8 Pages « < 3 4 5 6 7 > »
> [VAND] piese noi Originale sau Producator, piese de schimb
evali22
post 19 Nov 2012, 11:00
Post #121
Valabil in continuare....
dacia logan 2005 laureate
evali22
post 21 Nov 2012, 15:52
Post #122
Anunt valabil in continuare, citeva repere noi:
- maneta stergatoare cu buton Cb la------------- 60 ron/buc
- bloc lumini cu proiector model Valeo------------ 120 ron
- bucsi bascule de origine ------------------------ 25 ron/buc
- bujii Equiem------------------------------------ 60 ron/set
- termostat (producator) LG diesel--------------- 115 ron
- cap bara Lemforder ----------------------------- 90 ron/buc
- bieleta directie Lemforder------------------------ 90 ron/buc
- cap bara de origine------------------------------ 90 ron/buc
- bielete directie de origine------------------------ 80 ron/buc
- cap bara RTS------------------------------------50 ron/buc
- bielete directie RTS-------------------------------50 ron/buc
- termostat benzina------------------------------- 35 ron
- pivoti (LEMFORDER)------------------------------ 35 ron
- bascula de origine------------------------------- 110 ron
- set saboti (ATE)-------------------------------- 135 ron
- nuca schimbator Prestige plastic------- ---------- 35 ron
- nuca schimbator Prestige piele--------------------65 ron
- bucsi bara stabilizatore mijloc -------------------- 20 ron/buc
- bielete antiruliu de origine ------------------------ 25 ron/buc
- rulmenti roata FAG fara ABS ---------------------- 80 ron/buc
- rulmenti de spate originali -- ---------------------- 95 ron/buc.
- rulmenti fata originali pentru model fara ABS la ----- 90 ron
- rulment roata cu ABS pana in model 2007 -------- ron
- rulment roata cu ABS dupa model 2007------------ ron
- burduf planetara stanga Logan-------80 ron
- burduf schimbator viteze-------------35 ron
- mufe instalatie incalzire scaune-------10 ron/buc
- filtru ulei original Purflux benzina ------------------- 15 ron
- filtru ulei original Motorina ------------------------- 20 ron
- filtru aer benzina si motorina ----------------------- 25 ron
- filtru aer 16 valve --------------------------------- 25 ron
- filtru motorina EURO 3 ---------------------------- 115 ron
- filtru motorina EURO 4 ---------------------------- 125 ron
- filtru polen Valeo ---------------------------------- 25 ron
- oglinzi Prestige electrice ---------------------------270 ron/set
- proiectoare ceata Logan Ph1 Valeo ----------------- 70 ron/buc
- buton reglaj oglinzi electrice ------------------------35 ron
- buton deschidere usa -------------------------------10 ron
- amortizoare Monroe fata ----------------------------120 ro/buc
- amortizoare Monroe spate --------------------------105 ron/buc
- amortizoare Bilstein B4 fata -------------------------145 ron/buc
- amortizoare Bilstein B4 spate ------------------------125 ron/buc
- flanse amortizor originale -----------------------------35 ron/buc
- rulmenti amortizor SNR -------------------------------20 ron/buc
- bieleta antirasturnare --------------------------------70 ron
- bieleta antirasturnare VAN----------------------------80 ron
- carcasa cheie cu telecomanda ----------------------- 50 ron
- discuri frana VAN Brembo --------------------------- 135 ron/buc
- placute frana VAN Ferodo SL ------------------------125 ron/set
- discuri frana 259 pline Ferodo ------------------------175 ron/set
- discuri frana 259 ventilate Ferodo --------------------190 ron/set
- discuri frana 259 ventilate Brembo--------------------210 ron/set
- discuri fraba 259 ventilate Brembo Striate-------------185 ron/buc
