Mio C250
Mio C250
Laurentziu83 |
12 Dec 2007, 14:59
Membru autentic Group: Members Posts: 7.589 Joined: 17 May 05 From: Tziganistan |
Alydor |
12 Dec 2007, 15:26
Pressar Group: Members Posts: 2.771 Joined: 12 March 06 |
iesi cu el afara la cer liber si asteapta... poate sa dureze si 10 minute pana iti gaseste satelitii... sau baga un ochi in SYS.txt si vezi la setarile de GPS ce scrie... Vezi ca sunt postate continuturi de sys.txt pe forum
Suma respectelor, Alydor |
- Igo8 - C520
Laurentziu83 |
12 Dec 2007, 16:05
La mine nu scrie prea multe in setari. Fisierul sys.txt contine urmatoarele:
[debug] smart_2d=1 slowsim=1 loop_sim=1 [interface] mio=1 [speedcam] usemio=-12,90,37,27 enable_at_startup=1 Sa-i mai adaug ceva? Are gps incorporat SirfStar 3. Inclin sa cred ca e din pocketpc.ini eroarea... Vad ca la GPS protocol e setat NMEA, atat la default cat si la setarile pentru al meu. (nu am mai adaugat si setarile pentru alte device-uri, umpleam spatiul degeaba) [DEFAULT] info_names = "Unknown" ;can manage backlight value blight_value_manage = 0 ;can mange DIM/sleep blight_keys_manage = 1 ;gps settings gps_internal = 0 gps_protocol = "NMEA" gps_com_port = 1 gps_com_port_speed = 4800 ;brightness settings blight_max = 10 blight_reverse = 0 blight_smart=5 blight_key_BrightnessBA1 ="Brightness" blight_key_BrightnessAC1 ="ACBrightness" blight_key_BrightnessBA2 ="BacklightLuminanceLevel" blight_key_BrightnessAC2 ="ACBacklightLuminanceLevel" blight_key_BatteryTimeoutBA = "BatteryTimeout" blight_key_BatteryTimeoutAC = "ACTimeout" blight_key_BacklightOnTapBA = "BacklightOnTap" blight_key_BacklightOnTapAC = "ACBacklightOnTap" blight_key_MaxBrightnessBA="" blight_key_MaxBrightnessAC="" blight_key_OnOffBA = "OnOff" blight_key_OnOffAC = "ExtOnOff" ;only registry values blight_setmode1 = 1 ;use CPQSetH3800Brightness() blight_setmode2 = 0 ;use iPAQSetOnPowerBrightnessLevel() blight_setmode3 = 0 ;iPAQ H3xxx,but not for H38xx H39xx blight_setmode4 = 0 ;MIO blight_setmode5 = 1 ;MIO blight_setmode7 = 1 ;use event BackLightChangeEvent blight_useevent_1 = 1 ;use event SDKBackLightChangeEvent blight_useevent_2 = 1 ;use event BackLightNotifyEvent blight_useevent_3 = 0 ;use WM_WININICHANGE blight_useevent_4 = 0 ;use key_bd1() event blight_useevent_5 = 0 ;SystemIdleTimerReset(); blight_useevent_6 = 0 ;Keybd2(); blight_useevent_7 = 0 ; length of the sound buffer in milliseconds sound_q_length = 0 -------------------------------------------------------- [MIOC250] gps_internal = 1 gps_protocol = "NMEA" gps_com_port = 2 gps_com_port_speed = 4800 tmc_port = 1 tmc_speed = 38400 gx_width=320 gx_height=240 gx_format=160 gx_xpitch=2 gx_ypitch=640 gx_orientation=1 blight_min = 1 blight_max = 8 blight_reverse = 0 blight_smart = 4 blight_key_BatteryTimeoutBA = "BatteryTimeout" blight_key_BatteryTimeoutAC = "ACTimeout" blight_key_BacklightOnTapBA = "BacklightOnTap" blight_key_BacklightOnTapAC = "ACBacklightOnTap" blight_key_OnOffBA = "OnOff" blight_key_OnOffAC = "ExtOnOff" blight_setmode5 = 1 Pe GPS am schimbat din 0 in 1 si din 1 in 2, dar degeaba. 12 Dec 2007, 20:06: A MERS, DUPA REINSTALAREA SOFTULUI. MAI INCERC MAINE CU ALTE HARTI. This post has been edited by Laurentziu83: 12 Dec 2007, 20:06 |
Laurentziu83 |
15 Dec 2007, 00:05
Revin iar in acest topic.
