Mici Intrebari -dar mai putin tehnice-, care nu merita topic separat
DannyY |
#15481
Opel/Honda/Opel
Astra G/Civic 4D/Corsa E
2004/2015/2019
bion |
#15482
facherilor io sunt un clasic in viata. De aia ma autocitez.
![]() "Lidar has a narrow beam, and easily targets an individual vehicle, thereby eliminating the need for visual estimation,[15][1] and records an image of the license plate at the same instant as recording the speed violation. Speed estimation takes less than half a second which together with the narrow, targeted beam results in offending vehicles having little warning even when using an evasion device. Lidar can measure the distance between vehicles to detect 'too close' (tailgating) infringements. The speed of a vehicle in the shadow of another vehicle cannot be measured." Deci unica sansa e sa mergi la aspiratie ![]() This post has been edited by bion: 21 Nov 2017, 19:34 |
SLZ Scala
DannyY |
#15483
Io ziceam de punctele de apreciere...
Opel/Honda/Opel
2004/2015/2019
bion |
#15484
Io parca ase ama auzit. Acu am descifrat ce a cioplit ala pe placuta de lut.la puncte amenda: 4 puncte X145=580 ( stie aritmetica are liceu) ;penalizare: nu scrie nik
SLZ Scala
radian |
#15485
dacia logan
ambition
- HD 06 LDM
iulia_boris |
#15486
![]() Membru autentic Group: Members Posts: 434 Joined: 17 September 10 ![]() |
Imposibil fara punctaje..
This post has been edited by iulia_boris: 22 Nov 2017, 10:25 |
Dokker Laureate 1,6..
2016
- B 696 BUL Cu cat cunosc mai bine oamenii, cu atat iubesc mai mult cainii.
DragosP |
#15487
Ceva de plastic
Cu noi este Dumnezeu! |
radian |
#15488
Intocmirea gresita a PVului este un motiv de anulare a lui.
dacia logan
ambition
- HD 06 LDM
AR-18-MOS |
#15489
Doar daca prin acesta s-a pricinuit partii o vatamare ce nu poate fi inlaturata decat prin anularea lui.
BMW
730Ld
'07 High Executive
bion |
#15490
Viciu de procedura. La trebunal cu ei.
SLZ Scala
DannyY |
#15491
Meletianu' avea sapca pe cap? Copca inchisa? Barbierit reglementar?
Opel/Honda/Opel
2004/2015/2019
bion |
#15492
Ighen. A si mormait un nume. Mi-a arata filmari. cenzurat ala mai mic care dadea cu laseru statea pe bancheta din spate si ginea cu divaisu pe geam si se distra copios. Erau foarte mandri de jucaria lor.
![]() PS amandoi stiau sa scrie si sa citeasca. |
SLZ Scala
DragosP |
#15493
Ceva de plastic
bion |
#15494
IPS Semafor te mananca in pomohaci . Sa te scarpine episcopu de Husi .
![]() 22 Nov 2017, 13:43: Sufar ca mi-a stricat CV dupa 32 de ani.Si ca nu aveam divaisu activat.Poate , poate ![]() This post has been edited by bion: 22 Nov 2017, 12:43 |
SLZ Scala
radian |
#15495
QUOTE(DannyY @ 22 Nov 2017, 13:15) Razi tu razi, dar am un amic, taximetrist care a ajjuns la tribunal pentru asa ceva. La intrarea in Vulcan un politst de pe trotuar ii face semn sa opreasca. Amicul a crezut ca respectivul are nevoie sa mearga ce stiu eu unde si are nevoie de un taxi. Teapa... Politistul ii cere actele si ii salta permisul pe motiv ca-l vazuse cu cateva minute inainte, fiind in alta masina, cum a depasit pe linia continua un cap tractor tras pe dreapta. De aici se lasa cu cearta, de genul, bai nene daca tu erai in urma mea si m-ai vazut iar acum ai ajuns inaintea mea insemna ca si tu ai depasit la fel ca mine, in plus, nu ai cascheta pe cap, nu esti echipat regulamentar, nu ai coleg, esti singur, n-ai voie sa ma opresti daca esti singur, in plus nu ai repsectat procedura de oprite, te-ai purtat de parca ai fi avut nevoie de taxi. |
dacia logan
ambition
- HD 06 LDM
DragosP |
#15496
Și ție ți se pare că e fix același lucru?
Ceva de plastic
bion |
#15497
IPS, in lumea asta laica nu se exista doua cestiuni identice.
In alta ordine de idei am aflat azi cestiuni f. interesante despre ce si cum e cu refugiatii astai arabi.De pe suse implicate.Cand oi avea on mooood corespunzator o sa va povestesc. This post has been edited by bion: 22 Nov 2017, 13:16 |
SLZ Scala
DragosP |
#15498
Auzi bre? Ai avut viteza aia?
Da? Hai, pași pe covorași, la culcare! |
Ceva de plastic
bion |
#15499
Pomohaci sa te tuce dragu de tine.Proba video arata viteza aia, Io nici nu am contestat.A fost o chestie descriptiva cu ceva observatii. Faceam si io postari.
