posts: 47 Joined: 10 August 05 ![]() |
si eu am platit suport si numere rosii
VW
Passat B6
2009 2.0 CRTDI 110CP+
Codrin |
#1383
QUOTE(blaci @ 15 Aug 2005, 16:05) Sunt persoana fizica autorizata si as vrea sa cumpar un Logan Laureate 1.4 cu banii jos. As vrea sa va intreb daca trebuie sa platesc si TVA-ul; daca da atunci pot sa scriu jos din profit pretul masinei? Daca ai SRL platesti TVA si-l deduci apoi. Daca ai AF nu stiu cum sta treaba, dar oricum de anul viitor se transforma in SRL. |
Mazda
Loghy |
#1384
![]() Membru autentic Group: Members Posts: 203 Joined: 27 April 05 From: Bucuresti ![]() |
Nu e normal!!!
Vocea Clientului sau OPC! |
Logan 1.6 MPI
2004 - Ambition
- B XX RRJ Good things come to those who wait...
simon |
#1385
![]() Membru autentic Group: Members Posts: 735 Joined: 30 October 04 ![]() |
Doar suporti numere (incl.manopera
![]() ![]() This post has been edited by simon: 18 Aug 2005, 02:01 |
Megane III
2009 Dinamique 1.6 16V
sir_zven |
#1386
![]() Membru incepator Group: Members Posts: 15 Joined: 30 July 05 ![]() |
e complet pe dos.
la ipso de ex. de unde am luat-o eu mi-au spalat-o...aranjat-o (chestii normale care trebuie sa le faca dealerul) era pe aici si o lista cu atributiile dealerului "pregatirea de vanzare".... chestii care nu se platesc in plus am prins promotie suporti numere, un plin de rezervor si o geanta frigorifica GRATUIT. This post has been edited by sir_zven: 18 Aug 2005, 03:04 |
Logan Laureate 1.4
- B-13-AMD "You see, wire telegraph is a kind of a very, very long cat. You pull his tail in New York and his head is meowing in Los Angeles.
Do you understand this? And radio operates exactly the same way: you send signals here, they receive them there. The only difference is that there is no cat." - Albert Einstein |
G.R. |
#1387
Membru autentic Group: Members Posts: 266 Joined: 17 December 04 ![]() |
QUOTE(pgpdesign @ 17 Aug 2005, 16:37) ca se platesc cele zise mai sus + suport numere + numere rosii. De ultimele 2 nu am mai intrebat pentru ca mi se parea normal sa le platesti. Nu este normal să plătești pentru suporții de numere 160-180 de mii când în comerț se găsesc cu 70 de mii. Dacă vrea ca mașina ta să circule cu reclama lui pe suporți, să ți-i dea gratuit sau cel puțin la preț normal. Pe de altă parte este vorba și de vânzare condiționată (acceptată de Dacia-Renault), fiindcă nu-ți dă mașina decât cu suporții lor. Cel puțin așa a fost la COMERȚ BOGYO SRL Sf. Gheorghe. Ce mă enervează însă cel mai mult, că dealerii nu justifică suma cerută, ei spun că este contravaloarea serviciilor de pregătire a mașinii. Ei i-am pus să justifice suma cerută și nu au știut. Știam eu (ei nu!) că numerele roșii costă 520 de mii, dar de acolo până 910 mii pauză. La început îmi spuneau că suporții sunt 100, după care 140, mai târziu 160. Am reclamat la VC unde încercau să mă consoleze cu faptul că a murit și capra vecinului, că în București se plătesc 1,5 mil. În mod normal prețul unui produs nou trebuie să conțină toate taxele și serviciile. Este o porcărie faptul că în momentul când te duci să ridici mașina ți se spune că mai trebuie să plătești aia și aialaltă. |
Logan 1.6 Preferance
- CV 03 XXJ
#1388
Deci:
1. NU trebuie sa platesti ulei motor si nici lichid de frana. Daca vin cu faza asta se presteaza una bucata telefon la VC cu mentiunea ca in conformitate cu ordonanta privind comercializarea produselor si serviciilor (OG 99/2000) vanzarea conditionata este INTERZISA, si ca te vezi nevoit sa te adresezi ANPC in vederea luarii masurilor legale si respectarea dispozitiilor din textul de lege: QUOTE( OG 99/2000) Art. 58. - Este interzisă condiționarea vânzării către consumator a unui produs de cumpărarea unei cantități impuse sau de cumpărarea concomitentă a unui alt produs sau serviciu. De asemenea, este interzisă prestarea unui serviciu către consumator, condiționată de prestarea altui serviciu sau de cumpărarea unui produs Eu zic sa incepi de pe acum sa scrii o scrisorica scrisa la VC in care sa intrebi ce trebuie platit la ridicarea masinii si daca trebuie platit, asa cum ai auzit tu, uleiul si lichidul de frana. Adica ei livreaza masinile fara ulei si fara lichid de frana? Adica le livreaza nefunctionale? Consumatorul trebuie sa poata folosi produsul achizitionat din momentul in care il cumpara din magazin. NU trebuie sa mai dea nici un ban pe produs aditional. Produsul livrat trebuie sa functioneze si trebuie facuta proba. Punct. Scrie pe bonul de comanda ca se platesc astea separat? NU. Deci... Dar eu traiesc cu impresia ca la mijloc este ori o informare partiala, ori o dezinformare |
G.R. |
#1389
Klaus, fiecare dealer încasează o anumită sumă, doar justificarea diferă. În cazul de față ei spun că uleiul motor se plătește. Totuși nu înțeleg de ce Dacia, după atâtea reclamații de ce nu face nimic. Practic pregătirea mașinii pt. vânzare se încasează dublu, o dată de la Dacia, o dată de la client.
