5 Pages « < 3 4 5
> Scaner OBD pe bluetooth, pt android, Wince etc
post 29 Mar 2012, 13:44
Post #121
Torque Pro (OBD2 & Car) v1.5.50
mirror
This post has been edited by IRONICK: 29 Mar 2012, 13:44
Squirrel
post 25 Apr 2012, 07:31
Post #122
Captain of Black Pearl™…
Torque Pro (OBD2 & Car) v1.5.58
What's in this version:
  1. Tip: Turn on 'Faster Communication' in the OBD settings for faster read speeds!
  2. Facebook integration - dials can now be posted to your status
  3. Profile editor now supports user units.
  4. Equation parser now supports signed values - eg: '(signed(A)*255)+B'
  5. Translation updates
  6. If your phone goes slow when Torque quits then you have bugged bluetooth drivers - enable the 'Hang fix for HTC/Samsung' in the settings (set it to 'Yes') to work around the issue
Dacia Duster - RO 44 AWD 2010 1,6 16v 4×4 Laureaté Noir Nacré
Fire, walk with me...in 4 strokes, water cooled.
Empirey
post 15 May 2012, 11:21
Post #123
Salut. Sunt nou in asa ceva, unde gasesc la logan mufa in care sa bag acest scanner ?
Logan 1.4 mpi 2005
post 15 May 2012, 11:23
Post #124
Torque Pro (OBD2 & Car) v1.5.60
Half-dial display bugfix
Wi-Fi Sync of data to PC (PC software on wiki)
Updates to Alarms, Fuel type (CNG), GPS
Prius PID support for plugins
Some mode6 updates (beta)
Barometer support
Histories for 0-60, 1/4 mile
Download
Mirror
This post has been edited by IRONICK: 15 May 2012, 11:25
DB77AAA
post 15 May 2012, 13:14
Post #125
DB77AAA
@Empirey - Mufa este in torpedou, pe peretele din spate.
This post has been edited by DB77AAA: 15 May 2012, 13:15
ex: oltcit, dacia 12 TRS, 1325 - DB77AAA, DB05PHZ 1996, 1995
zanga
post 1 Jun 2012, 09:15
Post #126
Daciot solenzar
A testat cineva OBDScope v1.60 ?
Am gasit o varianta, am semnat-o dar am probleme la instalare ("unable to install").
L.E. Am testat pe E72
This post has been edited by zanga: 1 Jun 2012, 09:16
Dacia Logan - BC ## MSU Preference - 2004
Daca Ai Cap Iese Altfel
Esti prost si vrei sa te remarci? Aprinde proiectoarele!
Esti cel mai prost? Aprinde si stopul de ceata!
Squirrel
post 1 Jun 2012, 13:35
Post #127
Oficial sunt la 1.5.64
What's New in this version:
  • Tip: Turn on 'Faster Communication' in the OBD settings for faster read speeds!
  • Setting to show popup to remind you to remove adapter
  • OBD speed correction factor added
  • Remembers last dashboard screen shown when switching apps
  • Fix dial start angle bug
  • Fix 80-100MPH bug
  • Translation updates
  • If your phone goes slow when Torque quits then you have bugged bluetooth drivers - enable the 'Hang fix for HTC/Samsung' in the settings (set it to 'Yes') to work around the issue
Torque Pro (OBD2 & Car) v1.5.64
zanga
post 2 Jun 2012, 18:27
Post #128
Daciot solenzar
QUOTE(IRONICK @ 20 Nov 2011, 18:45)
-In cazul unui gps cu WinCE6 se porneste bluetooth, hOBD si se scaneaza de acolo. Tot acolo se baga parola/pin.
In control panel la bluetooth, dupa "Scan Device" gaseste interfata?
La mine apare "bluetooth hardware error 10050 (controller not present)" pe Wayteq x960BT.
Din hobd nu gaseste nimic desi bluetooth-ul functioneaza normal in shell-ul lui.
post 7 Jun 2012, 08:53
Post #129
Din programul gps-ului o gaseste, dar nu face pairing. Nici nu trebuie. Din hOBD trebuie sa faca. Acolo este simplu, ii dai scan, o sa apara in lista, bagi pin-ul si apply. Eventual un restart, dar trebuie sa o ia si din prima.
zanga
post 7 Jun 2012, 09:25
Post #130
Daciot solenzar
http://hobdrive.userecho.com/topic/48405-w...60bt-dont-work/
Curios este ca in Screens ➧ Settings ➧ OBD Port Settings apare Bluetooth OK .
Insa nu imi apar campurile ca in user manual(PIN, BT service num).
vet
post 19 Sep 2012, 08:20
Post #131
Membrul
Dacia Logan 2007 / KissFM 1.5 dCi
eurocristi
post 18 Dec 2012, 17:19
Post #132
Imaginea de mai sus este de pe un telefon cu Android?
Daca da,este o aplicatie la liber sau cu plata? Cum se numeste?
Multumesc!
logan ambition 2005
membru proaspat dar experimentat in auto
post 18 Dec 2012, 17:28
Post #133
Despre ce crezi tu ca se vorbeste pe topicul asta pana acum?
Torque Pro (OBD2 & Car) v1.6.28
http://anonym.to/?http://ul.to/atb3lqwi
This post has been edited by IRONICK: 18 Dec 2012, 17:30
eurocristi
post 18 Dec 2012, 21:33
Post #134
Multam!
