Opel Crossland X (Polizorul Turbo), și Mazda CX-30. Două plasticuri.
tomageorgian |
#1531
![]() Membru autentic Group: Members Posts: 1.398 Joined: 22 February 10 From: Franta ![]() |
. Kia Niro Phev
Laguna3 2.0dCI ex. Latitude 2.0dCI C5 x7 2.0hdi Logan 1.6mpi E39 530D Laguna 3 2.0dCi Qashqai 1.5dCI Twingo 2 1.2i E28 520i |
bion |
#1532
Inghesuiala mare sub capace. Mijto de lucrat
SLZ Scala
b06fcn |
#1533
![]() DOCTOR Group: Members Posts: 5.897 Joined: 27 February 05 From: Bucuresti/Galati ![]() |
Misto japoneza. Sa te duca sanatos pe unde ai nevoie...
marksman edit: multumesc! This post has been edited by marksman: 26 Jun 2020, 13:33 |
21
1.9dT, 1989
- B 06 FCN MB C 220d 4MATIC
dizzy |
#1534
![]() Work smart not hard! Group: Members Posts: 5.114 Joined: 11 February 04 ![]() |
Are nevoie de un anume tip de benzina?
Sau merge cu orice ? |
Whirpool
ex Dacia Logan
axabrt |
#1535
![]() Membru autentic Group: Members Posts: 4.193 Joined: 15 February 05 From: Ploiesti ![]() |
Focus mk3.5
#1536
![]() - Group: Members Posts: 22.736 Joined: 19 April 05 From: Romania ![]() |
QUOTE(bgdrenault @ 24 Jun 2020, 08:38) Pacat de ranga aia care sustine capota la motor. Cat sa si fost doua amortizoare de capota, in comparatie cu ranga aia? 30 E in plus. Si meganul turcesc are, chiar doua. Pana si loganul Cum sa strici o frumusete cu o pwla bleaga? O parere tipica de coltul strazii. Oare cand o sa iesiti si voi din bula???? |
#1537
![]() fan Dacia Group: Members Posts: 21.628 Joined: 12 November 05 From: Bucuresti ![]() |
- negru pe alb
marksman |
#1538
Post mortem nihil est Group: Members Posts: 7.732 Joined: 1 November 04 From: sat ![]() |
Da, merge cu CO 95 minim. I-am pus CO 100.
Opel / Mazda
Crossland X / CX-30
2019 / 2020 Nick Ușor
AndreiMR |
#1539
![]() Membru alfist Group: Members Posts: 3.828 Joined: 15 January 09 From: Pitesti ![]() |
Din cate am mai citit...pentru motorul asta mai bine e sa folosesti benzina de 95. Ideea e sa mearga mai mult in regim de aprindere prin compresie, iar teoretic benzina cu CO mare ar preveni asta.
This post has been edited by AndreiMR: 24 Jun 2020, 12:53 |
2018
Mazda 3 G120
Challenge 2015 Land Rover Discovery Sport TD4 SE
2008 Mazda 2 TE EX: Clio III dci Dynamique/Mazda CX-7 Revolution/ Alfa Romeo 159 2.4 jtdm |
marksman |
#1540
Eu stiam ca de obicei la motoare cu RC peste 10(11?) se recomanda benzina cu CO mare. Pe buson scrie "min 95".
This post has been edited by marksman: 24 Jun 2020, 13:04 |
Opel / Mazda
Crossland X / CX-30
psychoo |
#1541
![]() Membru Group: Members Posts: 3.722 Joined: 23 August 07 From: Timisoara ![]() |
Multi kmp fara nici un fel de probleme iti doresc.
Interiorul simplist cu acele cusaturi la vedere imi pare f fain. Ignora haterii, capota cu amortizoare nu are utilitate. La cat de des trebuie umblat sub capota e mai mult decat suficienta tija. Sa nu vorbim de fiabilitate si greutate redusa. Se stie ca mazda cauta sa reduca greutatea de peste tot... |
Focus
marksman |
#1542
@psychoo: multam. Daca vrei sa o vezi pe viu, da un semn, parca suntem consateni, din ce imi aduc aminte.
QUOTE(einstein1984 @ 24 Jun 2020, 08:32) QUOTE(bion @ 24 Jun 2020, 10:00) ![]() IMG_20200623_153850.jpg ( Size: 5.23mb ) Number of downloads: 459 |
Opel / Mazda
Crossland X / CX-30
Victorine |
#1543
QUOTE(marksman @ 24 Jun 2020, 13:57) Eu stiam ca de obicei la motoare cu RC peste 10(11?) se recomanda benzina cu CO mare. Pe buson scrie "min 95". O fi, dar asa cum zice si colegu' mai sus, asta functioneaza si ca un diesel si-atunci trebe ca benziba sa se aprinda usor la comprimarea amestecului. Da banui ca stie cslculatorul ce sa faca si la CO mai mare. |
Toyota
Auris Touring Sports HSD
2014
MyKe89 |
#1544
![]() Membru RFG Group: Members Posts: 3.071 Joined: 16 December 07 From: Bucuresti ![]() |
E supraalimentat cu compresor mecanic? Sau ce e arătarea aia cu fulie neagră?
'23 Honda
CR-V
e:HEV '02 BMW Z3 1.9i
'91 MB W124 230E |
marksman |
#1545
Da, are compresor mecanic. Cica asa au reusit sa atinga curba de cuplu maxim cu 1000 rpm mai jos.
