516 Pages  1 2 3 > »
Closed TopicStart new topic
> Impreza WRX SW 2002, ...si Ignis Sport 2004
Muttley
post 27 Aug 2014, 16:15
__________________
Culoare Z2S D02
Jante originale + 185/55 vechi = 14kg
Jantele originale - 5.9kg (cules de prin topic si de prin amintiri)
TDM - 7.5kg
TDM vopsite alb + Kumho 185/50 = plus 15kg (nov 2020, da eroare la limita cantarul).
Hankook K125 185/55/15, 6.8kg.
Sparco Assetto Gara - 6.3kg.
Sparco cu Hankook, totul nou, 13.1kg.
QUOTE(Fratzica @ 23 Apr 2018, 23:11)
Engine Oil (≈ 4.1 Litres) Fully Synthetic only 5W-30 Over 100k 10w-40
Gearbox Oil  (≈ 2.2 Litres) 75W-90 GL4
Coolant (≈ 4.98 Litres) 990E0-59J44-000 Ethylene Glycol based Antifreeze (suzuki super cool blue or p-HOAT is best), make sure you thoroughly flush the system before refilling
CPS J5T23891
09409-09304 - clips patrat overfender
09409-07332 - clips mare si negru de 6.7mm cu miez (e peste tot)
09409-08334 - clips rotund overfender spate.
09409-08328 - clips rotund overfender fata.
09409-08327 - clips negru push grila fata si bara fata jos.
OC 217/6 - Mahle, ulei motor.
W 610/1 - Mann, ulei motor.
C 2653 - Mann, filtru aer.
CU 2326 - Mann, filtru habitaclu.
Garnitura buson motor 14x20.
De pe autovit, un VIN de STI 2006: JF1GDFLH36G066515
This post has been edited by Muttley: 14 Nov 2023, 15:18
Dacia 1310 TLX 1988
post 27 Aug 2014, 16:35
Pai s-o conduci sanatos.
QUOTE(Muttley @ 27 Aug 2014, 16:15)
noul model, pe care desi l-au uratit grav
Well, cam greu, ca nici o versiune nu murise de draguta ce era.
balanel
post 27 Aug 2014, 16:55
Transmisie automata - confort si siguranta.
Chiar ca o masina misto! Felicitari, s-o porti sanatos!
chevrolet aveo sedan t300 LT+ a14xer - 1.4 benzina aspirat 100 CP/ 2013 (in curand alta masina, cu transmisie automata)
Mwe Louis-Rene Panhard si Emile Levassor, inventatorii transmisiei manuale.
Fan Mircea Badea.
Rob3rto
post 27 Aug 2014, 17:03
Imi pare rau ca n-ai stat mai mult cand mi-ai dat carburatorul, vroiam s-o studiez putin wub.gif
Dacia 1300 1981 - PH 88 VBA
4x4
post 27 Aug 2014, 17:49
Übermensch
Multi kmp!
E mai rapida decat dacia ta?
This post has been edited by 4x4: 27 Aug 2014, 18:00
W S S
Attere Dominatum!
post 27 Aug 2014, 18:40
QUOTE(Muttley @ 27 Aug 2014, 18:08)
- primii NERVI, si aveau sa se perpetueze pana-n ziua de azi, si am sa-i am si maine si mult d-acu-ncolo;
- alti nervi, de alta natura;
- griji si dezamagire;
- primele regrete reale, primele intentii de a-i face vant.
AR-18-MOS
post 27 Aug 2014, 18:43
( -_・) ︻デ═一
Stepway, chiar...
Concord
post 27 Aug 2014, 19:15
Nervi gaseai sa iti faci cu orice masina. Mai bine ramai sanatos si te bucura te partile ei bune ( cele care au ramas )
Renault Megane 2010
post 27 Aug 2014, 19:36
QUOTE(Muttley @ 27 Aug 2014, 19:55)
Se pare ca asa fac mai toate...
Si cea mai nasoala... Am luat masina asta ca sa-mi placa s-o conduc, si am ajuns s-o urasc.
Rauvoitorii zic asa de dacii (da' banuiesc ca asta o stii).
Sa conduci ceva ce nu-ti place, nu prea e ok, chiar daca cu restul (frana de motor, etc.) te poti obisnui.
P-A-C-O
post 27 Aug 2014, 19:39
What you see is what you get!
QUOTE(Muttley @ 27 Aug 2014, 18:55)
Ce mi se parea la inceput, si anume ca nu prea are frana de motor, avea sa se demonstreze a fi muuult mai nasol, si mai ales, e o functie prevazuta de fabricant!
