33 Pages « < 6 7 8 9 10 > »
> [VAND] Piese Noi LOGAN si RENO, suntem un magazin nou, avem preturi mici
RadulescuRomulus
post 29 Dec 2011, 10:45
Post #211
Sunt cu ochii pe voi!
CASTROL MAGNATEC DIESEL 5W40 4L- 120 RON
CASTROL MAGNATEC DIESEL 10W40 4L - 100 RON
CASTROL EDGE 5W30 1L 45 RON
CASTROL EDGE 5W30 5L 200 RON
CASTROL EDGE 5W40 TURBO DIESEL 1L 35 RON
CASTROL EDGE 5W40 TURBO DIESEL 5L 140 RON
CASTROL EDGE TURBO DIESEL 5W40 4L 125 RON
CASTROL MAGNATEC DIESEL 5W40 B4 1L 30 RON
CASTROL MAGNATEC DIESEL 5W40 B4 5L 130 RON
CASTROL MAGNATEC DIESEL B4 - 10W40 - 1L 30 RON
CASTROL MAGNATEC DIESEL B4 - 10W40 - 5L 105 RON
Ulei VAT, facut in Polonia:
Vat SynGold 5W-40 1L 25 RON
Vat SynGold 5W-40 4L 92 RON
LOGAN ------------------piese marca Starline, garantie 3 ani!
Descriere ------------------------------------- Pret vanzare
Elemente de directie---------------------------- 31.04
Cap Bara Dreapta-------------------------------- 41.96
Cap Bara Stanga---------------------------------- 41.98
Bieleta directie----------------------------------- 44.05
Bieleta directie----------------------------------- 44.65
Amortizoare spate------------------------------- 154.01
Amortizoare fata--------------------------------- 138.23
Pivot------------------------------------------------ 33.83
Kit-uri rulmenti roata fata fara ABS----------- 38.08
Kit-uri rulmenti roata spate--------------------- 32.25
Bascula dreapta---------------------------------- 106.18
Bascula stanga------------------------------------ 106.18
Bucsa bascula------------------------------------- 14.11
Bieleta antiruliu---------------------------------- 13.46
Discurii frana 260 ventilat--------------------- 147.63 / set 2 buc
Discurii frana 238 plin-------------------------- 95.19 / set 2 buc
Saboti frana fara ABS--------------------------- 66.64
Saboti frana cu ABS----------------------------- 108.46
Filtru ulei------------------------------------------- 15.74
Filtre aer DCI-------------------------------------- 16.39
Filtre habitaclu----------------------------------- 19.24
SAU orice alta marca doriti.
Toate reperele de mai sus sunt marca Starline. Avem la vanzare si alte marci, mai cunoscute pe piata, pt care oferim pret la solicitare expresa. Mai mult, garantia este de 3 ani la reperele Starline!
REPERE UNIVERSALE:
antigel G12 13,19 RON
antigel G12 38,93 RON
lichid spalat parbriz -20 grade 5,40 RON
lichid spalat parbriz -20 grade 15,35 RON
acumulator 44 amperi 196,83 RON
acumulator 54 amperi 232,82 RON
acumulator 66 amperi 275,16 RON
acumulator 74 amperi 305,03 RON
acumulator 97 amperi 393,86 RON
Bec Megalight Ultra H7 - 55w 38,03 RON
Bec incandescent H7 GE 13,57 RON
LICHID FRANA TEXTAR, dot 4, 1L :
~ cine a mai cumparat articole de la mine, pretul de achizitie pt lichid frana TEXTAR ramane 37.50 RON.
Pretul intreg este de 41 ron / 1L.
VW Passat berlina 2.0 Tdi CR + DSG 04.2009 - diesel, 140cp - B 69 COI
EX: megane 2.1, 1.5dci, 101 magari - B 314 ZDA
RadulescuRomulus
post 30 Dec 2011, 10:58
Post #212
RadulescuRomulus
post 31 Dec 2011, 12:44
Post #213
Sarbatori Fericite si cele bune in 2012!
RadulescuRomulus
post 2 Jan 2012, 10:13
Post #214
La Multi Ani cu impliniri tuturor posesorilor de renou!
Incepem anul 2012 cu o promotie:
- in primele 2 saptamani ale anului 2012, lichidul de frana Textar 1L, DOT 4 = 32 ron!