Dupa reinstalarea softului original (venit pe CD-ul din pachet), am constatat o scadere a sensibilitatii GPS-ului, in sensul ca receptioneaza mult mai greu satelitii, de exemplu daca il iau de pe bord si ma uit la el, ma trezesc ca pierde receptia. La fel si daca il pun in buzunarul interior de la haina. Mie nu mi se pare normal. Aveti idee de la ce ar putea fi? Mentionez ca nu l-am demontat, scapat jos, nimic din toate astea, totul dupa ce am incercat sa-i introduc alte harti si ce implica din asta. Vreo setare din soft, am stricat cumva sistemul de operare al PNA-ului (desi in rest merge bine, fara probleme). This post has been edited by Laurentziu83: 15 Dec 2007, 00:07 |
DFA |
17 Dec 2007, 12:11
moderator://DC/Logan Group: Moderatori Posts: 3.514 Joined: 30 September 05 From: Buzău, RO |
Poate e doar o impresie de-a ta...
Fă niște teste în diferite locații, cu cronometrul în mână, să vezi cât timp îi i-a să vadă 3-4 sateliți. |
Logan III Comfort
ECO-G 100cp
2021 sedan
ex Logan I 1.5 |
hms |
17 Dec 2007, 14:42
Membru incepator Group: Members Posts: 40 Joined: 21 September 05 From: Galati |
Fa hard reset. Apoi reinstaleaza si vezi daca mai observi ceva probleme.
Clio Symbol
2004 1,4 8V
Laurentziu83 |
17 Dec 2007, 22:29
I-am facut hard reset, instalat, reinstalat, folosit fara interventii la fisiere, folosit cu setari de 1 si 2 in loc de 0 si 1, la fel, semnalul la sateliti este foarte slab, daca il las la geam de-abia gaseste 3 sateliti (nici pe aia tot timpul), daca il pun pe bord poate sa gaseasca cativa sateliti (sau nu), daca il iau in mana pierde semnalul, etc, se comporta exact ca un aparat de radio la care s-a intrerupt firul de la antena.
Momentan l-am dat la cineva care se pricepe, daca nu si nu, la garantie cu el, pacat insa ca plec sambata pana in Austria, poate reusesc sa-l fac pana atunci. |
Amedeus |
17 Dec 2007, 23:29
Membru cu Logan Group: Members Posts: 1.907 Joined: 13 December 04 From: TM |
"La fel si daca il pun in buzunarul interior de la haina."
Din buzunar, sigur nu merge. |
Megane Sedan IV Tce 116
2019 Business
hms |
18 Dec 2007, 08:45
Daca trebuie dus la garantie, ti-l pot da pe-al meu sa-ti faci treaba.
Nu mai am anul asta plecari din tara. Poate vara viitoare. |
Clio Symbol
2004 1,4 8V
Laurentziu83 |
21 Dec 2007, 22:56
Problema s-a rezolvat !
