29 Pages « < 25 26 27 28 29 >
> [VAND]piese DACIA noi-REDUCERE DE PRETURI
Floryn_Cis
post 20 Apr 2017, 10:13
Post #781
Daciar Razboinic
arbore cotit cu palier normal ai ?
Dacia 1300 Dacia 1300 Berlina 1972 berlina - Sb03cjs
Dacia 1300 1,4L 5 trepte , 1972
Ford Escort Ghia 1,6 16v C.L.X. combi, 1999
valy051
post 20 Apr 2017, 10:43
Post #782
Nu
x x x - x
valy051
post 26 Apr 2017, 12:53
Post #783
Vand piese NOI Dacia 1310/1410 si Dacia Papuc(motor benzina):
Alternator Dacia 12V(Cod 1114)--------------------------170 lei
Antifurt buson rezervor benzina(Aluminiu)-----------------------25 lei
Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---------60 lei
Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm---100 lei/2buc.
Ax pompa apa Dacia(INOXIDABIL) ------------------------10 lei
Bascula sup.cu pivot(rebucsata Fartec)pentru DACIA PAPUC------------35 lei
Bascula Inferioara cu pivot(rebucsata Fartec)pentru DACIA PAPUC--------50 lei
Bec 21W/5W(dublu filament) ---------------------------1 lei/buc
Bieleta directie(tabla ambutisata)Dacia(Topoloveni)------------40 lei
Bloc diode--------------------------------------------25 lei
Borne acumulator(bronz) --------------------------------7 lei/set
Brida radiator -------------------------------------------------2 lei
Bucsa ax volan----------------------------------------------2.5 lei
Bucsa bascula sup.(Fartec)) ------------------------------------10 lei
Bucsa caseta directie(teflon) ---------------------------------5-lei/buc
Bucsa cauciuc bascula spate -------------------------------4-lei
Bucsa cuplaj volan(Fartec Brasov)----------------------------10-lei
Bucsa tirant----------- ----------------------------------16-lei/4buc
Burduf planetara(mare) --------------------------------------5-lei
Burduf planetara(mic) ----------------------------------------4-lei
Buson baie ulei -----------------------------------------------4-lei
Buson radiator ------------------------------------------------2-lei
Butuc roata fata Dacia Papuc(3 prezoane)(tractiune spate)--------55-lei
Butuc roata fata Dacia Berlina-Combi(3 prezoane)---------------------------50 lei
Cala carburator textolit ------------------------------------------1,5 lei
Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)8buc--150 lei/set 4buc
Camere Victoria 175/185/195-14 ----------------------------6 ron
Capac delcou Dacia ----------------------------------------------7 lei
Carbuni electromotor Dacia-Oltcit -----------------------------6 lei
Carburator Dacia 1400(27)(S.H.perfecta stare)---------------55 lei
Ceas presiune ulei-----------------------------------------------10 lei
Cheie combinata buson ulei baie+c.v. Dacia------------------15 lei
Chiulasa neechipata 1310/1410 -----------------------------250 lei
Cleste dezizolator multifunctional----------------------------2,5lei
Cleste dezizolator cablu(profesional)-------------------------25 lei
Comutator semnal. directie 1310/1410 ----------------------12 lei
Culbutori (2 buc.)-------------------------------------------------10 lei/buc
Curea trapez.dintata GATES6213MC AVX10x825La--------13 lei
Curea trapez.SUPER 9.5x950 -------------------------------11 lei
Curea ventilator Fartec 10x6x1000 --------------------------5 lei
Curea ventilator Fartec 10x8x1218 --------------------------9 lei
Cutie sigurante 10 cai ----------------------------------------8 lei
Cuzineti palier R1(Brașov)Dacia1310/1410 ----------------35 lei
Disc ambreiaj Dacia 1310/1410(Fi 180)original------------55 lei
Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)---12 lei
Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20lei
Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10 lei
Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 lei
Garnituri cilindrii receptori spate Dacia-----------------------3 lei
Garnituri motor DACIA 1410(set)-------------------------------------40 lei
Inele sincron C.V.-----------------------------------------------25 lei
Jicloare 1300/1400 Carfil(diferite)---------------------------3lei/buc
Motor stergator parbriz ARO 10------------------------------35 lei
Oala planetara(dinspre roata) ------------------------------35 lei
Patent 200mm---------------------------------------------------5 lei
Pistol aer cu manometru(0,5-10bar)(Italia) -------------30 lei
Pivot superior--------------------------------------------------25 lei
Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----40 lei/set
Releu far(4pic.) -------------------------------------------------3 lei
