[VAND] piese noi Originale sau Producator, piese de schimb
evali22 |
#181
![]() Membru autentic Group: Members Posts: 535 Joined: 18 January 11 From: Bucuresti ![]() |
Attached thumbnail(s) IMG_0060.JPG ( Size: 417.6k ) Number of downloads: 814 IMG_0062.JPG ( Size: 352.01k ) Number of downloads: 850 IMG_0063.JPG ( Size: 517.9k ) Number of downloads: 832 IMG_0083.JPG ( Size: 254.11k ) Number of downloads: 830 |
2005 laureate
evali22 |
#182
Anunt valabil in continuare, citeva repere noi:
- maneta stergatoare cu buton Cb la------------- 60 ron/buc - bloc lumini cu proiector model Valeo------------ 120 ron - bucsi bascule de origine ------------------------ 25 ron/buc - bujii Equiem cu 2 craci-------------------------- 60 ron/set - bujii Equiem cu 1 crac---------------------------50 ron/set - termostat (producator) LG diesel--------------- 115 ron - cap bara Lemforder ----------------------------- 90 ron/buc - bieleta directie Lemforder------------------------ 90 ron/buc - cap bara de origine------------------------------ 90 ron/buc - bielete directie de origine------------------------ 80 ron/buc - cap bara RTS------------------------------------50 ron/buc - bielete directie RTS-------------------------------50 ron/buc - termostat benzina------------------------------- 35 ron - pivoti (LEMFORDER)------------------------------ 35 ron - bascula de origine------------------------------- 110 ron - set saboti (ATE)-------------------------------- 135 ron - nuca schimbator Prestige plastic------- ---------- 35 ron - nuca schimbator Prestige piele--------------------65 ron - bucsi bara stabilizatore mijloc -------------------- 20 ron/buc - bielete antiruliu de origine ------------------------ 25 ron/buc - rulment roata fata FAG (fara ABS) ----------------105 ron/buc - set rulmenti roata fata FAG (fara ABS)-------------160 ron/set (2 buc) - rulment roata fata MAPCO (fara ABS)---------------70 ron/buc - rulment roata spate MAPCO------------------------60 ron/buc - burduf planetara stanga Logan-------80 ron - burduf schimbator viteze-------------35 ron - mufe instalatie incalzire scaune-------10 ron/buc - filtru ulei original Purflux benzina ------------------- 15 ron - filtru ulei original Motorina ------------------------- 20 ron - filtru aer benzina si motorina ----------------------- 25 ron - filtru aer 16 valve --------------------------------- 25 ron - filtru motorina EURO 3 ---------------------------- 115 ron - filtru motorina EURO 4 ---------------------------- 125 ron - filtru polen Valeo ---------------------------------- 25 ron - filtru uleu Duster-----------------------------------35 ron - oglinzi Prestige electrice ---------------------------270 ron/set - proiectoare ceata Logan Ph1 Valeo ----------------- 70 ron/buc - buton reglaj oglinzi electrice ------------------------35 ron - buton deschidere usa -------------------------------10 ron - amortizoare Monroe fata ----------------------------120 ro/buc - amortizoare Monroe spate --------------------------105 ron/buc - amortizoare Bilstein B4 fata -------------------------145 ron/buc - amortizoare Bilstein B4 spate ------------------------125 ron/buc - flanse amortizor originale -----------------------------35 ron/buc - rulmenti amortizor SNR -------------------------------20 ron/buc - bieleta antirasturnare --------------------------------70 ron - bieleta antirasturnare VAN----------------------------80 ron - carcasa cheie cu telecomanda ----------------------- 50 ron - discuri frana VAN Brembo --------------------------- 135 ron/buc - placute frana VAN Ferodo SL ------------------------125 ron/set - discuri frana 259 pline Ferodo ------------------------175 ron/set - discuri frana 259 ventilate Ferodo --------------------190 ron/set - discuri frana 259 ventilate Brembo--------------------210 ron/set - discuri fraba 259 ventilate Brembo Striate-------------185 ron/buc - placute frana TRW ----------------------------------- 60 ron/set - placute frana Ferodo FQT ----------------------------125 ron/set - placute frana Ferodo Premier--------------------------95 ron/set - cablu ambreiaj MPI-DCI -------------------------------45 ron - cablu acceleratie MPI -------------------------------- 35 ron - sonda servodirectie -----------------------------------50 ron - sonda mers inapoi -------------------------------------35 