B 48 C U P Logan 1.6 MPI, Preference, race car wannabe
Dsign |
9 Apr 2012, 20:47
#1171
Led Tuning Man Group: Members Posts: 3.498 Joined: 24 November 03 From: Bucuresti |
D
2004 Preference 1.6MPI Egee
Dsign |
14 Apr 2012, 15:48
#1172
Franele de spate cu disc inca sunt la vanzare. Se mai po testa saptamana asta pe masina mea
D
Dsign |
15 Apr 2012, 19:02
#1173
Improvizatie : frana pe spate cu discuri, partea a2a, aproape de montajul final.
Saptamana asta am facut urmatoarele : - proba statica a intregului ansamblu fuzete/etrieri/discuri - izolat bine cu banda de hartie etrierii, portetrierii si fuzetele - tratat cu zinc - vopsit etrierii cu vopsea albastra, speciala pentru aceasta aplicatie - montat garniturile noi, asamblat etrierii - gresat bine culisele cu vaselina ceramica (+1400 grC) - achizitionat si montat placute de frana TRW - achizitionat si montat aerisitoare noi Dupa atata bibileala, oare mai poate spune cineva ca se face improvizatie aici? Mai pun 2-3 poze cu noua mea ocupatie, catifelare in camp electrostatic. This post has been edited by Dsign: 15 Apr 2012, 19:04 Attached thumbnail(s) 07042012386.jpg ( Size: 839.58k ) Number of downloads: 1822 07042012387.jpg ( Size: 814.98k ) Number of downloads: 1923 12042012388.jpg ( Size: 557.72k ) Number of downloads: 1953 15042012391.jpg ( Size: 841.05k ) Number of downloads: 1882 15042012394.jpg ( Size: 569.75k ) Number of downloads: 1835 15042012395.jpg ( Size: 958.51k ) Number of downloads: 435 15042012396.jpg ( Size: 734.33k ) Number of downloads: 509 |
D
dogy_10 |
17 Apr 2012, 19:58
#1174
Membru autentic Group: Members Posts: 901 Joined: 17 December 06 From: Timisoara |
ce vopsea ai folosit la etrieri?
Dsign |
18 Apr 2012, 10:27
#1175
Vopsea de etrieri, la spray. Duplicolor.
D
18 Apr 2012, 10:35
#1176
- Group: Members Posts: 21.928 Joined: 19 April 05 From: Romania |
matheo66c |
18 Apr 2012, 21:14
#1177
Low rider Group: Members Posts: 397 Joined: 24 May 09 From: Pantelimon |
@IRONICK,la glise sa nu bagi vaselina normala,o sa se faca cauciuc si iti ramane etrierul blocat pe ele,patita de mandea!
This post has been edited by matheo66c: 18 Apr 2012, 21:15 |
2007-Preferance Abs Plus
- IF 12 LOW
Dsign |
18 Apr 2012, 22:17
#1178
Confirm, este o nebunie completa sa cureti dupa ce s-a intarit vaselina aia ordinara prin etrieri...
