4 Pages < 1 2 3 4 >
> turometru..., care ii maxim ?
ady134u
post 29 May 2008, 19:50
Post #61
QUOTE(pskint25 @ 29 May 2008, 14:41)
baiatu' cu alimentatia.. parerea mea e sa te lasi de meserie...
nu esti coerent nici in exprimare (gramatica) nici in idee...
http://www.daciaclub.ro/index.php?showtopic=113487&hl=
din toate posturile tale reiese un singur lucru... NIMIC.
am patiti am patit asta eset..da nu aveam turatii mari:)
maxim a fost 4000 cand am patit ....
solenza confort ---- - CJ-09-BSH
[B]T.S.R.[SIZE=7][COLOR=red]
Brambus
post 29 May 2008, 19:57
Post #62
member
This post has been edited by Brambus: 29 May 2008, 19:58
Renault Megane 2 2007 Megane 2 R26 - B969FEF
andrei041
post 29 May 2008, 20:21
Post #63
2/E
QUOTE(miki_slz @ 29 May 2008, 17:42)
Eu am facut o depasire in 3 la 5500 si aveam 120 . Nu mi s-o taiat nimic.
Pai si ce ar fi trebuit sa se taie? Alimentarea se taie la 6000rpm in treptele 3,4 si 5 rolleyes.gif
Ford Fiesta 1.4 tdci 2008 - Ghia
miki_slz
post 29 May 2008, 21:06
Post #64
Solnitzar
pai zicea colegu ca lui ii s-o taiat firu biggrin.gif la 4000 si de aceea mi se parea ciudat.
Dacia Solenza/ NOVA GTI 2004 Scala /98 - CJ 31 MKI/CJ 03 MKI
R19/16v
post 29 May 2008, 21:43
Post #65
Oldschool Member
QUOTE(andrei041 @ 29 May 2008, 21:21)
ALIMENTATIE, oameni buni! ALIMENTATIE!!
DS 5H VRSCA Screamin' eagle
AR-18-MOS
post 29 May 2008, 21:45
Post #66
( -_・) ︻デ═一
QUOTE(andrei041 @ 29 May 2008, 20:21)
Si ECU de unde stie in ce treapta esti ... ?
miki_slz
post 29 May 2008, 21:51
Post #67
Solnitzar
This post has been edited by miki_slz: 29 May 2008, 21:51
nh1980ro
post 29 May 2008, 22:31
Post #68
QUOTE(R19/16v @ 29 May 2008, 22:43)
I-a picat sanvishu' din mana cand a vazut ce turatie are si i s-a taiat alimentatia.. icon_mrgreen.gif
Brambus
post 30 May 2008, 08:15
Post #69
member
post 30 May 2008, 09:31
Post #70
ce topic de balarii...pacat ca nu se poate muta pe fortiuning...
marius80_eugen
post 30 May 2008, 09:49
Post #71
QUOTE(R19/16v @ 27 May 2008, 10:36)
De unde stie ECU in ce viteza e masina?
Ecu calculeaza treapta in functie de turatie si viteza !
QUOTE(AR-18-MOS @ 27 May 2008, 18:48)
Depinde si ce cauciucuri ai tu pe berlina ... wink.gif Ca eu pe asfalt usccat nu imi intra ABS-ul deloc la franari de urgenta ... smile.gif
@andrei041, cand se "taie" alimentarea, motorul NU se opreste, ci doar oscileaza intre anumite valori(mici)de turatii.
Intre valori MARI ! Adica intre 5.800 - 6.200 !
QUOTE(ady134u @ 27 May 2008, 19:22)
totusi la patinare pe loc poti da maxim turatie ca nu afce chesti dinastea....
ca am obsservat cum trec de 6000 poc ....da daca incerci pe iarba mereg pana in 7000 la mine asa sa intamplat:) (stand pe loc...)
sau ma mai gandeam ca se ia in calcul si viteza care o atingi intre 50-60 km/h si se taie:))alimetatia
Nu aveai cum sa ajungi la 7000 nici macar din cauza oscilatiei si a inertiei acului turometrului !!!
QUOTE(Solenzul @ 29 May 2008, 14:04)
Scuzati-ma ca ma bag si eu in vorba,  blush.gif  dar fiind vorba de turatii am si eu o intrebare.
As vrea sa stiu care e turatia optima a motorului la care sa trec dintr-o treapta de viteza inferioara la una superioara. Unii mi-au spus ca la 2000 altii la 2500 alti la 3000. Nu stiu ce sa mai cred, in loc sa ma lamureasca m-au bagat total in ceata.  wacko.gif  Am o solenza clima 1.4 mpi din 2003.
