[VAND]piese DACIA noi-REDUCERE DE PRETURI
valy051 |
#661
Membru autentic Group: Members Posts: 2.667 Joined: 9 April 09 From: Bucuresti ![]() |
x
x
x
- x
valy051 |
#662
Vand piese NOI Dacia:
Alternator Dacia(Cod 1114)--------------------------170 lei Antifurt buson rezervor benzina(Aluminiu)-----------------------25 lei Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---------60 lei Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm---100 lei/2buc. Ax pompa apa Dacia(INOXIDABIL) ------------------------10 lei Bascula sup.cu pivot(rebucsata Fartec)DACIA-Papuc------------35 lei Bec 21W/5W(dublu filament) ---------------------------1 lei/buc Bieleta directie(tabla ambutisata)Dacia(Topoloveni)------------40 lei Bloc diode(mari) --------------------------------------------25 lei Borne acumulator(bronz) --------------------------------7 lei/set Brida radiator -------------------------------------------------2 lei Bucsa ax volan----------------------------------------------2.5 lei Bucsa bascula sup.(Fartec)) ------------------------------------10 lei Bucsa caseta directie(teflon) ---------------------------------5-lei/buc Bucsa cauciuc bascula spate -------------------------------4-lei Bucsa cuplaj volan(Fartec Brasov)----------------------------10-lei Bucsa tirant----------- ----------------------------------16-lei/4buc Burduf planetara(mare) --------------------------------------5-lei Burduf planetara(mic) ----------------------------------------4-lei Buson baie ulei -----------------------------------------------4-lei Buson radiator ------------------------------------------------2-lei Butuc roata fata Dacia Papuc(3 prezoane)(tractiune spate)--------55-lei Butuc roata fata Dacia Berlina-Combi(3 prezoane)---------------------------50 lei Cala carburator textolit ------------------------------------------1,5 lei Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)8buc--150 lei/set 4buc Camere Victoria 175/185/195-14 ----------------------------6 ron Capac pompa apa Dacia(Pulsor - Scornicesti)----------------100 lei Capac delcou Dacia -------------------------------------------5 lei Carbuni alternator Urziceni ------------------------------------5 lei Carbuni electromotor Dacia-Oltcit -----------------------------6 lei Carburator Dacia 1400(27)(S.H.perfecta stare)---------------55 lei Ceas presiune ulei-----------------------------------------------10 lei Cheie combinata buson ulei baie+c.v. Dacia------------------15 lei Chiulasa neechipata 1310/1410 -----------------------------250 lei Cleste dezizolator multifunctional----------------------------2,5lei Cleste dezizolator cablu(profesional)-------------------------25 lei Comutator semnal. directie 1310/1410 ----------------------12 lei Culbutori (2 buc.)-------------------------------------------------10 lei/buc Curea trapez.dintata GATES6213MC AVX10x825La--------13 lei Curea trapez.SUPER 9.5x950 -------------------------------11 lei Curea ventilator Fartec 10x6x1000 --------------------------5 lei Curea ventilator Fartec 10x8x1218 --------------------------9 lei Cutie sigurante 10 cai ----------------------------------------8 lei Cuzineti ST R1 Dacia1310/1410 ----------------------------25 lei Disc ambreiaj Dacia 1310/1410(Fi 180)original------------55 lei Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)---12 lei Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20lei Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10 lei Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 lei Garnituri cilindrii receptori spate Dacia-----------------------3 lei Garnituri motor 1410(set)-------------------------------------30 lei Inele sincron C.V.