Passat B6 2006 BMP
Passat B6 2006 BMP
xmisterx |
#91
Membru autentic Group: Members Posts: 1.662 Joined: 12 October 17 From: Brasov ![]() |
Laguna 2
2003 Privilege 1.9 dci 120 hp Clio life evo 2019 0.9 75 HP
Bogeyman |
#92
![]() Membru autentic Group: Members Posts: 206 Joined: 4 December 17 From: Pe langa BZ ![]() |
L am rezolvat azi. Sper sa nu mai am surprize neplacute la prima ploaie zdravana. Oricum am facut proba si e ok, nu mai da deloc. Trebuie sa repet operatiunea pe.partea stanga, preventiv, deocamdata nu s probleme.
VW
Passat
2006 BMP Sufferin' succotash!
Bogeyman |
#93
De vreo 2-3 saptamani auzeam un fluierat metalic pe spate cand se incalzeau rotile. M-am gandit la placute, ieri am prins programare la mecanic. Cei patru culisanti pe ambele etriere erau blocati, etrierii la fel, placutele de pe interiorul discului-praf Cred ca pe spate nu mai aveam frana.
Am curatat cu peria de sarma culisantii, rezolvat pistoanele de la etriere, gresat si pus la loc + placute TRW. Aproape 280.000 km. clp.jpg ( Size: 461.19k ) Number of downloads: 1111 clpr.jpg ( Size: 603.52k ) Number of downloads: 1114 brk.jpg ( Size: 325.17k ) Number of downloads: 1117 pds.jpg ( Size: 905.92k ) Number of downloads: 1105 trw.jpg ( Size: 456.62k ) Number of downloads: 1082 280k.jpg ( Size: 241.21k ) Number of downloads: 118 This post has been edited by Bogeyman: 28 Sep 2020, 10:04 |
VW
Passat
Bogeyman |
#94
De la un schimb de ulei si filtru, aceleasi ca ultima data (Castrol+Purflux), am ajuns sa dau cutia jos.
S-au schimbat disc ambreiaj (LUK), trompa cutie, simering schimbator cutie si flansa pompa de apa. Volanta, placa de presiune si rulmentul sunt in regula. Apoi, daca tot aveam masina la operatie, am schimbat si garnitura capac supape, verificat bujii (NGK, albe, uscate), bobine si inlocuit un furtun care era rupt. Nu stiu daca e placebo sau nu, dar mi se pare ca masina merge altfel. 281.300 km. gb1.jpg ( Size: 531.09k ) Number of downloads: 173 gb2.jpg ( Size: 817.04k ) Number of downloads: 145 gb3.jpg ( Size: 484.94k ) Number of downloads: 137 elr.jpg ( Size: 684.29k ) Number of downloads: 131 gds.jpg ( Size: 335.48k ) Number of downloads: 116 |
VW
Passat
Bogeyman |
#95
Saptamana trecuta a facut 2 ani de cand e la mine si aproape 284k km, adica am facut undeva la 18.500 km in 2 ani. Tot saptamana trecuta incepuse sa faca figuri instalatia de gaz in sensul ca intra pe gaz cand avea chef, mai mult nu. Am crezut initial ca trebuie schimbate filtrele, dupa care mi-am dat seama ca nu-i de la filtre (la primul schimb de filtre nu mai intra deloc pe gaz). Asadar, s-a schimbat chestia de mai jos, nu stiu ce e ca n-am fost eu, l-am trimis pe tata si el n-a intrebat. Acum e ok.
gpl.jpg ( Size: 287.6k ) Number of downloads: 133 270+70 filtrele Ieri l-am prins pe mecanicul meu liber si am dus-o pentru schimbarea curelei de distributie pe care o luasem de anul trecut cred. A aruncat un ochi pe acolo cand am umblat la cutie cu scurgerea de care ziceam mai sus si mi-a zis ca ar trebui s-o inlocuiesc. S-a schimbat si o rola, plus cureaua de la pompa de apa si antigelul. Curelele de accesorii si celelalte role sunt ok. Masina merge in continuare bine, fara probleme de nici un fel. Ma bate un gand s-o vand si sa iau ceva mai nou, dar mi-e c-o sa-mi para rau, deci ma mai gandesc ![]() tmb1.jpg ( Size: 388.67k ) Number of downloads: 158 tmb2.jpg ( Size: 374.67k ) Number of downloads: 155 tmb3.jpg ( Size: 440.87k ) Number of downloads: 138 tmb.jpg ( Size: 335.08k ) Number of downloads: 129 This post has been edited by Bogeyman: 9 Mar 2021, 13:50 |
VW
Passat
Laurentziu83 |
#96
Era bun daca spalai si radiatorul de freon cu ocazia asta, sa ai racoare la vara.