Aseara am montat franele de spate cu disc, partea a2a Totul a decurs perfect. Am demontat cu grija vechiul sistem, am curatat bine puntea in zona fuzetei, eram chiar pregatit cu niste spray cu zinc si spray cu vopsea neagra, in eventualitatea in care nu arata prea bine prin zona. A fost totul neasteptat de curat, asa ca am purces la treaba. Am montat mai intai fuzetele goale. S-au prins perfect in cele 4 suruburi, exact ca o fuzeta normala de Logan, ba chiar fuzeta de Clio are un element de centrare mai solid. Am continuat cu montajul discului pe fuzeta, operatiune destul de simpla pentru cine are scule potrivite. Peste disc am asezat etrierul gata echipat. Am strans toate suruburile la cuplu, am legat conductele si cablurile de frana de mana si gata! S-au dus 4 ore de munca. Momentan, din lipsa de timp si poate si de fonduri, merg cu cablurile de frana lungi, acelea de MCV modificate sa mearga cu vechiul sistem. Cam asta ar fi singura improvizatie la franele acestea, in acest moment. In rest, totul s-a potrivit la perfectie. Mai ramane de facut o aerisire ca la carte (am facut ieri cateva pedale, dar eram prea obosit sa insist), insa abia dupa ce masor niste presiuni inainte si dupa repartitor. Am convingerea ca nu-si mai face treaba, iar daca asa e, il voi scoate de tot si voi pune un repartitor reglabil in habitaclu in locul lui. Asta se va intampla abia dupa prima etapa de Campionat. Acum incerc sa ma obisnuiesc cu noua configuratie, deja simt imbunatatiri in functionarea franei de mana. Poze voi pune maine. |
D
20 Apr 2012, 23:13
#1179
QUOTE(matheo66c @ 18 Apr 2012, 22:14) @IRONICK,la glise sa nu bagi vaselina normala,o sa se faca cauciuc si iti ramane etrierul blocat pe ele,patita de mandea! Nu este ce te gandesti tu. Uite o poza cu el: images.jpg ( Size: 78.69k ) Number of downloads: 497 |
matheo66c |
21 Apr 2012, 00:20
#1180
QUOTE(IRONICK @ 20 Apr 2012, 23:13) Atunci scuzele mele,daca este ceramica,este perfecta |
- IF 12 LOW
Markos |
21 Apr 2012, 00:29
#1181
fost programator Group: Members Posts: 8.016 Joined: 27 October 05 From: Scursurești Vale |
da' pozilii?
unde-s pozilii?! |
Megan
Dsign |
21 Apr 2012, 09:12
#1182
Ma scuzati, am incercat sa postez de la serviciu si se pare ca n-a mers treaba asa ca, scuze de watermark
Dupa calculele si masuratorile mele, ecartamentul s-a marit cu 2 cm, momentan ma lupt cu lichidul acela mult prea vascos si greu de aerisit. Frana de mana functioneaza brutal, asa cum mi-am dorit, nu liniar ca la vechiul sistem. Attached thumbnail(s) IMG_20120417_203251.jpg ( Size: 156.21k ) Number of downloads: 427 IMG_20120417_203306.jpg ( Size: 138.66k ) Number of downloads: 545 IMG_20120417_205233.jpg ( Size: 145.15k ) Number of downloads: 535 IMG_20120417_213124.jpg ( Size: 209.85k ) Number of downloads: 586 IMG_20120417_222004.jpg ( Size: 206.77k ) Number of downloads: 567 IMG_20120417_224511.jpg ( Size: 154.85k ) Number of downloads: 549 |
D
Dsign |
22 Apr 2012, 20:00
#1183
Gata in totalitate cu "improvizatia". Acum am aerisit complet, am pus lichid cat trebuie, cum trebuie. Franele sunt acum suuuuper controlabile, insa la nevoie, brutale. Spatele lucreaza excelent, iar frana de mana ma va ajuta ca corectez devierile subviratoare de la cursele de slalom.
Improvizatie?! This post has been edited by Dsign: 22 Apr 2012, 20:00 |
D
4x4 |
22 Apr 2012, 20:52
#1184
Übermensch Group: Members Posts: 3.394 Joined: 24 March 07 |
pe fata ce discuri ai?
W
S
S Attere Dominatum!
Dsign |
23 Apr 2012, 17:02
#1185
Pe fata am discuri 260 x 22 mm, de VAN sau de Clio 3 (acelasi drac)
Pe spate sunt discuri de 240 x 8 mm, de Clio 3 sau Megane 2 |
D
YRX |
24 Apr 2012, 07:28
#1186
Membru autentic Group: Members Posts: 4.771 Joined: 6 July 06 From: Bucuresti |
De ce folosesti prezoanele alea cu piulite la roti, e vreo limitare tehnica sau e treaba de preferinte?
2005 Ambition 1.6 MPI
Dsign |
24 Apr 2012, 16:50
#1187
Se monteaza roata mult mai usor si mult mai rapid pe przoanele alea. In plus, pentru jantele de 17" (care au o flansa de prindere foarte groasa) e nevoie de prezoane sau suruburi lungi.
Am optat pentru solutia asta atunci cand mi-am achizitionat jantele de 17". La curse se foloseste acelasi sistem, tocmai datorita usurintei la montaj (nu mai stai sa potrivesti gaura rotii cu gaura butucului, nu mai pui surubul stramb, samd) |
D
LuluMOB |
24 Apr 2012, 17:08
#1188
Membru cu pedale. Group: Members Posts: 1.136 Joined: 28 October 05 From: Iași |
Si mie mi se pare mai practic sistemul cu piulite, oare de ce se prefera suruburile?