S-a dovedit a fi de la cardul de 4 gb pe care il montasem pe el. Am scos cardul, am repornit gps-ul, l-am lasat la geam cateva minute, timp in care s-a conectat la 5-6 sateliti si a mers perfect. L-am testat prin oras si la fel a mers fara gres. Concluzia: Nu instalati pe el carduri mai mari decat aveti nevoie. Daca va incap hartile pe soft si, la Mio incap toate in memoria lui, nu va complicati sa mai instalati si cine stie ce memorii mari. Una de 1 gb e suficienta, cred ca suporta bine si de 2 gb, dar nu am o astfel de memorie ca sa incerc. Multumesc tuturor pentru sprijinul acordat ! Nu aveati de unde sa stiti acest amanunt si nici mie nu mi-a trecut prin cap. |
C@talin |
22 Dec 2007, 01:39
mie tot numi plac pna-urile
Range Rover
V8 5.0
Vogue SE
R19/16v |
22 Dec 2007, 01:47
Oldschool Member Group: Moderatori Posts: 13.793 Joined: 2 December 04 From: Ploiesti |
@Laurentiu cu 1 si 2GB functioneaza ok.
DS
5H
Laurentziu83 |
23 Dec 2007, 08:41
Intr_adevar, a mers perfect, m_a dus cu bine pana la arad, ba chiar pe ultimele sute de kilometri l_am folosit in depasiri, sa vad configuratia drumului. Aici vede 10 sateliti, deh, mai aproape de civilizatie.
cioco_cmc |
5 Jan 2008, 19:19
Membru incepator Group: Members Posts: 4 Joined: 5 January 08 |
Care stie sa imi explice si mie cum pot sa fac un hard reset pe un mio c250?????
Il am din spania am cd de romanina ptr el insa nu merge dupa ce ii instalez harta romaniei!!! Nu imi mai intra deloc in miomap..Va rog sa ma ajutati!!!!!!!!!!!!!!!!!!! |
1410
1997
- ct-33-cmc
Alydor |
6 Jan 2008, 10:28
tii apasat butonul de oprit/pornit cam 10 secunde
- Igo8 - C520
cioco_cmc |
6 Jan 2008, 18:48
am incercat si resetu iar acum cand ii dau instalare dupa cd imi zice memory full si nu imi mai intra deloc in mio.
cum ii pot formata hardu sau cum pot sterge ce are pe hard ?????? |
1410
1997
- ct-33-cmc
GoGu |
6 Jan 2008, 20:06
Prea de la tara Group: Moderatori Posts: 1.970 Joined: 14 August 03 From: Iasi |
Cu Mio Transfer hack poti accesa flash-ul device-ului (nu are HDD...)
Gasesti link in topicul despre c220 (care e cam aceeasi treaba cu c250-ul). Ai grija ce stergi de acolo, sa nu omori windows-ul, sterge doar din hartile din directorul Maps din My Flash Disk\Miomap\miomap Cat despre instalarea hartii RO in mod oficial cred ca e posibil doar daca aparatul vine cu o licenta full europe (si aici cu problemute, de ex. eu am c220 cu licenta east-europe + Grecia, si cu toate astea nu imi accepta "oficial" ultimele 2 harti ale Romaniei). |
Scenic 1.5dCi
recolta 2012
cioco_cmc |
7 Jan 2008, 11:45
k mersi am facut si asta am instalat acum dupa un cd din romania cu licenta dar zice hardewere id changed si acum nu stiu ce sa ii mai fac ????????
astept sugestii va rog ce ii pot face mai departe |
1410
1997
- ct-33-cmc
GoGu |
7 Jan 2008, 12:47
Daca ai instalat de pe alt cd (chiar "original"), altul decat cel inclus in pachet cu aparatul, licenta NU este valida (fisierul license.db e legat de hardware-ul aparatului).