Bogeyman |
#97
Racoare am (sau aveam vara trecuta). O sa-l intreb pe mecanic, asta daca nu cumva e montat tot la loc cand ajung p-acolo.
VW
Passat
Bogeyman |
#98
Am facut un consum de gaz de la rezervor gol, bagat 39 litri (100 lei), mers pana la gol. 310 km, adica 12,58 l/100, 50/50 urban/extra. Adica echivalentul a putin peste 6 l/100 pe benzina. Sunt din ce in ce mai multumit de feru' asta de 23 de ani, avand in vedere ce putin mi a cerut in 2 ani si ceva de cand il am. Desi am zis ca nu mai vreau diesel, ma tot uit la tentații (a6 c5, c6, 159 2,4, a8 d3, e 65, e 53), cred ca mi s a facut de bagat bani in fiare. O fi din cauza ca am iar garaj...
Inspirat de colegul Rue, am spalat farurile pe dinti cu colgate. Sa vad cat ține. Rezultatul e multumitor pentru mine. |
VW
Passat
Bogeyman |
#99
Am schimbat caseta de directie. Am observat niste pete de ulei sub masina, s a verificat si erau de la caseta. Bine, mai erau si niste zgomote plus lichidul de servo care scadea constant. Am dat comanda, a venit caseta (Autotechnik, 900 lei). Montata, facut geometria, dezastru. Mergea greu si facea ca toti dracii la viraj. Am dat o jos si am luat de la second, 250 lei. Una noua oem este 3.800 de lei. S a montat, facut geometria, totul ok pana acum. Ma apropii de 290 k si de un nou schimb de ulei.
Cred ca trebuie sa schimb si discurile față, am vibratii in volan la frana peste 100 km/h. |
VW
Passat
Bogeyman |
#100
Ma apropii de 290k cu fierul. Unii cică sa incerc Ravenol. N o sa schimb filtrul de aer si polen, doar cel de ulei.
In continuare, nimic de zis. Bagă caldura, am muzică, nu intra apa cand ploua, consum 8,5 pe ultimii 3k km, mergeeeeeeee ![]() |
VW
Passat
Bogeyman |
#101
289.753 km
Ravenol.jpg ( Size: 460.2k ) Number of downloads: 123 vt.jpg ( Size: 427.55k ) Number of downloads: 138 Si un mic bonus ![]() jack.jpg ( Size: 548.91k ) Number of downloads: 145 Urmeaza la primavara discuri si placute fata, amortizoare spate (cel de pe stanga am vazut ca a curs), anvelope si eventual o toba pentru ca are camasa atacata rau de rugina. |
VW
Passat
Bogeyman |
#102
Sambata trecuta am observat pete sub masina in garaj. Cand am scos-o, s-a aprins si indicatorul de temperatura din bord. Am dus-o direct la mecanic, curgere de antigel posibil la pompa de apa.
Ieri a intrat la rezolvat, pompa Hepu. La montaj s-a rupt si intinzatorul curelei de distributie, asa ca l-am schimbat si pe ala. 291.000 km wpm.jpg ( Size: 568.61k ) Number of downloads: 143 tgh.jpg ( Size: 291.9k ) Number of downloads: 127 frntd.jpg ( Size: 410.51k ) Number of downloads: 112 Tot ce trebuie pentru o atmosfera de lucru relaxata. pnp.jpg ( Size: 382.6k ) Number of downloads: 130 ngr.jpg ( Size: 378.63k ) Number of downloads: 125 |
VW
Passat
Bogeyman |
#103
Am schimbat jugul de la bara spate, era complet mancat in jurul prinderilor si a inceput brusc sa faca un zgomot de ziceai ca umblu cu o galeata de fiare dupa mine. Nu m-am interesat sa-l sudez, direct de la sh, 100 de lei.
rbpr.jpg ( Size: 614.86k ) Number of downloads: 136 Am trecut si pe la anvelope, am nevoie de 2, cele de pe fata sunt Bridgestone si le voi schimba cel mai probabil anul viitor, inca arata bine si au profil suficient. Am gasit Sava all season la 290 de lei bucata, Sebring 355, Hankook 410 parca (nu erau pe stoc, vin la comanda), astea p-aici prin sat. O sa ma uit si la magazinele online sa vad ce gasesc si pe acolo. |
VW
Passat
mircea_aq |
#104
![]() Membru autentic Group: Members Posts: 3.231 Joined: 13 October 06 ![]() |
Le schimbi si tu de pe fata pe spate, uite o octavia in parcare la carfur baneasa.
