15 Pages « < 12 13 14 15 >
> [VAND] piese si accesorii Dacia 1300, unele compatibile si cu 1310 - 1410
OCEBE
post 19 Apr 2013, 19:19
Post #391
Up
dacia 1300
Am avut o DACIA 1300
OCEBE
post 21 Apr 2013, 16:07
Post #392
Oferta valabila
dacia 1300
OCEBE
post 24 Apr 2013, 05:36
Post #393
Up
dacia 1300
OCEBE
post 26 Apr 2013, 12:20
Post #394
Up
dacia 1300
OCEBE
post 30 Apr 2013, 06:58
Post #395
Reduceri de preturi*:
Lista actualizata cu piese de schimb si accesorii este urmatoarea:
01 N. Alternator 12V 36A, fabricatie EP licenta Ducellier .......................................... 1 buc x 60 lei/buc (fost 75 lei);
06 N. Bec far 12V / 45W 40W (clasic) ………………………………………….…………………………………. 4 buc x 1,50 lei/buc (fost 2 lei);
07 F. Bec far halogen "GE" 12V / 45W 40W ………………….………...…….………………………….….. 1 buc x 4 lei/buc (fost 5 lei);
08 N. Bec far halogen "Philips Premium" 12V / 60W 55W ……….…..….…………...……………… 1 buc x 6 lei/buc (fost 8 lei);
10 N. Bec far halogen "Tungsram" 12V / 60W 55W …….…………...…….………………………………1 buc x 6 lei/buc (fost 8 lei);
11 N. Becuri rezerva (continutul setului vizibil in foto) …….….……….……………….....…………. 1 set x 8 lei/set (fost 10 lei);
Toate becurile si setul de rezerva (poz 6 - 11) cu 30 lei (fost 40 lei)
12 N. Bloc lumini (1310, 1410).............................................................................. 1 buc x 17 lei/buc (fost 20 lei);
13 F. Bobina inductie (carcasa metal) ..................................................................... 1 buc x 10 lei/buc (fost 12 lei);
14 N. Bobina inductie (carcasa metal) .................................................................... 1 buc x 12 lei/buc (fost 15 lei);
15 F. Bobina inductie cu rezistenta (carcasa ebonita) ................................................ 2 buc x 10 lei/buc (fost 12 lei);
16 N. Borne gabarit mare acumulator ..................................................................... 1 set x 5 lei/set;
17 N. Borne gabarit mic acumulator ....................................................................... 1 set x 3 lei/set;
18 F. Bricheta bord completa.................................................................................. 1 buc x 12 lei/buc (fost 15 lei);
19 N. Bucsa caseta directie ……………………….………….……………………….…………………….………….. 2 buc x 2 lei/buc;
21 N. Burduf planetara mare ................................................................................. 1 buc x 2,50 lei/buc (fost 3 lei);
22 N. Burduf planetara mica .................................................................................. 1 buc x 2,50 lei/buc (fost 3 lei);
23 N. Cala pompa benzina plastic ........................................................................... 1 buc x 1 leu/buc;
24 N. Capac tambur roata spate ……………….......…....………………..…………...…………………….…. 1 buc x 2 lei/buc;
26 F. Claxon fabr. Iugoslavia (inclusiv lamele prindere) ............................................. 1 buc x 6 lei/buc;
29 F. Condensator aprindere .................................................................................. 3 buc x 2 lei/buc;
30 F. Cric cu manivela ........................................................................................... 1 ans x 12 lei/ans;
32 F. Duza spalator parbriz inox 1300 ……..……………...………………………………………………………. 1 buc x 6 lei/buc (fost 8 lei);
33 F. Electromotor (demaror) ................................................................................ 1 buc x 50 lei/buc (fost 60 lei);
35 N. Fise aprindere Urziceni (set complet, culori diferite).......................................... 1 set x 10 lei/set;
36 N. Furca fixare conducta frana ……….…………………………………………………………………….………. 2 buc x 1 leu/buc;
37 N. Garnitura cala pompa benzina ....................................................................... 2 buc x 0,50 lei/buc;
38 N. Garnituri frana spate (ptr. berlina) …………………....….……………………………….………………. 1 set x 1 leu/set;
39 N. Garnituri pompa benzina (set) ………………….……….………………………………………………….... 1 set x 5 lei/set;
40 N. Geam tripla spate dr 1300 ............................................................................. 1 buc x 8 lei/buc;
41 F. Lampa cutie acte (cu intrerupator si bec) .......................................................... 1 buc x 8 lei/buc;
44 F. Piulite antifurt roti cu cheie (4 piulite + 1 cheie) ................................................ 1 ans x 12 lei/ans;
45 N. Pivot superior ……………………….….………....………………………………...…………….………..….…… 1 buc x 8 lei/buc (fost 10 lei);
47 N. Pompa benzina (motor carburator)…..……...………….....................................………… 1 buc x 25 lei/buc;
48 N. Punte redresoare alternator completa............................................................... 1 buc x 20 lei/buc (fost 25 lei);
49 N. Releu regulator tensiune electro-mecanic.......................................................... 1 buc x 12 lei/buc (fost 15 lei);
51 N. Rotor distribuitor ........................................................................................... 1 buc x 2 lei/buc;
52 F. Scrumiera bord 1310, 1410 ............................................................................. 2 buc x 5 lei/buc;
53 F. Scrumiera usa spate (fara rama din usa) ………………………..………………...……………………… 2 buc x 5 lei/buc;
54 F. Set garnituri motor 1400 (complet dar desigilat) ................................................ 1 set x 10 lei/set (fost 12 lei);
55 N. Simering AS 36 x 54 x 11 fabr. Fartec Bv (planetara lunga).......……....….....……..….. 2 buc x 5 lei/buc;
56 F. Sonda presiune ulei 0,35 bar ptr. bec ................................................................ 1 buc x 5 lei/buc;
57 F. Sonda temperatura lichid racire 115 gr ptr. bec .................................................. 1 buc x 5 lei/buc;
58 F. Termostat radiator........................................................................................... 2 buc x 6 lei/buc (fost 8 lei);
59 F. Ventilator climatizare (bord) ............................................................................. 1 buc x 25 lei/buc;
61 F. Yala usa (pentru model >1310) cu o cheie ……………….……………..……………..……………….. 1 buc x 8 lei/buc;
Fotografii pentru toate produsele ofertate gasiti la postul nr. 259.
