29 Pages « < 23 24 25 26 27 > »
> [VAND]piese DACIA noi-REDUCERE DE PRETURI
valy051
post 18 Jun 2016, 10:25
Post #721
Vand piese NOI Dacia 1310/1410 si Dacia Papuc(motor benzina):
Alternator Dacia(Cod 1114)--------------------------170 lei
Antifurt buson rezervor benzina(Aluminiu)-----------------------25 lei
Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---------60 lei
Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm---100 lei/2buc.
Ax pompa apa Dacia(INOXIDABIL) ------------------------10 lei
Bascula sup.cu pivot(rebucsata Fartec)pentru DACIA PAPUC------------35 lei
Bascula Inferioara cu pivot(rebucsata Fartec)pentru DACIA PAPUC--------50 lei
Bec 21W/5W(dublu filament) ---------------------------1 lei/buc
Bieleta directie(tabla ambutisata)Dacia(Topoloveni)------------40 lei
Bloc diode--------------------------------------------25 lei
Borne acumulator(bronz) --------------------------------7 lei/set
Brida radiator -------------------------------------------------2 lei
Bucsa ax volan----------------------------------------------2.5 lei
Bucsa bascula sup.(Fartec)) ------------------------------------10 lei
Bucsa caseta directie(teflon) ---------------------------------5-lei/buc
Bucsa cauciuc bascula spate -------------------------------4-lei
Bucsa cuplaj volan(Fartec Brasov)----------------------------10-lei
Bucsa tirant----------- ----------------------------------16-lei/4buc
Burduf planetara(mare) --------------------------------------5-lei
Burduf planetara(mic) ----------------------------------------4-lei
Buson baie ulei -----------------------------------------------4-lei
Buson radiator ------------------------------------------------2-lei
Butuc roata fata Dacia Papuc(3 prezoane)(tractiune spate)--------55-lei
Butuc roata fata Dacia Berlina-Combi(3 prezoane)---------------------------50 lei
Cala carburator textolit ------------------------------------------1,5 lei
Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)8buc--150 lei/set 4buc
Camere Victoria 175/185/195-14 ----------------------------6 ron
Capac pompa apa Dacia(Pulsor - Scornicesti)----------------100 lei
Capac delcou Dacia ----------------------------------------------7 lei
Carbuni electromotor Dacia-Oltcit -----------------------------6 lei
Carburator Dacia 1400(27)(S.H.perfecta stare)---------------55 lei
Ceas presiune ulei-----------------------------------------------10 lei
Cheie combinata buson ulei baie+c.v. Dacia------------------15 lei
Chiulasa neechipata 1310/1410 -----------------------------250 lei
Cleste dezizolator multifunctional----------------------------2,5lei
Cleste dezizolator cablu(profesional)-------------------------25 lei
Comutator semnal. directie 1310/1410 ----------------------12 lei
Culbutori (2 buc.)-------------------------------------------------10 lei/buc
Curea trapez.dintata GATES6213MC AVX10x825La--------13 lei
Curea trapez.SUPER 9.5x950 -------------------------------11 lei
Curea ventilator Fartec 10x6x1000 --------------------------5 lei
Curea ventilator Fartec 10x8x1218 --------------------------9 lei
Cutie sigurante 10 cai ----------------------------------------8 lei
Cuzineti palier R1(Brașov)Dacia1310/1410 ----------------35 lei
Disc ambreiaj Dacia 1310/1410(Fi 180)original------------55 lei
Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)---12 lei
Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20lei
Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10 lei
Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 lei
Garnituri cilindrii receptori spate Dacia-----------------------3 lei
Garnituri motor 1410(set)-------------------------------------30 lei
Inele sincron C.V.-----------------------------------------------25 lei
Jicloare 1300/1400 Carfil(diferite)---------------------------3lei/buc
Motor stergator parbriz ARO 10------------------------------35 lei
Oala planetara(dinspre roata) ------------------------------35 lei
Patent 200mm---------------------------------------------------5 lei
Pistol aer cu manometru(0,5-10bar)(Italia) -------------30 lei
Pivot superior--------------------------------------------------20 lei
Presa pivoti Dacia----------------------------------------------45 lei
Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----40 lei/set
Releu far(4pic.) -------------------------------------------------3 lei
Releu protectie halogene 30A(Italy) -----------------------10 lei
Releu semnalizare Sacele ------------------------------------10 lei
Releu tensiune mecanic Bulgaria-12V ----------------------30 lei
