Logan 1.4 from India
martin245 |
![]() EX PAT Group: Members Posts: 913 Joined: 1 April 06 From: Karlsbad Germany (again) ![]() |
logan 14 mpi Simply RED
- GB 1 Bessy Regs
mahesh |
Membru incepator Group: Members Posts: 9 Joined: 4 January 08 ![]() |
![]() I stay in Mumbai (Bombay). I have bought a new Renault Logan 1.6 GLX (Mahindra-Renault Logan 1.6 GLX as it is called in India). Its been 2 months that I have bought this wonderful car. I have driven around 1500 KMs with the highest speed touching 130 KM / Hr. I have not yet been given a user manual for my car. I will receive it soon from the dealer. However, whatever I have read on internet for this car - it seems it is fair enough if I drive the car at 5th gear with a RPM of 3000 - 3500 (130 KM / hr) within first 3 months. Just wanted to check on this message board if my assumption for this is correct. If not, I will drive it at lower speeds. However, this car has so much of power and the engine responds so well that I get too tempted to drive it at this speed considering even when that the car is new (just 2 months old). Although driving at higher speed - I make sure that I drive safe. I would drive at higher speeds only on roads that are meant to be driven on higher speeds - There is a express way in india connecting two twin cities viz., Mumbai and Pune. The distance is 180 KMS. In normal conditions I make sure I drive at lower speeds (max 80 KMs/Hr on 5th gear). Also I have one more question. I change my gears as follows: 2nd Gear 20 Kms/hr 3rd Gear 40 Kms/hr 4th Gear 50 Kms/hr And after this, I am in my 5th gear. Is the above gear change good enough for logan? If not, then what it should be? Regards, Mahesh |
Mahindra-Renault
2007 1.6 GLX
martin245 |
Hi
Change gear at 2000RPM (up and down) You can go round at less revs in 4th like around town just by touching the gas pedal BUT if you need to go faster than change down to 3rd anyway if you have driven 1500km you have now run in your car ![]() so off you go now and feel and enjoy your power ![]() 1st 2nd and 3rd speeds are OK but I would wait till at least 60 till 4th gear and at least 80 till 5th ![]() I hope you get your handbook soon .I would like an English one as well ![]() Stu This post has been edited by martin245: 7 Jan 2008, 21:13 |
- GB 1 Bessy Regs
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 18th July 2025 - 05:19 |
