29 Pages « < 27 28 29
> [VAND]piese DACIA noi-REDUCERE DE PRETURI
valy051
post 4 Apr 2018, 08:31
Post #841
Vand piese NOI Dacia 1310/1410 si Dacia Papuc(motor benzina):
Alternator Dacia 12V(Cod 1114)--------------------------200 lei
Antifurt buson rezervor benzina(Aluminiu)-----------------------25 lei
Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---------40 lei
Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm---100 lei/2buc.
Ax pompa apa Dacia(INOXIDABIL) ------------------------10 lei
Bascula sup.cu pivot(rebucsata Fartec)pentru DACIA PAPUC------------50 lei
Bascula Inferioara cu pivot(rebucsata Fartec)pentru DACIA PAPUC--------40 lei
Bec 21W/5W(dublu filament) ---------------------------1 lei/buc
Bieleta directie(tabla ambutisata)Dacia(Topoloveni)------------50 lei
Bloc diode--------------------------------------------40 lei
Borne acumulator(bronz) --------------------------------7 lei/set
Brida radiator -------------------------------------------------2 lei
Bucsa ax volan----------------------------------------------2.5 lei
Bucsa bascula sup.(Fartec)) ------------------------------------15 lei
Bucsa caseta directie(teflon) ---------------------------------5-lei/buc
Bucsa cauciuc bascula spate -------------------------------4-lei
Bucsa cuplaj volan(Fartec Brasov)----------------------------10-lei
Bucsa tirant----------- ----------------------------------16-lei/4buc
Burduf planetara(mare) --------------------------------------5-lei
Burduf planetara(mic) ----------------------------------------4-lei
Buson baie ulei -----------------------------------------------4-lei
Buson radiator ------------------------------------------------2-lei
Butuc roata fata Dacia Papuc(3 prezoane)(tractiune spate)--------75-lei
Butuc roata fata Dacia Berlina-Combi(3 prezoane)---------------------------75 lei
Cala carburator textolit ------------------------------------------1,5 lei
Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)8buc--150 lei/set 4buc
Camere Victoria 175/185/195-14 ----------------------------6 ron
Capac delcou Dacia ----------------------------------------------7 lei
Carbuni electromotor Dacia-Oltcit -----------------------------6 lei
Carburator Dacia 1400(27)(S.H.perfecta stare)---------------55 lei
Ceas presiune ulei-----------------------------------------------20 lei
Cheie combinata buson ulei baie+c.v. Dacia------------------15 lei
Cleste dezizolator multifunctional----------------------------2,5lei
Cleste dezizolator cablu(profesional)-------------------------25 lei
Comutator semnal. directie 1310/1410 ----------------------25 lei
Culbutori (2 buc.)-------------------------------------------------10 lei/buc
Curea trapez.dintata GATES6213MC AVX10x825La--------13 lei
Curea trapez.SUPER 9.5x950 -------------------------------11 lei
Curea ventilator Fartec 10x6x1000 --------------------------5 lei
Curea ventilator Fartec 10x8x1218 --------------------------9 lei
Cutie sigurante 10 cai ----------------------------------------15 lei
Cuzineti palier R1(Brașov)Dacia1310/1410 ----------------65 lei
Disc ambreiaj Dacia 1310/1410(Fi 180)original------------80 lei
Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)---12 lei
Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20lei
Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10 lei
Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 lei
Garnituri cilindrii receptori spate Dacia-----------------------3 lei
Garnituri motor DACIA 1410(set)-------------------------------------65 lei
Inele sincron C.V.-----------------------------------------------25 lei
Jicloare 1300/1400 Carfil(diferite)---------------------------3lei/buc
Motor stergator parbriz ARO 10------------------------------35 lei
Oala planetara(dinspre roata) ------------------------------35 lei
Patent 200mm---------------------------------------------------5 lei
Pistol aer cu manometru(0,5-10bar)(Italia) -------------30 lei
Pivot superior--------------------------------------------------25 lei
Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----40 lei/set
Releu far(4pic.) -------------------------------------------------5 lei
Releu protectie halogene 30A(Italy) -----------------------15 lei
Releu semnalizare Sacele ------------------------------------15 lei
Releu tensiune mecanic Bulgaria-12V ----------------------30 lei
Rotor electromotor D.Sacele --------------------------------100 lei
Rotor alternator D.Sacele------------------------------------60 lei
Rulment ambreiaj Fi180(39060) ---------------------------15 lei
Rulment biconic Mare(35305)C.V---------------------------45 lei
Rulment conic302/37 -----------------------------------------14 lei
Rulment roata fata 6207 -------------------------------------20 lei