Practic, atunci cand o calc, si o mai calc uneori, ca d-aia am luat-o, cand nu apas pe acceleratie, ea ramane turata, sau scade in turatie extrem de lent. Asta inseamna ca frana de motor, in ture mari, nu exista. Mai inseamna ca atunci cand combin frana de motor cu cea de serviciu... motorul practic accelereaza.
asta pare o chestie foarte nasoala pentru siguranta in traficul urban.. tine-te de ei cu reclamatii sa-ti puna un soft actualizat , nu cred ca a ta e singura cu problema respectiva (da, e o problema reala, aburelile alea cu "protectia cutiei" sunt pentru ciobanii care n-au nicio treaba cu domeniul auto)
masina e frumoasa, pare asezata insa la 15k nu prea are voie sa faca figuri ! sleep.gif
post 27 Aug 2014, 19:44
Cati forinti fu ? Mie nu-mi place, un Clio RS sehas ca nou ar fi fost alegerea, ramaneau si bani, intretinerea nu e scumpa, si manca ungusrimul asta a tau la cina cu 60 de cai in plus.
MihaiD
post 27 Aug 2014, 20:13
In .ro astia se ocupa de Cupa Swift si sunt alesi sa faca asta de catre Suzuki Romania. Fa-le scandal la reprezentanta, poate accepta sa-ti resofteze masina pe garantie biggrin.gif.
A, si daca o sa bagi ceva circuit cu ea, un LSD e obligatoriu wink.gif.
Renault Megane R26 2008 - XX-xx-xxx
post 27 Aug 2014, 20:15
S-o stăpânești sănătos!
Mașina îți era numa' bună ca a doua mașină (îndrăznesc să scot din ecuație bătrâna dacie), cu care să te joci când ai chef. Acoperă prea puțin din nevoi, e totuși clasă mică, iar așteptările tale sunt prea mari.
Cât despre OPC, dacă otomobilu' așa a fost proiectat și nu încalcă niciun normativ european sau românesc, poți să uiți.
post 27 Aug 2014, 20:56
Vezi ca Torque indica aiurea pozitia pedalei. Bine, nu reactioneaza la toate masinile asa.
This post has been edited by IRONICK: 27 Aug 2014, 21:00
MihaiD
post 27 Aug 2014, 21:17
Da, Torque se asteapta la 5V/100% din TPS si de fapt posibil ca TPS-ul tau sa fie cu 4.5V/100%(sau alta valoare sub 5V).
Dupa cate stiu eu, la Swift Cup, remaparea ridica redline-ul si mareste puterea cu intre 5 si 10 cai, dar cel mai simplu ii suni pe baietii aia si ii intrebi - cu ocazia asta le spui si de problema ta, poate-ti dau o solutie (resoftare partiala, etc...). Daca exista o solutie, mergi la reprezentanta si poate, poate o sa se lase cu o rezolvare a problemei rolleyes.gif .
This post has been edited by MihaiD: 27 Aug 2014, 21:21
MihaiD
post 27 Aug 2014, 21:52
Nu neaparat. Ii suni pe cei din Cluj cu Cupa Swift, vezi daca au o solutie si te interesezi si despre softul de cupa. Daca au, mergi la reprezentanta din Bucuresti, si le spui ca din punctul tau de vedere masina este inutilizabila, esti dezamagit, etc... dar sunt unii autorizati Suzuki care ar putea rezolva problema. Poate ai noroc...
4x4
post 27 Aug 2014, 22:00
Übermensch
Fara a avea nici o cunostinta vis-a-vis de sistemele folosite pe suzuki, pot totusi sa iti sugerez o treaba.
La pedala de ambreiaj ai sigur un senzor de pozitie, e folosit de sistemul de CC, posibil si de sistemul ce previne pornitul motorului cat timp esti in viteza? si in cazul masinii mele la fwtut cumplet pedala de accelertie.
Nu intru in detalii, face exacat cum spui tu, delay la apasare, retrogradari extrem de nasoale, practic no joy of driving.
Am scos mufa din senzor, am ramas fara CC laugh.gif , dar acuma am masina. Poti incerca treaba asta, e foarte usor de facut si in caz de merge, rezultatele sunt pe masura.
Fenomenul a fost observat si de tipul asta:
https://www.youtube.com/watch?v=cNTA5jpznlI...E3VjruzwfoG0ZGw
This post has been edited by 4x4: 27 Aug 2014, 22:04
W S S
Attere Dominatum!
AR-18-MOS
post 27 Aug 2014, 22:49
( -_・) ︻デ═一
QUOTE(Muttley @ 27 Aug 2014, 21:27)
exemplu: depasesti, ramai in treapta, te repliezi in spatele celei de-a 2-a masini din fata, franezi, timp in care ea accelereaza => situatie de maxima ciocolata.
Eu am condus Loganu' de curse, timp de vreo doua saptamani cu arcul de la acceleratie rupt, si cablul improvizat ca sa stea fix. Astfel ca nu numai ca calcam pedala, da' trebuie s-o si ridic ca sa nu mai accelereze. icon_mrgreen.gif
post 28 Aug 2014, 08:18
QUOTE(MihaiD @ 27 Aug 2014, 21:17)
Nu stiu daca este calitatea adaptorului sau o referinta interna da tensiune. Si tensiunea bateriei citita din adaptor este mult mai mica. Si nu este problema de fire sau contacte, cu multimetrul masurat in acelasi loc este corecta.
post 28 Aug 2014, 08:35
Numa pseudo japonezele au probleme din astea...Driverx o fi rezolvat cu ralantiul la Lancer? huh.gif
R E M U S
post 28 Aug 2014, 08:48
Group: Modelatori
Mitsubishi Colt 2009
sa mergi tare intrand pe contrasens in toate curbele? MEAH
sa mergi tare pastrandu-ti banda? asta inseamna sa fii mafiot
restu' e cancan...