- CV 03 XXJ
pgpdesign |
#1390
Ca ceva este in neregula e clar. Unii platesc si nu spun nimic. Altii fac scandal si nu mai platesc nimic. Parerea mea este ca daca plata ar fi justificata nu ar renunta la ea chiar daca se face scandal.
klaus: nu cred ca respectivii taximetristi aveau de ce sa ma abureasca. Sa platesti in plus nu e un motiv de lauda. PS: acelasi service iti baga pe gat un spalat de masina obligatoriu de cate ori mergi la ei sa-ti repare masina. Totul incepe de la 150.000 spalat + 50.000 "diagnosticare". |
Dacia Duster
1.5 4WD
2012
- B 102 DOT
#1391
Pai... du-te cu masina spalata data viitoare.
Oricum, si spalatul ala se incadreaza la art. 58 mentionat mai sus... |
powerx |
#1392
![]() Membru Group: Members Posts: 192 Joined: 2 March 04 From: Iasi sau Vaslui ![]() |
am primit ieri un plic de la Dacia cum ca "ati facut alegerea corecta, bla bla bla"...
Sunt curios cam in cat timp vine masina dupa ce ai primit acest plic? sau nu prea are importanta? Multumesc, trebuie sa ma intelegeti si pe mine, sunt nerabdator ![]() |
Logan Ambition
Verde cameleon
- VS-23-XYZ Mic si rau, mai mult mic decat rau.
kurupt |
#1393
![]() Membru autentic Group: Members Posts: 282 Joined: 29 May 05 ![]() |
Eu nici macar plicul nu am primit
![]() ![]() Am platit avansul in 18 iulie, masina au promis pe mijlocul lui lunii septembrie. Sunt curios oare la ce serie de sasiu se afla acum productia? |
Ambiance
- ##### --=-- The KING Of The Hill --=--
powerx |
#1394
eu pe 8 iulie am dat comanda, vc zice ca pe 7 octombrie o primesc, si dealeru zice ca pe 27 sept..probabil vei primi si tu, dar mai tarziu..greu e cu asteptarea asta..
Logan Ambition
Verde cameleon
silverone_82 |
#1395
![]() Membru Group: Members Posts: 100 Joined: 27 July 05 From: Bucuresti ![]() |
QUOTE(powerx @ 20 Aug 2005, 17:03) eu pe 8 iulie am dat comanda, vc zice ca pe 7 octombrie o primesc, si dealeru zice ca pe 27 sept..probabil vei primi si tu, dar mai tarziu..greu e cu asteptarea asta.. ![]() ![]() |
Laureate 1.6MPI
- B-xx-XXX De te bate-o grija grea , nu te plange , taci si bea!!!
powerx |
#1396
ideea e ca Dacia e in remont(reparatii, vacanta, sau mai stiu eu ce e asta) in luna august, asa ca toate comenzile din iulie vin prin septembrie-octombrie. oricum, cei de la Dacia dau un termen mai mare pentru a preveni diferite probleme ce pot aparea. De obicei, masina vine in preajma datei zise de dealer.
La mine datele sunt ceva de genu: dealer - 27 sept, VC - 7 oct, termen limita pe factura - 14 oct. Eu sper sa vina mai devreme de 27 sept..m-am plictisit de atat asteptat, nu mai am rabdare ![]() PS: nu e nevoie neaparat sa suni la ei, vezi ca era pe pagina de la dacia un formular prin care puteai trimite mail la VC, si iti trimit ei raspuns sau te suna in legatura cu presupusa data a venirii masinii. |
Logan Ambition
Verde cameleon
silverone_82 |
#1397
de pe 15 sau de pe 20 august,nu mai stiu sigur,au iesit din remont deci cred ca se pregatesc GOLANII sa intre pe banda daca nu au intrat deja
Laureate 1.6MPI
Rommel |
#1398
![]() Membru incepator Group: Members Posts: 12 Joined: 9 August 05 ![]() |
Eu am facut comanda pe 5 aug. si dealer-ul (ADRAS Dr. Taberei) mi-a zis ca pe 10 oct. vine masina. Cei care si-au luat masina prin acest dealer, puteti sa-mi spuneti daca este serios?
