LOGAN 1.2 16V, CE PARERE AVETI? ATI TESTAT?
ARMIUS |
Group: Members Posts: 0 Joined: 22 July 09 ![]() |
LOGAN 1.4MPI + LOGAN VAN 1.5DCI
valerica1 |
![]() Membru Group: Members Posts: 116 Joined: 5 June 09 ![]() |
incearca sa urci o panta de 45 grade cu el si o sa vezi cat e de bun,
sandero
diverse
Flipper1986 |
Membru incepator Group: Members Posts: 30 Joined: 19 October 07 From: Galati ![]() |
NU am testat, dar pt oras cred ca e bun mai ales pe sandero, pe logan obia o sa se taraie
iar daca masina merge mult inafara orasului nu renteaza acest motor mai ales daca soferul e vitezoman ca va consuma mult pt ca e mic motorul si va fi turat mai mult la o viteza de exemplu de 130km/h fata de 1.6mpi care va avea la aceeasi viteza o turatei mai mica. |
1.5 DCI 65CP, Ambition, 2006
- GL-XX-XXX
adrian_c |
![]() Membru actionand in sectorul privat Group: Members Posts: 453 Joined: 14 November 04 From: DB, Bucuresti, Paris, Belgia ![]() |
Cred ca ar fi super tare sa puna motorul ala de Matiz 800 cm3
Solenza Scala
xx.09.2004
- DB-05-xxx Citroen C4 1.6HDI xx.04.2009 - 710-BxD
ArtVandelay |
![]() Anytown, USA.. Group: Members Posts: 2.662 Joined: 5 January 08 From: Craiova ![]() |
hummerul urca la 60
focus
2001 He wondered why the boomerang kept getting bigger. Then, it hit him.
I got 99 cookiez cause a bitch ate one. |
roland |
Serje |
MTD
Optima
53 SPB HW
QUOTE(ArtVandelay @ 22 Jul 2009, 15:25) Altu'... Hummerul nu urca o panta de 60 de grade, urca o panta de 60%, dupa cum se poate vedea chiar in specificatiile sale: untitled.JPG ( Size: 93.32k ) Number of downloads: 2517 Panta de 60% inseamna ca pe o distanta de 100 metri urci o verticala de 60 metri. ( http://mathforum.org/library/drmath/view/63099.html ) Deci in acest caz Tg(a) = 0.6 (adica 60/100). Tg(30) = 0,57 ... Iar arctg(0,6) = 30grade si vreo 55 minute. Pana la 60 de grade mai e cale lunga... |
ArtVandelay |
bine,bine..da' vezi ca e rampa
focus
![]() Ai gasit si tu ceva sa te legi. Ai intrebat repede profesorul de legislatie? |
ArtVandelay |
pana una alta, vezi cum e treaba cu mersul pe contrasens si mersul pe interzis..ca la lb romana ne-am lamurit
This post has been edited by ArtVandelay: 22 Jul 2009, 15:25 |
focus
vijelie |
Declivitatile maxime pe drumurile publice sunt in jur de 10%, adica abia 5.7 grade sexazecimale.
This post has been edited by vijelie: 22 Jul 2009, 15:30 |
Duster
2011 Laureate dCi
@ArtVandelay
Da, da, stiu ca la munte cand urci tu costisa mergi pe rampa, iar cand o cobori mergi pe panta, plin de scrofulosenie. Cu masurarea inclinarii rampei si pantei ai probleme si faci confuzii grosolane, in rest, scrofulosenia la ea acasa, ce sa spun. |
liviu2004 |
Si care e problema tehnica?
Tigra Twintop
LuluMOB |
![]() Membru cu pedale. Group: Members Posts: 1.136 Joined: 28 October 05 From: Iași ![]() |
Despre grade si procente (problema mult discutata la ciclisti):
http://en.wikipedia.org/wiki/Grade_(slope) Sa vedeti voi la biciclisti cum se urca si se coboara 45-60 de grade sau mai mult, asa, cu rasuflarea tinuta... |
ABS+ AC 1.4MPI 06/2007
corbex |
QUOTE(LuluMOB @ 22 Jul 2009, 20:06) Despre grade si procente (problema mult discutata la ciclisti): http://en.wikipedia.org/wiki/Grade_(slope) Sa vedeti voi la biciclisti cum se urca si se coboara 45-60 de grade sau mai mult, asa, cu rasuflarea tinuta... Nu cred ! La 45 de grade ai mari dificultati in a urca pe jos, incaltat in bocanci. Poate e vorba de 45%, conform lamuririlor de mai sus. |
2005, cheala
LuluMOB |
Nu, nu, e vorba de artisti in ale ciclismului, care masoara viteza pe cadranul de la apometru si citesc gradele de la rampa pe eticheta sticlei de coniac... daca te aud ca le spui asta rad de tine (eu am patit-o).
corbex |
Mea culpa! Daca citeam mai atent imi dadeam seama ca-i iei peste picior.
