Fuel reserve, How many fuel reserve has tank?
kodalo |
Membru incepator Group: Members Posts: 20 Joined: 11 April 05 ![]() |
Dacia logan
Ambiance 1.4 MPI
- NN XXX BBBB
mccoy |
![]() Membru autentic Group: Members Posts: 273 Joined: 2 January 05 From: small town in Vojvodina ![]() |
Enough to reach gas station ...`cause they are on every corner.
I guess 4-5 L. |
Laureate 1.6
- ...98-7. -----------------------------
Divide et impera ... and unite in EU ! ----------------------------- |
KNIGHT_C |
![]() Membru Group: Members Posts: 117 Joined: 4 January 05 From: Bucuresti ![]() |
From the moment when the lamp is on, you have for sure enough fuel to go around 30 - 35 km.
Nobody knows for sure how many fuel is in the tank, you can check the hide menu which can gives you an ideea but even this one is not 100 % exactly. |
LOGAN Ambition
- B 40 ZZZ Nu judecati oamenii dupa hotararile si faptele lor inainte de a intelege conjuctura in care le-au luat respectiv facut.
mccoy |
I think but I am not quite sure that standard is 80 km
from the moment when the lamp is on for every car ![]() This post has been edited by mccoy: 17 Jun 2005, 16:06 |
Laureate 1.6
KNIGHT_C |
It's hard to talk about a standard because everything depends of comsuption. If you are on highway, you could go 80 km with 5 litres, but in a town the distance is less (in the best case 60 km, in a big city maybe less than 50 km), that's why I said around 30-35 km because in this way you couldn't remain without fuel in any case.
LOGAN Ambition
Czar |
![]() Membru incepator Group: Members Posts: 11 Joined: 9 December 04 From: Skopje ![]() |
I agree ... And I have performed some tests.
It is all about consumption! With average of 6.6 l/100km the lamp lights on 80 km to gas station. With average of 9.2 l/100km the lamp lights on 50 km to gas station. My guess is that there are between 4.5 and 4.8 liters when the light goes on! |
1.6 Laureate
- -862-OK
sir_zven |
![]() Membru incepator Group: Members Posts: 15 Joined: 30 July 05 ![]() |
Logan Laureate 1.4
- B-13-AMD "You see, wire telegraph is a kind of a very, very long cat. You pull his tail in New York and his head is meowing in Los Angeles.
Do you understand this? And radio operates exactly the same way: you send signals here, they receive them there. The only difference is that there is no cat." - Albert Einstein |
novauto |
Membru incepator Group: Members Posts: 38 Joined: 13 July 05 From: Serbia ![]() |
One strange behavior:
Fuel indicator is discrete, not analog. Every bar appears according to resistance and there is table for it ![]() |
Boris |
![]() Croatian member Group: Members Posts: 497 Joined: 20 October 04 From: Zagreb, Croatia ![]() |
QUOTE(novauto @ 28 Oct 2005, 08:20) One strange behavior: Fuel indicator is discrete, not analog. Every bar appears according to resistance and there is table for it ![]() It's just an indikator, like you say, it's not a measurement instrument. The purpose of it is for you to have a good guess of how many fuel you have left. |
Logan Laureate 1.6
2005 + LPG Landi Renzo sequent Reliability of machines is inversely proportional to the number and importance of people watching it
novauto |
mccoy |
Do not torture gas station personnel by pouring 7 l
Laureate 1.6
mccoy |
QUOTE(KNIGHT_C @ 17 Jun 2005, 15:17) It's hard to talk about a standard because everything depends of comsuption. If you are on highway, you could go 80 km with 5 litres, but in a town the distance is less (in the best case 60 km, in a big city maybe less than 50 km), that's why I said around 30-35 km because in this way you couldn't remain without fuel in any case. 80 km ![]() ![]() |
Laureate 1.6
novauto |
mccoy |
Average consumption from book , manufacturers data for mixed drive,
not from board computer. |
Laureate 1.6
novauto |
bness |
![]() Membru incepator Group: Members Posts: 41 Joined: 10 October 05 ![]() |
QUOTE(novauto @ 31 Oct 2005, 10:36) I didn't try to calculate consumption using board computer (since I haven't it ![]() Instead, I have measured consumption between two periods when fuel reserve lights on. The best way to calculate fuel consumption is to fill your tank to maximum (to see fuel in tank opening) then drive few hundred km and fill tank same as you fill first time. Then caluclate. It is good if you can do this same way few times and then sum all fuel and km and then calculate. |
Laureat Pack 1.5dci
- 686 96
costi |
you cannot do this with Logan
according to the RO side discussions, you can pour-in up to 60 l of gas instead of the 50 l recommended by the manufacturer; filling up like this can make the engine run erratically in some cases; so do not exceed to much the recommended tank capacity |
DSN/SLZ
bness |
QUOTE(costi @ 31 Oct 2005, 15:13) you cannot do this with Logan according to the RO side discussions, you can pour-in up to 60 l of gas instead of the 50 l recommended by the manufacturer; filling up like this can make the engine run erratically in some cases; so do not exceed to much the recommended tank capacity You are probably right. I did't know that abouth Logan tank. I was speeking generaly. But, for me is a bit confusing that you ken puor up to 10 l og gasoline more in the tank of 50 l capasity. Is that meen that the thank is 60 l but it is recomendet tu use only 50 l, or somthink other. Please translate romanian part of discussions. Thanks. |
Laureat Pack 1.5dci
- 686 96
costi |
There was no clear cut conclusion about the issue.