- filtru benzina, BOSCH = 30 ron
Diametru [mm] 62.00
Înaltime [mm] 143.00
Preparare combustibil: injectie benzina
Diametru admisie [mm] 8
Diametru evacuare [mm] 8
Se potriveste la:
Marca--------------------------KW CP cod motor
DACIA SOLENZA 1.4 cu 55 / 75
DACIA SUPERNOVA 1.4 cu 55 / 75
RENAULT LOGAN 1.4 cu 55 / 75 / K7J 710
RENAULT LOGAN 1.6 cu 64 / 87 / K7M 710
RENAULT LOGAN 1.6 cu 77 / 105 / K4M 690
PEUGEOT PARTNER Tepee 1.6 cu 72 / 98
PEUGEOT PARTNER Tepee 1.6 cu 88 / 120 / 5FS (EP6C)
PEUGEOT PARTNER Tepee 1.6 cu 66/ 90/ NFR (TU5JP4B)
PEUGEOT PARTNER Tepee 1.6 cu 80 / 109 / NFU (TU5JP4)
PEUGEOT 206 si 206+
PEUGEOT 207 CC cu motor 1.6 16V turbo
PEUGEOT 207 SW cu motor 1.6 16V sau 1.4 16V sau 1.6 16V RC
PEUGEOT 307 CC, 307 SW
PEUGEOT 308 CC, 308 SW
CITROËN:
saxo
xsara
C3
C4
C5, inclusiv motorul de 2.0 16VBioFlex
Berlingo
This post has been edited by RadulescuRomulus: 2 Jan 2012, 11:21
RadulescuRomulus
post 3 Jan 2012, 18:05
Post #215
Valabil!
RadulescuRomulus
post 4 Jan 2012, 23:01
Post #216
valabil!
Steel Tormentor
post 5 Jan 2012, 14:42
Post #217
Un pret pentru servofrana pentru masina din semnatura?
Dacia Logan 2007 Preference 1.4MPI
emilian69
post 5 Jan 2012, 17:49
Post #218
Salut un pret te rog pentru doua capete de bara si doi pivoti pentru o Laguna II 120 cp,88 kw fabricatie 2001.Ms.
Renault Laguna II 2001 Dynamique - TR-04-
Cine nu este cu noi este impotriva noastra
RadulescuRomulus
post 5 Jan 2012, 19:53
Post #219
@Steel Tormentor: ai pm
@emilian69: in curand vei avea PM smile.gif
red.bogdan
post 5 Jan 2012, 21:48
Post #220
pentru un megane din 99 classic 1.6 16v
bieleta directie si bascula cu pivot si bucse pe partea stanga aveti si la ce pret?
renault megane 1999 1 - M 6402 XT
lostone
post 5 Jan 2012, 23:10
Post #221
Maneta bloc lumini cu proiectoarea pt un logan 2004 laureate?
logan laureat 2004
RadulescuRomulus
post 5 Jan 2012, 23:17
Post #222
@emilian69 - ai PM
@red.bogdan - ai si tu PM
@lostone: imi pare rau, nu.
neiu
post 5 Jan 2012, 23:29
Post #223
discuri frana fata renault laguna 1998 1.8 16v 88kw?
ms
renault laguna 1.8i 1998 berlina - TM 11 RFT
Florin
RadulescuRomulus
post 6 Jan 2012, 10:50
Post #224
@neiu - ai PM
ciumiki
post 8 Jan 2012, 11:27
Post #225
sunt interesat de regulator presiune pompa injectie pt masina din semnatura.
Renault Megane 2007, 1.5 dci
megane 2.2, 1.5 dci, 63 kw, an 2007
beberazvan_n
post 8 Jan 2012, 22:45
Post #226
Salut Romulus, mai imi poti da odata preturile pentru cablu frana de mana. Vreau sa le schimb pe ambele pana la urma. Ne auzim, mersi.
Renault Megane 2, 1.5 dci... 2003 - IF-03-VZL
gabyu
post 8 Jan 2012, 23:45
Post #227
cablaj pentru oglinzi electrice logan ph1 aveti?
Dacia Solenza 2004 Scala
radian
post 9 Jan 2012, 08:45
Post #228
Ai cumva butuc pentru portbagaj?