- placute frana TRW ----------------------------------- 60 ron/set
- placute frana Ferodo FQT ----------------------------125 ron/set
- placute frana Ferodo Premier--------------------------95 ron/set
- cablu ambreiaj MPI-DCI -------------------------------45 ron
- cablu acceleratie MPI -------------------------------- 35 ron
- sonda servodirectie -----------------------------------50 ron
- sonda mers inapoi -------------------------------------35 ron
- plafoniera 3 becuri ------------------------------------35 ron
- plafoniera 1 bec ---------------------------------------30 ron
- contactor lumina pedala frana ------------------------- 20 ron
- spirala airbag volan ------------------------------------ 60 ron
- kit distributie MPI -------------------------------------175 ron
- pompa apa de origine MPI -----------------------------215 ron
- pompa apa HEPU pt benzina ---------------------------175 ron
- kit distributie DCI ------------------------------------- 315 ron
- pompa apa DCI ----------------------------------------215 ron
- kit ambreiaj SACHS 1.6 MPI ---------------------------- 390 ron/set
- kt ambreiaj Origine 1.4 MPI-----------------------------330 ron/set
- curele accesorii ---------------------------------------- 55 ron
- kit accesorii MPI model cu AC de origine -----------------240 ron
- kit accesorii DCI model cu AC de origine -----------------255 ron
- role ghidaj MPI/DCI------------------------------------- 35 ron
- spray luciu anvelope ------------------------------------25 ron
- autocolante stalpi Prestige ------------------------------35 ron/set
- aeratoare Prestige argintii -------------------------------65 ron/set
- aeratoare Duster cromate--------------------------------60 ron/set
- set tapiterie Black Line----------------------------------140 ron/set
- ulei motor, ELF, CASTROL, MOBIL, ARAL-------------------Intrebati
- set incalziri scaune complet cu carenaje-------------------200 ron
- tapiserie Black Line ( 4 tetiere)----------------------------140 ron
- ARAL HIGH TRONIC 5W-40 4L-----------------110 ron
- ARAL HIGH TRONIC 5W-40 1L------------------30 ron
- CAS EDGE 5W-40/1 T.D. 5W40 -1L------------37 ron
- CAS EDGE 5W-40/4 T.D. 5W40 -4L------------135 ron
- CAS EDGE 5W-40/5 T.D. 5W40 -5L------------160 ron
- CAS EDGE 5W-40 B4 5W-40 B4/5-1L ----------44 ron
- CAS EDGE 5W-40 B4 5W-40 B4/5-4L ----------145 ron
- CAS EDGE 5W-40 B4 5W-40 B4/5-5L ----------165 ron
- CAS EDGE 5W-30 5W-30 -1L ----------------51 ron
- CAS EDGE 5W-30 5W-30 -4L ----------------190 ron
- CAS EDGE 5W-30 5W-30 -5L ----------------215 ron
- CAS MAGNATEC C3 5W-40 -1L ----------------35 ron
- CAS MAGNATEC C3 5W-40 -4L ----------------125 ron
- CAS MAGNATEC C3 - 5W-40 -5L ----------------140 ron
- CAS MAGNATEC DIESEL B4 5W-40 -1L-------------35 ron
- CAS MAGNATEC DIESEL B4 5W-40 -4L------------130 ron
si multe altele...se pot aduce si piese pentru masini straine,
mentionez ca piesele sunt de origine.
evali_daniel este id-ul meu
0766.403.938 Vali
mike077
post 24 Nov 2012, 15:40
Post #123
Mersi !
Renault Clio 2017 1.2 Tce
evali22
post 26 Nov 2012, 21:12
Post #124
cu placere mike...
sus cu anuntul.....
evali22
post 29 Nov 2012, 09:43
Post #125
valabil in continuare....
Junkyard
post 29 Nov 2012, 19:23
Post #126
Salut.
Ma intereseaza daca pentru Megane III ai:
- oglinda stanga;
- nuca schimbator 6 viteze imbracat in piele.
Multumesc.
Renault Megane III Coupe 2011
evali22
post 3 Dec 2012, 13:50
Post #127
Junkyard nu am asa ceva, imi pare rau...
MyKe89
post 3 Dec 2012, 13:58
Post #128
Membru RFG
Salut!
Disponibilitate si preturi pentru 6001538227 si 6001538228?
Mersi!