Cred ca o sa trec si eu pe Android,desi nu prea ma targe inima,si am vrut sa fiu sigur.
Apropo,Wayteq il mai folosesti pentru monitorizare?
logan ambition 2005
post 19 Dec 2012, 10:23
Post #135
Da, pe ala l-am mai folosit din cand in cand. La telefon nu am suport.
eurocristi
post 28 Dec 2012, 12:01
Post #136
Multumesc inca o data pentru pont!
Adevarul e ca e mai usor cu Android dezavantajul fiind ca trebuie sa cari caramida dupa tine biggrin.gif .asta e.
logan ambition 2005
dorismuler
post 29 Dec 2012, 10:01
Post #137
salutare!
pe logan dci din 2011 functioneaza elm327 bt + torque?
Fost Posesor L_DCI_90_2011
eurocristi
post 29 Dec 2012, 17:26
Post #138
Nu vad de ce n-ar functiona atata timp cat mufa de conectare este corespunzatoare.
logan ambition 2005
dorismuler
post 29 Dec 2012, 17:42
Post #139
se spune ca ar fi schimbat niste protocoale, de-asta intreb, daca e cineva care chiar are asa ceva pe logan dci 2011 si poate confirma functionarea ori ba.
This post has been edited by dorismuler: 29 Dec 2012, 19:13
doctorasul
post 31 Dec 2012, 07:58
Post #140
Membru imbatranit
Group: Validating DaciaClub
Functioneaza.
Dacia Dacia - ot 92
dorismuler
post 31 Dec 2012, 08:25
Post #141
Multumesc!
Asa ceva a testat cineva? http://ecx.images-amazon.com/images/I/31AA...L500_AA300_.jpg
Face acelasi lucru ca si cea putin mai mare, cu portocaliu?
This post has been edited by dorismuler: 31 Dec 2012, 08:27
doiuxxl
post 4 Feb 2013, 10:52
Post #142
Buna.
Cu Torque sau un alt program pentru platforma android se pot citi km din calculator(NU din bord) la logan ?
Sunt curios daca se poate verifica la cumparare acest lucru.
Multumesc.
Dacia Logan 2019
post 4 Feb 2013, 11:00
Post #143
nu
E mult mai bine sã mã înºel din prea multã suspiciune decît din prea multã naivitate. - Cristoiu
noo_yd
post 4 Feb 2013, 16:00
Post #144
pe nokia 5800 ce soft ar trebui sa instalez ? sau pe symbian nu merge ?
dacia logan laureate - OT-23-XXX 2007
Cu cat cauti sa placi la toata lumea, cu atat esti in primejdie sa nu fii respectat de nimeni
zanga
post 4 Feb 2013, 16:06
Post #145
Daciot solenzar
OBDScope
noo_yd
post 4 Feb 2013, 16:42
Post #146
merci mult zanga, o singura rugaminte , softul si tot ce mi-ar trebui sa pot pune in functiune ce s-a discutat aici de unde le pot lua ?
zanga
post 4 Feb 2013, 16:47
Post #147
Daciot solenzar
Da, s-a discutat deja cateva pagini in urma.
In principiu il instalezi, il imperechezi cu adaptorul BT si aia e.
kingviper
post 2 Mar 2013, 13:46
Post #148
Salut!
Ce diferenta este intre intergetele ELM si VGATE?
Se 'pupa' cu Solenza din 2005?
Cum aflu prin ce protocol se face comunicarea?
P.S.: IRONICK, ai terminat lucrarea cu display-ul in bord? Poze, filmulet ceva sa vedem si noi opera?
Dacia Solenza - B 4* *** 2005, Confort
adema1981
post 4 Mar 2013, 16:05
Post #149
Salutare. Am si eu o problema cu consumul si instant si cel mediu. La un Logan DCI 2007 imi afiseaza un consum mediu de 19-21%. LPK este de 5 km/L si asa mai departe. Toti senzorii functioneaza ( corect ) cred eu. Imi afiseaza temp apa, presiune turbina etc dar cu consumul nu ii dau de cap. Puteti sa ma ajutati si pe mine va rog wub.gif
Poate e vreo setare si nu o gasesc eu. AM testat pe o distanta de 68 km in 3 zile diferite.
This post has been edited by adema1981: 4 Mar 2013, 16:06
Renault Captur 2015
Squirrel
post 21 Mar 2013, 08:50
Post #150
ELM329 - Can read CAN … restul e can-can…
The ELM329 is our CAN-only device that provides more CAN support than is in our popular ELM327. The current firmware adds several new features that users have requested.
The ELM329:
  • Supports ISO 15765, and SAE J1939
  • Also provides five user controllable protocols
  • Supports CAN periodic (wakeup) messages
  • Has a CAN Monitor for automatically switching to low power mode
  • Provides single wire CAN transceiver controls
  • Has general purpose inputs and an output
  • Can send an arbitrary CAN message at any time
  • Has an expanded and more friendly CRA function
  • Provides an active LED
In addition, we've improved code speed significantly over the v1.0 chip, increased the size of the RS232 transmit buffer, and maintained very good software and pin compatibility with the ELM327. Download a data sheet to find out more.
ELM329P v2.0 (PDIP): $21.00        ELM329SM v2.0 (SOIC): $21.00
This post has been edited by Squirrel: 21 Mar 2013, 08:51
5 Pages « < 3 4 5
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 28th July 2025 - 12:56