RadulescuRomulus
post 9 Jan 2012, 13:14
Post #229
@radian: am nevoie de VIN-ul masinii
@gabyu + @beberazvan_n + @ciumiki = aveti PM
konektor
post 9 Jan 2012, 17:53
Post #230
Capat bara si bascula , ambele pentru partea stanga, megane 2.2 1,5dci 80cp 2006
Multumesc
Renault Megane 2.2 2006 dCI 1.5 80hp
emilian69
post 9 Jan 2012, 19:37
Post #231
In ce zona este magazinul ca Miercuri am drum prin Buc. si poate trec si pe la voi.
RadulescuRomulus
post 9 Jan 2012, 22:26
Post #232
NOI SORTIMENTE DE ULEI MOTOR, in oferta noastra.
gama de ulei XT:
XToil Hypersynt 5W-40 1L = 16.90 ron
Ulei sintetic, Sae 5w-40 A3/B3/C3, WV 502.00/505.00, MB 229.1/229.3
XToil Hypersynt 5W-40 5L = 77.50 ron
XToil Synplus 10w-40 1L = 15.50 ron - 5L = 80 ron
Ulei semisintetic, Sae 10w-40 A3/B4-04, VW 500.00/505.00, MB 229.1
LA CASTROL, avem reconfigurare oferta, cu preturi MINIME:
CAS EDGE 0W-40/1 = 55 ron
CAS EDGE 0W-40/4 = 210 ron
EDGE 5W30 -1L = 44.50 ron
EDGE 5W30 -5L = 199 ron
EDGE TURBO DIESEL 5W40 -1L = 35 ron
EDGE TURBO DIESEL 5W40 - 5L = 141.50 ron
MAGNATEC C3 - 5W40 - 1L = 30.50 ron
MAGNATEC C3 - 5W40 - 5L = 120 ron
MAGNATEC DIESEL B4 - 5W40 - 1L = 29.50 ron
MAGNATEC DIESEL B4 - 5W40 - 4L = 114.50 ron
MAGNATEC A3/B4 - 10W40 - 1L = 27.50 ron
MAGNATEC A3/B4 - 10W40 - 5L = 110 ron
LICHID FRANA TEXTAR, dot 4, 1L: 37.50 ron
filtru benzina, BOSCH = 30 ron, compatibilitati in postul nr. 214.
@emilian69: ai PM
@konektor: nu stiu de ce, e blocat sistemul. marti revin pe PM cu o oferta.
Indiferent de valoarea comenzii, transport gratuit pentru Bucuresti. In tara trimit cu Posta Romana, in 16 ron si 25 ron, transportul cu plata ramburs in fct de greutatea coletului.
Multumesc,
10 Jan 2012, 09:18:
@konektor: ai PM
This post has been edited by RadulescuRomulus: 10 Jan 2012, 09:18
cosmin_angh3l
post 10 Jan 2012, 09:23
Post #233
salutare. un pret te rog pentru bobine Beru ? o zi buna
Renault Megane 2.2,2007/1.6 16V Megane 3 1.5dci 110 Dacia Logan,2017/1.5
RadulescuRomulus
post 10 Jan 2012, 09:25
Post #234
pt care din cele 2 masini din semnatura ta?
cosmin_angh3l
post 10 Jan 2012, 09:27
Post #235
pentru megane 1.6 16v...
RadulescuRomulus
post 10 Jan 2012, 10:26
Post #236
ai PM. . .
desmo
post 10 Jan 2012, 15:38
Post #237
salut. spune-mi si mie un pret pentru o bieleta anticuplu/antirasturnare, pentru masina din semnatura. Multumesc. Astept raspuns.
Renault Laguna III 2008/ 2.0 Dci-150 cp
constant si iute...
RadulescuRomulus
post 11 Jan 2012, 09:25
Post #238
@desmo: ai PM
BIBANU78
post 11 Jan 2012, 10:53
Post #239
Un pret pentru amortizoare fata logan DCI fabricatie 2005 ai cumva??
LOGAN preference 1.5 DCI - GJ-XX-XX
Eu
RadulescuRomulus
post 11 Jan 2012, 11:25
Post #240
@bibanu78: ai PM.
Multumesc.
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 23rd July 2025 - 12:56
