[VAND] DIVERSE, trusa sudura,motor elect.,etc,etc.
valy051 |
#121
Membru autentic Group: Members Posts: 2.667 Joined: 9 April 09 From: Bucuresti ![]() |
x
x
x
- x
valy051 |
#122
VAND sau SCHIMB doar cu telefoane mobile noi(ex.NOKIA:6700 Classic,C6-01,C5-03,C5-5MP,exclus fake-uri)
Suport diferenta pret,daca este cazul. Vand: Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------35ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----195ron Placute Widia------------------------------------------------5ron/buc Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 300------------------------450ron Dulap metalic tip fiset---------------------------------------250ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1400ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------550ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------670ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Electromotor Motostivuitor Bulgaria---------------------------------------------250ron Bucsi biela,simeringuri supapa pt.motor 3 cil.Bulgaria-------------------------50ron Capete bara,pompa ulei,pompa frana Motostivuitor 3 cil.Bulgaria-----------100ron Radiator Motostivuitor motor 3 cilindrii-----------------------------------------160ron telef.0763012130 |
x
x
x
- x
valy051 |
#123
Up!
x
x
x
- x
valy051 |
#124
x
x
x
- x
valy051 |
#125
Suport diferenta pret,daca este cazul. Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------35ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----195ron Placute Widia------------------------------------------------5ron/buc Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 300------------------------450ron Dulap metalic tip fiset---------------------------------------250ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1400ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------550ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------670ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Electromotor Motostivuitor Bulgaria---------------------------------------------250ron Bucsi biela,simeringuri supapa pt.motor 3 cil.Bulgaria-------------------------50ron Capete bara,pompa ulei,pompa frana Motostivuitor 3 cil.Bulgaria-----------100ron Radiator Motostivuitor motor 3 cilindrii-----------------------------------------160ron telef.0763012130 |
x
x
x
- x
valy051 |
#126
x
x
x
- x
valy051 |
#127
x
x
x
- x
valy051 |
#128
x
x
x
- x
valy051 |
#129
x
x
x
- x
valy051 |
#130
x
x
x
- x
valy051 |
#131
x
x
x
- x
valy051 |
#132
x
x
x
- x
valy051 |
#133
x
x
x
- x
valy051 |
#134
Suport diferenta pret,daca este cazul. Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator tractor U 650(12V;Cod 1134;36A)(NOU)----------300ron Semicuzineti Palier+Biela R1 Tractor U 650-------------------140ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------35ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----195ron Placute Widia------------------------------------------------5ron/buc Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 300------------------------450ron Dulap metalic tip fiset---------------------------------------250ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1400ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------550ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------670ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Electromotor Motostivuitor Bulgaria---------------------------------------------250ron Bucsi biela,simeringuri supapa pt.motor 3 cil.Bulgaria-------------------------50ron Capete bara,pompa ulei,pompa frana Motostivuitor 3 cil.Bulgaria-----------100ron Radiator Motostivuitor motor 3 cilindrii-----------------------------------------160ron telef.0763012130 |
x
x
x
- x
valy051 |
#135
x
x
x
- x
valy051 |
#136
x
x
x
- x
valy051 |
#137
x
x
x
- x
valy051 |
#138
x
x
x
- x
valy051 |
#139
x
x
x
- x
valy051 |
#140
x
x
x
- x
valy051 |
#141
VAND sau SCHIMB doar cu telefoane mobile noi (ex.NOKIA Nokia 6700 Classic Silver Chrome Nokia ,C6-01,Nokia C5-03,Nokia C5-5MP,exclus fake-uri)
Suport diferenta pret. Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator tractor U 650(12V;Cod 1134;36A)(NOU)----------300ron Semicuzineti Palier+Biela R1 Tractor U 650-------------------140ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------35ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----195ron Placute Widia------------------------------------------------5ron/buc Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 300------------------------450ron Dulap metalic tip fiset---------------------------------------250ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1400ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------550ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------670ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Electromotor Motostivuitor Bulgaria---------------------------------------------250ron Bucsi biela,simeringuri supapa pt.motor 3 cil.Bulgaria-------------------------50ron Capete bara,pompa ulei,pompa frana Motostivuitor 3 cil.Bulgaria-----------100ron Radiator Motostivuitor motor 3 cilindrii-----------------------------------------160ron telef.0763012130 This post has been edited by valy051: 16 Jan 2012, 13:10 |