ron - plafoniera 3 becuri ------------------------------------35 ron - plafoniera 1 bec ---------------------------------------30 ron - contactor lumina pedala frana ------------------------- 20 ron - spirala airbag volan ------------------------------------ 70 ron - kit distributie MPI -------------------------------------175 ron - pompa apa de origine MPI -----------------------------210 ron - pompa apa HEPU pt benzina ---------------------------175 ron - kit distributie DCI ------------------------------------- 315 ron - pompa apa DCI ----------------------------------------210 ron - kit ambreiaj SACHS 1.6 MPI ---------------------------- 390 ron/set - kit ambreiaj Origine 1.4 MPI-----------------------------330 ron/set - kit ambreiaj DCI producator LUK-------------------------350 ron - rulment ambreiaj hidraulic Valeo-------------------------170 ron - curele accesorii ---------------------------------------- 55 ron - kit accesorii MPI model cu AC de origine -----------------240 ron - kit accesorii DCI model cu AC de origine -----------------255 ron - role ghidaj MPI/DCI------------------------------------- 35 ron - spray luciu anvelope ------------------------------------25 ron - autocolante stalpi Prestige ------------------------------35 ron/set - aeratoare Prestige argintii -------------------------------65 ron/set - aeratoare Duster cromate--------------------------------60 ron/set - set tapiterie Black Line----------------------------------140 ron/set - ulei motor, ELF, CASTROL, MOBIL, ARAL-------------------Intrebati - set incalziri scaune complet cu carenaje-------------------200 ron - tapiserie Black Line ( 4 tetiere)----------------------------140 ron - duze stropitor tip perdea------------------------------------20 ron/set - ARAL HIGH TRONIC 5W-40 4L-----------------110 ron - ARAL HIGH TRONIC 5W-40 1L------------------30 ron - CAS EDGE 5W-40/1 T.D. 5W40 -1L------------37 ron - CAS EDGE 5W-40/4 T.D. 5W40 -4L------------135 ron - CAS EDGE 5W-40/5 T.D. 5W40 -5L------------160 ron - CAS EDGE 5W-40 B4 5W-40 B4/5-1L ----------44 ron - CAS EDGE 5W-40 B4 5W-40 B4/5-4L ----------145 ron - CAS EDGE 5W-40 B4 5W-40 B4/5-5L ----------165 ron - CAS EDGE 5W-30 5W-30 -1L ----------------51 ron - CAS EDGE 5W-30 5W-30 -4L ----------------190 ron - CAS EDGE 5W-30 5W-30 -5L ----------------215 ron - CAS MAGNATEC C3 5W-40 -1L ----------------35 ron - CAS MAGNATEC C3 5W-40 -4L ----------------125 ron - CAS MAGNATEC C3 - 5W-40 -5L ----------------140 ron - CAS MAGNATEC DIESEL B4 5W-40 -1L-------------35 ron - CAS MAGNATEC DIESEL B4 5W-40 -4L------------130 ron - CAS MAGNATEC BENZINA 10W-40 -1L-------------30 ron - CAS MAGNATEC BENZINA 10W-40 -4L-------------115 ron - CAS MAGNATEC BENZINA 10W-40 -5L--------------130 ron - CAS MAGNATEC DIESEL 10W-40 -1L---------------32 ron - CAS MAGNATEC DIESEL 10W-40 -4L---------------120 ron - CAS MAGNATEC DIESEL 10W-40 -5L---------------130 ron - ELF EVOLUTION SXR 5W-40 -4L--------------------135 ron - ELF EVOLUTION SXR 5W-40 -1L--------------------38 ron - ELF COMPETITION ST 10W-40/4L------------------85 ron - ELF COMPETITION ST 10W-40/1L------------------25 ron - ELF TURBO DIESEL 10W-40/5L---------------------110 ron - ELF TURBO DIESEL 10W-40/4L---------------------85 ron - ELF TURBO DIESEL 10W-40/1L---------------------25 ron - MOBIL SUPER 3000 5W-40/4L----------------------125 ron - MOBIL SUPER 3000 5W-40/1L-----------------------35 ron si multe altele...se pot aduce si piese pentru masini straine, mentionez ca piesele sunt de origine. evali_daniel este id-ul meu 0766.403.938 Vali |
2005 laureate
evali22 |
#183
Sus cu anuntul......
2005 laureate
bogdan mamba |
#184
Membru incepator Group: Members Posts: 1 Joined: 12 March 13 ![]() |
Salut, setul de duze il trimiti prin curier pana in Constanta? ceea ce ar creste pretul fata de 20 ron initial?
This post has been edited by bogdan mamba: 12 Mar 2013, 20:36 |
evali22 |
#185
@bogdan mamba ai PM
2005 laureate
pedrony75 |
#186
![]() Membru incepator Group: Members Posts: 30 Joined: 5 February 11 From: BUCURESTI ![]() |
Salut! Un pret pentru urmatoarele piese ptr Laguna 2 HB, 1,9 diesel, an 2002: flanse amortizor, rulmenti amortizor, amortizoare fata si amortizoare spate. Multumesc anticipat! Respect....
LAGUNA
evali22 |
#187
Valabil in continuare.....