Releu tensiune Sacele 12 V----------------------------------38 lei
Rotor electromotor D.Sacele --------------------------------90 lei
Rotor alternator D.Sacele------------------------------------60 lei
Rulment ambreiaj Fi180(39060) ---------------------------12 lei
Rulment biconic Mare(35305)C.V---------------------------45 lei
Rulment conic302/37 -----------------------------------------14 lei
Rulment roata fata 6207 -------------------------------------18 lei
Rulmenti cutie viteza(5tr) -------------------------------100 lei/set
Saboti frana 1310 (Fermit-Rm.Sarat)-----------------------80/set 4 buc
Semeringuri FARTEC-----110x130x13(arbore Tractor U 650)-------12lei
-------------------------80x100x10-----------------------------8 lei
-------------------------50x70x10(butuc roata ARO)-------------7 lei
--------------------------35x50x8(distributie Dacia)-------------5 lei
--------------------------26x42x10(planetara Dacia 1310)-------4 lei
Simering priza C.V. 17x28x7/13F ---------------------------------4 lei
Set sigurante(8A-16A)----------------------------------------------2 lei
Set Yalle usi+portbagaj1310 -------------------------------------40 lei
Sonda litrometrica 5726(ARO?)-----------------------------------20 lei
Sonda ulei ceas -----------------------------------------------------22 lei
Stator alternator ----------------------------------------------------55 lei
Stergatoare SACA 400mm/16''(set) -----------------------------10 lei
Suporti motor Dacia-------------------------------------------------25 lei
Termostat Dacia -----------------------------------------------------10 lei
Triunghi reflectorizant ----------------------------------------------20 lei
Valve tubeles ----------------------------------------------------------1 lei
Telef.0763012130
x x x - x
valy051
post 24 Jun 2016, 10:12
Post #722
Telef.0763012130
x x x - x
valy051
post 2 Jul 2016, 16:54
Post #723
Telef.0763012130
x x x - x
valy051
post 7 Jul 2016, 16:12
Post #724
Telef.0763012130
x x x - x
valy051
post 10 Jul 2016, 21:15
Post #725
Telef.0763012130
x x x - x
valy051
post 16 Jul 2016, 21:26
Post #726
Telef.0763012130
x x x - x
valy051
post 23 Jul 2016, 07:00
Post #727
Telef.0763012130
x x x - x
valy051
post 28 Jul 2016, 11:06
Post #728
Telef.0763012130
x x x - x
valy051
post 4 Aug 2016, 08:22
Post #729
Telef.0763012130
x x x - x
valy051
post 10 Aug 2016, 22:18
Post #730
Telef.0763012130
x x x - x
valy051
post 17 Aug 2016, 12:16
Post #731
Telef.0763012130
x x x - x
Kiraly
post 18 Aug 2016, 17:54
Post #732
Buna! Chiuloasa are scaune si ghiduri sau este complet neechipata? Ce fabricatie este? Poze aveti?
This post has been edited by Kiraly: 18 Aug 2016, 20:26
Kiraly
post 22 Aug 2016, 17:02
Post #733
Astept pozele!
valy051
post 23 Aug 2016, 07:27
Post #734
Pentru user Kiraly
23 Aug 2016, 15:48:
Telef.0763012130
This post has been edited by valy051: 23 Aug 2016, 15:48
x x x - x
valy051
post 2 Sep 2016, 19:53
Post #735
Telef.0763012130
x x x - x
constantin d
post 7 Sep 2016, 17:13
Post #736
Va salut,o poza cu blocul de diode se poate pune? Multumesc.
dacia 1300 1971 - renault
valy051
post 8 Sep 2016, 12:57
Post #737
Pentru userul constantin d,foto Bloc Diode
Telef.0763012130
x x x - x
valy051
post 15 Sep 2016, 08:51
Post #738
Telef.0763012130
x x x - x
emildebreti
post 15 Sep 2016, 19:05
Post #739
Buna ziua. rotor alternator de dacia 1300 din 78 aveti?
multumesc
Dacia 1300 Dacia 1300 1978 - Ph32zty
valy051
post 21 Sep 2016, 10:50
Post #740
Raspuns PM user-ului emildebreti
Telef.0763012130
x x x - x
valy051
post 27 Sep 2016, 19:26
Post #741
Telef.0763012130
x x x - x
valy051
post 3 Oct 2016, 12:40
Post #742
Telef.0763012130
x x x - x
valy051
post 9 Oct 2016, 11:02
Post #743
Telef.0763012130
x x x - x
valy051
post 15 Oct 2016, 19:35
Post #744
Telef.0763012130
x x x - x
valy051
post 21 Oct 2016, 11:54
Post #745
Telef.0763012130
x x x - x
valy051
post 28 Oct 2016, 13:37
Post #746
Telef.0763012130
x x x - x
valy051
post 4 Nov 2016, 12:29
Post #747
Telef.0763012130
x x x - x
Adrian Frigo
post 4 Nov 2016, 20:10
Post #748
Membru cu o tigaie de dacie
QUOTE(valy051 @ 4 Nov 2016, 13:29)
Dacia 1300/ 1310/1410 GTL/CL/Lj/Renault /1972/1986/1997/2000 și ceva... - XX-00-UAP/ACR
Mașina este ca femeia,dacă nu o întreții....TE LASĂ!
Daciot convins!
valy051
post 7 Nov 2016, 15:07
Post #749
Pentru user Adrian Frigo :
x x x - x
valy051
post 11 Nov 2016, 12:41
Post #750
Telef.0763012130
x x x - x
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 14th July 2025 - 12:49
