[VAND] piese si accesorii Dacia 1300, unele compatibile si cu 1310 - 1410
OCEBE |
#361
![]() Membru autentic Group: Members Posts: 1.324 Joined: 30 January 04 From: galati ![]() |
1300 Am avut o DACIA 1300
OCEBE |
#362
Se rezerva si pozitia
60 F. Yala usa (pentru model > 1310) si portbagaj (model cu "impingere") cu o cheie … 1 ans Restul ramane valabil |
OCEBE |
#363
Lista actualizata cu piese de schimb si accesorii este urmatoarea:
01 N. Alternator 12V 36A, fabricatie EP licenta Ducellier .............................................. 1 buc x 75 lei/buc; 06 N. Bec far 12V / 45W 40W (clasic) ………………………………………….…………………………………. 4 buc x 2 lei/buc; 07 F. Bec far halogen "GE" 12V / 45W 40W …………………………...…….………………………….….. 1 buc x 5 lei/buc; 08 N. Bec far halogen "Philips Premium" 12V / 60W 55W ……….…..….…………...……………… 1 buc x 8 lei/buc; 09 N. Bec far halogen "Tesla" 12V / 60W 55W ………………..……………...………………………………1 buc x 8 lei/buc; 10 N. Bec far halogen "Tungsram" 12V / 60W 55W …….…………..…….………………………………1 buc x 8 lei/buc; 11 N. Becuri rezerva (continutul setului vizibil in foto) ……….………….……………….....…………. 1 set x 10 lei/set; Toate becurile si setul de rezerva (poz 6 - 11) cu 40 lei 12 N. Bloc lumini (1310, 1410).................................................................................. 1 buc x 20 lei/buc; 13 F. Bobina inductie (carcasa metal) ........................................................................ 1 buc x 12 lei/buc; 14 N. Bobina inductie (carcasa metal) ....................................................................... 1 buc x 15 lei/buc; 15 F. Bobina inductie cu rezistenta (carcasa ebonita) ................................................. 2 buc x 12 lei/buc; 16 N. Borne gabarit mare acumulator ........................................................................ 1 set x 5 lei/set; 17 N. Borne gabarit mic acumulator .......................................................................... 1 set x 3 lei/set; 18 N. Bricheta bord completa..................................................................................... 1 buc x 15 lei/buc; 19 N. Bucsa caseta directie …………………………………………………………….…………………….………….. 2 buc x 2 lei/buc; 21 N. Burduf planetara mare ...................................................................................... 1 buc x 3 lei/buc; 22 N. Burduf planetara mica ....................................................................................... 1 buc x 3 lei/buc; 23 N. Cala pompa benzina plastic ............................................................................... 1 buc x 1 leu/buc; 24 N. Capac tambur roata spate ……………….......…....………………..…………...…………………….…. 1 buc x 2 lei/buc; 25 26 F. Claxon fabr. Iugoslavia (inclusiv lamele prindere) ................................................. 1 buc x 6 lei/buc; 29 F. Condensator aprindere ....................................................................................... 3 buc x 2 lei/buc; 30 F. Cric cu manivela ................................................................................................. 1 ans x 12 lei/ans; 31 N. Cui poantou ....................................................................................................... 1 buc x 5 lei/buc; 32 F. Duza spalator parbriz inox 1300 ……..……………...………………………………………………………. 1 buc x 8 lei/buc; 33 F. Electromotor (demaror) ..................................................................................... 1 buc x 60 lei/buc; 34 N. Filtru benzina ……………………………………..……..……………………...……………………………………… 1 buc x 2 lei/buc; 35 N. Fise aprindere Urziceni (set complet, culori diferite).............................................. 1 set x 10 lei/set; 36 N. Furca fixare conducta frana ……….…………………………………………………………………….………. 2 buc x 1 leu/buc; 37 N. Garnitura cala pompa benzina ............................................................................ 2 buc x 0,50 lei/buc; 38 N. Garnituri frana spate (ptr. berlina) …………………....….……………………………….………………. 1 set x 1 leu/set; 39 N. Garnituri pompa benzina (set) ………………………….………………………………………………….... 1 set x 5 lei/set; 40 N. Geam tripla spate dr 1300 ................................................................................. 1 buc x 8 lei/buc; 41 F. Lampa cutie acte (cu bec) .................................................................................. 1 buc x 8 lei/buc; 42 N. Membrana pompa benzina (set garnituri cu tija) .………….....….…………..………….………..1 buc x 8 lei/buc; 43 44 F. Piulite antifurt roti cu cheie (4 piulite + 1 cheie) .................................................... 1 ans x 12 lei/ans; 45 N. Pivot superior ………………………….………....…………………………………...…………….………..….…… 1 buc x 10 lei/buc; 46 N. Plutitor carburator plastic .................................................................................... 1 buc x 2 lei/buc; 47 N. Pompa benzina (motor carburator)…..……...…………......................................