Releu protectie halogene 30A(Italy) -----------------------10 lei
Releu semnalizare Sacele ------------------------------------10 lei
Releu tensiune mecanic Bulgaria-12V ----------------------30 lei
Rotor electromotor D.Sacele --------------------------------90 lei
Rotor alternator D.Sacele------------------------------------60 lei
Rulment ambreiaj Fi180(39060) ---------------------------12 lei
Rulment biconic Mare(35305)C.V---------------------------45 lei
Rulment conic302/37 -----------------------------------------14 lei
Rulment roata fata 6207 -------------------------------------18 lei
Rulmenti cutie viteza(5tr) -------------------------------100 lei/set
Saboti frana 1310 (Fermit-Rm.Sarat)-----------------------80/set 4 buc
Semeringuri FARTEC-----110x130x13(arbore Tractor U 650)-------12lei
-------------------------80x100x10-----------------------------8 lei
-------------------------50x70x10(butuc roata ARO)-------------7 lei
--------------------------35x50x8(distributie Dacia)-------------5 lei
--------------------------26x42x10(planetara Dacia 1310)-------4 lei
Simering priza C.V. 17x28x7/13F ---------------------------------4 lei
Set sigurante(8A-16A)----------------------------------------------2 lei
Set Yalle usi+portbagaj1310 -------------------------------------40 lei
Sonda litrometrica 5726(ARO?)-----------------------------------20 lei
Sonda ulei ceas -----------------------------------------------------22 lei
Stator alternator ----------------------------------------------------55 lei
Stergatoare SACA 400mm/16''(set) -----------------------------10 lei
Suporti motor Dacia-------------------------------------------------25 lei
Termostat Dacia -----------------------------------------------------10 lei
Triunghi reflectorizant ----------------------------------------------20 lei
Valve tubeles ----------------------------------------------------------1 lei
Telef.0763012130
x x x - x
valy051
post 2 May 2017, 19:14
Post #784
Telef.0763012130
x x x - x
iustin_uap
post 5 May 2017, 20:50
Post #785
Trebuia sa finalizam o comanda, dar ati plecat din localitate. V-am trimis mesaj in privat acum cateva zile ca sa va reamintesc. L-ati primit?
Dacia 1300/1310 73/83
valy051
post 9 May 2017, 11:15
Post #786
Telef.0763012130
x x x - x
valy051
post 14 May 2017, 10:42
Post #787
Telef.0763012130
x x x - x
valy051
post 20 May 2017, 19:18
Post #788
Telef.0763012130
x x x - x
valy051
post 27 May 2017, 15:07
Post #789
Telef.0763012130
x x x - x
valy051
post 4 Jun 2017, 00:21
Post #790
Telef.0763012130
x x x - x
valy051
post 11 Jun 2017, 15:32
Post #791
Telef.0763012130
x x x - x
valy051
post 17 Jun 2017, 15:40
Post #792
Telef.0763012130
x x x - x
valy051
post 26 Jun 2017, 20:52
Post #793
Telef.0763012130
x x x - x
valy051
post 5 Jul 2017, 08:12
Post #794
Telef.0763012130
x x x - x
valy051
post 13 Jul 2017, 20:33
Post #795
Telef.0763012130
x x x - x
valy051
post 21 Jul 2017, 11:58
Post #796
Telef.0763012130
x x x - x
valy051
post 28 Jul 2017, 10:39
Post #797
Telef.0763012130
x x x - x
valy051
post 4 Aug 2017, 06:21
Post #798
Telef.0763012130
x x x - x
valy051
post 10 Aug 2017, 19:34
Post #799
Telef.0763012130
x x x - x
SEBASTIAN_RC
post 10 Aug 2017, 19:42
Post #800
ENG.
Am si eu nevoie momentam de trei repere.
Sticla de la lampa de lumina din portbagaj.
Bare stabiliazoare fata-spate de 24mm grosime, sau mcar sa imi spui ce ai mai gros.
RENAULT 12TS 1977 / Spania
RACING CODE (chiptuning & dyno)
valy051
post 16 Aug 2017, 12:45
Post #801
Telef.0763012130
x x x - x
valy051
post 23 Aug 2017, 19:52
Post #802
Telef.0763012130
x x x - x
valy051
post 1 Sep 2017, 19:48
Post #803
Telef.0763012130
x x x - x
valy051
post 6 Sep 2017, 19:28
Post #804
Telef.0763012130
x x x - x
valy051
post 14 Sep 2017, 13:45
Post #805
Telef.0763012130
x x x - x
valy051
post 19 Sep 2017, 12:56
Post #806
Telef.0763012130
x x x - x
vs66cia
post 21 Sep 2017, 18:57
Post #807
Ma intereseaza urmatoarele. Astept PM cu detalii.
Rulment roata fata 6207 - ai 2set-uri?
Set Yalle usi+portbagaj1310 - as dori niste poze
Multumesc!
Dacia 1310 1997 - VS 66 CIA
valy051
post 22 Sep 2017, 15:01
Post #808
Telef.0763012130
x x x - x
valy051
post 25 Sep 2017, 14:44
Post #809
Telef.0763012130
x x x - x
raresvintea
post 27 Sep 2017, 10:51
Post #810
Cum arata Sonda litrometrica 5726(ARO?)-----------------------------------20 lei
As vrea poze, vreau sa o folosesc in alta aplicatie
skoda octavia '03 elegance - B72FAR
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 14th July 2025 - 09:17
