Schimbat scaune Logan
juristul2000 |
![]() "Membru 20 cm record" Group: Members Posts: 793 Joined: 6 October 05 From: Oradea ![]() |
Laurate 2005
- AR-07-RZV 20% warn permanent!!!
decat sa...... mai bine nu!!!! NU, da spaga!!! |
PAULIC |
![]() Membru incepator Group: Members Posts: 39 Joined: 1 June 07 From: Bucuresti ![]() |
Uite cum am rezolvat eu problema.
Attached thumbnail(s) Picture_044.jpg ( Size: 589.6k ) Number of downloads: 7514 Picture_046.jpg ( Size: 775.66k ) Number of downloads: 8667 |
MERCEDES LOGAN
E 220 CDI 1,5 DCI
W211 2003 LAUREATE 2006
- B38TXY B48VCK LOGAN LAUREATE 1,5 DCI 2006
MERCEDES E 220 CDI 2003 |
alexis |
![]() daciot Group: Members Posts: 204 Joined: 30 June 05 From: Bucuresti ![]() |
@Paulic: arata bine scaunele; de unde si cat te-a costat? S-au adaptat usor? Sinele de logan sunt la inaltimi diferite. Cum ai adaptat prinderile centurilor de siguranta?
Spring
2021
- B XX HXX
juristul2000 |
cam la asa ceva ma gandesc si eu dar numai pe fata,in spate nu stau :)Paul asteptam detalii
Laurate 2005
PAULIC |
Diferenta de inaltime dintre sinele de logan este de 60 mm,dar se compexeaza foarte usor. Tapiteria este de mercedes E class den 2000. In afara de diferenta de inaltime trebuie compoxata si o diferenta in lalime,care la aceste scaune este de 100 mm. Am sa revin cu detalii daca intereseaza pe cineva.
MERCEDES LOGAN
E 220 CDI 1,5 DCI
juristul2000 |
Pe mine ma intereseaza, am inteles ca ce se potrivesc destul de usor ar fi scaunele de Ford
Laurate 2005
alexis |
Spring
2021
- B XX HXX
GOLAN 91 |
![]() Membru Group: Members Posts: 172 Joined: 13 April 06 ![]() |
Sau astea...
This post has been edited by GOLAN 91: 16 Nov 2008, 18:31 Attached thumbnail(s) Picture_181.jpg ( Size: 181.55k ) Number of downloads: 7847 |
Laureat 1.4 MPI
- B 42 ZIF
alexis |
Ai uitat sa pornesti blitzul...
Spring
2021
- B XX HXX
GOLAN 91 |
Nu stiu dece nu merge:( ????
Laureat 1.4 MPI
- B 42 ZIF
Lostboy |
Încearcă să o micșorezi...
PAULIC |
Deci,sa revin cu detalii. Pe partea dinspre interiorul masinii(sina din dreapta cum stai pe scaunul soferului),am taiat o tabla destul de groasa(6-8mm),lunga de 420mm si lata de 60 mm,am gaurito si am prinso in locul in care se prindea vechia sina se la scaunul loganului. Pe partea cealalta trebuind sa compesez inaltimea de 60mm ,am luat alta tabla de aceeasi grosime cu prima,de aceeasi lungime(420mm) dar lalimea fiind de 120 mm.Aceasta tabla am indoito pe lungime in forma de s si am compesat diferenta de inaltime de 60mm. Acestea fiind facute am prins scaunul ca si cum ar fi fost al masinii,fara niciun fel de greutati intimpinate.Sper sa intelegeti ceva din tentativa mea de desen. Linia de jos curbata ar fi podeaua loganului,indreapta se vede tablaindoita in forma de s iar in stinga tabla care ramine la nivelul podelei
Attached File(s) |
MERCEDES LOGAN
E 220 CDI 1,5 DCI
alexis |
@Paulic: si cu sistemul (capul) de prindere lal centurii de siguranta cum ai facut? L-ai pus pe cel de logan?