-----------------------------------------------25 lei Jicloare 1300/1400 Carfil(diferite)---------------------------3lei/buc Motor stergator parbriz ARO 10------------------------------35 lei Oala planetara(dinspre roata) ------------------------------35 lei Patent 200mm---------------------------------------------------5 lei Pistol aer cu manometru(0,5-10bar)(Italia) -------------30 lei Pivot superior--------------------------------------------------20 lei Presa pivoti Dacia----------------------------------------------45 lei Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----40 lei/set Releu far(4pic.) -------------------------------------------------3 lei Releu protectie halogene 30A(Italy) -----------------------10 lei Releu semnalizare Sacele ------------------------------------10 lei Releu tensiune mecanic Bulgaria-12V ----------------------30 lei Releu tensiune Sacele 12 V----------------------------------38 lei Rotor electromotor D.Sacele --------------------------------90 lei Rotor alternator D.Sacele------------------------------------60 lei Rulment ambreiaj Fi180(39060) ---------------------------12 lei Rulment biconic Mare(35305)C.V---------------------------45 lei Rulment conic302/37 -----------------------------------------14 lei Rulment roata fata 6207 -------------------------------------18 lei Rulmenti cutie viteza(5tr) -------------------------------100 lei/set Saboti frana 1310 (Fermit-Rm.Sarat)-----------------------80/set 4 buc Semeringuri FARTEC-----110x130x13(arbore Tractor U 650)-------12lei -------------------------80x100x10-----------------------------8 lei -------------------------50x70x10(butuc roata ARO)-------------7 lei --------------------------35x50x8(distributie Dacia)-------------5 lei --------------------------26x42x10(planetara Dacia 1310)-------4 lei Simering priza C.V. 17x28x7/13F ---------------------------------4 lei Set sigurante(8A-16A)----------------------------------------------2 lei Set Yalle usi+portbagaj1310 -------------------------------------40 lei Sonda litrometrica 5726(ARO?)-----------------------------------20 lei Sonda ulei ceas -----------------------------------------------------22 lei Stator alternator ----------------------------------------------------55 lei Stergatoare SACA 400mm/16''(set) -----------------------------10 lei Suporti motor Dacia-------------------------------------------------25 lei Termostat Dacia -----------------------------------------------------10 lei Triunghi reflectorizant ----------------------------------------------20 lei Valve tubeles ----------------------------------------------------------1 lei Telef.0763012130 |
x
x
x
- x
valy051 |
#663
x
x
x
- x
valy051 |
#664
x
x
x
- x
valy051 |
#665
x
x
x
- x
valy051 |
#666
x
x
x
- x
valy051 |
#667
x
x
x
- x
valy051 |
#668
x
x
x
- x
valy051 |
#669
x
x
x
- x
valy051 |
#670
x
x
x
- x
valy051 |
#671
x
x
x
- x
valy051 |
#672
x
x
x
- x
valy051 |
#673
x
x
x
- x
valy051 |
#674
x
x
x
- x
valy051 |
#675
x
x
x
- x
valy051 |
#676
x
x
x
- x
valy051 |
#677
x
x
x
- x
valy051 |
#678
x
x
x
- x
valy051 |
#679
x
x
x
- x
valy051 |
#680
x
x
x
- x
valy051 |
#681
x
x
x
- x
valy051 |
#682
Alternator Dacia(Cod 1114)--------------------------170 lei Antifurt buson rezervor benzina(Aluminiu)-----------------------25 lei Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---------60 lei Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm---100 lei/2buc. Ax pompa apa Dacia(INOXIDABIL) ------------------------10 lei Bascula sup.cu pivot(rebucsata Fartec)pentru DACIA PAPUC------------35 lei Bascula Inferioara cu pivot(rebucsata Fartec)pentru DACIA PAPUC--------50 lei Bec 21W/5W(dublu filament) ---------------------------1 lei/buc Bieleta directie(tabla ambutisata)Dacia(Topoloveni)------------40 lei Bloc diode(mari) --------------------------------------------25 lei Borne acumulator(bronz) --------------------------------7 lei/set Brida radiator -------------------------------------------------2 lei Bucsa ax volan----------------------------------------------2.5 lei Bucsa bascula sup.