Initial mi-au atras atentia discurile fata aproape inexistente, apoi am vazut ca omul se respecta cu premium contact, nu cu eco sau alte porcarii. @fata fata.jpg ( Size: 137.8k ) Number of downloads: 150 @spate spate.jpg ( Size: 131.46k ) Number of downloads: 138 |
xxxxxxxx
xxxxxxxx
xxxxxxxx
Bicicleta galbena |
#105
![]() Sunt nembru, domnule! Group: Members Posts: 2.220 Joined: 29 January 13 From: Bucuresti ![]() |
Toti gasesc scuze pentru asemenea mizerii lasate pe masini, 'merg decat in oras', 'nu merg tare', 'nu mai bag bani in ea' etc etc.
Peugeot
407 1.8 16v
Bogeyman |
#106
Cele pe care le am pe spate arata mult mai bine decat cele din pozele colegului.
Cred ca iau Riken. |
VW
Passat
axabrt |
#107
![]() Membru autentic Group: Members Posts: 4.292 Joined: 15 February 05 From: Ploiesti ![]() |
Termina cu prostiile și ia hankook k127. Sunt in gama medie de preț și mie mi se par ok, m am împrietenit cu ele. Îți recomand și vredestein ultrac am avut și am fost de multumit .
https://www.tyrereviews.com/Tyre/Vredestein/Ultrac-Satin.htm Uite intri și tu aici și citești de cauciucuri in general Vredestein au nota mare după cum vezi... Stai departe de Dunlop sunt niste mizerii Cu continental n am avut tangenta. Michelin am avut dar am sentimente amestecate. N am mai luat. This post has been edited by axabrt: 4 Jun 2022, 13:26 |
Focus mk3.5
Bogeyman |
#108
Negatives: long braking distances in the dry and wet
Positives: short braking distances in the wet ![]() |
VW
Passat
Aleex |
#109
![]() out. Group: Members Posts: 176 Joined: 11 November 13 From: Bucuresti ![]() |
Uita-te la k125, le-am avut pe Mondeo care a fost condus in toate regimurile posibile si nu m-au dezamagit. Inainte am avut GoodYear EfficientGrip Performance si Dunlop Sport BluResponse (set si set), nu ai cum sa le numesti mizerii, pe mine nu m-au dezamagit absolut deloc, doar ca se consumau cam repede (faceam mult extraurban in perioada aia, cam 20k pe sezon).
De asemenea, daca ai 205/55 16 (asa aveam si la Mondeo, zic dimensiunea asta in particular pentru ca nu am gasit pentru alte dimensiuni care ma interesau) a aparut anul asta varianta imbunatatita a lui k125, respectiv k135, i le-am recomandat unui prieten si e foarte multumit. Hankook-ul in zilele noastre mi se pare un compromis ideal, mai ales pe dimensiuni uzuale, mai mici. La dimensiuni mai mari ai UHP-urile care pot schimba putin datele problemei. Am fost atat de multumit incat pe Megane-ul maica-mii am pus K125 (195/65 15), dar masina e condusa preponderent in oras, km putini, uzura minima. Inainte a avut si ea GoodYear-ul de mai sus si inainte de GY au fost niste Michelin EnergySaver care devenisera plastic destul de timpuriu, desi carne aveau din belsug, iar pe ud erau destul de buclucase). Pentru 205/55 16 nici nu cred ca gasesti k127, dar nu bag mana in foc, ideal ar fi K135. My 2 cents ![]() This post has been edited by Aleex: 5 Jun 2022, 14:32 |
BMW
Seria 5 F10
2012 Kawasaki Z750 2009
Renault Megane 2 2008 Authentique 1.6 16v |
mircea_aq |
#110
Daca audi pune cu incredere hankook-uri ca echipare de fabirca la a4, nu stiu de te-ai feri sa iei la passat.
Eu as lua ceva touring gen primacy sau cinturato. |
xxxxxxxx
xxxxxxxx
xxxxxxxx
bgdrenault |
#111
![]() bgd Group: Members Posts: 3.614 Joined: 4 February 07 From: Piatra Neamt ![]() |
Nexen?
