Fuel reserve, How many fuel reserve has tank?
martin245 |
![]() EX PAT Group: Members Posts: 913 Joined: 1 April 06 From: Karlsbad Germany (again) ![]() |
logan 14 mpi Simply RED
- GB 1 Bessy Regs
voicamic |
![]() Membru Group: Members Posts: 178 Joined: 28 December 04 From: Bucuresti ![]() |
QUOTE(martin245 @ 26 Apr 2006, 21:03) The "Romanian litre" as you call it is in fact the metric litre, meaning 1 litre = 1 cubic decimeter. Maybe Touho was tricked by the fuel pump by 1-2 litres, but I succeeded filling some 56 litre in my tank in a similar situation. |
Dacia Logan MCV
Laureate 1.5 dCI 68 CP
- B-**-*** Fugi D'acia!
sorin_f39 |
![]() Ferrari fan Group: Members Posts: 2.431 Joined: 22 August 05 From: Galați ![]() |
The tank is big, the consumption is ok, so, all you have to do is to get some money, fill the tank, and ... go on the road!
Megane 2.2 Bicorp
Dynamique 1.6 16V (2007)
- GL I'm the freedom man / That's how lucky I am.
Touho |
![]() Membru incepator Group: Members Posts: 26 Joined: 29 December 05 From: Sant Martí Sarroca (CATALONIA) ![]() |
Hi all,
I filled the tank with 58 litres or that is what I payed... But what I know for sure is that I have driven more tha 950km and still I have some fuel left (the last line in the level indicator is still on). And when I filled the tank so much, it took about 300 km to start moving the level indicator. So I do not think I was cheated. Of course, I think oil stations are allowed to calibrated the pumps with about 2% of "mistake", but I can tell you that comparing the number of liters and the km I have done I do not think I was really cheated by the oil station. Next time I will go to any oil station and I will fill the tank to the maximum again and I will be able to see if in a Spanish oil station I can fill the tank with so many litres too... So I will be able to compare it with Andorra's. See you! |
LOGAN BASIC
- 1.4 75 cv
sorin_f39 |
QUOTE(Touho @ 28 Apr 2006, 09:11) Hi all, I filled the tank with 58 litres or that is what I payed... But what I know for sure is that I have driven more tha 950km and still I have some fuel left (the last line in the level indicator is still on). And when I filled the tank so much, it took about 300 km to start moving the level indicator. So I do not think I was cheated. Of course, I think oil stations are allowed to calibrated the pumps with about 2% of "mistake", but I can tell you that comparing the number of liters and the km I have done I do not think I was really cheated by the oil station. Next time I will go to any oil station and I will fill the tank to the maximum again and I will be able to see if in a Spanish oil station I can fill the tank with so many litres too... So I will be able to compare it with Andorra's. See you! In these conditions (the tank full and more than 950 km running), you pulled out an average consumption about 6.1 litre / 100 km, which is very good! The official average consumption, given by Dacia, is 5.7 litre / 100 km. But, let me ask you something. What was the maximum, respectively the average speed you drove with? |
Megane 2.2 Bicorp
Smeagol |
![]() Membru ... Group: Members Posts: 238 Joined: 18 November 05 From: Timisoara ![]() |
QUOTE(zorpetus @ 27 Apr 2006, 22:35) Could you please describe what kind of "erratic" running? Just running or even problems starting the engine? You can damage the filter used to capture the gasoline vapors. You need to have some room in your tank so that the differences of pressure and the vaporization effect take place. On the Romanian section there is a long explanation about the gasoline vapors recirculation system in place and how you can damage the carbon filter. It is guaranteed for around 60 thousand kilometers, but it can be damaged much sooner if you keep your gasoline tank filled in excess all the time. |
Logan Ambition
2006, 1.6 MPI
- TM 10 ??? "Ai grija ce-ti doresti. S-ar putea sa capeti."
Touho |
Hi all,
I did it again... but I wont anymore after reading that filling the tank can be dangerous. I went to a Spanish oil station and I filled the tank with 58 litres, like I did in Andorra right after the level indicator turned the reserve fuel light on. So they were the same circumstances like in Andorra. So what I can see is that right away after the reserve fuel indicator turns on, the tank can be filled with 58 litres of fuel or even more, so its capacity is much bigger than what it is said in the book. About my average speed to get that 1000 km with 58 litres I have to confess that I am almost never driving over 110 and the area where I live is quite flat. And I always try to use long gears and try to drive softly. My last car was a Renault 19 1.9 diesel and I am driving it the same way. And as I have discovered, my Dacia Logan 1.4 is consuming almost like my old Renault 19 diesel, I feel very happy with my new Logan. See you! |
LOGAN BASIC
- 1.4 75 cv
Kiril |
Membru incepator Group: Members Posts: 3 Joined: 1 May 06 ![]() |
for most of the cars is around to pass 80km or 5 litters...
Yugo
Tempo 1.1
clan |
![]() Membru incepator Group: Members Posts: 97 Joined: 10 June 05 From: Bucuresti ![]() |
Last year I drove around 90km since the light was on. I drove with such a fear... with constant speed and easy acceleration... Do not try this!
Logan Laureate 1,4
- B-00-000
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 25th July 2025 - 13:17 |