'23 Honda CR-V e:HEV
'02 BMW Z3 1.9i
'91 MB W124 230E
evali22
post 4 Dec 2012, 10:46
Post #129
MyKe89 nu am disponibile reperele tale, imi pare rau.
evali22
post 8 Dec 2012, 12:43
Post #130
sus cu anuntul....
evali22
post 12 Dec 2012, 18:21
Post #131
Valabil in continuare.....filtre si uleiuri la preturi mici...
evali22
post 15 Dec 2012, 13:49
Post #132
evali22
post 17 Dec 2012, 10:06
Post #133
Cine mai doreste DUZE stropitor tip perdea, sau adus la pretul de 25 ron/set, nu sunt multe asa ca grabiti-va.....
evali22
post 19 Dec 2012, 12:17
Post #134
ciumiki
post 19 Dec 2012, 12:19
Post #135
duzele sunt compatibile cu megane 2 ?
Renault Megane 2007, 1.5 dci
megane 2.2, 1.5 dci, 63 kw, an 2007
evali22
post 20 Dec 2012, 10:34
Post #136
ciumiki nu stiu daca sunt compatibile, la clio nu sunt
Victorine
post 23 Dec 2012, 21:56
Post #137
Bujiile de benzinar sunt dinalea cu 2 electrozi de masa, da? Spune si cum mai esti prin Bucuresti, cum lucrezi acum de sarbatori, as lua si eu un set de bujii, filtru ulei, aer, un Castrol EDGE 5w40 B4 (apropos, e FST?), un termostat si 2 duze de spalare parbriz, toate reperele pentru 1,6 MPi. Imi vin neamurile de la capitala la Timisoara de anul nou si as vrea sa combin transportul, deci ma intereseaza daca esti accesibil in perioada asta, pana pe 27-28 decembrie.
bogdanreno
post 24 Dec 2012, 06:44
Post #138
pt symbol motor k7j700 cod 8200070454
renault megane /2007 symbol/2002
evali22
post 24 Dec 2012, 09:07
Post #139
bogdanreno, nu am de unde sa fac rost de inelul de toba, imi pare rau.
flaviaru
post 26 Dec 2012, 19:52
Post #140
Salut, mai ai vreun set de duze? In ce zona se face predarea. ms
Dacia Logan 2006/1.6 MPI
evali22
post 30 Dec 2012, 15:01
Post #141
Valabil in continuare....sus cu duzele tip perdea......
31 Dec 2012, 13:02:
Fie ca toate visele pe care le fauriti in aceste zile magice de Sarbatoare sa se implinesca si drumul strabatut pentru realizarea lor sa va aduca bucurie in inimi, iar in case, fericire si belsug. La multi ani va doresc si un an nou plin de bucurii si impliniri.
This post has been edited by evali22: 31 Dec 2012, 13:02
evali22
post 3 Jan 2013, 21:33
Post #142
- duze stropitor tip derdea------------25 ron/set
evali22
post 5 Jan 2013, 13:45
Post #143
danvizi
post 7 Jan 2013, 09:33
Post #144
QUOTE(evali22 @ 21 Nov 2012, 15:52)
0766.403.938 Vali
Salutare si La Multi Ani!
Ma intereseaza si pe mine pentru un Megane Diesel 1,5 2008 86CP motor K724 urmatoarele:
Kit distributie (curea + rola) - pret si marca si daca se poate reperul
Kit accesorii (curea + rola ghidaj +rola intinzatoare) - pret si marca
Trebuie schimbata si pompa de appa??????
Masina are 64000 KM si 5 ani.
Se ofera garantie si factura???
Multumesc anticipat.
Dan din Slatina.
Renault Megane Sedan 1.5 dci 86 cp 2008
evali22
post 9 Jan 2013, 12:06
Post #145
evali22
post 11 Jan 2013, 11:07
Post #146
evali22
post 14 Jan 2013, 11:15
Post #147
Sus cu duzele stropitor
evali22
post 17 Jan 2013, 13:56
Post #148
0766.403.938 Vali
evali22
post 20 Jan 2013, 19:18
Post #149
Valabil in continuare.......
evali22
post 23 Jan 2013, 18:59
Post #150
sus cu anuntul......
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 13th July 2025 - 14:38