ABS+ AC 1.4MPI 06/2007
Dsign |
24 Apr 2012, 19:01
#1189
Este mai scump de fabricat. In plus, Renault are un sistem dobitoc pentru franele pe spate : tamburul/discul tine loc de butuc de roata, respectiv roata se prinde si se centreaza direct de el. Asadar, e mai usor sa faci 4/5 gauri filetate, decat sa faci 4/5 gauti canelurate in care sa infigi prezoane, apoi sa fabrici si niste piulite pentru ele...
D
YRX |
25 Apr 2012, 06:35
#1190
Aha, m-am lamurit acum.
Dsign |
25 Apr 2012, 17:44
#1191
D
turbodxman |
25 Apr 2012, 18:12
#1192
------------- Group: Members Posts: 3.327 Joined: 1 August 08 From: Ro |
Ideal ar fi sa ai prinderea jantelor pe butuc cu o singura piulita, centrala F1 style
b44dvl |
25 Apr 2012, 21:51
#1193
Membru cu 1300 Group: Members Posts: 447 Joined: 9 March 09 From: Bucuresti |
Testai franele in zona Orhideea? cu farurile alea ca nocturnele de pe stadion, nu intelegeam cine e asa de grabit de nu poate sa stea linistit la rosu
Ma surprins faptu ca nu ti-am auzit toba.... |
1300 din
1976
- B 44 DvL Bad Mojo Mother Fucker
Dsign |
26 Apr 2012, 09:51
#1194
Toba e pe silent mode zilele astea Facem si noi niste pasaje ca lumea la aripile alea ?
D
b44dvl |
26 Apr 2012, 12:03
#1195
QUOTE(Dsign @ 26 Apr 2012, 09:51) Incercam in vara asta, pasajele le am acasa in garaj dar nu am bani sa le pun accept oricand donatii Vezi ca ti-am dat si un PM pe 4T, sa-mi raspunzi si mie te rog frumos This post has been edited by b44dvl: 26 Apr 2012, 12:09 |
1300 din
1976
Dsign |
26 Apr 2012, 18:42
#1196
Cateva cadre de la ultima etapa din CNIA 2011.
Attached thumbnail(s) php5xfh8V_1000px.jpg ( Size: 109.04k ) Number of downloads: 412 phpcr7yxz_1000px.jpg ( Size: 92.87k ) Number of downloads: 400 phpGBH7Km_1000px.jpg ( Size: 125.66k ) Number of downloads: 389 phphRIFZq_1000px.jpg ( Size: 115.48k ) Number of downloads: 387 phplJBM5K_1000px.jpg ( Size: 108.12k ) Number of downloads: 366 phpvIHLsT_1000px.jpg ( Size: 118.43k ) Number of downloads: 346 |
D
b44dvl |
27 Apr 2012, 11:58
#1197
Cand mai sunt astfel de evenimente? Ultimu stiu ca a fost la centru comercial Militari:-P si din pacate nu am venit:(
1300 din
1976
Dsign |
27 Apr 2012, 18:42
#1198
Urmatorul eveniment, si anume prima etapa din CNIA se va desfasura intre 11 si 13 Mai la Baneasa Shopping City (Mall Baneasa-IKEA) dupa cum urmeaza:
- vineri, 11 mai, antrenamente neoficiale - sambata 12 mai, antrenamente cronometrate si 2 manse de concurs - duminica 13 mai, premierea + demonstratii ale participantilor + demonstratii cu vedete + taxi ride + alte surprize Sunteti asteptati in galeria LoganClub |
D
b44dvl |
27 Apr 2012, 21:19
#1199
Daca afli si un orar ar fi super, eu as vrea sa vin dar vreau sa stiu intre ce ore :-P
1300 din
1976
nalodaniel |
27 Apr 2012, 21:36
#1200
a3a oara scriu corect Group: Members Posts: 361 Joined: 24 March 08 From: suceava |
ce dimensiuni/compozitie/forma au cauciucele de competitie?
1986
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 6th June 2024 - 14:20 |