Rulmenti cutie viteza(5tr) -------------------------------100 lei/set
Saboti frana 1310 (Fermit-Rm.Sarat)-----------------------90/set 4 buc
Semeringuri FARTEC-----110x130x13(arbore Tractor U 650)-------15lei
-------------------------80x100x10-----------------------------8 lei
-------------------------50x70x10(butuc roata ARO)-------------7 lei
--------------------------35x50x8(distributie Dacia)-------------10 lei
--------------------------26x42x10(planetara Dacia 1310)-------6 lei
Simering priza C.V. 17x28x7/13F ---------------------------------6 lei
Set sigurante(8A-16A)----------------------------------------------4 lei
Set Yalle usi+portbagaj1310 -------------------------------------60 lei
Sonda litrometrica 5726(ARO?)-----------------------------------20 lei
Sonda ulei ceas -----------------------------------------------------35 lei
Stator alternator ----------------------------------------------------65 lei
Stergatoare SACA 400mm/16''(set) -----------------------------10 lei
Suporti motor Dacia-------------------------------------------------25 lei
Termostat Dacia -----------------------------------------------------10 lei
Triunghi reflectorizant ----------------------------------------------20 lei
Valve tubeles ----------------------------------------------------------1 lei
Telef.0763012130
x x x - x
valy051
post 13 Apr 2018, 07:33
Post #842
Telef.0763012130
x x x - x
valy051
post 23 Apr 2018, 14:36
Post #843
Telef.0763012130
x x x - x
valy051
post 3 May 2018, 21:16
Post #844
Telef.0763012130
x x x - x
valy051
post 15 May 2018, 09:46
Post #845
Telef.0763012130
x x x - x
valy051
post 21 May 2018, 08:57
Post #846
Telef.0763012130
x x x - x
valy051
post 28 May 2018, 13:11
Post #847
Telef.0763012130
x x x - x
valy051
post 5 Jun 2018, 08:31
Post #848
Telef.0763012130
x x x - x
robert.roby
post 12 Jun 2018, 14:54
Post #849
salut
manual de reparatie ai cumva?
dacia logan 2010 1.6
valy051
post 13 Jun 2018, 17:48
Post #850
Bucsa bascula sup.(Fartec)) ------------------------------------25 lei
Bucsa caseta directie(teflon) ---------------------------------10 lei/buc
Bucsa cauciuc bascula spate -------------------------------6 lei
Bucsa cuplaj volan(Fartec Brasov)----------------------------15lei/buc
Bucsa tirant----------- ----------------------------------20 lei/4buc
Butuc roata fata Dacia Papuc(3 prezoane)(tractiune spate)--------80-lei
Butuc roata fata Dacia Berlina-Combi(3 prezoane)---------------------------80lei
Capac delcou Dacia ----------------------------------------------8 lei
Carbuni electromotor Dacia-Oltcit -----------------------------9 lei
Ceas presiune ulei-----------------------------------------------25lei
Comutator semnal. directie 1310/1410 ----------------------40lei
Cuzineti palier R1(Brașov)Dacia1310/1410 ----------------100 lei
Disc ambreiaj Dacia 1310/1410(Fi 180)original------------95 lei
Garnituri motor DACIA 1410(set)-------------------------------------80 lei
Inele sincron C.V.-----------------------------------------------30 lei/buc
Jicloare 1300/1400 Carfil(diferite)---------------------------6lei/buc
Oala planetara(dinspre roata) ------------------------------50lei
Pivot superior--------------------------------------------------35lei
Releu far(4pic.) -------------------------------------------------8lei
Releu protectie halogene 30A(Italy) -----------------------20lei
Releu semnalizare Sacele ------------------------------------25 lei
Rotor electromotor D.Sacele --------------------------------120 lei
Rotor alternator D.Sacele------------------------------------85 lei
Rulment ambreiaj Fi180(39060) ---------------------------25 lei
Rulment biconic Mare(35305)C.V---------------------------65 lei
Rulment conic302/37 -----------------------------------------18 lei
Rulment roata fata 6207 -------------------------------------28lei
Rulmenti cutie viteza(5tr) -------------------------------150lei/set
Set Yalle usi+portbagaj1310 -------------------------------------80lei
Sonda ulei ceas -----------------------------------------------------45 lei
Telef.0763012130
x x x - x
robert.roby
post 15 Jun 2018, 10:49
Post #851
salut.
alternator nou aveti?
valy051
post 16 Jun 2018, 18:47
Post #852
Telef.0763012130
x x x - x
valy051
post 23 Jun 2018, 07:23
Post #853
Telef.0763012130
x x x - x
valy051
post 30 Jun 2018, 17:43
Post #854
Telef.0763012130
x x x - x
valy051
post 6 Jul 2018, 07:44
Post #855
Telef.0763012130
x x x - x
valy051
post 15 Jul 2018, 07:38
Post #856
valy051 Postat 6 Jul 2018, 07:44
Telef.0763012130
x x x - x
valy051
post 22 Jul 2018, 08:34
Post #857
Telef.0763012130
x x x - x
valy051
post 31 Jul 2018, 20:42
Post #858
Telef.0763012130
x x x - x
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 14th July 2025 - 01:49