Laureate 1.6
- B-xx-xxx
#1399
![]() - Group: Members Posts: 22.737 Joined: 19 April 05 From: Romania ![]() |
Eu am facut comanda pe 8 Aug si astept in a doua jumatatea a lui sept. Sper sa fie asa.
florin79 |
#1400
Membru incepator Group: Members Posts: 31 Joined: 22 June 05 ![]() |
Am facut comanda pe 03.06.2005. si a venit msina pe 27.07.2005 si pe 29 am luat-o.pe factura era 8.08.2005 deci a venit mai repede!!!
- SB 79 FLR
madalina82 |
#1401
![]() Membru Group: Members Posts: 106 Joined: 4 October 04 From: Bucuresti ![]() |
Salutare tuturor!
As avea si eu nevoie de sfatul vostru caci nu prea stiu ce credit e mai avantajos. Vreau sa-mi iau un Logan Preference 1,4, GE, nemetalizat si sa dau un avans de 4400 euro. Nu mai am nici un alt credit, venitul meu total este de 400 euro, iar creditul vreau sa il fac pe o perioada de 3 ani. Ceea ce ma intereseaza este o rata lunara cat mai mica si niste comisioane/ dobanzi acceptabile. Ce ma sfatuiti? Stiu ca s-a discutat mult pe aceasta tema...dar va rog.....HELP ME!!!!!! |
DSN
clima
- B 39 DSX
#1402
Poti sa faci o simulare pe site-ul Dacia ca sa iti faci o parere. http://www.dacia.ro/CalculeazaPretul_Logan.html
madalina82 |
#1403
QUOTE(ironickSQUAD @ 23 Aug 2005, 10:32) Poti sa faci o simulare pe site-ul Dacia ca sa iti faci o parere. http://www.dacia.ro/CalculeazaPretul_Logan.html Multam, insa este creditul propus de Dacia este cel prin BRD care este cel mai dezavantajos (dobanda mare la euro, costuri substantiale). Eu ma gandisem la Volskbank sau Tiriac. ![]() |
DSN
clima
- B 39 DSX
#1404
Eu am pus ca idee . . . link-ul.
Eu mi-am luat credit in lei cu dobanda fixa de la BRD. Daca cauti pe net gasesti simulatoare la fiecare banca. http://www.vbr.ro/vb_application/default.asp?pgnr=100 |
madalina82 |
#1405
De ce ai ales un credit in lei si nu in euro? Multam pt info! |
DSN
clima
- B 39 DSX
#1406
Am scris aici de ce.
simon |
#1407
QUOTE(madalina82 @ 23 Aug 2005, 10:44) Multam, insa este creditul propus de Dacia este cel prin BRD care este cel mai dezavantajos (dobanda mare la euro, costuri substantiale). Pe site-ul Dacia este prezentata si varianta Modelease care este foarte interesanta pentru ca permite un avans de 10% si o valoare reziduala de 20%. Nu ai treaba cu banca ci doar cu RCI Leasing prin intermediul dealer-ului. Este atractiva pentru ca iti iei masina printr-un avans mic (cca 42 milioane, 22 avans pentru retinere autoturism si 20 cind iti vine masina peste cca 1 luna), lucru important pentru cei care nu au economii substantiale. In plus 20% din pretul masinii il platesti peste 5 ani ca valoare reziduala. Daca nu vei vrea sa platesti aceasta suma, este prevazut in contractul de leasing, RCI poate prelua masina deci ai platit doar 80%. Desigur poti alege sa achiti si cei 20% si sa incerci sa vinzi masina daca vrei sa-ti iei alta noua. |
Megane III
madalina82 |
#1408
QUOTE(simon @ 23 Aug 2005, 11:22) Pe site-ul Dacia este prezentata si varianta Modelease care este foarte interesanta pentru ca permite un avans de 10% si o valoare reziduala de 20%. Nu ai treaba cu banca ci doar cu RCI Leasing prin intermediul dealer-ului. Este atractiva pentru ca iti iei masina printr-un avans mic (cca 42 milioane, 22 avans pentru retinere autoturism si 20 cind iti vine masina peste cca 1 luna), lucru important pentru cei care nu au economii substantiale. In plus 20% din pretul masinii il platesti peste 5 ani ca valoare reziduala. Daca nu vei vrea sa platesti aceasta suma, este prevazut in contractul de leasing, RCI poate prelua masina deci ai platit doar 80%. Desigur poti alege sa achiti si cei 20% si sa incerci sa vinzi masina daca vrei sa-ti iei alta noua. Simon, tu vorbesti de Leasing aici. Eu nu am cum sa-mi iau pe leasing caci sunt persoana fizica. Ironik, ai niste argumente solide. Si eu sunt in dificultatea de a alege CREDIT EURO VS CREDIT LEI. ![]() |
DSN
clima
- B 39 DSX
sir_zven |
#1409
Exista leasing si pentru persoane fizice si daca nu ma insel "Modelease" de la Dacia este chiar asa ceva.
Logan Laureate 1.4
#1410
Pentru Logan leasing-ul nu are nici un avantaj pentru persoane fizice. Doar pentru juridice, iti recuperezi tva-ul.
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 20th July 2025 - 08:51 |