x
x
x
- x
valy051 |
#142
Suport diferenta pret. Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator tractor U 650(12V;Cod 1134;36A)(NOU)----------300ron Semicuzineti Palier+Biela R1 Tractor U 650-------------------140ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------35ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----195ron Placute Widia------------------------------------------------5ron/buc Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 300------------------------450ron Dulap metalic tip fiset---------------------------------------250ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1400ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------550ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------670ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Electromotor Motostivuitor Bulgaria---------------------------------------------250ron Bucsi biela,simeringuri supapa pt.motor 3 cil.Bulgaria-------------------------50ron Capete bara,pompa ulei,pompa frana Motostivuitor 3 cil.Bulgaria-----------100ron Radiator Motostivuitor motor 3 cilindrii-----------------------------------------160ron telef.0763012130 |
x
x
x
- x
valy051 |
#143
x
x
x
- x
valy051 |
#144
x
x
x
- x
valy051 |
#145
x
x
x
- x
valy051 |
#146
x
x
x
- x
valy051 |
#147
x
x
x
- x
valy051 |
#148
Suport diferenta pret. Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator tractor U 650(12V;Cod 1134;36A)(NOU)----------300ron Semicuzineti Palier+Biela R1 Tractor U 650-------------------140ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------35ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Placute Widia------------------------------------------------5ron/buc Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 300------------------------450ron Dulap metalic tip fiset---------------------------------------250ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1400ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13(arbore Tractor U 650)----10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------550ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------670ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Electromotor Motostivuitor Bulgaria---------------------------------------------250ron Bucsi biela,simeringuri supapa pt.motor 3 cil.Bulgaria-------------------------50ron Capete bara,pompa ulei,pompa frana Motostivuitor 3 cil.Bulgaria-----------100ron Radiator Motostivuitor motor 3 cilindrii-----------------------------------------160ron telef.0763012130 |
x
x
x
- x
valy051 |
#149
x
x
x
- x
valy051 |
#150
Suport diferenta pret. Electromotor Volkswagen Jetta-S.H.----------------------------90ron Alternator tractor U 650(12V;Cod 1134;36A)(NOU)----------300ron Semicuzineti Palier+Biela R1 Tractor U 650-------------------140ron Electromotor(Demaror)Tractor U 650(NOU)-------------------550ron Alternator Volkswagen Jetta-S.H.-------------------------------90ron Element filtru ulei avion(inoxidabil)-----------------------------40ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Placute Widia------------------------------------------------5ron/buc Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 300---------------------------450ron Dulap metalic tip fiset------------------------------------------250ron Dulap metalic 2 usi--------------------------------------------400ron Masina gaurit cu coloana(380V)----------------------------1400ron Pompa picior(1cilindru)-----------------------------------------12ron Pompa picior(2cilindrii)------------------------------------------22ron Cutite strung vidia-----------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13(arbore Tractor U 650)----10ron ------80x100x13----------------------------------------------------8ron ------50x70x10------------------------------------------------------7ron -------35x50x8------------------------------------------------------5ron --------26x42x10----------------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------550ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------670ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Electromotor(Demaror),,BALKANCAR''Bulgaria-------------------------------450ron Bucsi biela,simeringuri supapa pt.motor 3 cil.Bulgaria-------------------------50ron Capete bara,pompa ulei,pompa frana Motostivuitor 3 cil.Bulgaria-----------100ron Radiator Motostivuitor motor 3 cilindrii-----------------------------------------160ron telef.0763012130 |
x
x
x
- x
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 14th July 2025 - 11:48 |