(Fartec)) ------------------------------------10 lei Bucsa caseta directie(teflon) ---------------------------------5-lei/buc Bucsa cauciuc bascula spate -------------------------------4-lei Bucsa cuplaj volan(Fartec Brasov)----------------------------10-lei Bucsa tirant----------- ----------------------------------16-lei/4buc Burduf planetara(mare) --------------------------------------5-lei Burduf planetara(mic) ----------------------------------------4-lei Buson baie ulei -----------------------------------------------4-lei Buson radiator ------------------------------------------------2-lei Butuc roata fata Dacia Papuc(3 prezoane)(tractiune spate)--------55-lei Butuc roata fata Dacia Berlina-Combi(3 prezoane)---------------------------50 lei Cala carburator textolit ------------------------------------------1,5 lei Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)8buc--150 lei/set 4buc Camere Victoria 175/185/195-14 ----------------------------6 ron Capac pompa apa Dacia(Pulsor - Scornicesti)----------------100 lei Capac delcou Dacia -------------------------------------------5 lei Carbuni alternator Urziceni ------------------------------------5 lei Carbuni electromotor Dacia-Oltcit -----------------------------6 lei Carburator Dacia 1400(27)(S.H.perfecta stare)---------------55 lei Ceas presiune ulei-----------------------------------------------10 lei Cheie combinata buson ulei baie+c.v. Dacia------------------15 lei Chiulasa neechipata 1310/1410 -----------------------------250 lei Cleste dezizolator multifunctional----------------------------2,5lei Cleste dezizolator cablu(profesional)-------------------------25 lei Comutator semnal. directie 1310/1410 ----------------------12 lei Culbutori (2 buc.)-------------------------------------------------10 lei/buc Curea trapez.dintata GATES6213MC AVX10x825La--------13 lei Curea trapez.SUPER 9.5x950 -------------------------------11 lei Curea ventilator Fartec 10x6x1000 --------------------------5 lei Curea ventilator Fartec 10x8x1218 --------------------------9 lei Cutie sigurante 10 cai ----------------------------------------8 lei Cuzineti ST R1 Dacia1310/1410 ----------------------------25 lei Disc ambreiaj Dacia 1310/1410(Fi 180)original------------55 lei Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)---12 lei Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20lei Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10 lei Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 lei Garnituri cilindrii receptori spate Dacia-----------------------3 lei Garnituri motor 1410(set)-------------------------------------30 lei Inele sincron C.V.-----------------------------------------------25 lei Jicloare 1300/1400 Carfil(diferite)---------------------------3lei/buc Motor stergator parbriz ARO 10------------------------------35 lei Oala planetara(dinspre roata) ------------------------------35 lei Patent 200mm---------------------------------------------------5 lei Pistol aer cu manometru(0,5-10bar)(Italia) -------------30 lei Pivot superior--------------------------------------------------20 lei Presa pivoti Dacia----------------------------------------------45 lei Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----40 lei/set Releu far(4pic.) -------------------------------------------------3 lei Releu protectie halogene 30A(Italy) -----------------------10 lei Releu semnalizare Sacele ------------------------------------10 lei Releu tensiune mecanic Bulgaria-12V ----------------------30 lei Releu tensiune Sacele 12 V----------------------------------38 lei Rotor electromotor D.Sacele --------------------------------90 lei Rotor alternator D.Sacele------------------------------------60 lei Rulment ambreiaj Fi180(39060) ---------------------------12 lei Rulment biconic Mare(35305)C.V---------------------------45 lei Rulment conic302/37 -----------------------------------------14 lei Rulment roata fata 6207 -------------------------------------18 lei Rulmenti cutie viteza(5tr) -------------------------------100 lei/set Saboti frana 1310 (Fermit-Rm.Sarat)-----------------------80/set 4 buc Semeringuri FARTEC-----110x130x13(arbore Tractor U 650)-------12lei -------------------------80x100x10-----------------------------8 lei -------------------------50x70x10(butuc roata ARO)-------------7 lei --------------------------35x50x8(distributie Dacia)-------------5 lei --------------------------26x42x10(planetara Dacia 1310)-------4 lei Simering priza C.V. 17x28x7/13F ---------------------------------4 lei Set sigurante(8A-16A)----------------------------------------------2 lei Set Yalle usi+portbagaj1310 -------------------------------------40 lei Sonda litrometrica 5726(ARO?)