Comportamentul ala ciudat nu are legatura cu fiablititatea.
mars
post 28 Aug 2014, 09:11
meow or never
Frumoasa masinuta! Imi aduc aminte ca m-a cam alergat una pe centura si se tinea al naibii de bine. Abia la iesirea spre Colentina am vazut ca era mai sportiva wink.gif.
Mercedes-AMG A 35 (2023)
post 28 Aug 2014, 09:31
Eu cred ca avea probleme cu senzorul de pozitie, este normala cresterea usoara de turatie atunci cand se apasa pe ambreiaj, sa sustina diverse consumatoare (gen servodirectie, ac, etc) si sa nu se opreasca motorul. Daca scoti din viteza in mers si ridici piciorul de pe acceleratie si ambreiaj, o sa vezi ca nu ajunge la ralanti, ci il tine turat la peste 1500rpm. Doar ca in frana de motor nu trebuie sa se intample asta.
This post has been edited by IRONICK: 28 Aug 2014, 09:33
cristio_79
post 28 Aug 2014, 10:10
QUOTE(4x4 @ 27 Aug 2014, 23:00)
Ala mai degraba este un intrerupator, decat un senzor. Am avut si eu o problema cu unul la una dintre masini, am facut mai multe diagnoze si aparea tot timpul eroarea, chiar daca era stearsa. Pe tester aparea ca fiind apasata pedala de ambreiaj, cu toate ca pedala era libera. Sfatul a fost sa-l schimb, ceea ce am si facut. Mi s-a parut o idee mai sprintena la plecarea de pe loc si in treptele inferioare. Nu am mai ajuns sa pun Lexia pe masina sa vad daca se sterge singura sau nu. Voi face acest lucru saptamana viitoare.
Mecanicul mi-a spus ca limiteaza demarajele daca este defect, masina find putin mai lenesa.
Am masurat intrerupatorul demontat cu un aparat de masura si valorile indicau ca este bun.
This post has been edited by cristio_79: 28 Aug 2014, 10:12
Mai traiti? Bine...
post 28 Aug 2014, 10:46
QUOTE(Muttley @ 28 Aug 2014, 10:24)
Ironick, cine avea probleme cu senzorul de pozitie? Stiftu'?
nu, masina lu' 4x4
ianacosti
post 28 Aug 2014, 12:46
Dar consumul instantaneu cade la zero in frana de motor?
Si la a mea am observat ca nu prea are frana de motor in treptele 4, 5 si 6, dar nu se accelereaza, doar deccelereaza foarte lent si consumul instant afisat e 0. (1.2 TSI 105 CP)
P.S. Exista foliie transparenta pentru far? Super tare. Imi dai si mie un cod, un nume al foliei?
DACIA SOLENZA 2005 - BV 78 EDM
SEAT TOLEDO NH 1.2 TSI 105 CP 2014
EX. DACIA SOLENZA 2005
R19/16v
post 28 Aug 2014, 13:14
Oldschool Member
Cum o sa scada la 0 daca motorul e turat? Cine sa-l tina turat?
DS 5H VRSCA Screamin' eagle
MihaiD
post 28 Aug 2014, 15:31
QUOTE(IRONICK @ 28 Aug 2014, 08:18)
Am zis ca desi senzorul de TPS e de 5V, ECU-ul se asteapta ca la 100% clapeta deschisa TPS-ul sa-i indice 4.5V(sau alta valoare sub 5V) si de aia Torque ii indica alta valoare sub 100%. Am mai vazut asta la o Mazda, care-i arata pe Torque ca clapeta se deschide numai ~ 90% cand era la full throttle. Pe testerul de la Mazda(care era calibrat pe voltajul exact) arata 100%.
This post has been edited by MihaiD: 28 Aug 2014, 15:35
marksman
post 28 Aug 2014, 15:46
Post mortem nihil est
QUOTE(Muttley @ 28 Aug 2014, 14:33)
Folia e transparenta, relativ groasa, extrem de elastica si foarte scumpa. Folierea capotei (ca apropo, e pamant de flori la capitolu' vopsea) m-ar costa 250e. Am zis pas si las eventuale probleme-n grija politei Casco.
Folierea farurilor si a proiectoarelor a costat 230 de lei parca.
Pe forumul vw era un tip care-si infoliase toata masina. Vreo 5000 de lei l-a costat smile.gif
Nick Ușor
516 Pages  1 2 3 > »
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 12th July 2025 - 12:33