Opel / Mazda
Crossland X / CX-30
AmunDei |
#1546
![]() Fără turbo viața e pustiu... Group: Members Posts: 1.985 Joined: 8 June 07 From: Cucuveieni Deal ![]() |
Da, are compresor mecanic atasat, rolul lui e de a ajuta la mentinerea unui amestec sarac pentru modul de functionare in regimul "Spark Controlled Compression Ignition". De altfel nu adauga prea multa putere (il tradeaza valorile mici de cuplu comparativ cu o supraalimentare obisnuita) ci mai mult trateaza curba de cuplu.
Motorul nu functioneaza niciodata strict ca un diesel, adica fara scanteie, fiindca acest lucru nu a fost facut inca posibil. In schimb, la sarcini mici si viteze mici, bujia aprinde doar o mica parte din amestec, restul de amestec arzand prin autoaprindere ca la diesel. Nu avem cum sa stim in ce fel influenteaza CO - ul benzinei comportamentul motorului in acest mod de functionare fiindca intr-adevar, se cam bate cap in cap cu intentia de detonatie controlata. Dar e clar ca un CO ridicat va fi util pentru momentele cand motorul functioneaza ca un benzinar normal, adica la sarcini/turatii/viteze mari, fiindca raportul ala de comprimare e wow. Motorul asta ar fi senzatie pe o masina usoara. A, si multi kmp fara incidente si de la mine! marksman edit: Multam! This post has been edited by marksman: 24 Jun 2020, 13:50 |
bgdrenault |
#1547
![]() bgd Group: Members Posts: 3.584 Joined: 4 February 07 From: Piatra Neamt ![]() |
Megane
Sedan 1,33 140 CP
2019 Intens
- XXX
marksman |
#1548
Ar fi cazul sa va potoliti, ca incep sa dau cu matura.
Opel / Mazda
Crossland X / CX-30
andreig1982 |
#1549
Membru autentic Group: Members Posts: 1.413 Joined: 15 January 06 ![]() |
QUOTE(bgdrenault @ 24 Jun 2020, 14:35) Ironick cred ca a vrut sa zica cu mai putine cuvinte ca lipsa amortizoarelor e cel mai probabil cauzata de sistemele de protectie a pietonilor. ![]() This post has been edited by andreig1982: 24 Jun 2020, 14:21 |
Logan Ambition
#1550
Eu stiu care este cauza, nu este singurul producator care le-a scos.
Sunt aceleasi discutii pe forumurile marcilor, indiferent de producator. Culmea, jurnalisti auto s-au plans de acelasi lucru, fara sa studieze macar prezenta chiar a doua incuietori la capota. This post has been edited by IRONICK: 24 Jun 2020, 14:27 |
AndreiMR |
#1551
In afara de taierea costurilor, care ar mai fi cauza? Siguranta pietonilor nu cred ca e de vina aici, fiindca sunt masini care inca nu au renuntat la amortizoarele pentru capota si s-au descurcat foarte bine la testele de impact cu pietonii
2018
Mazda 3 G120
andreig1982 |
#1552
Capotele active nu prea sunt compatibile cu amortizoarele de capota, de aia ziceam de protectia pentru pietoni. Mazda stiu ca foloseste sistemul asta.
Logan Ambition
dizzy |
#1553
Salut, intreb de curiozitate, la ce ar fi utile doua incuietori de capota, presupunanad ca sunt la marginile capotei dinspre nasul masinii? Nu exista pericolul sa se sprijine in 3 puncte din 4 si sa deformeze pe cea supra solicitata?
This post has been edited by dizzy: 24 Jun 2020, 14:45 |
Whirpool
ex Dacia Logan
AR-18-MOS |
#1554
BMW
730Ld
'07 High Executive
marksman |
#1555
Chiar si la ala din 2004 scrie asa
![]() Multam. |
Opel / Mazda
Crossland X / CX-30
#1556
EU zic sa scapi de rodaj si mergi si cu 95 si cu 98 sau 99 si vezi care-ti place mai mult. Motoreta de exemplu nu simtea diferenta la 99, dar masina, fiind si GDI si cu senzor de detonatii clar o simte si consuma mai putin.
- negru pe alb
marksman |
#1557
Acum astept sa se consume plinul facut cu benzina de CO 100. Am facut undeva la 128 km ieri, si zice ca mai merge inca 490. Urmatorul plin va fi cu benzina de CO 95 si teoretic din doua plinuri e gata rodajul.
Opel / Mazda
Crossland X / CX-30
Bicicleta galbena |
#1558
![]() Sunt nembru, domnule! Group: Members Posts: 2.210 Joined: 29 January 13 From: Bucuresti ![]() |
Peugeot
407 1.8 16v
eurocristi |
#1559
Membru autentic Group: Members Posts: 243 Joined: 16 May 07 From: Oradea ![]() |
Foarte faina masina!
Ai pus vreo frana involuntara cu stangul cand obisnuinta de la cutia manuala te face sa apesi ambreajul? Numa dupa cateva zile de condus automata reusesc sa ma oobisnuiesc cu ideea ca stangul are regim de relaxare. Noroc ca fac fazele doar la viteze mici. Multi kmp fara stres! |
ambition
2005 membru proaspat dar experimentat in auto
psychoo |
#1560
Am apasat eu "ambreiajul" in depasirea unui tir. Nu doresc senzatia nici dusmanilor...
Focus
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 18th July 2025 - 15:37 |