-----------------------------------20 lei Sonda ulei ceas -----------------------------------------------------22 lei Stator alternator ----------------------------------------------------55 lei Stergatoare SACA 400mm/16''(set) -----------------------------10 lei Suporti motor Dacia-------------------------------------------------25 lei Termostat Dacia -----------------------------------------------------10 lei Triunghi reflectorizant ----------------------------------------------20 lei Valve tubeles ----------------------------------------------------------1 lei Telef.0763012130 This post has been edited by valy051: 24 Nov 2015, 14:29 |
x
x
x
- x
mivanu |
#683
Membru incepator Group: Members Posts: 5 Joined: 26 November 03 From: Bucuresti ![]() |
Salut,
Ma intereseaza sa cumpar, Carburator CARFIL 32 IRMA[25,5]1300 -------------------150ron, cum trebuie procedat? Multumesc, Mihai Mivanu@yahoo.com |
1978
- B 978 UAP
valy051 |
#684
Alternator Dacia(Cod 1114)--------------------------170 lei Antifurt buson rezervor benzina(Aluminiu)-----------------------25 lei Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---------60 lei Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm---100 lei/2buc. Ax pompa apa Dacia(INOXIDABIL) ------------------------10 lei Bascula sup.cu pivot(rebucsata Fartec)pentru DACIA PAPUC------------35 lei Bascula Inferioara cu pivot(rebucsata Fartec)pentru DACIA PAPUC--------50 lei Bec 21W/5W(dublu filament) ---------------------------1 lei/buc Bieleta directie(tabla ambutisata)Dacia(Topoloveni)------------40 lei Bloc diode(mari) --------------------------------------------25 lei Borne acumulator(bronz) --------------------------------7 lei/set Brida radiator -------------------------------------------------2 lei Bucsa ax volan----------------------------------------------2.5 lei Bucsa bascula sup.(Fartec)) ------------------------------------10 lei Bucsa caseta directie(teflon) ---------------------------------5-lei/buc Bucsa cauciuc bascula spate -------------------------------4-lei Bucsa cuplaj volan(Fartec Brasov)----------------------------10-lei Bucsa tirant----------- ----------------------------------16-lei/4buc Burduf planetara(mare) --------------------------------------5-lei Burduf planetara(mic) ----------------------------------------4-lei Buson baie ulei -----------------------------------------------4-lei Buson radiator ------------------------------------------------2-lei Butuc roata fata Dacia Papuc(3 prezoane)(tractiune spate)--------55-lei Butuc roata fata Dacia Berlina-Combi(3 prezoane)---------------------------50 lei Cala carburator textolit ------------------------------------------1,5 lei Camasi cilindru DACIA 1300(73mm) din teava foraj sonda(pentru cunoscatori)8buc--150 lei/set 4buc Camere Victoria 175/185/195-14 ----------------------------6 ron Capac pompa apa Dacia(Pulsor - Scornicesti)----------------100 lei Capac delcou Dacia -------------------------------------------5 lei Carbuni alternator Urziceni ------------------------------------5 lei Carbuni electromotor Dacia-Oltcit -----------------------------6 lei Carburator Dacia 1400(27)(S.H.perfecta stare)---------------55 lei Ceas presiune ulei-----------------------------------------------10 lei Cheie combinata buson ulei baie+c.v. Dacia------------------15 lei Chiulasa neechipata 1310/1410 -----------------------------250 lei Cleste dezizolator multifunctional----------------------------2,5lei Cleste dezizolator cablu(profesional)-------------------------25 lei Comutator semnal. directie 1310/1410 ----------------------12 lei Culbutori (2 buc.)