SLZ Scala
DragosP |
#15500
Vezi că ai o obsesie cu ciocolata.
Ceva de plastic
dacis |
#15501
QUOTE(bion @ 21 Nov 2017, 18:26) Badie, ca sa traduc ce am vrut sa aflu de la matale: altadata cand a fost detectoru lu matale pus in priza si activ, l-ai prins in offside pe politistu cu lanterna laser? Ca eu am auzit tot soiul de mituri despre detectoarele astea: ca nu le detecteaza niciodata nimeni si nimic, la le poti detecta doar daca te-au tintit pe tine si cand deja ejti personaj principal pe film, ca le poti detecta daca tintesc o masina care este cu 20 de metri inaintea ori inapoia ta etc.etc.. QUOTE(bion @ 22 Nov 2017, 12:27) Asta e cert. Ca, daca nu stiau, se faceau apevisti pensionari si erau trimisi in misiune pe DC |
Logan KissFM 1,4
2008 dacis
bion |
#15502
In afara de povesti si google. O singura experienta cu un detector laser dar alt model am avut la sârbi. Coboram de pe un viaduct si eram f. aproape de cel din fata. Wistleru a carait scurt Laser. Dupa 3,-400 m erau milicajci cu instalatia. Nu am aviut pb ca acolo merg linistit ca aia te baga la beci.
https://youtu.be/A3v8zbzvaxc https://youtu.be/fFleQWVJt5U This post has been edited by bion: 22 Nov 2017, 20:26 |
SLZ Scala
eurocristi |
#15503
Membru autentic Group: Members Posts: 243 Joined: 16 May 07 From: Oradea ![]() |
O luai exact la fel si cu detectorul pornit. Te pisi pe el de detector cand e vorba de laser.
ambition
2005 membru proaspat dar experimentat in auto
bion |
#15504
Pai si io ce am zis?
Ala piuie cand a ajuns glontul. Fedbackul lui e de milisecunde. |
SLZ Scala
Victorine |
#15505
Cine ma poate ajuta sa ma lamuresc cu urmatoarea situatie?
Am primit 2 somatii de executare silita pentru neplata impozitului pe casa si teren, pentru fiecare dintre cei doi proprietari in cuantum de 170 de lei fiecare. Problema e urmatoarea: cei doi nu au aceeasi cota parte, iar unul e decedat (cel cu 2/3), fara sa fi initiat insa succesiunea. Merg sa platesc, dar cat? 2 x 170 lei pentru ca inca nu e facuta succesiunea, chiar daca unul din proprietari nu mai traieste, el trebuie sa plateasca impozit? Sau platesc doar pentru proprietarul ramas? Eu sunt implicat indirect, doar locuiesc in casa respectiva si mi-am asumat toate cheltuielile aferente. |
Toyota
Auris Touring Sports HSD
2014
GBX |
#15506
Membru autentic Group: Members Posts: 606 Joined: 26 May 13 From: aproape de Cluj ![]() |
Impozitul se calculează pentru bunul/bunurile supuse impozitării. Dacă sunt mai mulți proprietari, conform documentelor doveditoare (CVC, partaj, succesiune...), vor fi impozitați conform cotei-părți aferente. Dacă unul a decedat, plata impozitul nu se suspendă, căzând în sarcina moștenitorilor. Care, dacă nu plătesc până la succesiune, în numele defunctului, vor moșteni și datoriile cumulate.
This post has been edited by GBX: 25 Nov 2017, 09:30 |
ex. Renault
19 Europa
1997
Victorine |
#15507
Am inteles, deci platesc 2 x 170 lei. Multumesc.
Dar atunci cum se explica faptul ca au de platit aceeasi suma, desi difera cota parte a fiecaruia din proprietate, in lumina a ce ai spus mai sus? |
Toyota
2014
GBX |
#15508
Trebuie întrebat la Taxe și impozite de ce la ei figurează cu cote egale. Posibil să nu se fi declarat corect sau să se fi stabilit din oficiu aceste cote, in lipsa unor documente.
This post has been edited by GBX: 25 Nov 2017, 22:14 |
ex. Renault
19 Europa
1997
Victorine |
#15509
Multumesc!
Toyota
2014
radian |
#15510
O problema care n-as fi crezut ca-i problema...
Pe perioada revelionului vreau sa-l duc pe catel la o pensiune canina. A mai fost asta vara pe perioada concediului la Deva si a fost OK. Doar ca acum desi am incercat sa-i fac rezervare cu mai mult de o luna si jumatate inainte, nu mai sunt locuri lilbere. Am gasit o alta pensiune canina la Alba Iulia, astia au locuri libere dar imi cer sa le trimit poze dupa toate paginile din carnetul de sanatate sa se asigure ca-i OK catelul. E mai complicat sa-i gasesc cazare catelului decat sa-mi fac mie o rezervare... |
dacia logan
ambition
- HD 06 LDM
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 24th May 2025 - 04:35 |