2005, cheala
valerica1 |
QUOTE(klaus @ 22 Jul 2009, 14:10) unde lucrez panta pe care o cobor si urc e de 45 grade (garaj subteran), mai toate cladirile mari de birouri din Bucuresti AU PANTA DE 45 GRADE domnule Cosmin fac lucru asta zi de zi cu masina personala, si am facut si cu un logan 1,2 si te las pe tine sa imi zici ce crezi ca s-a intamplat |
sandero
diverse
vijelie |
Ia baga o poza, sa mai radem putin.
Duster
2011 Laureate dCi
BZN |
QUOTE(valerica1 @ 23 Jul 2009, 15:26) unde lucrez panta pe care o cobor si urc e de 45 grade (garaj subteran), mai toate cladirile mari de birouri din Bucuresti AU PANTA DE 45 GRADE ... Vezi, pe timpuri se gaseau echere. Daca vedeai unul (potrivit, nu orice model) sigur nu mai scriai acum asa ceva! ![]() This post has been edited by BZN: 23 Jul 2009, 15:08 |
Tico 0,796 6v, 1998
/Logan 1,598 16v, 2009
- AGXXMAV / AGXXVAB
QUOTE(valerica1 @ 23 Jul 2009, 15:26) unde lucrez panta pe care o cobor si urc e de 45 grade (garaj subteran), mai toate cladirile mari de birouri din Bucuresti AU PANTA DE 45 GRADE domnule Cosmin fac lucru asta zi de zi cu masina personala, si am facut si cu un logan 1,2 si te las pe tine sa imi zici ce crezi ca s-a intamplat Ia un poloboc si un raportor si masoara panta. Sa ne spui dupa aia gradul exact. |
LuluMOB |
QUOTE(valerica1 @ 23 Jul 2009, 14:26) unde lucrez panta pe care o cobor si urc e de 45 grade (garaj subteran), mai toate cladirile mari de birouri din Bucuresti AU PANTA DE 45 GRADE domnule Cosmin fac lucru asta zi de zi cu masina personala, si am facut si cu un logan 1,2 si te las pe tine sa imi zici ce crezi ca s-a intamplat ![]() |
Andy_ACS |
A pus un coleg linkul asta mai sus: http://en.wikipedia.org/wiki/Grade_(slope)
Macar pe poze daca va uitati si tot va dadeati seama de diferenta... Bafta! |
LuluMOB |
Valerica1, ia un aparat si fa o poza la loganul tau, din lateral, trage o dunga de sub spoilerul fata la un unghi de 45 de grade cu orizontala si zi-mi cat mai e pana la roata. Dupa aia sa-mi zici cu ce viteza trebuie sa vii lansat ca sa poti sa te inscrii pe urcare.
Nu mai intreb cum IESI de pe zona de urcare, inapoi pe orizontala. A, am uitat, in parcarile subterane e spatiu cacalau, se fac racordari 'dulci' de 50 de metri... 23 Jul 2009, 16:12: profil.jpg This post has been edited by LuluMOB: 23 Jul 2009, 16:12 |
Andy_ACS |
@LuluMOB - inteleg ce vrei tu sa ii demonstrezi si ai dreptate in principiu, dar exemplul nu e cel mai bun deoarece in general aceste urcari nu pornesc brusc, adca suprafata orizontala pana la un punct dupa care suprafata in urcare, ci gradual. La fel si la trecerea din urcare in orizontal, se face gradual ca o 'cocoasa', nu cu muchie.
Bafta! |
corbex |
Ca sa inteleaga biciclistii lui LuluMob ce-i aia panta de 45 de grade:
Desenati un patrat, cu baza orizontala, uniti oricare doua colturi opuse vreti voi si dupa aceea priviti inclinatia rezultata. As fi putut sugera si sa trasati bisectoarea unui unchi drept, dar ma tem ca e prea complicat, trebuie sa aflati ce-i aia bisectoare, la cite grade fierbe unghiul drept, si nici in librarii n-am mai vazut raportoare, ca sa nu mai zic de DEX-uri. Ramine metoda cu patratul. Daca inclinatia seamana cu ce stiti voi, atunci ne inscriem noi la "SPIRU HARET" - facultatea de poezie. This post has been edited by corbex: 23 Jul 2009, 19:12 |
2005, cheala
Amedeus |
QUOTE(liviu2004 @ 22 Jul 2009, 19:35) Problema e ca un Logan cu motorizarea din titlu nu urca o rampa cu inclinatia de 60° ![]() P.S. Un unghi de 45° inseamna o panta de 100%. ![]() Tramvaiele din Lisabona urca rampe de 13% lis.jpg ( Size: 124.63k ) Number of downloads: 2351 This post has been edited by Amedeus: 23 Jul 2009, 20:46 |
Megane Sedan IV Tce 116
2019 Business
valerica1 |
ma scuzati dar am gresit panta e de 35 de grade
de data asta ai avut dreptate domnule cosmin |
sandero
diverse
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 22nd July 2025 - 06:32 |
