logan 1.5dci vs passat 1.9tdi, :))
ecstasy_4u06 |
![]() Membru Group: Members Posts: 180 Joined: 19 July 07 From: Alba Iulia ![]() |
2003 Authentique
R19/16v |
Da
DS
5H
M i h a i |
![]() _______________________ Group: Members Posts: 5.669 Joined: 12 September 06 ![]() |
R19/16v>>Argumente tehnice?? intr un cuvant...De ce DA??
![]() This post has been edited by MHY: 29 Jan 2008, 23:52 |
Kojak |
...ce porcarie!
![]() passat 1.9 TDI = 131cp logan 1.5. DCi = 65 sau 70cp ![]() ...cred ca asta spune tot ![]() |
R19/16v |
1. 1.5dci - 79 cai/t, 1.9TDI - 82cai/t
2. 1.9TDI poate sa aiba 115 cai: QUOTE(tdiclub.com) 1.9 litre 4-cylinder 115hp "PD" - again similar to the A4-type engine but with the "pump-nozzle" injection system. Although the peak power is only slightly more than the 110, maximum torque is much higher and the engine has lower exhaust emissions. VW intends to gradually replace the 110hp models with this engine. Not available in North America, reportedly because the exhaust emission controls used on this engine cannot be used with fuels containing greater than 50 parts per million of sulfur, whereas at this writing (1999) fuels in North America can have as much as 500 parts per million. Models with this engine have badges with a silver "T" and red "DI". |
DS
5H
4abc |
![]() Sofer de duba! Group: Members Posts: 62 Joined: 19 March 07 ![]() |
Passatul B5.5 adica cel din imagine a fost disponibil la vremea lui cu urmatorele motorizari:
1. 1.9TDI-101cp 2. 1.9TDI-131cp 3. 2.5TDI-150cp In nici un caz nu cred ce e acolo.Mi se pare o aberatie crunta...poate daca passatul avea turbina defecta..nici asa nu cred.. ![]() PS:Motorul de 115cp este pe cel fabricat pana in 2001 si il bate de la distanta si pe cel de 1.9Dci de 120 cp! This post has been edited by 4abc: 30 Jan 2008, 00:17 |
Kangoo
2004 DCI 60
- 56-MDB
R19/16v |
Dac'asa zici tu, asa o fi, dar daca o spunea unul care sa n-aiba golf in semnatura, il credeam
DS
5H
4abc |
Nu e vorba de asta...insa e vorba de puterea motoarelor si de masinile care sunt acolo.Daca nu aveam Golf in semnatura ma credeai??...hai ca il scot...astea sunt specificatiile motoarelor...sa nu mai vb de cuplu...
In fine...eu am dat datele tehnice si nu mai era nevoie sa imi exprim parerea...de subintelege... |
Kangoo
2004 DCI 60
- 56-MDB
R19/16v |
Wiki nu e de acord cu postul #6
DS
5H
andr3y |
![]() Membru autentic Group: Members Posts: 200 Joined: 23 May 07 ![]() |
nici eu nu cred ... e regizat filmuletu
Megane 2.2
2007 / luxe privilege
- b 89 RUN
R19/16v |
QUOTE(youtube) About this video: corectare, are doar i rosu si doar 101 cai, acum am aflat. deci un 101 cai contra 85 cai. Mystery solved... |
DS
5H
rhunder |
![]() Membru autentic Group: Members Posts: 263 Joined: 15 August 06 From: Bucuresti ![]() |
si poate sunt ceva diferente si la greutatea masinii?
![]() Da daca ar alerga de 3 ori mai mult ca distanta care ar fi rezultatul? |
Dacia SuperNova
Clima
- b25wzj Clio II 2005 1.5 DCI 65
Megane Prima 1.6 16V - temporar! :) VW Golf V 1.9 tdi |
4abc |
Passatul are aprox 1500kg.Nu stiu cat are Loganul...insa ceea ce este evident este cuplul masinilor...adica din datele tehnice se poate deduce rezulatatul clar..pe langa asta haideti totusi sa fim realisti...
Kangoo
2004 DCI 60
- 56-MDB
R19/16v |
1075kg are loganul.
Si cam ce inseamna QUOTE pe langa asta haideti totusi sa fim realisti... ? |
DS
5H
Kojak |
daniel4ro |
![]() forumist anti Group: Members Posts: 1.166 Joined: 16 September 07 From: B U Z Ă U city ![]() |
explicatia e simpla: soferul passatului alimenta motorina de pe marginea variantei, de la tractoristi, pe cand "pilotul" Loganului alimenta doar de la PECO de firma
![]() Ei, cum vi se pare? ![]() |
Megane 2.1
2004 SEDANiel4ro Privilege, 1.5 DCI , 82 CP
- Numar DREPTUNGHIULAR
ncristi |
![]() Membru autentic Group: Members Posts: 1.910 Joined: 9 April 05 ![]() |
Tipul cu loganul rosu a amai aparut de cateva ori pe youtube...intr-unul din filmulete si-a lasat o pereche de cauciucuri pe asfalt.