Poti sa schimbi si la 2000 ture , dar si la 5.500 . Optima depinde in functie de viteza , contextul in care conduci si ce vrei sa faci mai departe . In medie incearca sa te mentii in mod constant pe la 2.300 - 2.500 ture .
QUOTE(bogdanmardare @ 29 May 2008, 15:14)
@Solenzul: turatia de cuplu maxim este de 2800 rotatii, deci la acea turatie (sau peste) este bine sa schimbi vitezele... Eu personal schimb la 3000 si peste,exceptand treapta I unde schimb la 2500 (unii colegi de forum spun ca asta e condus sportiv). Daca vrei sa schimbi la 2800, trebuie sa schimbi repede, altfel scade destul turatia si simti cum trepideaza (nevasta-mea schimba la 2800, dar se misca incet cu facaletul prin mamaliga biggrin.gif, asa ca turatia scade cam la 2000).
Nu are legatura acea turatie de cuplu maxim cu schimbatrul vitezei . Practic , tu la acea turatie abia ai cuplu , deci de acolo in sus ar trebui sa accelerezi daca ai nevoie . O schimbare de treapta in momentul cuplului nu te ajuta cu nimic , pentur ca vei "cade" cam pe la 1800 ture , und enu ai nici cuplu si nici putere . In schimba daca o schimbi pe la 4.200 - 4.500 , pici exact langa turatia de cuplu si atunci ii dai iar pana la puterea maxima .
Ai dreptate la viteza de sch9imbare a treptelor . Eu schimb treptele destul de repede si sunt cuplat in treapta superioara , inainte sa-mi ajunga turatia motorului mai jos decat daca ar fi in acea treapta cuplata .
Unii colegi nu au mers cu adevarat sportiv cu masinile lor si o turatie sau un zgomot mai puternic le dau transpiratii ...
La mersul normal nu cred ca trebuie  sa schimbi neaparat la 2500 3000. fiecare schimba dupa situatie si dupa cum simte ca merge masina.
QUOTE(nh1980ro @ 29 May 2008, 17:46)
Asa e.
Dar nu crezi ca era bine sa schimbi a 4-a la 5500? Cred ca aveai mai mult demaraj.. smile.gif
a -4-a la 5.500 ai cam 145-150 ...
QUOTE(AR-18-MOS @ 29 May 2008, 21:45)
repet : stie turatia si viteza , calculeaza singur treapta !
pskint25
post 30 May 2008, 10:32
Post #72
Membru de ieri pe maine
e un topic menit sa evidentieze subcultura? ti se taie alimentatia? duceti-va la ce se intampla doctore nu pe forumul de masini.. laugh.gif 090.gif 168.gif LolLolLo.gif radmasa.gif gun3.gif post-336-1110552475.gif death.gif coolspeak.gif sofer5.gif
turatii.. fiecare schimba cum poate. din ce observ, cum e situatia cum crede ca e mai bine pentru masina, sau pentru el.. vrei sa iei fata cuiva sau esti in depasire o turezi peste valoarea optima care cred ca e la cuplul maxim, pe langa 2800.Nu are nimeni un grafic dyno sa se vada cum trage masina la 6000 ture si la 3000? sa inteleaga lumea de ce e bine sa schimbi viteza si la ce turatii...
somebody please stop this massacre!!!
This post has been edited by pskint25: 30 May 2008, 10:35
Dacia Solenza 2004 Scala 1.4 MPi... vreau RS - B81PSK
Always ahead!
marius80_eugen
post 30 May 2008, 10:42
Post #73
Exista si un astfel de grafic ... dar de la Logan NU mai e valabil , apoi nici la mine ca am flash facut . Apoi in acel grafic ... nu intervin nici rezistenta la inaintare , nici greutatea care o are cineva in masina la un moment dat , nici calitatea benzinei care poate diferi , nici diferenta de suprafata pe care se deplaseaza masina .
This post has been edited by marius80_eugen: 30 May 2008, 10:44
pskint25
post 30 May 2008, 13:11
Post #74
da marius dar in cazul vantului, benzinei sau altor impedimente scaderea e proportionala in functie de regimul motorului turatie/treapta. Unde e varf in dyno test (fara rezistente) e varf de putere si daca ai rezistenta...
Always ahead!
marius80_eugen
post 2 Jun 2008, 16:23
Post #75
Pai daca tu ajungi la 5500 ture intr-a 5-a , atunci intr-adevar , nu conteaza vantul si restul .
pskint25
post 3 Jun 2008, 10:57
Post #76
~5200 ..se avatar... si daca as fi mers in trena unui SUV as fi ajuns probabil si la turatii mai mari... dar forta motorului era in momentul acela egala cu forta de frecare a aerului de masina= forta de rezistenta la inaintare...
Always ahead!