Spring
2021
- B XX HXX
banutu |
![]() membru cu bani Group: Members Posts: 494 Joined: 12 October 06 ![]() |
QUOTE(PAULIC @ 16 Nov 2008, 22:58) Deci,sa revin cu detalii. Pe partea dinspre interiorul masinii(sina din dreapta cum stai pe scaunul soferului),am taiat o tabla destul de groasa(6-8mm),lunga de 420mm si lata de 60 mm,am gaurito si am prinso in locul in care se prindea vechia sina se la scaunul loganului. Pe partea cealalta trebuind sa compesez inaltimea de 60mm ,am luat alta tabla de aceeasi grosime cu prima,de aceeasi lungime(420mm) dar lalimea fiind de 120 mm.Aceasta tabla am indoito pe lungime in forma de s si am compesat diferenta de inaltime de 60mm. Acestea fiind facute am prins scaunul ca si cum ar fi fost al masinii,fara niciun fel de greutati intimpinate.Sper sa intelegeti ceva din tentativa mea de desen. Linia de jos curbata ar fi podeaua loganului,indreapta se vede tablaindoita in forma de s iar in stinga tabla care ramine la nivelul podelei Cam periculos cu modificarile artizanale tinand cont ca acolo sunt elemente de securitate. Cel mai bine este sa montezi scaune de Sandero / faza 2 . Se potrivesc perfect si sunt mai ergonomice decat cele vechi. |
LOGAN /Megane 3
2006/2011
- AG-00-!!! Membru
GBi |
![]() Membru autentic Group: Members Posts: 264 Joined: 12 August 06 ![]() |
si la cat ajunge un scaun de "Sandel"
![]() This post has been edited by GBi: 17 Nov 2008, 17:47 |
Daciaaa
Golan :))
KissFM 1.6 08 / ex. Laureate 1.4 04 Tot ce e bun tre' sa dispara !
bobo77 |
Sigur are un pret foarte mare si nu se merita...
Laureate 1,6 mpi
2008 ph 2
alexis |
Eu ma gandeam la asa ceva:
Attached thumbnail(s) 31d5_1.JPG ( Size: 9.51k ) Number of downloads: 6942 |
Spring
2021
- B XX HXX
Marso |
![]() ***Membru*** Group: Members Posts: 547 Joined: 1 September 06 From: Bu***esti ![]() |
cam offtopic: puntea spate de la ce masina ai luat'o?
Laureate 1.6 MPI
2006 Gri Perla + GPL Renault Megane Privilege 1.6 16V Bleu
MCV Laureate 1.5 DCI 2007 Gri Platine |
juristul2000 |
Alexis si eu ma gandeam.Rezultatul-inca ma mai gandesc
Laurate 2005
banutu |
LOGAN /Megane 3
2006/2011
- AG-00-!!! Membru
GBi |
ce ziceti de FK_SpaceLook , problema vine la kitul de prindere care vine la scaune, se potriveste si la "Golan"
![]() PS: ei spun ca este universal ! Attached thumbnail(s) FK_SpaceLook.jpg ( Size: 140.42k ) Number of downloads: 6364 |
Daciaaa
Golan :))
PAULIC |
QUOTE(alexis @ 17 Nov 2008, 07:02) @Paulic: si cu sistemul (capul) de prindere lal centurii de siguranta cum ai facut? L-ai pus pe cel de logan? Se potriveste perfect cea de logan. Dar tot asa de bine puteam pune centura de siguranta de mercedes. @banutu, Daca citesti foarte atent,eu am folosit la sistemul de prindere in podea o tabla de3-4 ori mai groasa decit tabla din care este realizat sistemul la logan si de aceea nu imi pot face probleme din cauza securitatii.Referitor la scaunele de Sandero, eu nu vad o prea mare diferenta intre ele si cele de logan. Eu am 115kg si cind ma suiam in masina tot aveam impresia ca se rupe spatarul de la mijloc. Plus ca nu as face munca patriotica sa schimb o tapiterie de dacie cu una tot de dacie avind in vedere ca cele pe care le-am pus imi ofera un alt comfort. |
MERCEDES LOGAN
E 220 CDI 1,5 DCI
Adi florin |
#53
Membru autentic Group: Members Posts: 314 Joined: 29 July 06 From: Bucuresti ![]() |
Salutare,
Vad ca nu s-a mai scris de ceva timp aici. Eu am 1,94 inaltime. Pana acum mi se pareau ok scaunele de Logan, desi, cu tot reglajul lor lombar, parca tot nu-mi statea bine spatele. In weekend am mers cu un Ford Focus sau Fiesta (nu stiu exact). In acel scaun am stat pt prima data foarte bine intr-o masina. Ce e adevarat... n-am mers cu prea multe tipuri de masini... Nu ma mai durea spatele, iar tetiera era suficient de sus incat sa pot sta si cu capul rezemat bine. Intrebare intrebatoare... se pot pune scaunele acelea pe Logan? Fara prea multa bataie de cap, evident... |
Ambition 1.6MPI din 2007
misumisul |
#54
Membru incepator Group: Members Posts: 28 Joined: 28 March 10 ![]() |
Exista vreun scaun care se potiveste exact? In afara de cel original.
