Bula daciotului
Bula daciotului
ady77 |
#2911
________________
________________
ecnedifnocfollufsisoM |
xcss |
#2912
![]() Born to Be Epic Group: Members Posts: 1.669 Joined: 24 August 07 ![]() |
- Mit der Dummheit kämpfen Götter selbst vergebens.
SSilent |
#2913
![]() Membru Vitezoman Group: Members Posts: 1.235 Joined: 23 July 07 From: ...I'm everywhere... nowhere ![]() |
bai nene, daca nu stii engleza de ce dracu o "folosesti"?
1210
1986
- N/A dacie dezmembrata... in curs de RK ^_^
cu planuri de viitor (adica vise): -Yamaha Fazer 600 cm3 -Ford Escord 2000RS -Mercedes Benz W201 |
radian |
#2914
I shall waiting for you - se vrea o invitatie, o promisiune
I will waiting for you - suna a avertisment, amenintare Mai bine scria: I'll waiting for you, si atunci impaca si capra si varza... ![]() |
dacia logan
ambition
- HD 06 LDM
#2915
ai intrebat-o pe madam radian?
radian |
#2916
dacia logan
ambition
- HD 06 LDM
psychoo |
#2917
![]() Membru Group: Members Posts: 3.721 Joined: 23 August 07 From: Timisoara ![]() |
QUOTE(radian @ 21 Nov 2008, 07:47) I shall waiting for you - se vrea o invitatie, o promisiune I will waiting for you - suna a avertisment, amenintare Mai bine scria: I'll waiting for you, si atunci impaca si capra si varza... ![]() i will BE waiting for you sau i shall WAIT for you sau i will (i`ll) wait...nu se poate i will waiting. o zi buna ![]() |
Focus
radian |
#2918
Corect!
dacia logan
ambition
- HD 06 LDM
#2919
![]() fan Dacia Group: Members Posts: 21.604 Joined: 12 November 05 From: Bucuresti ![]() |
Oricum, ai postat in topicul corect.
- negru pe alb
vis-a-vis |
#2920
Logan MCV
Marty |
#2921
Bai engleji-lor, da' daca-i "I am waiting for you", e corect?
Gillette
De unica folosinta
2011
Ov |
#2922
extrem
nh1980ro |
#2923
Pai si unde e will?
Kona/Renault
Lana'i/Clio 3
2007/2009
ady77 |
#2924
________________
________________
variable_dynamics |
#2925
![]() Membru autentic Group: Members Posts: 976 Joined: 24 May 07 From: Bucuresti ![]() |
QUOTE bobina se ferifica cu un aparat de masura , pentru a verifica prima infasurrare secundata a primei bobine se pune aparatul de 20 khilohmi si se pune bornele intre fisa 1 si 4 valoarea trebuie sa fie indicata de aparat pe la 7,4 khilohmi la fel se verifica si bobina sencundara nr.2 intre bornele 2 si 3 adica fisele care se duc la cilindru 2 si 3. Primarul bobinei nr 1 se fericica intre pinul al 3 numerotat de sus in jos si primul pin de la mufa valoarea care o afiseaza aparatul de masura e de 0.5ohmi . Pentru a verifica infasurarea a doua primara se cupleaza intre pinul 3 si prinul 2 ar valoarea e tot de 0.5 ohmi daca nu indica bobina e defecta. Intre pinul 1 si pinul 2 aparatul indica 1 ohm fiindca se aduna infasurarile doarece amble infasurari sunt legate la pinul 3 de la mufa bobinei. Recunoasteti cine djasu82 este personajul..... |
EX Dacia
Nova GTi
AR-18-MOS |
#2926
Eram sigur!