"N" semnifica produs nou/nefolosit; "F" semnifica produs folosit; toate produsele sunt functionale.
Pentru cei din Galati, livrarea se face preferabil personal. Valoarea minima a unei asemenea comenzi este de 10 lei.
Pentru alte localitati, produsele pot fi trimise ramburs prin curier sau posta doar daca valoarea depaseste 20 lei (plafonul valoric e o cerinta a postei), cheltuielile de expeditie fiind suportate de cumparator in cuantum de:
100% pentru trimiterile facute prin curier rapid;
50% pentru trimiteri facute prin Posta Romana;
Bonusuri si discounturi:
Pentru comenzi de peste 50 lei ofer discount; la valori de peste 100 lei discountul devine consistent, ajungand la 33% in cazul comandarii intregii liste ramase.
* Reducerile sunt valabile pentru comenzile facute pana la data de 10 mai.
Daca sunt neclaritati, va rog sa-mi solicitati informatii suplimentare.
Cei interesati ma pot contacta aici, prin PM, sau email (ocb642001@yahoo.com)
dacia 1300
OCEBE
post 1 May 2013, 16:48
Post #396
Up
dacia 1300
OCEBE
post 4 May 2013, 06:08
Post #397
Up
dacia 1300
OCEBE
post 6 May 2013, 17:57
Post #398
Up
dacia 1300
OCEBE
post 8 May 2013, 05:52
Post #399
Up
dacia 1300
OCEBE
post 9 May 2013, 19:11
Post #400
Up
dacia 1300
OCEBE
post 12 May 2013, 08:46
Post #401
Up
dacia 1300
OCEBE
post 15 May 2013, 05:23
Post #402
Se mentin preturile cu reducerile anuntate la postul 395.
dacia 1300
OCEBE
post 18 May 2013, 12:22
Post #403
Up
dacia 1300
OCEBE
post 20 May 2013, 19:24
Post #404
Up
dacia 1300
OCEBE
post 22 May 2013, 13:05
Post #405
Up
dacia 1300
OCEBE
post 27 May 2013, 06:32
Post #406
Oferta valabila
dacia 1300
OCEBE
post 31 May 2013, 15:08
Post #407
Up
dacia 1300
Floryn_Cis
post 2 Jun 2013, 00:14
Post #408
Daciar Razboinic
60 F. Yala usa (pentru model > 1310) si portbagaj (model cu "impingere") cu o cheie … 1 ans x 20 lei/ans;Attached Image
o mai ai ?
Dacia 1300 Dacia 1300 Berlina 1972 berlina - Sb03cjs
Dacia 1300 1,4L 5 trepte , 1972
Ford Escort Ghia 1,6 16v C.L.X. combi, 1999
OCEBE
post 2 Jun 2013, 06:41
Post #409
@Floryn_Cis,
Pozitia respectiva s-a dat.
Mai e pozitia 61, care nu cuprinde si yala portbagaj: F. Yala usa (pentru model >1310) cu o cheie la 8 lei .
dacia 1300
OCEBE
post 3 Jun 2013, 17:43
Post #410
Up
dacia 1300
OCEBE
post 5 Jun 2013, 15:31
Post #411
Up
dacia 1300
OCEBE
post 10 Jun 2013, 06:16
Post #412
dacia 1300
OCEBE
post 12 Jun 2013, 06:40
Post #413
Up
dacia 1300
OCEBE
post 15 Jun 2013, 05:55
Post #414
Up
dacia 1300
OCEBE
post 17 Jun 2013, 06:37
Post #415
Up
dacia 1300
OCEBE
post 19 Jun 2013, 18:57
Post #416
Up
dacia 1300
OCEBE
post 21 Jun 2013, 19:15
Post #417
Up
dacia 1300
OCEBE
post 25 Jun 2013, 07:09
Post #418
Up
dacia 1300
OCEBE
post 29 Jun 2013, 08:15
Post #419
Up
dacia 1300
OCEBE
post 6 Jul 2013, 08:38
Post #420
Up
dacia 1300
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 13th July 2025 - 01:36