Am pe masina de serviciu, sunt foarte ok si silentioase. |
Megane
Sedan 1,33 140 CP
- XXX
2019 Intens
b06fcn |
#112
![]() DOCTOR Group: Members Posts: 5.906 Joined: 27 February 05 From: Bucuresti/Galati ![]() |
Si eu recomand Nexen, N’Blue HD, am pe Megane si pe Kia, foarte OK pe ud...
21
- B 06 FCN
1.9dT, 1989 MB C 220d 4MATIC
Bogeyman |
#113
S-a schimbat bateria azi, Rombat Cyclon de 62 Ah, daca nu ma insel. Sambata am fost la cumparaturi, am ajuns acasa si cand am vrut s-o bag la garaj, pauza. N-a dat semne, doar ca a tras un pic mai mult cand am pornit-o dimineata. Macar a avut bunul simt sa nu ma lase prin sat.
VW
Passat
Bogeyman |
#114
După 3 ani jumate, șobolanul a plecat de la mine. Nu aveam intenția s-o vând, dar așa a fost să fie.
Urmează căutarea următoarei tigăi. Mă uit la Logan, Polo, Passat B6, Golf V, Megane 2 (am fost pasager in we intr-un 1,6-placut impresionat), Alfa 156, 147, 159 si care s-or mai incadra in cerințe: benzina (eventual GPL), motor maximum 2 litri, undeva pe la 3 mii eur. Să vedem ce va fi. This post has been edited by Bogeyman: 1 Nov 2022, 20:04 |
VW
Passat
tr04www |
#115
![]() Membru autentic Group: Members Posts: 1.123 Joined: 13 October 09 From: Bucuresti ![]() |
Dintre cele enumerate de tine, Passat B6 e cel mai bun. Doar că nu benzinar, un 2.0 diesel de 140 cp,sau și mai bine de 170.
Talisman
Intense 2016
Filip |
#116
![]() Forumist Group: Members Posts: 3.083 Joined: 23 July 09 ![]() |
Daca tot te-ai uitat la Megane 2 mai bine te orientezi la o Laguna 3 mai ales daca vii de pe Passat. Eu am gasit la o cautare sumara 2 exemplare - ambele de 2 litri benzina, unul la 2700 altul la 3100 eur. Dar trebuie cautate f atent sa nu aiba probleme. Laguna 3 are si 1.6 16v, dar eu unul as lua cu 1.5 DCi, alt motor nu-l vad pe masina asta, numai ca e cam scumpa cu 1.5 dci pe ea.
Sau megane 2 1.5 dci, il gasesti si la 1500 euro. Eu totusi am condus un Megane 2 1.5 dci in cateva ocazii - cateva sute de km, si pe autostrada si in oras, e mai bine decat un logan, dar sincer ca pozitie de condus, interior, spatiu la interior - mi s-a parut sub o laguna 1. Bine, era cam cazatura acel Megane, dar ma refer la chestii pe care nu ai cum sa le schimbi - pozitie de condus, spatiu interior, ergonomie, nu m-a impresionat cartela aia si frana de mana stil mansa de avion. Daca vii de pe Passat si vrei un Renault, trebuie sa fie minim Laguna. my 2 cents. ![]() This post has been edited by Filip: 2 Nov 2022, 04:51 |
#117
![]() fan Dacia Group: Members Posts: 21.734 Joined: 12 November 05 From: Bucuresti ![]() |
din cele mentionate, loganul la 3000 de euro e singurul in stare sa mearga un an cerand doar bani de carburant si revizie fara alte surprize.
- negru pe alb
Bogeyman |
#118
Așa mă gândeam și eu.
Sunt in căutări febrile, nu pot sta prea mult fără mașina, sper doar să iau decizia corectă. Mă tentează foarte tare ceva cu cutie automată si aici iese din schemă Logan. Dar poate o să știu ce vreau cand o s-o văd, problema mea e că nu sunt setat pe o anumită marcă. |
VW
Passat
#119
la 3000 de euro si cutie automata eu zic ca te inscrii la probleme scumpe pe viitor.
- negru pe alb
Avani |
#120
![]() Membru autentic Group: Members Posts: 2.133 Joined: 23 October 07 From: Capitala gri ![]() |
Nu neapărat. Mai poți găsi un mini cooper r50 automat, benzină, 1.6, vreo 115 ponei cum e ăsta
This post has been edited by Avani: 2 Nov 2022, 16:11 |
. Think forward !
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 4th August 2025 - 01:10 |