BMW
730Ld
'07 High Executive
variable_dynamics |
#2927
Quote:crising, 9 Oct 2008, 07:00
QUOTE Pare sa fie turnesol, la fel cum sunt protejate pragurile la exterior. Daca e asa si au curatat foarte bine zona inainte de aplicare au facut treaba buna. Nu cred ca vei mai avea probleme cu rugina in acea zona. http://www.daciaclub.ro/Dacia-recheama-in-...98216-s360.html Acela este probabil grund. Turnesol in niciun caz(turnesolul este un compus chimic folosit pentru determinarea caracterului acid ori bazic al unei solutii sau substante). TEROSON o fi vrut crising sa zica(firma care fabrica compusi destinati acoperirilor de protectie). Justificare: Cred ca era prea de dimineata(vezi ora). ![]() |
EX Dacia
Nova GTi
#2928
QUOTE(alphabluesky @ 22 Nov 2008, 23:58) QUOTE(alphabluesky @ 22 Nov 2008, 11:20) sant foarte rapide masinile pe propulsie electrica,si in plus nu ai nevoie de cutie de viteza,filtre de ulei, antigel ,radiator, si multe alte chesti ce le are o masina pe petrol Incercam sa scriem corect romaneste, dar nu ne iese. macar de scria sint..... Logane, e ori Sunt ori "sînt""dar in nici un caz cum a scris el. Ca nici asa nu e bine, dupa cum spune doamna http://ancaroman.wordpress.com/2007/12/30/...in-a-sint-sunt/, e alta problema. This post has been edited by einstein1984: 23 Nov 2008, 12:46 |
- negru pe alb
logan1.5dci |
#2929
Nu Există Informații Group: Members Posts: 881 Joined: 29 September 05 From: Dobrogea ![]() |
ainstaine, gresesti, citeste Hotararea Academiei Romane/ 1993.
Daca nu ar exista "sunt" , este corect sant cu caciulita de " î " asta zice hotararea aia. Sau cauta in DOOM. Din pacate" s-a f..ut butonul "(Esca, Opere Alese) si nu merge link-ul ala. " În Monitorul Oficial Nr. 59, din 22 martie 1993 sunt publicate, în anexă, Regulile "Sextil Pușcariu" pentru scrierea literelor "â" și "î". Literele â și î corespund aceluiași sunet, întrebuințându-se după urmatoarele reguli: î se scrie întotdeauna la începutul și la sfârșitul nemijlocit al cuvântului: îl îmbrățișez, împărat, înger, își, îți, amărî, coborî, hotărî, târî, urî ... ; tot cu î scriem și în corpul cuvintelor, când, prin compunere, î de la mijlocul cuvintelor ajunge medial: neîmpăcat, neîndurat, neînsemnat, preaînălțat, preaîntâmpinat. Vom scrie într-însul, dar dânsul; în toate celelalte cazuri se scrie, în corpul cuvintelor, â: bând, când, făcând, gât, mormânt, râu, român, sfânt, vânt ... " si el acolo a scris sant adica ... sânt .... asta zic eu ......daca nu se revenea la "sunt" s-ar fi scris sânt ; acum intelegi ainstain ? This post has been edited by logan1.5dci: 23 Nov 2008, 22:19 |
- Nu Există Informații
tester |
#2930
![]() dacia tester ;) Group: Members Posts: 747 Joined: 22 August 07 From: iasi ![]() |
QUOTE(AR-18-MOS @ 7 Oct 2008, 20:01) Se pot regla la orice service care are un luxmetru. Si daca nici asa nu e bine, incearca sa schimbi becurile cu ceva mai calitativ. LUXMETRU: http://tbn0.google.com/images?q=tbn:IpZVP2...0.jpg.small.jpg aparat de reglat faruri CU LUXMETRU: http://tbn0.google.com/images?q=tbn:xFCt9l...loads/1684A.bmp PS: incearca sa te abtii de la atatea prostii macar in post! |
- is xx xxx
AR-18-MOS |
#2931
Si daca era regloscop?
BMW
730Ld
'07 High Executive
#2932
Logane, daca nu se scria sunt, nu se scria nici cu â ci cu î. Parerea mea!. Dar varianta lui , adica "sânt " nu e in dictionar ca forma a lui a fi ci.....
SÂNT, -Ă, sânți, -te, adj., s.m. și f. (Pop.) Sfânt. – Lat. sanctus. Deci cu totul altceva. Norma citata de tine zice a pentru a fi aveam "sunt". Nu sunt habotnic, la fel de corect mi se pare si sînt insa ce a facut el e un furculicion. This post has been edited by einstein1984: 24 Nov 2008, 08:31 |
- negru pe alb
liviu2004 |
#2933
Aia nu e BULA.