This post has been edited by misumisul: 8 Sep 2011, 07:45 |
- CT79CDC
#55
![]() - Group: Members Posts: 22.716 Joined: 19 April 05 From: Romania ![]() |
Nu o sa gasesti niciodata scaune perfect compatibile. Din motive de low cost (faciou dacia), au sprijinit sina din interior pe tunelul central.
Dsign |
#56
Sparco EVO, cu sinele scaunelor originale, plus adaptare facuta acasa din profile patrate de otel.
Scaunele acestea sunt cu spatar fix (dintr-o bucata) si au prinderile pe laterale. Centurile au fost o vreme cele originale, dupa care am montat centuri Sparco de strada, cu prindere in cate 4 puncte, cu catarama rapida, omologata pentru circulatia pe drumurile publice. Scaunele au omologare FIA pana in 2012 PS: au fost noi, insa cam asa arata dupa 2 ani de utilizare cotidiana (s-a rarit materialul tapiteriei, insa acesta se poate inlocui pe bucati la un tapiter, fara prea mari batai de cap) Confortabile nu sunt, insa pastreaza o pozitie corecta a corpului la volan, nu iti permit sa te tolanesti intr-o parte, sa stai cu spatarul culcat pe spate sau mai stiu eu in ce alte pozitii smecheresti. Am condus in ele 500km legati, cu o singura oprire pentru pipi. A doua zi m-am dat la curse iar a treia zi am repetat cei 500km, cu 2 opriri de data asta (mititeii de pe Valea Oltului sunt irezistibili) Pe viraje stranse nu ai surpriza sa te trezesti cu pasagerul peste tine si nici soferul nu are cum sa sara pe locul din dreapta (asa cum se intampla cu vechile scaune, cele de fabrica, alunecam din ele imediat) This post has been edited by Dsign: 8 Sep 2011, 12:13 Attached thumbnail(s) jepege_023.jpg ( Size: 582.81k ) Number of downloads: 1509 IMGP0038.jpg ( Size: 229.27k ) Number of downloads: 1761 |
D
2004 Preference 1.6MPI Egee
#57
Standard Seat
Modified Seat Height of squab side bolster 45mm 50mm Height of backrest side bolster 55mm 70mm Width across flat part of backrest 34cm 31cm Width across flat part of squab 36cm 33cm Attached thumbnail(s) 110948_2mg.jpg ( Size: 324.75k ) Number of downloads: 1639 110948_3mg.jpg ( Size: 295.62k ) Number of downloads: 1418 110948_4mg.jpg ( Size: 632.24k ) Number of downloads: 1286 110948_5mg.jpg ( Size: 295.09k ) Number of downloads: 1176 110948_6mg.jpg ( Size: 291.34k ) Number of downloads: 1007 110948_8mg.jpg ( Size: 315.88k ) Number of downloads: 955 110948_10mg.jpg ( Size: 337.19k ) Number of downloads: 1049 110948_11mg.jpg ( Size: 365.99k ) Number of downloads: 1185 110948_13mg.jpg ( Size: 356.43k ) Number of downloads: 1266 110948_14mg.jpg ( Size: 368.97k ) Number of downloads: 1184 110948_15mg.jpg ( Size: 353.5k ) Number of downloads: 971 |
YRX |
#58
![]() Membru autentic Group: Members Posts: 5.098 Joined: 6 July 06 From: Bucuresti ![]() |
Nu gasesti spuma de densitate corecta pe la noi nici sa dai cu tunu', numai moale gen burete. Am cautat io, vroiam sa fac aproape smecheria din poze, dar mai orientata spre comfort.
Prelucrarea lui ala din poze este de toata jena, a cioplit-o cu cutteru' ![]() This post has been edited by YRX: 8 Aug 2012, 17:00 |
2005 Ambition 1.6 MPI
unchiu |
#59
Membru incepator Group: Members Posts: 3 Joined: 15 March 08 ![]() |
@PAULIC - Te rog daca se poate sa postezi din nou schita cu adaptarea sinelor pt alt scaun. Multumesc.
Zafira
2002 Confort
alex_vlb |
#60
Membru incepator Group: Members Posts: 1 Joined: 7 July 09 ![]() |
a pus cineva scaune de laguna pe logan ca sa lamureasca umpic situatia si sa ne spuna ce a modificat la suporti.
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 15th July 2025 - 15:58 |