Oricum, mesajul "hardware id changed" e de la licenta care nu se potriveste cu hardware-ul. Licenta aceepta doar anumite harti (depinde pe ce zona ai licenta) si, mai mult decat atat, anumite versiuni ale hartilor. De ex. eu am licenta pe Europa de est, inclusiv RO, dar ultimele 2 harti nu mi le mai accepta. Mai mult cauta si tu pe google ca intram in zona "gri" si nu e voie pe aici |
Scenic 1.5dCi
recolta 2012
cioco_cmc |
7 Jan 2008, 21:18
bine mersi frumos ma descurc eu de aici
1410
1997
- ct-33-cmc
RIon |
29 Mar 2008, 22:12
pasionat Group: Members Posts: 2.835 Joined: 22 May 04 From: CJ |
Eu caut in POI niste hoteluri in Poiana Brasov, si nu mi le gaseste... Sport si Bradul... voi le aveti???
Skoda
Octavia 2
- de CJ www.raresion.ro
Alydor |
30 Mar 2008, 13:49
- Igo8 - C520
RIon |
30 Mar 2008, 15:50
kessy
Skoda
Octavia 2
Alydor |
30 Mar 2008, 21:41
szive...
- Igo8 - C520
kmn |
22 Apr 2008, 18:44
Membru incepator Group: Members Posts: 71 Joined: 24 May 07 From: Bucuresti |
salut ,
sunt si eu prospat detinator al unui mio c250 si as vrea sa stiu daca merge cumva pe el pus igo 2008 3d daca si la instalat cineva sa lase niste impresii despre cum ii merge merci anticipat |
Fluence
2012 dynamique
- B xxx KMN K_M_N
Alydor |
22 Apr 2008, 18:54
Merge... dar cam prost avand in vedere harta (si asa varza) a romaniei si cei 32 de mega de ram cu care e dotat...... ramai deocamdata la 3.3 si ultimile harti
Suma respectelor, Alydor This post has been edited by Alydor: 22 Apr 2008, 18:55 |
- Igo8 - C520
cornelus |
24 Apr 2008, 10:59
Membru incepator Group: Members Posts: 21 Joined: 28 February 06 From: Bucuresti |
Am pus mio versiunea 3.3 pe mio c250 ,problema este ca am modificat fisierul sys in toate felurile posibile citite aici si nu am reusit sa vad decit pe jumatate de display imaginea . M-am lasat pagubas . Acum am pus un skin ( riks 4.4 ) gasit tot pe forum care imi place cu arata . Intrebare: Influenteaza negativ functionarea aparatului acest skin daca am versiunea mio 3.2 din sept . 2006 .
Cum pun o versiune mai noua sau cum fac update la V3.3 ? Multumesc anticipat ! |
vw
passat
- B 01 A Y G
cornelus |
27 Apr 2008, 21:24
Nu ma ajuta nimeni sa pun si eu v3.3 pe mio c250 ?
vw
passat
- B 01 A Y G
cornelus |
4 May 2008, 05:53
Multumesc ! l-am vandut .
vw
passat
- B 01 A Y G
mariusd4 |
9 Jan 2009, 11:52
Membru autentic Group: Members Posts: 3.967 Joined: 16 October 07 From: Bucuresti |
Acum a venit momentul sa scriu si eu . De ieri sunt posesorul unui Mio c250 sh si cred ca este facut PDA caci are o multime de aplicatii . Singura pb cu el ar fi sau cu mine caci nu booteaza de pe card sau nu stiu eu cum sa intru din Mio Map pe Igo. Daca il pornesc normal intra pe MIO si nu pot folosi Igo de pe el, daca scot si reintroduc cardul se incarca cu toate aplicatiile de PDA si pot fol Igo . As putea sa fac cumva sa-l fac sa booteze de pe card fara sa mai fiu nevoit sa-i scot cardul de memorie ? Va multumesc pentru sfaturi si v-as ruga daca se poate sa imi dati un sfat la mariusd444@yahoo.com
Renault/Skoda
Logan/Fluence /Octavia/BMW/Octavia
2007/2010/2014/2012/2019
- B 112 ... "Nebunul care perseverează in nebuia sa va deveni înțelept".
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 24th May 2024 - 02:44 |