The tank is either too "elastic" or the dilatation space is too large. The general opinion was that manufacturer's recommendations should be observed. One Logan owner complained about irregular engine functioning following such an over filled tank. Nothing wrong happens with 4-5 extra liters but filling it up to the last inch does not seem a good idea. |
DSN/SLZ
novauto |
QUOTE(bness @ 31 Oct 2005, 15:08) The best way to calculate fuel consumption is to fill your tank to maximum (to see fuel in tank opening) then drive few hundred km and fill tank same as you fill first time. Then caluclate. It is good if you can do this same way few times and then sum all fuel and km and then calculate. Yes, I have tried that way, but questions is when fill up again? I thought reserve lamp is good candidate, but it looks like not ... |
avathan |
eu. Group: Banned Posts: 586 Joined: 16 March 05 From: Buc ![]() |
QUOTE(mccoy @ 17 Jun 2005, 17:01) I think but I am not quite sure that standard is 80 km from the moment when the lamp is on for every car ![]() the standard I knew of it's 50 km ... ONCE I made ~42 km in town after the lamp light up ... some OTHER time I made 30 outside ... This post has been edited by avathan: 31 Oct 2005, 17:19 |
a
Rosu
1800
- @ unu,doi,trei,patru,cinci ... zero
loganek from CZECH REPUBLIK |
![]() Membru incepator Group: Members Posts: 21 Joined: 1 November 05 ![]() |
LOGAN 1,4
- 2M2 ....
voicamic |
![]() Membru Group: Members Posts: 178 Joined: 28 December 04 From: Bucuresti ![]() |
I should say that counting on the fuel reserve more than 20-25 km is not a good idea.
Consuming almost the last drop of fuel in the tank leads to the aspiration of the residues settled on the tank bottom into the fuel injection system of the engine. Once the injectors plugged, the next trip is obviously to car service. Better not! Of course I speak as a Romanian driver, using Romanian fuel, which is not always so clean. Maybe you guys abroad have "cristal clear" fuel out there! |
Dacia Logan MCV
Laureate 1.5 dCI 68 CP
- B-**-*** Fugi D'acia!
Boris |
Logan Laureate 1.6
Touho |
![]() Membru incepator Group: Members Posts: 26 Joined: 29 December 05 From: Sant Martí Sarroca (CATALONIA) ![]() |
Hi all!
Last week I went to Andorra with my Logan 1.4 MPI and like everybody does, I filled the fuel tank to the top. I drove about 10 km with the fuel reserve light on and then I filled the tank with 58 litres more. I have driven in all kind of situations since then (city, motorways...) and I have driven 700 km and still I have 3 lines left in the fuel level indicator. The car is running great and I have driven 7000 km since I bought it. If I can get to 900 km till de reserve fuel light turns on, I will be very happy. See you! |
LOGAN BASIC
- 1.4 75 cv
Boris |
Logan Laureate 1.6
sorin_f39 |
![]() Ferrari fan Group: Members Posts: 2.431 Joined: 22 August 05 From: Galați ![]() |
Officially, the tank has a capacity of 50 litre. But, in fact, there is a reserve, about 10 litre, so the real capacity of the tank is about 58 - 60 litre.
Megane 2.2 Bicorp
Dynamique 1.6 16V (2007)
- GL I'm the freedom man / That's how lucky I am.
martin245 |
![]() EX PAT Group: Members Posts: 913 Joined: 1 April 06 From: Karlsbad Germany (again) ![]() |
Could these be Rumanian litres
Stu |
logan 14 mpi Simply RED
- GB 1 Bessy Regs
sorin_f39 |
Yes, Martin, I'm talking about Romanian litres. What kind of liquid measure are you use?
Megane 2.2 Bicorp
zorpetus |
Membru Group: Members Posts: 120 Joined: 17 April 06 ![]() |
QUOTE(costi @ 31 Oct 2005, 15:13) you cannot do this with Logan according to the RO side discussions, you can pour-in up to 60 l of gas instead of the 50 l recommended by the manufacturer; filling up like this can make the engine run erratically in some cases; so do not exceed to much the recommended tank capacity Could you please describe what kind of "erratic" running? Just running or even problems starting the engine? |
None
None
- None
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 26th July 2025 - 04:49 |