-------------------------------------------------10 lei/buc Curea trapez.dintata GATES6213MC AVX10x825La--------13 lei Curea trapez.SUPER 9.5x950 -------------------------------11 lei Curea ventilator Fartec 10x6x1000 --------------------------5 lei Curea ventilator Fartec 10x8x1218 --------------------------9 lei Cutie sigurante 10 cai ----------------------------------------8 lei Cuzineti ST R1 Dacia1310/1410 ----------------------------25 lei Disc ambreiaj Dacia 1310/1410(Fi 180)original------------55 lei Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)---12 lei Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20lei Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10 lei Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 lei Garnituri cilindrii receptori spate Dacia-----------------------3 lei Garnituri motor 1410(set)-------------------------------------30 lei Inele sincron C.V.-----------------------------------------------25 lei Jicloare 1300/1400 Carfil(diferite)---------------------------3lei/buc Motor stergator parbriz ARO 10------------------------------35 lei Oala planetara(dinspre roata) ------------------------------35 lei Patent 200mm---------------------------------------------------5 lei Pistol aer cu manometru(0,5-10bar)(Italia) -------------30 lei Pivot superior--------------------------------------------------20 lei Presa pivoti Dacia----------------------------------------------45 lei Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----40 lei/set Releu far(4pic.) -------------------------------------------------3 lei Releu protectie halogene 30A(Italy) -----------------------10 lei Releu semnalizare Sacele ------------------------------------10 lei Releu tensiune mecanic Bulgaria-12V ----------------------30 lei Releu tensiune Sacele 12 V----------------------------------38 lei Rotor electromotor D.Sacele --------------------------------90 lei Rotor alternator D.Sacele------------------------------------60 lei Rulment ambreiaj Fi180(39060) ---------------------------12 lei Rulment biconic Mare(35305)C.V---------------------------45 lei Rulment conic302/37 -----------------------------------------14 lei Rulment roata fata 6207 -------------------------------------18 lei Rulmenti cutie viteza(5tr) -------------------------------100 lei/set Saboti frana 1310 (Fermit-Rm.Sarat)-----------------------80/set 4 buc Semeringuri FARTEC-----110x130x13(arbore Tractor U 650)-------12lei -------------------------80x100x10-----------------------------8 lei -------------------------50x70x10(butuc roata ARO)-------------7 lei --------------------------35x50x8(distributie Dacia)-------------5 lei --------------------------26x42x10(planetara Dacia 1310)-------4 lei Simering priza C.V. 17x28x7/13F ---------------------------------4 lei Set sigurante(8A-16A)----------------------------------------------2 lei Set Yalle usi+portbagaj1310 -------------------------------------40 lei Sonda litrometrica 5726(ARO?)-----------------------------------20 lei Sonda ulei ceas -----------------------------------------------------22 lei Stator alternator ----------------------------------------------------55 lei Stergatoare SACA 400mm/16''(set) -----------------------------10 lei Suporti motor Dacia-------------------------------------------------25 lei Termostat Dacia -----------------------------------------------------10 lei Triunghi reflectorizant ----------------------------------------------20 lei Valve tubeles ----------------------------------------------------------1 lei Telef.0763012130 |
x
x
x
- x
valy051 |
#685
x
x
x
- x
Musi |
#686
Membru incepator Group: Members Posts: 3 Joined: 11 December 15 ![]() |
Salut, volan care sa se potriveasca la papuc gasesc? (Am auzit ca si cel de supernova merge, zic bine?)
Papuc
valy051 |
#687
x
x
x
- x
valy051 |
#688
x
x
x
- x
razvan1985 |
#689
![]() membru...unic Group: Members Posts: 2.046 Joined: 18 May 11 From: bucuresti ![]() |
Se poate o poza cu cuzineții 1310/1400 ST/R1,25lei?
Dacia/Delta
1410/1310/L/MLS
1996/1988
- B 91 RZN/B 191 RZN decat una proasta,mai bine mai multe bune...(masina)
valy051 |
#690
x
x
x
- x
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 14th July 2025 - 16:49 |