………… 1 buc x 25 lei/buc; 48 N. Punte redresoare alternator completa.................................................................. 1 buc x 25 lei/buc; 49 N. Releu regulator tensiune electro-mecanic............................................................. 1 buc x 15 lei/buc; 50 51 N. Rotor distribuitor ............................................................................................... 1 buc x 2 lei/buc; 52 F. Scrumiera bord 1310, 1410 .............................................................................. 2 buc x 5 lei/buc; 53 F. Scrumiera usa spate (fara rama din usa) ………………………………………...……………………… 2 buc x 5 lei/buc; 54 F. Set garnituri motor 1400 (complet dar desigilat) ................................................ 1 set x 12 lei/set; 55. N. Simering AS 36 x 54 x 11 fabr. Fartec Bv (planetara lunga).......……....…....……….. 2 buc x 5 lei/buc; 56 F. Sonda presiune ulei 0,35 bar ptr. bec ................................................................. 1 buc x 5 lei/buc; 57 F. Sonda temperatura lichid racire 115 gr ptr. bec .................................................. 1 buc x 5 lei/buc; 58 F. Termostat radiator............................................................................................. 2 buc x 8 lei/buc; 59 F. Ventilator climatizare (bord) .............................................................................. 1 buc x 25 lei/buc; 60 61 F. Yala usa (pentru model >1310) cu o cheie ……………….…………………………..……………….. 1 buc x 8 lei/buc; Fotografii pentru toate produsele ofertate gasiti la postul nr. 259. Precizari: Daca in denumire nu se specifica destinatia stricta, in principiu acel produs poate fi utilizat pe toata gama 1300, 1310, 1410. "N" semnifica produs nou/nefolosit; "F" semnifica produs folosit; toate produsele sunt functionale. Pentru cei din Galati, livrarea se face preferabil personal. Valoarea minima a unei asemenea comenzi este de 10 lei. Pentru alte localitati, produsele pot fi trimise ramburs prin curier sau posta doar daca valoarea depaseste 20 lei (plafonul valoric e o cerinta a postei), cheltuielile de expeditie fiind suportate de cumparator in cuantum de: * 100% pentru trimiterile facute prin curier rapid; * 50% pentru trimiteri facute prin Posta Romana; Bonusuri si discounturi: Pentru comenzi de peste 50 lei ofer discount; la valori de peste 100 lei discountul devine consistent, ajungand la 33% in cazul comandarii intregii liste ramase. Daca sunt neclaritati, va rog sa-mi solicitati informatii suplimentare. Cei interesati ma pot contacta aici, prin PM, sau email (ocb642001@yahoo.com) |
OCEBE |
#364
Up
OCEBE |
#365
Oferta valabila
OCEBE |
#366
Up
OCEBE |
#367
Oferta valabila
OCEBE |
#368
Up
OCEBE |
#369
Up
OCEBE |
#370
Oferta valabila
OCEBE |
#371
Up
OCEBE |
#372
Oferta valabila
OCEBE |
#373
Up
OCEBE |
#374
Up
OCEBE |
#375
Oferta valabila
OCEBE |
#376
Up
OCEBE |
#377
Up
31 Mar 2013, 06:37: Oferta valabila This post has been edited by OCEBE: 31 Mar 2013, 06:37 |
OCEBE |
#378
Up
OCEBE |
#379
Up
OCEBE |
#380
up
OCEBE |
#381
Oferta de la postul 363 valabila
OCEBE |
#382
Up
OCEBE |
#383
Up
OCEBE |
#384
Up
OCEBE |
#385
01 N. Alternator 12V 36A, fabricatie EP licenta Ducellier .............................................. 1 buc x 75 lei/buc; 06 N. Bec far 12V / 45W 40W (clasic) ………………………………………….…………………………………. 4 buc x 2 lei/buc; 07 F. Bec far halogen "GE" 12V / 45W 40W …………………………...…….………………………….….. 1 buc x 5 lei/buc; 08 N. Bec far halogen "Philips Premium" 12V / 60W 55W ……….…..….…………...……………… 1 buc x 8 lei/buc; 09 N. Bec far halogen "Tesla" 12V / 60W 55W ………………..……………...………………………………1 buc x 8 lei/buc; 10 N. Bec far halogen "Tungsram" 12V / 60W 55W …….…………..…….………………………………1 buc x 8 lei/buc; 11 N. Becuri rezerva (continutul setului vizibil in foto) ……….………….……………….....…………. 1 set x 10 lei/set; Toate becurile si setul de rezerva (poz 6 - 11) cu 40 lei 12 N. Bloc lumini (1310, 1410).................................................................................. 1 buc x 20 lei/buc; 13 F. Bobina inductie (carcasa metal) ........................................................................ 1 buc x 12 lei/buc; 14 N. Bobina inductie (carcasa metal) ....................................................................... 1 buc x 15 lei/buc; 15 F. Bobina inductie cu rezistenta (carcasa ebonita) ................................................. 2 buc x 12 lei/buc; 16 N. Borne gabarit mare acumulator ........................................................................ 1 set x 5 lei/set; 17 N. Borne gabarit mic acumulator .......................................................................... 1 set x 3 lei/set; 18 N. Bricheta bord completa..................................................................................... 1 buc x 15 lei/buc; 19 N. Bucsa caseta directie …………………………………………………………….…………………….………….. 