GPS WayteQ x820, Totul despre acest tip de GPS
eugen_b_e |
#421
Membru incepator Group: Members Posts: 58 Joined: 22 August 07 From: Constanta ![]() |
Megane Sedan Privilege 1,5dci 105 CP
- CT xx xxx
2007 Renault Megane Sedan Privilege 1,5 dci 105 CP 2007
Renault Megane Sedan Techno 1,33 TCE 140 CP 2024 |
corbex |
#422
Am, lua-le-ar dracu, cel care a facut kitul pe care l-am instalat a pus acolo fisierele astea cu indicatii de a fi copiate in map-urile corespunzatoare. Doat ca in loc de ta a pus tt. Dar si fisierul harta era tot tt (tom tom a preluat tele atlas).
This post has been edited by corbex: 21 Feb 2013, 15:43 |
2005, cheala
Squirrel |
#423
![]() Captain of Black Pearl™… Group: Members Posts: 4.466 Joined: 13 March 08 From: partea mea: Drum bun! ![]() |
- Have a Snickers!
- Why? - Everytime you get hungry, you turn into a diva… Eu zic să abordezi cu calm problema…Undeva este o scăpare. |
Duster
- RO 44 AWD
2010 1,6 16v 4Ś4 Laureaté Noir Nacré Fire, walk with me...in 4 strokes, water cooled.
corbex |
#424
L-am facut sa mearga. Secretul era aici:
[switchmap] changer="\Storage Card\iGO8\MapChanger\MapChanger.exe" 1=",map_ta,\Storage Card\iGO8,\Storage Card\iGO8," 2=",map_nt,\Storage Card\iGO8,\Storage Card\iGO8," 3=",map_ot,\Storage Card\iGO8,\Storage Card\iGO8," 4=",map_us,\Storage Card\iGO8,\Storage Card\iGO8," ;---first path - path to content folder, second - to igo8.exe. ;Examples if maps and igo on the same place: ;4=",map_us,\Storage Card\iGO8,," and 'changer' key not required Unpack "mapchanger" folder into directory where igo8.exe installed (typicaly \Storage Card\IGO8). Copy map files: Teleatlas -> map navteq -> map_nt Other -> map_ot User -> map_us There is a possibility to specify the name of the map provider for MapChanger menu buttons: [switchmap] map_ta="Provider 1" map_nt="Provider 2" map_ot="Provider 3" map_us="Provider 4" If not to specify it the text on buttons will be by default (TELEATLAS, NAVTEQ, OTHER, USER). This post has been edited by corbex: 24 Feb 2013, 11:53 |
2005, cheala
Renopel |
#425
Membru incepator Group: Members Posts: 47 Joined: 15 October 09 From: Bucuresti ![]() |
QUOTE(2012 @ 15 Feb 2013, 20:26) Impresia mea e ca habar n-ai ce-s alea un sistem de operare, un procesor, un set de instructiuni, o interfata... QUOTE(klaus @ 15 Feb 2013, 20:46) Pai... te impiedica cineva? Apuca-te de facut soft compatibil, sunt convins ca o sa fie multi doritori. QUOTE(Gill_ro @ 16 Feb 2013, 09:07) @Renopel crezi ca Android-ul fie el ICS sau Jelly Beam ( nu zic de versiunile anterioare), o sa mearga decent pe acest aparat cu doar cei 128 mb ram? Daca da, spor la realizarea softului sa fie compatibil cu partea hard. Probabil aveti cunostinte in domeniu care ma depasesc, insa argumentul "nu se poate" fara o minima explicatie mi se pare lipsit de spiritul acestui forum deschis tocmai spre dialog, provocare si aflarea unor raspunsuri la problemele pe care le avem fiecare. Raspunsul lui Gil_ro mi se pare suficient sa inteleg ca exista un minim de cerinte hard pe care X820BT nu le indeplineste pentru a fi un candidat de suport Android. Merci. |
Vectra B
1997
corbex |
#426
Are destul hard, n-o sa stii tu sa-l pui de acord cu androidul. Realizarea unui sistem de operare e binisor mai complicata decit tiuningul de logan.
2005, cheala
Gill_ro |
#427
![]() ..Nici paine fara munca, nici munca fara paine.. Group: Members Posts: 2.349 Joined: 1 February 07 From: Bucuresti ![]() |
Renopel vezi ce telefoane de generatie mai veche cu android au cam acceasi configuratie ca WayteQ ( sa zicem HTC DREAM ) si daca e poti pleca de acolo cu realizarea portarii androidului pe PNA-ul tau.
Megane II.1 / Megane IV GT ///
- = B-006-ILL
2004 Sedan Privilege 1.5 dci / 2017 GT 1.6 dci Mi-e grea maturitatea, mi-e greu să fiu docil,
Aș da orice pe lume să redevin copil! |
predal |
#428
Membru incepator Group: Members Posts: 1 Joined: 29 July 15 ![]() |
Salut,
De unde pot downloada si eu ghidul? Am un x820 si nu stiu cum sa ii actualizez hartile. Cand il conectez la calculator nu mi-l vede windowsul. Multumesc |
Focus
corbex |
#429
Vezi si tu daca e setat ca mass storage. Daca nu, scoate-i cardul, baga-l intr-un cititor si copiezi ce vrei. Poti incerca mai multe poturi usb, mai multe calculatoare.
2005, cheala
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 4th August 2025 - 11:25 |