Tigra Twintop
#2934
QUOTE(Victoras2001 @ 24 Nov 2008, 09:54) Infantil!!! La asa replica, asa raspuns. Eu daca-mi pierd portofelul si-l gaseste Dorel isi poate permite sa cumpere toata scara de bloc in care stai, cu tot cu locatari. Pentru asa un geniu ca tine am sa dezvalui un secret. E adevarat ca io-s rupt in cur rau de tot, dar sa nu scapi din vedere faptul ca mai exista si oameni pentru care o masina reprezinta doar un mijloc de deplasare, nu o carte de vizita, nu un STATUT sau o clasificare sociala. gigi bekali, unde erai tu tata! Si de ce ti-ai luat Logan si nu maibach???? naspa sa fii din caracal! Liviu, e bula pentru ca cineva vrea sa scrie corect, dar nu prea reuseste. This post has been edited by einstein1984: 24 Nov 2008, 16:18 |
- negru pe alb
logan1.5dci |
#2935
Victoras2001 |
#2936
QUOTE(einstein1984 @ 24 Nov 2008, 11:45) gigi bekali, unde erai tu tata! Si de fe ti-ai luat Logan si nu maibach???? naspa sa fii din caracal! Liviu, e bula pentru ca cineva vrea sa scrie corect, dar nu prea reuseste. Puiut, presupunand ca stai in blocul de pe Valea Cascadelor, care-i bula? Si cu Liviu care era problema? Esti atat de subtil incat ai inceput sa-ti explici poantele in p.s.? Sa-ti mai amintesc ca dupa ce faci o gafa si esti prins la mijloc, daca cel care-ti atrage atentia n-are prezenta de spirit sa dea quote la mesajul tau, iti modifici instantaneu mesajul, schimbandu-i complet intelesul? Deh... Acum iti formezi personalitatea. This post has been edited by Victoras2001: 24 Nov 2008, 14:33 |
ZAZ
Zaporojeț
logan1.5dci |
#2937
QUOTE(einstein1984 @ 24 Nov 2008, 09:57) QUOTE(argon @ 24 Nov 2008, 13:52) Uite daca nu erai tu sa ma luminezi nu as fi aflat niciodata, atotplinule de invatatura, chiar tu sa nu stii ca sunt destule 'pistoale' reglabile la cuplu?! ![]() ![]() This post has been edited by logan1.5dci: 24 Nov 2008, 14:27 |
AR-18-MOS |
#2938
Da' de ce nu va luati la bataie ... ?
BMW
730Ld
'07 High Executive
Victoras2001 |
#2939
Depinde pe cine intrebi.
Daca ma intrebi pe mine, nu apreciez in mod deosebit metoda, desi da rezultate bune. ![]() |
ZAZ
Zaporojeț
#2940
QUOTE(mariusxr3 @ 11 Nov 2008, 23:56) salut. hai sa . spun ceva la toti despre ford escort rs 2000, eu am una si sunt foarte multumit de ea am facut cu ea cel putin 20 de mii de km si nici o problema cu ea doar doua bucse de la trapez care ma costat 30 ron este o masina destul de rara avand in vedere faptul ca o fost o serie limitata si sunt mai scumpe fata de eu escort normal motorul este ok si sunt foarte rezistente a mea are 178000 de km si motorul nu are nici un pic de ulei nici nu consuma ulei consumul de carburant este ok afara undeva intre 7/8 litri si in oras undeva pe la 10 litri apropo de caroserie este facuta mult mai rezistenta la rugina fiind o tabla tratata sunt electrician auto si in legatura cu instalatia electrica nu prea sunt probleme dar in schimb la golf sunt destule si la caroserie apar probleme unde lucrez este si tinichigerie si am vazut multe golfu-ri ruginite in diverse locuri. ford escort rs este o masina rara si nu oricine o sa aiba asa masina hotarea este a ta.salut si toate cele bune Daca nu are ulei, ce sa consume? Caracalene (sau cum se numesc locuitorii orasului caracal), tu nu stii unde stau eu, asa ca nu mai vorbi. Oricum, domnu bekali2, mare minune sa umbli matale cu 1-2 meleoane de euro in numerar in portofel, ca te-ar durea fundul ingrozitor. Ce nu stie argon e ca un service Renault nu e garaj de F1 ca sa aiba pistol etalonat la 105 Nm (ca au ele niste trepte e altceva). Sau ca pistoalele alea se folosesc prin fabrica si costa cat salariul lui pe 3 luni. QUOTE(logan1.5dci @ 24 Nov 2008, 15:01) Scuze, oricat m-as abtine, chiar n-am vrut, dar e la fileu. ![]() Tot forumul e plin de bulele unuia, care vrea sa gandeasca corect ....dar nu prea ii reuseste. ![]() Macar unii incearca! Dar e frumos ca recunosti This post has been edited by einstein1984: 24 Nov 2008, 16:28 |
- negru pe alb
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 15th July 2025 - 13:28 |