Solenzul
post 8 Jun 2008, 18:05
Post #77
Membru curios
Am o noua intrebare. Nu ma pricep asa de bine si am solenza de curand. Am ajuns cu solenza mea la 6.000 de ture in treapta a 5-a la o viteza de 140 km/ora. Este bun raportul turatii-viteza in treapta a 5-a? Solenza mea e din 2004, clima.
Dacia Solenza 2004 Clima ; Duster Explorer 2017 ; - AG-09-***, AG-26-***
nh1980ro
post 8 Jun 2008, 18:21
Post #78
Da sigur erai in viteza a 5-a, atunci iti patineaza ambreiajul.
Incearca sa-l mai reglezi daca se mai poate.
pskint25
post 10 Jun 2008, 14:53
Post #79
nu are cum, sau nu erai in a 5-a. eu intr-a 5-a la 195 aveam 55oo rot/min.
Always ahead!
AR-18-MOS
post 10 Jun 2008, 15:41
Post #80
( -_・) ︻デ═一
Si nu ti-ai luat zboru la viteza aia ... ?
nh1980ro
post 10 Jun 2008, 15:42
Post #81
E ca la elicopter, turometrul se invartea si stabiliza masina .. icon_mrgreen.gif
toto
post 10 Jun 2008, 15:50
Post #82
Destul de fost membru
QUOTE(pskint25 @ 10 Jun 2008, 16:53)
in ce conditii ai obtinut aceasta performanta...?!?
Honda CIVIC 5D 1.8 Sport M/T - '07
romania, frumoasa tara...pacat ca e locuita...
AR-18-MOS
post 10 Jun 2008, 15:54
Post #83
( -_・) ︻デ═一
Solenzul
post 10 Jun 2008, 21:45
Post #84
Membru curios
Eram cu viteza a 5-a. Care sa fie problema? Cum o pot rezolva? Nu cred ca patineaza ambreajul... dry.gif
pskint25
post 11 Jun 2008, 08:43
Post #85
pe A2, o zi insorita de vara cu benzina 98, nu aveam atunci chip tuning si evacuare, 2 persoane in masina, si la un moment dat daca nu ma insel in calarasi pe la mk 70 e o panta mai mare. Aveam deja 150 daca nu ma insel sau chiar mai mult la inceputul ei, si cand a inceput rampa am prins din spate un Range Rover si am mers in trena lui, dupa ce l-am depasit am facut poza din avatar, adica atunci cand drumul a ajuns la orizontala...
AR-18-MOS .. glumetule tongue.gif era foaaaarte instabila... am riscat enorm sa fac asa ceva mai ales sa merg in trena aluia... marele meu noroc a fost ca nu a batut vantul in nici o directie pe toata durata drumului... si am alergat ca ma grabeam al dracu de rau...trebuia sa ajung in Bucuresti urgent... A2=56 min biggrin.gif
Always ahead!
marius80_eugen
post 11 Jun 2008, 10:26
Post #86
QUOTE(Solenzul @ 8 Jun 2008, 18:05)
Daca tu chiar erai intr-a 5-a , atunci iti patineaza RAU ambreiajul . La turatia aia ar trebui sa fii in treapta a 4-a la 140 !
QUOTE(pskint25 @ 10 Jun 2008, 14:53)
QUOTE(AR-18-MOS @ 10 Jun 2008, 15:41)
Viteza era cea afisata de kilometraj , deci real era mai mica ( 175 aprox ) , DAR este totusi o realizare . Partea buna e ca omul traieste si masina este intreaga ! icon_mrgreen.gif Sa nu uitam totusi ca era in coborare si in spatele unui SUV ... icon_mrgreen.gif
ionutt daniel
post 11 Jun 2008, 15:21
Post #87
Nu e imposibil. Eu cand aveam Solenza urcam frecvent la 180(maxim)km/h pe drum drept, conditii normale de drum. Cum a specificat el, drum in panta si alta masina in fata mai poate creste viteza. Oricum, nu recomand cuiva sa mearga asa cu Solenza, care de la 145-150 km/h este destul de nesigura, plus ca vantul face un zgomot destul de mare.
renault espace 2.2 - bulgariax4
AR-18-MOS
post 11 Jun 2008, 15:29
Post #88
( -_・) ︻デ═一
Rachete frate ... ! :mellow
darius
post 11 Jun 2008, 18:40
Post #89
Seat Cordoba 6L - xx-xx-xxx
marius80_eugen
post 12 Jun 2008, 14:08
Post #90
AR-18-MOS cred ca ti-am mai spus ca nu avem 112 KW , nici macar la cuplu , care nu se masoara in KW !
darius : up.gif
This post has been edited by marius80_eugen: 12 Jun 2008, 14:09
4 Pages < 1 2 3 4 >
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 27th July 2025 - 00:15