Loganul are motor de 65 hp si probabil "cipuit". Dus pe undeva pe la 80-90hp si avnd o masa mai mica este posibil ca filmuletul sa fie real. Asta in conditiile in care passatul sa aiba motorul de 105 hp. This post has been edited by ncristi: 30 Jan 2008, 10:46 |
kadjar - 1.2 tce 130 hp
ZEN - 2017 Sandero stepway 0.9 tce
Ford focus 1.6 tdci 110 hp Ford ecosport 1.0 ecoboost 125hp Skoda octavia 1.2 tsi 105 hp |
sb-55-dan |
![]() Membru si atat Group: Members Posts: 833 Joined: 6 July 05 ![]() |
Explicatia e clara..Passat-ul e cel de 101 cai si la greutatea lui demareaza mai greu. Si apropo cel de 115 cai nu se compara cu dci-ul de 120 de cai, avantaj clar in favoarea dci-ului.
renault
Laguna II, Laguna III
2003, 2011 Renault Laguna II Dynamique 1.9 Dci 120CP
Renault Laguna III Dynamique 2.0Dci 150CP |
bonk |
![]() Membru autentic Group: Members Posts: 305 Joined: 9 June 06 ![]() |
=)) .... super tare faza .... mai conduc un caddy din cand in cand ... 101 hp ... si n-a prea stat logan in fata
Megane 1 /1.4 16v
- GJ-05-...
sb-55-dan |
cum a fost explicat si mai sus intr-un post daca are DI rosu nu inseamna ca are 131 CP!!!
inainte de a afirma ceva documentati-va!!!!!!!!! |
renault
bonk |
dc crezi u ca nu are 131 hp daca are DI-rosu ??? ca nu cunosc pe nimeni care sa le fi vopsit ... si chiar daca ar avea 101 ....
Megane 1 /1.4 16v
- GJ-05-...
sb-55-dan |
vad ca esti in necunostinta de cauza..deci no comment
mai vb cand o sa ai cunostinte minime de motorizari. si nu stiu ce vi se pare asa aberant ca un logan sa demareze mai bine ca un passat..dar na, asta-i lumea... |
renault
bonk |
da u lucrezi la VAG .... de cunosti asa de bine motorizarile ????
Megane 1 /1.4 16v
- GJ-05-...
sb-55-dan |
Nu frate dar am cunostinte minime despre genul masinilor si motorizarile lor, plus de asta masina de serv e un Passat.
renault
bonk |
bine ... sa revenim la topic:)
Megane 1 /1.4 16v
- GJ-05-...
cj98czh |
![]() Membru de la Cluj ... Group: Moderatori Posts: 23.336 Joined: 27 March 06 From: Cluj-Napoca ![]() |
Exista Passat cu DI rosu cu 101 cai...
Mazda 3
Zoom-Zoom
2018
Io_mi_s |
![]() Membru autentic Group: Members Posts: 989 Joined: 25 August 06 From: Galati ![]() |
Daca motorul Logan-ului era turat pana pe la 4500, iar al Passat-ului la, sa zic, vreo 3000? Ma-ntreb si io... si pe voi... ar fi fost posibil?
Megane 2.2
2006/Confort Privilege
Kojak |
...ar mai fi o explicatie: sa fie busita turbina passat-ului
4abc |
Acum poate ma invart....daca Loganul e cipuit...nu stiu la cat poate ajunge maxim..cred ca aprox la 90-100cp si Passatul mai are vreo 200.000km in bord atunci totul e posibil.Trebuie sa tinem cont totusi si de greutatea masinilor.Passatul Variant are aprx 1500-1600kg iar Loganul 1000 deci dupa un calcul scurt avantaj Logan la raportul cal/kg....
E foarte posibil... Uite cum ma invart daca am calculat un pic lucrurile ![]() PS:Sigur e de 101cp.Cel de 131 rupe aderenta.... ![]() This post has been edited by 4abc: 30 Jan 2008, 17:59 |
Kangoo
2004 DCI 60
- 56-MDB
ady85btz |
Mirific.
Passatul avea motoru pe folie ![]() |
Kia
Cee'd ~the BEST~
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 15th May 2025 - 11:40 |