2005 laureate
just_horia |
#188
![]() Membru autentic Group: Members Posts: 387 Joined: 7 October 11 From: Galati ![]() |
Salut! Fa-mi te rog o oferta pentru urmatoarele piese de Dacia SuperNova Clima:
* kit distributie * pompa apa. Daca nu curge trebuie musai schimbata? Am 120.000 km * curele accesorii * set saboti frana spate * capete bara fata x2 * pivoti x2 * bucsa bara stabilizatoare, tirant * bucse bascula * biela antirului (leaga motorul de sasiu, in zona cutiei de viteze) Toate pentru Dacia SuperNova Clima Multumesc. |
Super Nova
2001/Clima 0721 176 172
sorinache11 |
#189
![]() Membru autentic Group: Members Posts: 363 Joined: 25 August 12 From: Constanta ![]() |
salut.
vreau o oferta pentru urmatoarele piese [de origine]: -tampon hidroelastic -bieleta antibasculare -discuri fata [cu rulment si ABS] -discuri spate [cu rulment si ABS] -placute frana fata -placute frana spate -flansa si rulment sarcina renault scenic 2 din 2004; 1.5 dCi; 74 kw; serie sasiu: vf1jm020532231250; motor k9k-f7 |
SCENIC 2; 1.5 dCi; 101 CP
calinnov |
#190
![]() Membru autentic Group: Members Posts: 629 Joined: 28 December 06 From: Alba Iulia ![]() |
Salut,
Imi poti face o oferta de pret pentru: - flanse amortizor. Renault Megan II. 2, VIN VF1LMSEC638194234. Multumesc |
ex. Renault
Sedan 2.2, 1.6 16V, 82kw
2006 Exp. ex. Renault Sedan 2.2, 1.5 dci, 78kw, 2007 Exp
Renault Estade 2.2, 1.9 dci, 96kw, 2007 Priv ex. Renault Clio Symbol 1.4 8V 2003 55kw Exp |
evali22 |
#191
aveti PM domnilor...
2005 laureate
MyKe89 |
#192
![]() Membru RFG Group: Members Posts: 3.070 Joined: 16 December 07 From: Bucuresti ![]() |
De ce nu pui preturile aici?
'23 Honda
CR-V
e:HEV '02 BMW Z3 1.9i
'91 MB W124 230E |
LiviuHF |
#193
![]() Ro.A.F. Group: Members Posts: 227 Joined: 16 April 11 From: Botoșani/Bacău ![]() |
Salut,
poti sa-mi aduci jiglor spalator 8200600847,si un pret te rog(este vorba de duze spalare parbriz tip perdea folosite pe kangoo>2008 din cate am inteles) Multumesc anticipat |
Megane II Sedan
2004 1.6 83kw Renault Megane II Sedan 2003 1.6 83kw
Think! It ain`t illegal yet... |
evali22 |
#194
LiviuHF pot sa iti aduc duzele dar sunt foarte scumpe undeva la 85 ron bucata.
2005 laureate
evali22 |
#195
valabil.....
2005 laureate
Laza Andrei |
#196
![]() Laza Group: Members Posts: 42 Joined: 7 April 09 From: Bucuresti ![]() |
Salut!
Vreau si eu o oferta pt urmatoarele repere: - bucsi bara stabilizatoare ( capete + mijloc ) - bucsi bascula 4 buc - bascula fata stanga - dreapta - spira airbag volan - discuri fata 280 mm - kit distributie Megan 1 breck , 1.6 16 v , din 99 , 79kw , VF1KA040521507721, tip motor k4MA7. Multumesc This post has been edited by Laza Andrei: 4 Apr 2013, 10:16 |
Megane
1.6 16v
- B-97-LAZ
evali22 |
#197
2005 laureate
mike077 |
#198
Membru incepator Group: Members Posts: 72 Joined: 26 July 07 From: Hunedoara ![]() |
Salut Vali,
ai cumva urmatoarele repere: - obturator praf balama antivant; - ulei LiquiMoly Leichtlauf High Tech 5W-40 ? Filtrul de polen este cu tot cu rama de fixare in locas? Attached thumbnail(s) protectie_praf_obturator_8200574748_001_500x500.jpg ( Size: 64.32k ) Number of downloads: 555 |
Clio
2017 1.2 Tce
evali22 |
#199
valabil...
2005 laureate
orwo |
#200
![]() taxidriver Group: Members Posts: 58 Joined: 3 July 06 From: timisoara ![]() |
buna ,bobina inductie mpi 1,4?
2006,1.4 YELLOW CAB
- TM-50-RWO [/B]taxi for ever
evali22 |
#201
orwo ai PM
Valabil in continuare..... |
2005 laureate
evali22 |
#202
2005 laureate
evali22 |
#203
valabil in continuare....!
2005 laureate
evali22 |
#204
2005 laureate
evali22 |
#205
sus cu anuntul....
2005 laureate
evali22 |
#206
valabil in continuare......
2005 laureate
evali22 |
#207
2005 laureate
pustiull |
#208
![]() Membru autentic Group: Members Posts: 553 Joined: 26 July 10 From: Bucuresti ![]() |
ambreiaj de megane 2.1 motor 1.6 16v un pret?
disc placa rulment discuri frana 259 ventilate Brembo--------------------210 ron/set se potriveste pe meganul meu? multumesc |
Megane 2
2004 1.6 16v
- b-287-JoN
MyKe89 |
#209
Salut!
Spidan 21546 si 21545? Sau GKN 303522 si 303521? Multumesc! |
'23 Honda
CR-V
'91 MB W124 230E |
evali22 |
#210
2005 laureate
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 13th July 2025 - 14:41 |