2 buc x 2 lei/buc; 21 N. Burduf planetara mare ...................................................................................... 1 buc x 3 lei/buc; 22 N. Burduf planetara mica ....................................................................................... 1 buc x 3 lei/buc; 23 N. Cala pompa benzina plastic ............................................................................... 1 buc x 1 leu/buc; 24 N. Capac tambur roata spate ……………….......…....………………..…………...…………………….…. 1 buc x 2 lei/buc; 26 F. Claxon fabr. Iugoslavia (inclusiv lamele prindere) ................................................. 1 buc x 6 lei/buc; 29 F. Condensator aprindere ....................................................................................... 3 buc x 2 lei/buc; 30 F. Cric cu manivela ................................................................................................. 1 ans x 12 lei/ans; 32 F. Duza spalator parbriz inox 1300 ……..……………...………………………………………………………. 1 buc x 8 lei/buc; 33 F. Electromotor (demaror) ..................................................................................... 1 buc x 60 lei/buc; 35 N. Fise aprindere Urziceni (set complet, culori diferite).............................................. 1 set x 10 lei/set; 36 N. Furca fixare conducta frana ……….…………………………………………………………………….………. 2 buc x 1 leu/buc; 37 N. Garnitura cala pompa benzina ............................................................................ 2 buc x 0,50 lei/buc; 38 N. Garnituri frana spate (ptr. berlina) …………………....….……………………………….………………. 1 set x 1 leu/set; 39 N. Garnituri pompa benzina (set) ………………………….………………………………………………….... 1 set x 5 lei/set; 40 N. Geam tripla spate dr 1300 ................................................................................. 1 buc x 8 lei/buc; 41 F. Lampa cutie acte (cu bec) .................................................................................. 1 buc x 8 lei/buc; 44 F. Piulite antifurt roti cu cheie (4 piulite + 1 cheie) .................................................... 1 ans x 12 lei/ans; 45 N. Pivot superior ………………………….………....…………………………………...…………….………..….…… 1 buc x 10 lei/buc; 47 N. Pompa benzina (motor carburator)…..……...…………......................................………… 1 buc x 25 lei/buc; 48 N. Punte redresoare alternator completa.................................................................. 1 buc x 25 lei/buc; 49 N. Releu regulator tensiune electro-mecanic............................................................. 1 buc x 15 lei/buc; 51 N. Rotor distribuitor ............................................................................................... 1 buc x 2 lei/buc; 52 F. Scrumiera bord 1310, 1410 .............................................................................. 2 buc x 5 lei/buc; 53 F. Scrumiera usa spate (fara rama din usa) ………………………………………...……………………… 2 buc x 5 lei/buc; 54 F. Set garnituri motor 1400 (complet dar desigilat) ................................................ 1 set x 12 lei/set; 55. N. Simering AS 36 x 54 x 11 fabr. Fartec Bv (planetara lunga).......……....…....……….. 2 buc x 5 lei/buc; 56 F. Sonda presiune ulei 0,35 bar ptr. bec ................................................................. 1 buc x 5 lei/buc; 57 F. Sonda temperatura lichid racire 115 gr ptr. bec .................................................. 1 buc x 5 lei/buc; 58 F. Termostat radiator............................................................................................. 2 buc x 8 lei/buc; 59 F. Ventilator climatizare (bord) .............................................................................. 1 buc x 25 lei/buc; 61 F. Yala usa (pentru model >1310) cu o cheie ……………….…………………………..……………….. 1 buc x 8 lei/buc; Fotografii pentru toate produsele ofertate gasiti la postul nr. 259. "N" semnifica produs nou/nefolosit; "F" semnifica produs folosit; toate produsele sunt functionale. Pentru cei din Galati, livrarea se face preferabil personal. Valoarea minima a unei asemenea comenzi este de 10 lei. Pentru alte localitati, produsele pot fi trimise ramburs prin curier sau posta doar daca valoarea depaseste 20 lei (plafonul valoric e o cerinta a postei), cheltuielile de expeditie fiind suportate de cumparator in cuantum de: * 100% pentru trimiterile facute prin curier rapid; * 50% pentru trimiteri facute prin Posta Romana; Bonusuri si discounturi: Pentru comenzi de peste 50 lei ofer discount; la valori de peste 100 lei discountul devine consistent, ajungand la 33% in cazul comandarii intregii liste ramase. Daca sunt neclaritati, va rog sa-mi solicitati informatii suplimentare. Cei interesati ma pot contacta aici, prin PM, sau email (ocb642001@yahoo.com) |
OCEBE |
#386
Up
OCEBE |
#387
Up
OCEBE |
#388
Up
OCEBE |
#389
Oferta valabila
OCEBE |
#390
Up
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 13th July 2025 - 01:36 |
